Peter Suh
8 hours ago, maxime said:
Did you enable hotplug of sata disks on bios settings?
Is it a new installation or an upgrade?
Hi @maxime
no I dont think so as its not described in the guide. I must be using the default hotpulg value. Can you please tell me what it should be and how do i set it?
Edit: Ok reading it again, in BIOS SATA is set to AHCI (default was RAID). Other options are ATA/AHCI/RAID.. hope it helps.
This is a new install. Though I was using DSM6.0 on this machine before but I am setting up a new system and HDD currently installed do not have any version of DSM installed.
 @Peter Suh & @pocopico
Edited by Sam1
10 hours ago, Vodka2014 said:
Hi @Peter Suh & @pocopico
For some odd reason i am still getting No Internet on the DSM Update Page. I have installed this on my GEN8 different versions and on proxmox and all the same. can you let me know why this happens and how to fix it please.
Thanks
Below are APRL fabio's RSS settings.
https://github.com/fbelavenuto/arpl/blob/main/files/board/arpl/overlayfs/opt/arpl/model-configs/DS923%2B.yml
  rss_server: "https://raw.githubusercontent.com/fbelavenuto/arpl/main/rss.xml"
  rss_server_ssl: "https://raw.githubusercontent.com/fbelavenuto/arpl/main/rss.xml"
  rss_server_v2: "https://raw.githubusercontent.com/fbelavenuto/arpl/main/rss.json"
Below are pocopico's DS3622xs+ settings.
https://github.com/pocopico/redpill-load/blob/develop/config/DS3622xs%2B/7.1.1-42962/config.json
        "rss_server": "http://example.com/null.xml",
        "rss_server_ssl": "https://example.com/null.xml",
        "small_info_path": "https://example.com/null",
"rss_server_v2": "https://example.com/autoupdate/v2/getList",
"security_version_server": "https://example.com/smallupdate",
         "updateurl": "http://example.com/",
"update_server": "http://example.com/",
"update_server_ssl": "https//example.com/",
        "myds_region_api_base_url": "https://example.com"
Below are my M SHELL DS3622xs+ settings.
https://github.com/PeterSuh-Q3/redpill-load/blob/master/config/DS3622xs%2B/7.1.1-42962/config.json
  "rss_server": "https://raw.githubusercontent.com/pocopico/redpill-load/develop/rss.xml",
  "rss_server_ssl": "https://raw.githubusercontent.com/pocopico/redpill-load/develop/rss.xml",
  "rss_server_v2": "https://raw.githubusercontent.com/pocopico/redpill-load/develop/rss.json",
There is a clear difference between these 3 rss settings.
ARPL is probably open to auto-update everything.
However, I'm not sure how to further adjust TCRP.
You can install the latest version during the DSM installation process, but
I hope pocopico, fabio or someone else can guide me on what settings to modify if I need to enable automatic updates from updates within DSM to internet.
It seems that pocopico's intention is still to avoid infinite recovery or KP situations when DSM updates the latest update in real time.
Since pocopico is developing a more stable and improved next-generation TCRP, I would like to open real-time updates in this next-generation.
Edited by Peter Suh
12 hours ago, Sam1 said:
Can someone help? When trying pocopio boot loader (0.9.8/latest) DS918+ installation gets stuck at 57% and fails due to corrupt .PAT file installation.
then I used Peter Suh with friends boot loader and I can install the .PAT file and installation  completes successfully but after reboot the device again asks for .PAT file to be installed again. Tried both DSM918+ and 920+. Same result. 3622xs gets stuck and fails with corrupt PAT file error.  Anyone else’s seeing this issue?
configuration
Dell T20
G3220 CPU
4 GB RAM
Baremetal install.
Recently, a review on bare metal 55% ~ 57% corruption messages has been done in a server forum in Korea.
A user who presented a hotplug solution related to sata multiplex in the past posted this part.
The relatively slow USB stick scans the synoboot, synoboot1, synoboot2, synoboot3 partitions, which is at a disadvantage compared to the VM.
The detection of these four partitions correlates directly with the 55% to 57% corruption messages.
Therefore, it is recommended to use a stick with USB 3.0 specifications and a USB 3.0 port as fast as possible.
