beantje Posted July 27, 2020 Share #426 Posted July 27, 2020 9 hours ago, beantje said: LS: cannot access /dev/dri: no such file ore directory So I'm doing something wrong So today i have tried again, i have downloaded Loader:Jun's Loader v1.04b. ( https://xpenology.com/forum/topic/12952-dsm-62-loader/ ) then i added extra.lzma/extra2.lzma for loader 1.04b ds918+ DSM 6.2.3 v0.13.3 to the img file, convert to vmdk for esxi, run it then i backup old i915, replace it with this one the high end model (same as above but for the new driver in 6.2.3 Update2 http://s000.tinyupload.com/?file_id=60054869936813513844) but still nothing, not even ls dev/dri, im i doing it wrong ? thanks for helping! Quote Link to comment Share on other sites More sharing options...
IG-88 Posted July 27, 2020 Author Share #427 Posted July 27, 2020 if you use a i5-10600t then this driver would be the one you need to test: 8086:9BC8 => iGPU UHD 630, Low End Desktop i5 10500 and lower https://ark.intel.com/content/www/us/en/ark/products/199279/intel-core-i5-10600t-processor-12m-cache-up-to-4-00-ghz.html -> 9BC8 Quote Link to comment Share on other sites More sharing options...
beantje Posted July 27, 2020 Share #428 Posted July 27, 2020 (edited) 1 hour ago, IG-88 said: if you use a i5-10600t then this driver would be the one you need to test: 8086:9BC8 => iGPU UHD 630, Low End Desktop i5 10500 and lower https://ark.intel.com/content/www/us/en/ark/products/199279/intel-core-i5-10600t-processor-12m-cache-up-to-4-00-ghz.html -> 9BC8 Thanks for helping me out, but i have tried all of them and still nothing show up dev/dri and then now i tried this insmod and got this insmod: ERROR: could not insert module /volume1/Netwerkschijf/i915.ko: Unknown symbol in module edit, i just placed it in the update folder and on reboot i saw this but still same thing Edited July 27, 2020 by beantje Quote Link to comment Share on other sites More sharing options...
IG-88 Posted July 27, 2020 Author Share #429 Posted July 27, 2020 4 minutes ago, beantje said: insmod: ERROR: could not insert module /volume1/Netwerkschijf/i915.ko: Unknown symbol in module the the same procedure as above for bimmer2020 i915.ko in /usr/lib/modules/update/ ? (and related kernel modules that are loaded on boot from there) still using jun's extra/extra2 or any older extra/extra2 - replace them with the extra/extra2 i made for 6.2.3 Quote Link to comment Share on other sites More sharing options...
beantje Posted July 27, 2020 Share #430 Posted July 27, 2020 41 minutes ago, IG-88 said: the the same procedure as above for bimmer2020 i915.ko in /usr/lib/modules/update/ ? (and related kernel modules that are loaded on boot from there) still using jun's extra/extra2 or any older extra/extra2 - replace them with the extra/extra2 i made for 6.2.3 OK so i did it wrong, i replaced the extra/extra2 then i did reboot, try insmod did not work replaced the file on /usr/lib/modules/update did not work then i placed the file in /usr/lib/modules/ reboot and now it WORKS!!!! EVEN PLEX HW TRANSCODE!!!!! i thank you so much!!!!! i even updated it on my main server!!! (is there anywhere i can donate for your work ?) THANK YOU AGAIN! Quote Link to comment Share on other sites More sharing options...
IG-88 Posted July 27, 2020 Author Share #431 Posted July 27, 2020 1 hour ago, beantje said: (is there anywhere i can donate for your work ?) no, but trying to help others here in the forum is always appreciated thanks for retesting with plex, i will edit the 1st post and also add some information so its more clear how to do it (the way i intended it to be used) Quote Link to comment Share on other sites More sharing options...
bimmer2020 Posted July 31, 2020 Share #432 Posted July 31, 2020 I9-9900t es, in the active hardware decoding ("extra/extra2" and "i915.ko"). Use Web (Chrome) to play Emby multimedia videos (4k x265), CPU utilization is more than 70%, before this 8700t hardware decoding CPU utilization is only about 50%, I do not know why? Quote Link to comment Share on other sites More sharing options...
mosaati Posted July 31, 2020 Share #433 Posted July 31, 2020 I would like to report that I just tested the 3E98 U2 after the update and it works just fine. Greatly appreciated. I apologize for not reporting sooner as the whole family was in quarantine due to contracting COVID-19. Quote Link to comment Share on other sites More sharing options...
