Altaram 0 Posted December 2, 2019 Share Posted December 2, 2019 Good morning everyone. First of all congratulate Trauma for creating the script. I have a problem and I am not able to install / run it. I am quite noob in the use of DSM and I do not know if it is possible that a simple guide could be made explaining its installation step by step. Thank you. Quote Link to post Share on other sites
advin 3 Posted December 4, 2019 Share Posted December 4, 2019 Nice CPU Frequency scaling Script Quote Link to post Share on other sites
Jseinfeld 3 Posted December 14, 2019 Share Posted December 14, 2019 (edited) The script is designed to be automatic and only needs one small change initally. Change the "Highload" value to 65. More on why that needs to match the "midload" value below. - Save it to your home folder - Make it executable - `chmod +x <scriptname.sh>` - e.g: - `chmod +x scaling.sh` - Run the script (in background) - `./<scriptname.sh> &` - e.g: - `./scaling.sh &` - By default the script is set to do this ---- Set CPU Speed to lowest value, it can support, at below 50% load ---- Set CPU Speed to 50% value, it can support, above 50% & below 65% load ---- Set CPU Speed to 100% value, it can support, at above 85% load. (This needs to match midload i.e 65%, as the script will not change CPU between mid & highload) - Before you go changing any values, I would suggest trying the script out first. See if the machine seems "fast" enough. If not, then change those "lowload", "midload" & "highload" values. => For example, if you want it to be "snappy", set the "lowload" value to say 5% load, "midload" to say 50% and "highload" to say 50%. This will keep your CPU at lowest below 5% CPU usage, at 50% speed till 50% load and at 100% speed above 50% load => If you want it extra "snappy" - set the "lowload" value to say 5% load, "midload" to say 15% and "highload" to say 15%. This will keep your CPU at lowest below 5% CPU usage, at 50% speed till 15% load and at 100% speed above 15% load NOTE: - CPU Speed is gathered from the CPU supported values, so it auto-adjusts to your CPU - The script will do NOTHING when CPU is between "midload" & "highload". Thus they need to be set to the SAME VALUE. Edited December 14, 2019 by Jseinfeld Quote Link to post Share on other sites
nadiva 4 Posted January 19, 2020 Share Posted January 19, 2020 On 9/30/2019 at 9:19 PM, Trauma said: Please try this as well and report the output of the command here please (for your cpu it should return "8") : cat /proc/cpuinfo | grep cores | sort -u | awk '{ print $4 }' is 1 ok for AMD? 4 cpus are listed in cpuinfo, but cores=1. interesting by default cpu is at max freq all of the time in all OS, but in DSM the performance is halved after boot (proven by benchmarks). scaling_setspeed is <unsupported>. Governor is performance. Min freq, max freq is correct. cat $(ls /sys/devices/system/cpu/cpufreq/policy*/scaling_cur_freq) 2100000 2100000 2100000 2100000 grep "MHz" /proc/cpuinfo cpu MHz : 2100.000 cpu MHz : 2100.000 cpu MHz : 2100.000 cpu MHz : 2100.000 cpuinfo_min_freq, cpuinfo_max_freq, cpuinfo_cur_freq, all seems correct, but performance is lower aes-256-xts 90198.74k 342936.66k 777926.06k 1132937.56k 1292978.86k setting governors does nothing, powersave keeps lowest freq, performance keeps highest freq (only the scaler.sh does the job, although very slowly.). driver is acpi-cpufreq, only one available on DSM. i set scaling_driver to highest freq, still low performance and fans off. dmidecode and UI shows highest freq. Performance still low. tried hundred commands, only when setting scalers up and down (which sets userspace), and then setting performance: for i in 0 1 2 3; do cpufreq-set -f 1400 -c $i; done for i in 0 1 2 3; do cpufreq-set -f 2100 -c $i; done for i in 0 1 2 3; do cpufreq-set -u 1400000 -c $i; done for i in 0 1 2 3; do cpufreq-set -u 2100000 -c $i; done for i in 0 1 2 3; do cpufreq-set -g performance -c $i; done ........performance is unlocked and fans go loud under load aes-256-xts 225339.77k 833591.27k 1901271.72k 2758488.41k 3190287.02k idle consumption is the same. i think the sequence of commands unlocked CPU TPU max from 12W to 35W. Crazy. Quote Link to post Share on other sites