In fact, this is what I also experienced with ASROCK workstation motherboards.
When I used a USB 3.0 specification stick with a USB 2.0 port, I encountered a corruption message.
It's gone with USB 3.0.
I don't know if the Dell T20 can meet these USB 3.0 specs.
And since this method is not yet 100% verified, a better solution is currently being sought.
Edited by Peter Suh
Thanks, alot for this info. I was just wondering. One thing i do like is TCRP Friend is Auto Updated on reboot if there is a new version. And yes it is easier to update via the GUI then downloading the file. from Synology.
13 hours ago, Sam1 said:
Hi @maxime
My installation process was failing, until I enabled "hotplug" to all my 6 disks (yes, in AHCI mode)
Certain versions of redpill loader (I've never managed to figure out which) block access to the Synology update servers by adding fake hosts entries (iirc). I think this was to ensure the devices never auto-updated.
You'll need to download the update file you want from https://archive.synology.com/download/Os/DSM and manually upload/install it in the DSM admin interface.
Sure I will try a USB3.0 drive. Maybe that is the cause of failure around 57% but would you expect this to not happen when using with friends bootloader?
Also any though on why with friends boot loader after build is able to install correctly and boot the drive to setup page. Once the .pat file is installed as part of the post bootloader NAS setup process the subsequent boot takes back to install .pat file again.. this just keeps repeating... any guidance would be greatly appreciated.
Thanks for this. So in an nutshell this safe guards users.
39 minutes ago, Vodka2014 said:
Good Day.
I would like to know how do i Extend the Partitions since i am getting an error copy error stating the disk is full on boot.
Thanks
I already created an image with the partitions adjusted to solve this problem.
Replace with this image and try rebuilding the loader for the same version and syno model.
https://github.com/PeterSuh-Q3/tinycore-redpill/releases/tag/v0.9.3.0-1
You have to use gparted to adjust it yourself, but it's not easy to use.
  • Like 2
AWESOME & Thanks alot
9 hours ago, damianssj661 said:
Could somebody please explain me, is xpenology installed just on pendrive or it will be installed on hard drive?
If it is installed on pendrive maybe i can use ssd disk (sata/nvme) and install xpenology on that?
-> Does xpenology mean bootloader only?
     Assuming that is the case, the answer is as follows.
-> Bootloader can be installed on pendrive or ssd/m-sata/m.2 sata.
I haven't tried installing the bootloader on the hard drive, but it seems to be usable as a drive dedicated to the bootloader.
I'm curious too, so I'll try it out.
-> For pendrive installation, select and use the USB boot menu,
    If installed on ssd/m-sata/m.2 sata drive, use sata boot menu.
    In general, DSM cannot be installed on m.2 NVMe and can only be used as a cache.
    I haven't tried to install a bootloader on M.2 NVMe, but it seems to work abnormally.
Isn't it something handled by Redpill to ignore SATA disks <1Go to make them work as SATA bootloader but not detected by DSM ?
I remember something like this.
How will a disk >1Go handled as a SATA bootloader ? maybe a partition with max 1Go is needed...
The SATA boot mode was made for Proxmox/ESXi in the beginning I think
But I may be wrong.
Edited by Orphée
But I may be wrong.
Have you ever looked at the dmesg of redpill's sata disk boot process?
Here's some of the log content:
It cheat with INNODISK MSATA 16GB.
No matter which large capacity SATA disk is used as a bootloader, this INNODISK MSATA 16GB will be.
In fact, if you force port the bootloader to MSATA and the USB boot option is used, there is no cheating, so MSATA can be used entirely as a bootloader, up to 24GB.
If MSATA of more than this capacity is used, it is used as a data disk during the DSM installation process, and the bootloader is initialized.
I'm telling you based on what I've actually tested.
Edited by Peter Suh
3 hours ago, Peter Suh said:
It's hard to give an exact answer because you didn't tell me in detail which LSI controller model you have.
@Peter SuhSorry about that. It is an LSI 9211-4i.
When I run lspci I get this
 RAID bus controller: LSI Logic / Symbios Logic SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 03)
When DSM Loads it states no disks.
Edited by Vodka2014
Lastly, from what you mentioned, your Synology model went from DS3622xs+ to DS1621+.