IG-88 Posted July 31, 2020 Author Share #434 Posted July 31, 2020 12 hours ago, bimmer2020 said: I9-9900t es, in the active hardware decoding ("extra/extra2" and "i915.ko"). Use Web (Chrome) to play Emby multimedia videos (4k x265), CPU utilization is more than 70%, before this 8700t hardware decoding CPU utilization is only about 50%, I do not know why? maybe try synologys own videstation to exclude emby as a source of problem, also try some different h.264 video material https://xpenology.com/forum/topic/24864-transcoding-without-a-valid-serial-number/ Quote Link to comment Share on other sites More sharing options...
etests Posted July 31, 2020 Share #435 Posted July 31, 2020 Hey Folks, I'm doing some tests on ESXi right now, because my last XPEnology is years and versions (5.x) ago. With help of @flyride I got 918+ running. Now I am on a new 3617 installation, because I prefer native SAS Support. With FixSynoBoot I solved the eSATA problem. Everything looks good, create Raid and Volume, but in Seriel Console I got some errors: [ 18.415623] BUG: Bad rss-counter state mm:ffff88061eecf1c0 idx:2 val:-1 ... [ OK ] :: Loading module mptctl ... [ OK ] :: Loading module megaraid_sas ... [ OK ] :: Loading module mpt2sas ... [ OK ] :: Loading module mpt3sas ... [ OK ] Insert net driver(Mindspeed only)... Starting /usr/syno/bin/synocfgen... /usr/syno/bin/synocfgen returns 0 All disk ready or timeout execeed [ 18.486300] md: invalid raid superblock magic on sdb1 [ 18.487202] md: invalid raid superblock magic on sdc1 [ 18.495084] md: invalid raid superblock magic on sdd3 [ 18.506535] md: invalid raid superblock magic on sde3 [ 18.516730] md: invalid raid superblock magic on sdf3 [ 18.524530] md: invalid raid superblock magic on sdg3 Partition Version=8 /sbin/e2fsck exists, checking /dev/md0... /sbin/e2fsck -pvf returns 0 Mounting /dev/md0 /tmpRoot ------------upgrade Begin upgrade procedure No upgrade file exists End upgrade procedure ============upgrade My grub is this: set extra_initrd="extra.lzma" set info="info.txt" set vid=0x058f set pid=0x6387 set sn=XXX set mac1=0011322CAXXX set rootdev=/dev/md0 set netif_num=1 #set extra_args_3617='earlycon=uart8250,io,0x3f8,115200n8 earlyprintk loglevel=15' set extra_args_3617='' set common_args_3617='syno_hdd_powerup_seq=0 HddHotplug=0 syno_hw_version=DS3617xs vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_port_thaw=1' set sata_args='sata_uid=1 sata_pcislot=5 synoboot_satadom=1 DiskIdxMap=0C SataPortMap=1 SasIdxMap=0' Loader: 1.03b DSM: 6.2.3-25426 Update 2 Thanks for your ideas. Quote Link to comment Share on other sites More sharing options...
flyride Posted July 31, 2020 Share #436 Posted July 31, 2020 Is there something not working? There are a lot of "normal" errors in /var/log/messages, particularly on bootup. Quote Link to comment Share on other sites More sharing options...
etests Posted July 31, 2020 Share #437 Posted July 31, 2020 Unbelievably fast. Raids are working. No problems in general, but I trie to find out, why hibernation is not working. 😅 Quote Link to comment Share on other sites More sharing options...
