CPU Frequency scaling for DS918+
Hi All!
i read all comments, and then try to solve my same problem, on my server XPEnology DS918+ (Asrock H110M ITX Mobo, i3-6100 CPU, 2 cores+ 2HT, 16GB DDR4 with 6.2.3-25426, today the last update) high cpu freq running. I do anything, but my cpu runs at highest freqency, on 3700. How can i do that  process?  Thanks!
Edited by Rick4
mistyping
  • 2 months later...
On 10/19/2020 at 7:52 AM, Demitsuri said:
Hello!
I've tested performance of my J4105, DS918+, 1.04b. Without script.
Geeknech 5 + docker.
docker run --rm davidsarkany/geekbench && docker rmi davidsarkany/geekbench
My result is https://browser.geekbench.com/v5/cpu/4246087
 It corresponds to Turbo clock 2500MHz, but DSM reports 1501MHz.
1500MHz - base.
1501MHz - active burst.
Older kernels don't always report turbo speeds properly. BSD works in some of the same way.
You sometimes see at least 3 frequencies:
Base: ex 800mhz
Peak: ex 2500mhz
Turbo: ex 2501
You could have many frequencies between 800 and 2500mhz, but 2501 would signify that the cpu is in turbo mode.
I am unable to get this to work on a 10th gen i7-10700. I get the task to run but it only puts the cpu at full turbo speed.
With these newer cpus, there are 4-5 different settings in bios regarding speedstep, speedshift etc. Do I need to disable anything?
thank you for such scripts it runs almost fine on my configuration (I3-4160, 8GB RAM, DSM 6.2.3 u3).
My CPU supports 3 governors - userspace, performance, powersafe.
Anyway I also realized, that for some unknown reason, the governor is time to time (usually at night when there is no load (?)) switched from "userspace" updated by the script to "performance" and then the running main function fails on the error already described in this forum (/usr/local/bin/scaler.sh: line 57: echo: write error: Invalid argument):
echo "$minfreq" > /sys/devices/system/cpu/cpu"${i}"/cpufreq/scaling_setspeed
Assuming that when the governor is set to different state from userspace it is not possible to externally update the frequency.
So in order to avoid the problem I just copied the the part of code checking and updating the governor in to the beginning of the main function:
# Set correct cpufreq governor to allow user defined frequency scaling
governor=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor)
if [ "$governor" != "userspace" ]; then
  for i in $(seq 0 "${cpucorecount}")
    do
      echo userspace > /sys/devices/system/cpu/cpu"${i}"/cpufreq/scaling_governor
  done
fi
So far I have no idea what and why the governor gets modified and especially to the "performance".
But at least such small modification prevents the script from failing.