Device-Tree based models such as DS1621+/DS920+/DS923+ cannot use HBA.
To be precise, the three platforms v1000/gemini lake/r1000 correspond to DT.
In other platforms, LSI 9211-4i works by automatically injecting mpt3sas driver.
Thanks @Peter Suh So, I should use DS3622xs then? I am doing a new build on some old hardware I have. Or what should I use.
7 hours ago, Vodka2014 said:
Thanks again for your support and help.
@Peter Suh I rebuilt the image and again no disks found on DS3622xs+
Haw many disk do you have?
If you can access the DSM installation request screen with ttyd as below,
Then send me the log with the command you see.
You must use a web browser.
http://<youripaddr>:7681/
id : root / pw : ( no password )
cat /var/log/linuxrc.syno.log
ls -l /sys/block
ls -la /sys/class/ata_device
ls -l /dev/syno*
ls -l /sys/block
ls -l /dev/syno*
Hi @Peter Suh
Please see the below & there is 4 SAS Disks.
SynologyNAS> cat /var/log/linuxrc.syno.log
START /linuxrc.syno.impl
Insert Marvell 1475 SATA controller driver
Insert basic USB modules...
:: Loading module usb-common ... [  OK  ]
:: Loading module usbcore ... [  OK  ]
:: Loading module ehci-hcd ... [  OK  ]
:: Loading module ehci-pci ... [  OK  ]
:: Loading module xhci-hcd ... [  OK  ]
:: Loading module xhci-pci ... [  OK  ]
:: Loading module usb-storage ... [  OK  ]
:: Loading kernel modules from extensions ...
Checking if kmods for thethorgroup.virtio should run using check-virtio.sh script
Checking for VirtIO
*No* VirtIO hypervisor detected
NOT loading kmods for thethorgroup.virtio
:: Loading kernel modules from extensions ... [  OK  ]
:: Executing "on_boot" custom scripts ...
Running "check-all-modules.sh" for all-modules->on_boot
broadwellnk
4.4.180
modules.alias.4.json
Copying kmod,sed,jq,lspci files to /sbin/
'kmod' -> '/bin/kmod'
'sed' -> '/usr/sbin/sed'
'jq' -> '/usr/sbin/jq'
'lspci' -> '/usr/sbin/lspci'
Copying lspci libraries to /lib/
'libz.so.1' -> '/lib/libz.so.1'
'libudev.so.1' -> '/lib/libudev.so.1'
'libattr.so.1' -> '/lib/libattr.so.1'
'libcap.so.2' -> '/lib/libcap.so.2'
link depmod, modprobe to kmod
3c59x.ko
3w-9xxx.ko
3w-sas.ko
3w-xxxx.ko
BusLogic.ko
a100u2w.ko
aacraid.ko
acenic.ko
advansys.ko
aic79xx.ko
aic7xxx.ko
aic94xx.ko
altera_tse.ko
alx.ko
am53c974.ko
amd8111e.ko
aqc111.ko
arcmsr.ko
asix.ko
atl1.ko
atl1c.ko
atl1e.ko
atlantic.ko
atp870u.ko
auxiliary.ko
ax88179_178a.ko
bcm-phy-lib.ko
bcm7xxx.ko
be2net.ko
bna.ko
bnx2.ko
bnx2x.ko
bnxt_en.ko
button.ko
cassini.ko
catc.ko
cdc-wdm.ko
cdc_eem.ko
cdc_ether.ko
cdc_mbim.ko
cdc_ncm.ko
cdc_subset.ko
ch9200.ko
cnic.ko
cpsw_ale.ko
crc-ccitt.ko
crc-itu-t.ko
cx82310_eth.ko
cxgb.ko
cxgb3.ko
cxgb4.ko
cxgb4vf.ko
dc395x.ko
de2104x.ko
de4x5.ko
dl2k.ko
dm9601.ko
dmfe.ko
dmx3191d.ko
dnet.ko
dpt_i2o.ko
e1000.ko
e1000e.ko
eata.ko