etests Posted July 31, 2020 Share #438 Posted July 31, 2020 (edited) DSM 6.2.3-25426 Update 2 working out of the Box with 1.03b on ESXi, but not working after replacing extra.lzma with 11.2_test: Boot on ESXi 6.7 with original 1.03b Loader (all good): The highlighted entry will be executed automatically in 0s. patching file etc/rc Hunk #1 succeeded at 184 (offset 13 lines). patching file etc/synoinfo.conf Hunk #1 FAILED at 261. 1 out of 1 hunk FAILED -- saving rejects to file etc/synoinfo.conf.rej patching file linuxrc.syno Hunk #1 FAILED at 39. Hunk #2 succeeded at 131 (offset 32 lines). Hunk #3 succeeded at 694 (offset 179 lines). 1 out of 3 hunks FAILED -- saving rejects to file linuxrc.syno.rej patching file usr/sbin/init.post cat: can't open '/etc/synoinfo_override.conf': No such file or directory START /linuxrc.syno Insert Marvell 1475 SATA controller driver Insert basic USB modules... :: Loading module usb-common ... [ OK ] :: Loading module usbcore ... [ OK ] :: Loading module ehci-hcd ... [ OK ] :: Loading module ehci-pci ... [ OK ] :: Loading module ohci-hcd ... [ OK ] :: Loading module uhci-hcd ... [ OK ] :: Loading module xhci-hcd ... [ OK ] :: Loading module usb-storage ... [ OK ] :: Loading module BusLogic ... [ OK ] :: Loading module vmw_pvscsi ... [ OK ] :: Loading module megaraid_mm ... [ OK ] :: Loading module megaraid_mbox ... [ OK ] :: Loading module megaraid ... [ OK ] :: Loading module scsi_transport_spi ... [ OK ] :: Loading module mptbase ... [ OK ] :: Loading module mptscsih ... [ OK ] :: Loading module mptspi ... [ OK ] :: Loading module mptsas[ 8.312612] sd 1:0:0:0: [sdb] No Caching mode page found [ 8.313475] sd 1:0:0:0: [sdb] Assuming drive cache: write through [ 8.314820] sd 1:0:0:0: [sdb] No Caching mode page found [ 8.315678] sd 1:0:0:0: [sdb] Assuming drive cache: write through [ 8.317621] sd 1:0:0:0: [sdb] No Caching mode page found [ 8.318471] sd 1:0:0:0: [sdb] Assuming drive cache: write through [ 18.432499] sd 1:0:1:0: [sdc] No Caching mode page found [ 18.433377] sd 1:0:1:0: [sdc] Assuming drive cache: write through [ 18.435439] sd 1:0:1:0: [sdc] No Caching mode page found [ 18.436341] sd 1:0:1:0: [sdc] Assuming drive cache: write through [ 18.439377] sd 1:0:1:0: [sdc] No Caching mode page found [ 18.440202] sd 1:0:1:0: [sdc] Assuming drive cache: write through ... [ OK ] :: Loading module mptctl ... [ OK ] :: Loading module megaraid_sas ... [ OK ] :: Loading module mpt2sas ... [ OK ] :: Loading module mpt3sas ... [ OK ] Insert net driver(Mindspeed only)... Starting /usr/syno/bin/synocfgen... /usr/syno/bin/synocfgen returns 0 All disk ready or timeout execeed [ 18.545176] md: invalid raid superblock magic on sdb1 [ 18.546051] md: invalid raid superblock magic on sdc1 [ 18.564310] md: invalid raid superblock magic on sdd3 [ 18.582823] md: invalid raid superblock magic on sde3 [ 18.604436] md: invalid raid superblock magic on sdf3 [ 18.626405] md: invalid raid superblock magic on sdg3 Partition Version=8 /sbin/e2fsck exists, checking /dev/md0... /sbin/e2fsck -pvf returns 1 Mounting /dev/md0 /tmpRoot ------------upgrade Begin upgrade procedure No upgrade file exists End upgrade procedure ============upgrade ls: /tmpRoot/usr/share/init/root-file-system.override: No such file or directory ls: /tmpRoot/usr/share/init/hostname.override: No such file or directory ls: /tmpRoot/usr/share/init/syslog-ng.override: No such file or directory ls: /tmpRoot/usr/share/init/dsmupdate.override: No such file or directory ls: /tmpRoot/usr/share/init/smallupdate.override: No such file or directory ls: /tmpRoot/usr/share/init/rc.override: No such file or directory Wait 2 seconds for synology manufactory device Fri Jul 