wreslrstud 0 Posted March 27, 2020 Share Posted March 27, 2020 Morning guys, I've been loving the script and am ready to apply it to the startup folder using the directions provided in this forum. Would one of you guys please post up how to remove the script from the startup folder in case I decide to not use it anymore? Quote Link to post Share on other sites
mattie112 0 Posted April 17, 2020 Share Posted April 17, 2020 Is this script supposed to be compatible with i5-4590T (base 2GHZ, boost 3GHZ). I always thought my virtual machines where slower then when I was running Linux but I just thought that it was overhead. However I recently noticed that my CPU was running at only 2GHZ so that would also explain it. With the script running (default settings) I still only go up to 2GHZ admin@nas:~$ cat /proc/cpuinfo | grep MHz cpu MHz : 2001.000 cpu MHz : 2001.000 cpu MHz : 2001.000 cpu MHz : 2001.000 admin@nas:~$ uptime 15:09:40 up 22 min, 2 users, load average: 2.47, 2.08, 1.74 admin@nas:~$ cat /proc/cpuinfo | grep MHz cpu MHz : 2001.000 cpu MHz : 2001.000 cpu MHz : 2001.000 cpu MHz : 2001.000 admin@nas:~$ cat /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state 2001000 130778 2000000 0 1900000 0 1800000 0 1700000 0 1600000 0 1500000 0 1400000 3738 1300000 0 1200000 0 1100000 0 1000000 0 900000 0 800000 0 Quote Link to post Share on other sites
Trauma 13 Posted April 18, 2020 Author Share Posted April 18, 2020 (edited) On 4/17/2020 at 3:10 PM, mattie112 said: Is this script supposed to be compatible with i5-4590T (base 2GHZ, boost 3GHZ). I always thought my virtual machines where slower then when I was running Linux but I just thought that it was overhead. However I recently noticed that my CPU was running at only 2GHZ so that would also explain it. With the script running (default settings) I still only go up to 2GHZ admin@nas:~$ cat /proc/cpuinfo | grep MHz cpu MHz : 2001.000 cpu MHz : 2001.000 cpu MHz : 2001.000 cpu MHz : 2001.000 admin@nas:~$ uptime 15:09:40 up 22 min, 2 users, load average: 2.47, 2.08, 1.74 admin@nas:~$ cat /proc/cpuinfo | grep MHz cpu MHz : 2001.000 cpu MHz : 2001.000 cpu MHz : 2001.000 cpu MHz : 2001.000 admin@nas:~$ cat /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state 2001000 130778 2000000 0 1900000 0 1800000 0 1700000 0 1600000 0 1500000 0 1400000 3738 1300000 0 1200000 0 1100000 0 1000000 0 900000 0 800000 0 acpi-cpufreq do not, as far as know, support turbo boost. Turbo boost is managed by intel_pstate scaling driver, which is not available with the 918+ kernel. I did not succeed to build and load successfully intel_pstate for now. Edited April 18, 2020 by Trauma Quote Link to post Share on other sites
richv31 4 Posted April 18, 2020 Share Posted April 18, 2020 sorry if this is a dumb question but is there an equivalent script for 1.03b/DS3615 6.2.2? Quote Link to post Share on other sites
JoeOIVOV 0 Posted April 18, 2020 Share Posted April 18, 2020 1 hour ago, richv31 said: sorry if this is a dumb question but is there an equivalent script for 1.03b/DS3615 6.2.2? I too am looking for this same script for 6.2.2. Quote Link to post Share on other sites
richv31 4 Posted April 18, 2020 Share Posted April 18, 2020 1 hour ago, JoeOIVOV said: I too am looking for this same script for 6.2.2. figured it out, ds3615 has scaling governors, 918+ does not. So for 3615 all you need to do is change the governor for all cores to ondemand or conservative (the two scaling governors). use this script in a scheduled task: #!/bin/sh for c in $(ls -d /sys/devices/system/cpu/cpu[0-9]*); do if ! grep -q 'conservative' $c/cpufreq/scaling_governor ; then echo conservative >$c/cpufreq/scaling_governor ; fi done Quote Link to post Share on other sites
mattie112 0 Posted April 19, 2020 Share Posted April 19, 2020 On 4/18/2020 at 3:22 PM, Trauma said: Hm, do you know if any other model does support this? I used to run the ds3615 but I changed it at some point (not sure why). Or perhaps I should switch to some other Hypervisor to run my VirtualMachines (esxi for example) and then run xpenology in a VM. Quote Link to post Share on other sites