ec_bhf.ko
eeprom_93cx6.ko
enic.ko
epic100.ko
esas2r.ko
esp_scsi.ko
et131x.ko
etxhci-hcd.ko
fdomain.ko
fealnx.ko
fixed_phy.ko
fm10k.ko
forcedeth.ko
ftdi_sio.ko
gdth.ko
genet.ko
gl620a.ko
governor_simpleondemand.ko
hamachi.ko
hpsa.ko
hptiop.ko
huawei_cdc_ncm.ko
i40e.ko
i40evf.ko
iavf.ko
ice.ko
igb.ko
igbvf.ko
igc.ko
initio.ko
int51x1.ko
ipheth.ko
ipr.ko
ips.ko
isci.ko
ixgb.ko
ixgbevf.ko
jme.ko
kalmia.ko
kaweth.ko
ks8851.ko
ks8851_mll.ko
ksz884x.ko
lan78xx.ko
lg-vl600.ko
libiscsi.ko
libphy.ko
liquidio.ko
macb.ko
mcs7830.ko
mdio-octeon.ko
mdio.ko
megaraid.ko
megaraid_mbox.ko
megaraid_mm.ko
megaraid_sas.ko
microchip.ko
mii.ko
mlx4_core.ko
mlx4_en.ko
mlx5_core.ko
mpt3sas.ko
mptbase.ko
mptctl.ko
mptsas.ko
mptscsih.ko
mptspi.ko
mvmdio.ko
mvsas.ko
mvumi.ko
myri10ge.ko
natsemi.ko
nb8800.ko
nct6775.ko
net1080.ko
netxen_nic.ko
nicpf.ko
nicvf.ko
niu.ko
ns83820.ko
pcnet32.ko
pegasus.ko
plusb.ko
pm80xx.ko
pmcraid.ko
qed.ko
qede.ko
qla1280.ko
qla3xxx.ko
qla4xxx.ko
qlcnic.ko
qlge.ko
qmi_wwan.ko
r8101.ko
r8125.ko
r8152.ko
r8153_ecm.ko
r8168.ko
r8169.ko
rndis_host.ko
rtl8150.ko
s2io.ko
samsung-sxgbe.ko
scsi_transport_spi.ko
sfc.ko
sierra_net.ko
sis190.ko
skge.ko
sky2.ko
smsc.ko
smsc75xx.ko
smsc911x.ko
smsc9420.ko
smsc95xx.ko
sr9700.ko
sr9800.ko
starfire.ko
stex.ko
sundance.ko
sungem.ko
sungem_phy.ko
sym53c8xx.ko
tehuti.ko
tg3.ko
thunder_bgx.ko
tlan.ko
tulip.ko
typhoon.ko
ufshcd.ko
uli526x.ko
usbnet.ko
usbserial.ko
via-velocity.ko
virtio.ko
virtio_blk.ko
virtio_mmio.ko
virtio_net.ko
virtio_pci.ko
virtio_ring.ko
virtio_scsi.ko
vmw_pvscsi.ko
vmw_vmci.ko
vmxnet3.ko
vxge.ko
wd719x.ko
winbond-840.ko
yellowfin.ko
zaurus.ko
depmod: WARNING: could not open /lib/modules//modules.order: No such file or directory
depmod: WARNING: could not open /lib/modules//modules.builtin: No such file or directory
insmod: can't insert '/lib/modules/ahci.ko': No such file or directory
Found SATA Controller : pciid 8086d00003a22  Required Extension : Searching for matching extension for ahci
Found Ethernet Interface : pciid 10ecd00008168 Required Extension : Searching for matching extension for r8168
Module r8168 loaded succesfully
Found VGA Controller : pciid 10ded0000128b  Required Extension : No matching extension
Found SATA Controller : pciid 1b4bd00009235  Required Extension : No matching extension
Ran "check-all-modules.sh" for all-modules->on_boot - exit=0
Running "install_rd.sh" for redpill-misc->on_boot
Starting ttyd, listening on port: 7681
Ran "install_rd.sh" for redpill-misc->on_boot - exit=0
Running "boot-wait.sh" for thethorgroup.boot-wait->on_boot
Confirmed a valid-looking /dev/synoboot device
Ran "boot-wait.sh" for thethorgroup.boot-wait->on_boot - exit=0
:: Executing "on_boot" custom scripts ... [  OK  ]
Extensions processed
Insert net driver(Mindspeed only)...