31 21:10:00 UTC 2020 /dev/md0 /tmpRoot ext4 rw,relatime,journal_checksum,data=ordered 0 0 none /sys/kernel/debug debugfs rw,relatime 0 0 sys /sys sysfs rw,relatime 0 0 none /dev devtmpfs rw,relatime,size=12334232k,nr_inodes=3083558,mode=755 0 0 proc /proc proc rw,relatime 0 0 linuxrc.syno executed successfully. Post init [ 30.617155] device-mapper: flashcache: preread max memmory count=2048 [ 30.647777] flashache: /dev/md2 exclude check success [ 30.648606] flashache: /dev/md3 exclude check success [ 30.649945] Only DIRTY blocks exist in cache [ 30.650615] flashcache: flashcache_writeback_load: md_blocks = 47682, md_sectors = 381456, md_block_size = 8 [ 30.650615] [ 32.157772] flashcache: creating finish [ 32.499033] BTRFS: has skinny extents MA-SYN-01 login: oot on ESXi 6.7 with modified 1.03b Loader (replaced extra.lzma, not working): patching file etc/rc patching file etc/synoinfo.conf Hunk #1 FAILED at 291. 1 out of 1 hunk FAILED -- saving rejects to file etc/synoinfo.conf.rej patching file linuxrc.syno patching file usr/sbin/init.post cat: can't open '/etc/synoinfo_override.conf': No such file or directory START /linuxrc.syno Insert Marvell 1475 SATA controller driver Insert basic USB modules... :: Loading module usb-common ... [ OK ] :: Loading module usbcore ... [ OK ] :: Loading module ehci-hcd ... [ OK ] :: Loading module ehci-pci ... [ OK ] :: Loading module ohci-hcd ... [ OK ] :: Loading module uhci-hcd ... [ OK ] :: Loading module xhci-hcd ... [ OK ] :: Loading module usb-storage ... [ OK ] :: Loading module scsi_transport_spi ... [ OK ] :: Loading module BusLogic ... [ OK ] :: Loading module vmw_pvscsi ... [FAILED] :: Loading module megaraid_mm ... [ OK ] :: Loading module megaraid_mbox ... [ OK ] :: Loading module megaraid ... [ OK ] :: Loading module mptbase ... [ OK ] :: Loading module mptscsih ... [ OK ] :: Loading module mptspi ... [ OK ] :: Loading module mptsas[ 2.003319] general protection fault: 0000 [#1] SMP [ 2.003332] Modules linked in: mptsas(F+) mptspi(F) mptscsih(F) mptbase(F) megaraid(F) megaraid_mbox(F) megaraid_mm(F) BusLogic(F) scsi_transport_spi(F) usb_storage xhci_hcd uhci_hcd ohci_hcd(F) ehci_pci(F) ehci_hcd(F) usbcore usb_common mv14xx(O) xxllouald(OF) [ 2.004208] CPU: 2 PID: 3899 Comm: insmod Tainted: GF O 3.10.105 #23739 [ 2.004220] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 12/12/2018 [ 2.004232] task: ffff88062082f040 ti: ffff88061dc80000 task.ti: ffff88061dc80000 [ 2.004244] RIP: 0010:[<ffffffff814bc205>] [<ffffffff814bc205>] _raw_spin_lock+0x5/0x30 [ 2.004256] RSP: 0018:ffff88061dc83c00 EFLAGS: 00010002 [ 2.004268] RAX: 0000000000000100 RBX: ffff88061d82fd18 RCX: 0000000000000000 [ 2.004280] RDX: 0000000000000000 RSI: ffff88061dc83c08 RDI: cccccccccccccccc [ 2.004292] RBP: cccccccccccccccc R08: 0000000000000000 R09: 0000000000000000 [ 2.004304] R10: ffff88061f4c0600 R11: 0000000000000000 R12: 0000000000000008 [ 2.004316] R13: ffff88061d82f008 R14: ffffffffa017df80 R15: ffff88061d82f000 [ 2.004328] FS: 00007f1462cb4700(0000) GS:ffff88063fd00000(0000) knlGS:0000000000000000 [ 2.004340] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 2.004352] CR2: 00007f146259fe10 CR3: 000000061ca64000 CR4: 00000000003407e0 [ 2.004364] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 2.004376] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 2.004388] Stack: [ 2.004400] ffffffff8103eb32 0000000000000086 0000000000000206 ffffffffa01a06e0 [ 2.004413] 0000000000000000 ffffffff8104a125 ffff88061d869940 ffffffffa01793da [ 2.004425] ffff880600000000 ffff88061d82fcf8 0000000000000000 ffff880620f22098 [ 2.004437] Call Trace: [ 2.004453] [<ffffffff8103eb32>] ? add_timer_on+0x52/0xa0 [ 