Trauma 13 Posted April 19, 2020 Author Share Posted April 19, 2020 As @richv31 mentioned DS3615 kernel also use acpi_cpufreq by default. But i don't know if intel_pstate is available /usable with this kernel/os. IMHO the hypersisor has nothing to do with this, or at least should be able to provide the necessary to use both. Quote Link to post Share on other sites
Lexizilla 3 Posted May 26, 2020 Share Posted May 26, 2020 (edited) Thanks for that great script. At starting with it had some problems with the load Avarage settings. Load Avarage needs to configured special to your system. 1, 2 or 4 Core CPU needs other settings for example... maybe this article will help some one else, too https://www.howtogeek.com/194642/understanding-the-load-average-on-linux-and-other-unix-like-systems EDIT: Would like to know, which load avarage is that script using ? Because it ´seems not to work correctly... For example: uptime show a la from 0.9( 1 Minute ) Lowload is set to 400 So for my understanding, everthing below a value from 4.0 should use the lowspeed config. But that is not the case. Alex Edited May 26, 2020 by Lexizilla Quote Link to post Share on other sites
ed_co 5 Posted June 23, 2020 Share Posted June 23, 2020 (edited) On 5/26/2020 at 12:07 PM, Lexizilla said: Thanks for that great script. At starting with it had some problems with the load Avarage settings. Load Avarage needs to configured special to your system. 1, 2 or 4 Core CPU needs other settings for example... maybe this article will help some one else, too https://www.howtogeek.com/194642/understanding-the-load-average-on-linux-and-other-unix-like-systems EDIT: Would like to know, which load avarage is that script using ? Because it ´seems not to work correctly... For example: uptime show a la from 0.9( 1 Minute ) Lowload is set to 400 So for my understanding, everthing below a value from 4.0 should use the lowspeed config. But that is not the case. Alex Could you please be more precise. Can you let us know your thoughts in detail? I will like to take advantage of the script, but at the same time I want my computer snappy. And I notice a little slow lately. Thanks By the way, I use the scaler with the following command line in the task scheduler (at boot-up event): lowload=025 midload=065 /volume1/Filer/Configuration\ DSM/cpu\ frequency\ scaling/scaler.sh & How can I change the values and update the running task with the new values safely. I guess if I change the values and save it, it will not change the current process, how can I do it then without restarting the machine? Edited June 23, 2020 by ed_co Quote Link to post Share on other sites
nadiva 4 Posted June 30, 2020 Share Posted June 30, 2020 CALM DOWN coming back to the script as my NAS is busier and busier, and having now cpu load around 0.5, it can get noisy. The noise is sinuous and therefore annoying. There's no real load, it's just the amount of of services is high and fileindexd makes sure to make repeated load pops. i attach my fork for HP Gen10 (non Plus). core count is reported as 1 for AMD, instead for processors are there, using nproc have only 3 frequencies, so had to remove unused coolfreq didn't like IF for each core, double conditions, added it to the same block to save some cpu cycles instead added Ramp mode, to switch to Turbo mode faster if there's a load spike added debug mode "-d" deamon checks only once per 5 seconds, it doesn't make sense to check it too often, if the load stats isn't updated You can merge with the original and pick what you like. Thanks for the script as I now can have quiet machine again. note: High cpu equals Turbo, processing power (e.g. AES test, or 10gbit encrypted transfer) gets doubled with minimal freq raise, and is handled by cpu note: freq ramp and deramp will be slow just like the cat /proc/loadavg interval but this is fine for me, if a long operation (10gbit copy, backup, plex transcoding, emby maintenance) is going to take place, it will catch up soon and delay will be meaningless note: "Fan speed mode" in DSM might have zero impact, and by default my machine starts in power saving mode @ed_co : once scripts runs, it's in memory, as a basic concept, you need to kill the existing process and restart if you did modifications scaler.sh Quote Link to post Share on other sites