Starting /usr/syno/bin/synocfgen...
/usr/syno/bin/synocfgen returns 0
Insert synorbd kernel module
Insert synofsbd kernel module
Insert sha256 kernel module
All disk ready or timeout execeed
Exit on error [1] DISK NOT INSTALLED...
Sun Dec 18 04:09:02 UTC 2022
none /sys/kernel/debug debugfs rw,relatime 0 0
SynologyNAS> ls -l /sys/block
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram0 -> ../devices/virtual/block/ram0
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram1 -> ../devices/virtual/block/ram1
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram10 -> ../devices/virtual/block/ram10
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram11 -> ../devices/virtual/block/ram11
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram12 -> ../devices/virtual/block/ram12
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram13 -> ../devices/virtual/block/ram13
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram14 -> ../devices/virtual/block/ram14
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram15 -> ../devices/virtual/block/ram15
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram2 -> ../devices/virtual/block/ram2
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram3 -> ../devices/virtual/block/ram3
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram4 -> ../devices/virtual/block/ram4
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram5 -> ../devices/virtual/block/ram5
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram6 -> ../devices/virtual/block/ram6
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram7 -> ../devices/virtual/block/ram7
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram8 -> ../devices/virtual/block/ram8
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 ram9 -> ../devices/virtual/block/ram9
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 synoboot -> ../devices/pci0000:00/0000:00:1d.7/usb2/2-3/2-3:1.0/host6/target6:0:0/6:0:0:0/block/synoboot
SynologyNAS> ls -la /sys/class/ata_device
drwxr-xr-x    2 root     root             0 Dec 18 04:13 .
drwxr-xr-x   54 root     root             0 Dec 18 04:09 ..
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 dev1.0 -> ../../devices/pci0000:00/0000:00:1f.2/ata1/link1/dev1.0/ata_device/dev1.0
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 dev2.0 -> ../../devices/pci0000:00/0000:00:1f.2/ata2/link2/dev2.0/ata_device/dev2.0
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 dev3.0 -> ../../devices/pci0000:00/0000:00:1f.2/ata3/link3/dev3.0/ata_device/dev3.0
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 dev4.0 -> ../../devices/pci0000:00/0000:00:1f.2/ata4/link4/dev4.0/ata_device/dev4.0
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 dev5.0 -> ../../devices/pci0000:00/0000:00:1f.2/ata5/link5/dev5.0/ata_device/dev5.0
lrwxrwxrwx    1 root     root             0 Dec 18 04:13 dev6.0 -> ../../devices/pci0000:00/0000:00:1f.2/ata6/link6/dev6.0/ata_device/dev6.0
SynologyNAS> ls -l /dev/syno*
crw-r--r--    1 root     root      201,   0 Dec 18 04:09 /dev/synobios
brw-------    1 root     root      135, 240 Dec 18 04:09 /dev/synoboot