2.004469] [<ffffffff8104a125>] ? queue_delayed_work_on+0x25/0x30 [ 2.004485] [<ffffffffa01793da>] ? mpt_attach+0x93a/0xc90 [mptbase] [ 2.004502] [<ffffffffa019db40>] ? mptsas_probe+0x10/0x490 [mptsas] [ 2.004518] [<ffffffff81298160>] ? pci_device_probe+0x60/0xa0 [ 2.004534] [<ffffffff81302d2a>] ? really_probe+0x5a/0x220 [ 2.004550] [<ffffffff81302fb1>] ? __driver_attach+0x81/0x90 [ 2.004565] [<ffffffff81302f30>] ? __device_attach+0x40/0x40 [ 2.004581] [<ffffffff81301023>] ? bus_for_each_dev+0x53/0x90 [ 2.004599] [<ffffffff813024c8>] ? bus_add_driver+0x158/0x250 [ 2.004614] [<ffffffffa01a3000>] ? 0xffffffffa01a2fff [ 2.004630] [<ffffffff813035b8>] ? driver_register+0x68/0x150 [ 2.004645] [<ffffffffa01a3000>] ? 0xffffffffa01a2fff [ 2.004661] [<ffffffffa01a3122>] ? mptsas_init+0x122/0x13a [mptsas] [ 2.004676] [<ffffffffa01a3000>] ? 0xffffffffa01a2fff [ 2.004691] [<ffffffff810003aa>] ? do_one_initcall+0xea/0x140 [ 2.004707] [<ffffffff8108925e>] ? load_module+0x1a0e/0x20f0 [ 2.004723] [<ffffffff81086410>] ? store_uevent+0x40/0x40 [ 2.004739] [<ffffffff810899d1>] ? SYSC_init_module+0x91/0xc0 [ 2.004754] [<ffffffff814bcc32>] ? system_call_fastpath+0x16/0x1b [ 2.004766] Code: 66 0f 1f 44 00 00 8d 8a 00 01 00 00 89 d0 f0 66 0f b1 0f 66 39 d0 75 e5 b8 01 00 00 00 c3 0f 1f 84 00 00 00 00 00 b8 00 01 00 00 <f0> 66 0f c1 07 0f b6 d4 38 c2 74 10 0f 1f 80 00 00 00 00 f3 90 [ 2.004778] RIP [<ffffffff814bc205>] _raw_spin_lock+0x5/0x30 [ 2.004790] RSP <ffff88061dc83c00> [ 2.004802] ---[ end trace 6d74f38908e1dd40 ]--- ... [FAILED] :: Loading module mptctl[ 2.006461] Fusion MPT misc device (ioctl) driver 3.04.20 [ 2.007315] mptctl: Registered with Fusion MPT base driver [ 2.007642] mptctl: /dev/mptctl @ (major,minor=10,220) ... [ OK ] :: Loading module megaraid_sas[ 2.009998] megasas: 06.506.00.00-rc1 Sat. Feb. 9 17:00:00 PDT 2013 ... [ OK ] :: Loading module mpt2sas[ 2.012639] mpt2sas version 20.00.00.00 loaded ... [ OK ] :: Loading module mpt3sas[ 2.015667] mpt3sas version 22.00.02.00 loaded ... [ OK ] :: Loading module sx8 ... [ OK ] :: Loading module aacraid[ 2.021277] Adaptec aacraid driver 1.2-0[30200]-ms ... [ OK ] :: Loading module aic94xx[ 2.023996] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded ... [ OK ] :: Loading module 3w-9xxx[ 2.026608] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014. ... [ OK ] :: Loading module 3w-sas[ 2.029631] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000. ... [ OK ] :: Loading module 3w-xxxx[ 2.032564] 3ware Storage Controller device driver for Linux v1.26.02.003. ... [ OK ] :: Loading module mvumi ... [ OK ] :: Loading module mvsas ... [ OK ] :: Loading module arcmsr ... [ OK ] :: Loading module isci[ 2.042928] isci: Intel(R) C600 SAS Controller Driver - version 1.1.0 ... [ OK ] :: Loading module hpsa ... [ OK ] :: Loading module nvme ... [ OK ] :: Loading module ata_piix[ 2.051508] ata_piix 0000:00:07.1: version 2.13 [ 2.054223] scsi1 : ata_piix [ 2.055189] scsi2 : ata_piix [ 2.055932] ata2: PATA max UDMA/33 cmd 0x1f0 ctl 0x3f6 bmdma 0x1060 irq 14 [ 2.056601] ata3: PATA max UDMA/33 cmd 0x170 ctl 0x376 bmdma 0x1068 irq 15 [ 2.114185] tsc: Refined TSC clocksource calibration: 3503.993 MHz [ 2.115145] Switching to clocksource tsc [ 2.214080] ata2: Read current link speed fail, retry 1 [ 2.220075] ata2: Read current link speed fail, retry 2 [ 2.226071] ata2: Read current link speed fail, retry 3 [ 2.243026] ata3: Read current link speed fail, retry 1 [ 2.249052] ata3: Read current link speed fail, retry 2 [ 2.255047] ata3: Read current link speed fail, retry 3 ... [ OK ] Insert net driver(Mindspeed only)... [ 2.270268] broadwell_synobios: module license 'Synology Inc.' taints kernel. [ 2.271236] 