Trauma 13 Posted July 2, 2020 Author Share Posted July 2, 2020 Le 01/07/2020 à 00:26, nadiva a dit : CALM DOWN ... Hello nadiva, Thanks for you feedback, much appreciated. I look into your contribution later this month i think (quite busy at this time). Cheers. Quote Link to post Share on other sites
ed_co 5 Posted July 14, 2020 Share Posted July 14, 2020 (edited) On 6/30/2020 at 3:26 PM, nadiva said: @ed_co : once scripts runs, it's in memory, as a basic concept, you need to kill the existing process and restart if you did modifications scaler.sh 2.67 kB · 3 downloads I know. I just couldn't find the process (with ps). Don't know why... And maybe as it was done with the schedule, someone could know a way to stop it in the UI/manager in DSM, as is in the boot up event. Edited July 14, 2020 by ed_co Quote Link to post Share on other sites
Dr_Frankenstein 0 Posted August 24, 2020 Share Posted August 24, 2020 (edited) I am just starting to play around with this script on my Intel NUC6CAYS, it has the same CPU as the 918+ (J3455) but it never seems to burst up to the specified 2.5ghz it just sits at its base clock of 1.5Ghz at all times. Is this normal behaviour? Was hoping to get the little bit of extra speed out of it when its processing lots of photos in Moments or running a VM. Edited August 24, 2020 by Dr_Frankenstein Quote Link to post Share on other sites
mcdull 0 Posted August 29, 2020 Share Posted August 29, 2020 Is it still usful if the DSM is run under Proxmox as a VM? Quote Link to post Share on other sites
Trauma 13 Posted August 29, 2020 Author Share Posted August 29, 2020 On 8/24/2020 at 11:25 AM, Dr_Frankenstein said: I am just starting to play around with this script on my Intel NUC6CAYS, it has the same CPU as the 918+ (J3455) but it never seems to burst up to the specified 2.5ghz it just sits at its base clock of 1.5Ghz at all times. Is this normal behaviour? Was hoping to get the little bit of extra speed out of it when its processing lots of photos in Moments or running a VM. As said before, this script won't help with burst frequency, I guess it's handled by intel_pstate and not cpu_freq. This version of the kernel is cpu_freq only, even if it's appollo lake version (that weird). Quote Link to post Share on other sites
Trauma 13 Posted August 29, 2020 Author Share Posted August 29, 2020 25 minutes ago, mcdull said: Is it still usful if the DSM is run under Proxmox as a VM? Yes it should still be usefull since VM's runs on there own kernel, the hypervisor only expose hosts cpu features. Quote Link to post Share on other sites
mcdull 0 Posted August 29, 2020 Share Posted August 29, 2020 4 minutes ago, Trauma said: Yes it should still be usefull since VM's runs on there own kernel, the hypervisor only expose hosts cpu features. But seems the cpu freqency is almost static no matter how when access in a VM. mine is always 3792.890 MHz Quote Link to post Share on other sites
mcdull 0 Posted August 29, 2020 Share Posted August 29, 2020 under proxmox I got error on /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor: No such file or directory Quote Link to post Share on other sites
Trauma 13 Posted August 30, 2020 Author Share Posted August 30, 2020 On 8/29/2020 at 5:56 PM, mcdull said: under proxmox I got error on /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor: No such file or directory So the hypervisor do not expose any scaling capabilities to the VM's. Maybe the host scale fine, so the script is useless ( on top of not compatible...) Maybe try to check if your host burst freq or not and try to fix it. Quote Link to post Share on other sites
mcdull 0 Posted August 31, 2020 Share Posted August 31, 2020 The host is fine when I enforce ondamand governor. the idle frequency is a bit high at 2.2G but it should be the norm of ryzen. Quote Link to post Share on other sites