brw-------    1 root     root      135, 241 Dec 18 04:09 /dev/synoboot1
brw-------    1 root     root      135, 242 Dec 18 04:09 /dev/synoboot2
brw-------    1 root     root      135, 243 Dec 18 04:09 /dev/synoboot3
Edited by Vodka2014
19 hours ago, Vodka2014 said:
Hi @Peter Suh
Checking for VirtIO
broadwellnk
4.4.180
3c59x.ko
3w-9xxx.ko
3w-sas.ko
3w-xxxx.ko
BusLogic.ko
a100u2w.ko
aacraid.ko
acenic.ko
advansys.ko
aic79xx.ko
aic7xxx.ko
aic94xx.ko
altera_tse.ko
alx.ko
am53c974.ko
amd8111e.ko
aqc111.ko
arcmsr.ko
asix.ko
atl1.ko
atl1c.ko
atl1e.ko
atlantic.ko
atp870u.ko
auxiliary.ko
ax88179_178a.ko
bcm-phy-lib.ko
bcm7xxx.ko
be2net.ko
bna.ko
bnx2.ko
bnx2x.ko
bnxt_en.ko
button.ko
cassini.ko
catc.ko
cdc-wdm.ko
cdc_eem.ko
cdc_ether.ko
cdc_mbim.ko
cdc_ncm.ko
cdc_subset.ko
ch9200.ko
cnic.ko
cpsw_ale.ko
crc-ccitt.ko
crc-itu-t.ko
cx82310_eth.ko
cxgb.ko
cxgb3.ko
cxgb4.ko
cxgb4vf.ko
dc395x.ko
de2104x.ko
de4x5.ko
dl2k.ko
dm9601.ko
dmfe.ko
dmx3191d.ko
dnet.ko
dpt_i2o.ko
e1000.ko
e1000e.ko
eata.ko
ec_bhf.ko
eeprom_93cx6.ko
enic.ko
epic100.ko
esas2r.ko
esp_scsi.ko
et131x.ko
etxhci-hcd.ko
fdomain.ko
fealnx.ko
fixed_phy.ko
fm10k.ko
forcedeth.ko
ftdi_sio.ko
gdth.ko
genet.ko
gl620a.ko
hamachi.ko
hpsa.ko
hptiop.ko
huawei_cdc_ncm.ko
i40e.ko
i40evf.ko
iavf.ko
ice.ko
igb.ko
igbvf.ko
igc.ko
initio.ko
int51x1.ko
ipheth.ko
ipr.ko
ips.ko
isci.ko
ixgb.ko
ixgbevf.ko
jme.ko
kalmia.ko
kaweth.ko
ks8851.ko
ks8851_mll.ko
ksz884x.ko
lan78xx.ko
lg-vl600.ko
libiscsi.ko
libphy.ko
liquidio.ko
macb.ko
mcs7830.ko
mdio-octeon.ko
mdio.ko
megaraid.ko
megaraid_mbox.ko
megaraid_mm.ko
megaraid_sas.ko
microchip.ko
mii.ko
mlx4_core.ko
mlx4_en.ko
mlx5_core.ko
mpt3sas.ko
mptbase.ko
mptctl.ko
mptsas.ko
mptscsih.ko
mptspi.ko
mvmdio.ko
mvsas.ko
mvumi.ko
myri10ge.ko
natsemi.ko
nb8800.ko
nct6775.ko
net1080.ko
netxen_nic.ko
nicpf.ko
nicvf.ko
niu.ko
ns83820.ko
pcnet32.ko
pegasus.ko
plusb.ko
pm80xx.ko
pmcraid.ko
qed.ko
qede.ko
qla1280.ko
qla3xxx.ko
qla4xxx.ko
qlcnic.ko
qlge.ko
qmi_wwan.ko
r8101.ko
r8125.ko
r8152.ko
r8153_ecm.ko
r8168.ko
r8169.ko
rndis_host.ko
rtl8150.ko
s2io.ko
samsung-sxgbe.ko
sfc.ko
sierra_net.ko
sis190.ko
skge.ko
sky2.ko
smsc.ko
smsc75xx.ko
smsc911x.ko
smsc9420.ko
smsc95xx.ko
sr9700.ko
sr9800.ko
starfire.ko
stex.ko
sundance.ko
sungem.ko
sungem_phy.ko
sym53c8xx.ko
tehuti.ko
tg3.ko
thunder_bgx.ko
tlan.ko
tulip.ko
typhoon.ko
ufshcd.ko
uli526x.ko
usbnet.ko
usbserial.ko
via-velocity.ko
virtio.ko
virtio_blk.ko
virtio_mmio.ko
virtio_net.ko
virtio_pci.ko
virtio_ring.ko
virtio_scsi.ko
vmw_pvscsi.ko
vmw_vmci.ko
vmxnet3.ko
vxge.ko
wd719x.ko
winbond-840.ko
yellowfin.ko
zaurus.ko
mpt3sas does not exist in the FOUND list below.
You should have found mpt3sas in the automatic recognition process of the device below.
Module r8168 loaded successfully
You already gave the HBA information through lspci a few days ago, as shown below.
(VID:PID) I think you need to look at additional pci devices.
Please provide more information above with the command below.
It must be run from the Tynicore linux prompt.
lspci -nn
If I know the VID / PID, let's check why it couldn't match the auto search.