2020-7-31 20:34:19 UTC [ 2.271508] synobios: load, major number 201 [ 2.271834] Brand: Synology [ 2.272135] Model: DS-3617xs [ 2.272156] set group disks wakeup number to 4, spinup time deno 7 [ 2.273021] synobios cpu_arch proc entry initialized [ 2.273043] synobios crypto_hw proc entry initialized [ 2.273064] synobios syno_platform proc entry initialized [ 2.273085] synobios open /dev/ttyS1 success Starting /usr/syno/bin/synocfgen... /usr/syno/bin/synocfgen returns 0 [ 2.275136] synobios: unload All disk ready or timeout execeed Exit on error [1] DISK NOT INSTALLED... [ 3.237255] usb 1-1: new full-speed USB device number 2 using xhci_hcd [ 3.249339] Got empty serial number. Generate serial number from product. Fri Jul 31 20:34:21 UTC 2020 none /sys/kernel/debug debugfs rw,relatime 0 0 sys /sys sysfs rw,relatime 0 0 none /dev devtmpfs rw,relatime,size=12332888k,nr_inodes=3083222,mode=755 0 0 proc /proc proc rw,relatime 0 0 linuxrc.syno failed on 1 starting pid 4328, tty '': '/etc/rc' :: Starting /etc/rc :: Mounting procfs ... [ OK ] :: Mounting tmpfs ... [ OK ] :: Mounting devtmpfs ... [ OK ] :: Mounting devpts ... [ OK ] :: Mounting sysfs ... [ OK ] mdadm: error opening /dev/md1: No such file or directory rc: Use all internal disk as swap. rc: No internal disk installed. swapon: can't stat '/dev/md1': No such file or directory :: Loading module sg[ 4.357081] sd 0:0:0:0: Attached scsi generic sg0 type 0 ... [ OK ] :: Loading module crc-ccitt ... [ OK ] :: Loading module crc-itu-t ... [ OK ] :: Loading module mdio ... [ OK ] :: Loading module fat ... [ OK ] :: Loading module vfat ... [ OK ] :: Loading module ip_tunnel ... [ OK ] :: Loading module vxlan ... [ OK ] :: Loading module dca[ 4.436263] dca service started, version 1.12.1 ... [ OK ] :: Loading module e1000e[ 4.440891] e1000e: Intel(R) PRO/1000 Network Driver - 3.6.0-NAPI [ 4.441849] e1000e: Copyright(c) 1999 - 2019 Intel Corporation. [ 4.443208] e1000e 0000:03:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode [ 4.444350] e1000e 0000:03:00.0: irq 78 for MSI/MSI-X [ 4.444898] e1000e 0000:03:00.0: irq 79 for MSI/MSI-X [ 4.445705] e1000e 0000:03:00.0: irq 80 for MSI/MSI-X [ 4.548623] e1000e 0000:03:00.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:11:32:2c:a7:88 [ 4.549804] e1000e 0000:03:00.0 eth0: Intel(R) PRO/1000 Network Connection [ 4.550840] e1000e 0000:03:00.0 eth0: MAC: 3, PHY: 8, PBA No: 000000-000 ... [ OK ] :: Loading module i2c-algo-bit ... [ OK ] :: Loading module igb[ 4.559367] Intel(R) Gigabit Ethernet Linux Driver - version 5.3.5.39 [ 4.560322] Copyright(c) 2007 - 2019 Intel Corporation. ... [ OK ] :: Loading module be2net ... [ OK ] :: Loading module ixgbe[ 4.568655] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.6.3 [ 4.569677] Copyright(c) 1999 - 2019 Intel Corporation. ... [ OK ] :: Loading module r8168 ... [ OK ] :: Loading module libcrc32c ... [ OK ] :: Loading module mii ... [ OK ] :: Loading module libphy ... [ OK ] :: Loading module atl1 ... [ OK ] :: Loading module atl1e ... [ OK ] :: Loading module atl1c ... [ OK ] :: Loading module alx ... [ OK ] :: Loading module uio ... [ OK ] :: Loading module ipg ... [ OK ] :: Loading module jme[ 4.619756] jme: JMicron JMC2XX ethernet driver version 1.0.8 ... [ OK ] :: Loading module skge ... [ OK ] :: Loading module sky2[ 4.628158] sky2: driver version 1.30 ... [ OK ] :: Loading module ptp_pch ... [ OK ] :: Loading module pch_gbe[ 4.636151] pch_gbe: EG20T PCH Gigabit Ethernet Driver - version 1.01 ... [ OK ] :: Loading module qla3xxx ... [ OK ] :: Loading module qlcnic[ 4.645163] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.2.42 ... [ OK ] :: Loading module qlge ... [ OK ] :: Loading module netxen_nic[ 4.654182] QLogic/NetXen Network Driver v4.0.80 ... [ OK ] :: Loading module sfc[ 4.658772] Solarflare NET driver v3.2 ... [ OK ] :: Loading module e1000[ 4.663407] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 4.664485] e1000: Copyright (c) 1999-2006 Intel Corporation. ... [ OK ] :: Loading module pcnet32[ 4.669144] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de ... [ OK ] :: Loading module vmxnet3[ 4.674077] VMware vmxnet3 virtual NIC driver - version 1.1.30.0-k-NAPI ... [ OK ] :: Loading module bnx2 ... [ OK ] :: Loading module bnx2x[ 4.684132] bnx2x: Broadcom NetXtreme II 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.78.17-0 (2013/04/11) ... [ OK ] :: Loading module igbvf[ 4.691249] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3.8.2 [ 4.692222] igbvf: Copyright (c) 1999-2015 Intel Corporation. ... [ OK ] :: Loading module ixgbevf[ 4.697629] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.6.1 [ 4.698568] Copyright(c) 1999 - 2019 Intel Corporation. ... [ OK ] :: Loading module r8101 ... [ OK ] :: Loading module r8125 ... [ OK ] :: Loading module r8169 ... [ OK ] :: Loading module tg3 ... [ OK ] :: Loading module usbnet ... [ OK ] :: Loading module ax88179_178a[ 4.724548] usbcore: registered new interface driver ax88179_178a ... [ OK ] :: Loading module button[ 4.729828] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0 [ 4.730944] ACPI: Power Button [PWRF] ... [ OK ] :: Loading module evdev ... [ OK ] :: Loading module atl2[ 4.743048] Atheros(R) L2 Ethernet Driver - version 2.2.3 [ 4.743883] Copyright (c) 2007 Atheros Corporation. ... [ OK ] :: Loading module e100[ 4.748551] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI [ 4.749461] e100: Copyright(c) 1999-2006 Intel Corporation ... [ OK ] :: Loading module ixgb[ 4.754886] ixgb: Intel(R) PRO/10GbE Network Driver - version 1.0.135-k2-NAPI [ 4.755526] ixgb: Copyright (c) 1999-2008 Intel Corporation. ... [ OK ] :: Loading module forcedeth ... [ OK ] :: Loading module tn40xx[ 4.764578] tn40xx: Tehuti Network Driver, 0.3.6.17.2 [ 4.765381] tn40xx: Supported phys : MV88X3120 MV88X3310 MV88E2010 QT2025 TLK10232 AQR105 MUSTANG ... [ OK ] :: Loading module cxgb ... [ OK ] :: Loading module cxgb3 ... [ OK ] :: Loading module cxgb4 ... [ OK ] :: Loading module atlantic ... [ OK ] :: Loading module bna[ 4.786981] Brocade 10G Ethernet driver - version: 3.1.2.1 ... [ OK ] :: Loading module vxge[ 4.791706] vxge: Copyright(c) 2002-2010 Exar Corp. [ 4.792462] vxge: Driver version: 2.5.3.22640-k ... [ OK ] :: Loading module aqc111[ 4.797028] usbcore: registered new interface driver aqc111 ... [ OK ] :: Loading module asix[ 4.801785] usbcore: registered new interface driver asix ... [ OK ] :: Loading module cx82310_eth[ 4.806244] usbcore: registered new interface driver cx82310_eth ... [ OK ] :: Loading module et131x[ 4.810703] et131x: module is from the staging directory, the quality is unknown, you have been warned. ... [ OK ] :: Loading module i40e[ 4.815650] i40e: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver - version 2.4.10 [ 4.816797] i40e: Copyright(c) 2013 - 2018 Intel Corporation. ... [ OK ] :: Loading module i40evf[ 4.821557] i40evf: Intel(R) 40-10 Gigabit Virtual Function Network Driver - version 3.6.15 [ 4.822705] Copyright(c) 2013 - 2018 Intel Corporation. ... [ OK ] :: Loading module mcs7830[ 4.827385] usbcore: registered new interface driver MOSCHIP usb-ethernet driver ... [ OK ] :: Loading module pegasus[ 4.832361] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 4.833522] usbcore: registered new interface driver pegasus ... [ OK ] :: Loading module plusb[ 4.837999] usbcore: registered new interface driver plusb ... [ OK ] :: Loading module r8152[ 4.842566] usbcore: registered new interface driver r8152 ... [ OK ] :: Loading module rtl8150[ 4.847196] usbcore: registered new interface driver rtl8150 ... [ OK ] :: Loading module s2io ... [ OK ] :: Loading module xgmac ... [ OK ] :: Loading module i2c-i801 ... [ OK ] :: Loading module adt7475 ... [ OK ] Can not detect ADT device, Retry: 1... :: Unloading module adt7475 ... [ OK ] :: Unloading module i2c-i801 ... [ OK ] :: Loading module i2c-i801 ... [ OK ] :: Loading module adt7475 ... [ OK ] Can not detect ADT device, Retry: 2... :: Unloading module adt7475 ... [ OK ] :: Unloading module i2c-i801 ... [ OK ] :: Loading module i2c-i801 ... [ OK ] :: Loading module adt7475 ... [ OK ] Can not detect ADT device, Retry: 3... :: Unloading module adt7475 ... [ OK ] :: Unloading module i2c-i801 ... [ OK ] :: Loading module i2c-i801 ... [ OK ] :: Loading module adt7475 ... [ OK ] :: Loading module synobios[ 10.961095] 2020-7-31 20:34:28 UTC [ 10.961611] synobios: load, major number 201 [ 10.962254] Brand: Synology [ 10.962750] Model: DS-3617xs [ 10.963212] set group disks wakeup number to 4, spinup time deno 7 [ 10.964126] synobios cpu_arch proc entry initialized [ 10.964860] synobios crypto_hw proc entry initialized [ 10.965609] synobios syno_platform proc entry initialized [ 10.966415] synobios open /dev/ttyS1 success ... [ OK ] [ 11.134141] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None udhcpc (v1.16.1) started eth0 Link encap:Ethernet HWaddr 00:11:32:2C:A7:88 inet addr:192.168.252.140 Bcast:192.168.252.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:7 errors:0 dropped:0 overruns:0 frame:0 TX packets:10 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:1044 (1.0 KiB) TX bytes:1660 (1.6 KiB) Interrupt:18 Memory:fd4a0000-fd4c0000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) :: Starting syslogd ... [ OK ] :: Starting scemd :: Starting services in background Starting findhostd in flash_rd... Starting services in flash_rd... Running /usr/syno/etc/rc.d/J01httpd.sh... Starting httpd:80 in flash_rd... Starting httpd:5000 in flash_rd... Running /usr/syno/etc/rc.d/J03ssdpd.sh... /usr/bin/minissdpd -i eth0 (15): upnp:rootdevice (51): uuid:upnp_SynologyNAS-0011322ca788::upnp:rootdevice (60): Synology/synology_broadwell_3617xs/6.2-23739/192.168.252.140 (48): http://192.168.252.140:5000/description-eth0.xml Connected. done. /usr/syno/bin/reg_ssdp_service 192.168.252.140 0011322ca788 6.2-23739 synology_broadwell_3617xs eth0 Running /usr/syno/etc/rc.d/J04synoagentregisterd.sh... Starting synoagentregisterd... Running /usr/syno/etc/rc.d/J30DisableNCQ.sh... Running /usr/syno/etc/rc.d/J80ADTFanControl.sh... Running /usr/syno/etc/rc.d/J98nbnsd.sh... Starting nbnsd... Running /usr/syno/etc/rc.d/J99avahi.sh... Starting Avahi mDNS/DNS-SD Daemon cname_load_conf failed:/var/tmp/nginx/avahi-aliases.conf :: Loading module hid ... [ OK ] :: Loading module usbhid[ 20.099616] usbcore: registered new interface driver usbhid [ 20.100449] usbhid: USB HID core driver ... [ OK ] ============ Date ============ Fri Jul 31 20:34:37 UTC 2020 ============================== starting pid 6746, tty '': '/sbin/getty 115200 console' Fri Jul 31 20:34:38 2020 DiskStation login: I think it's my fault, but don't find my mistake. Edited July 31, 2020 by etests Quote Link to comment Share on other sites More sharing options...
lolvince Posted August 8, 2020 Share #439 Posted August 8, 2020 Hello, thank you again for all the work;) I have been running an aspire one D270 for several years which works very well. I upgraded to version 6.2.3 by overwriting the old 6.1 system. the original network card is in 100Mb / s is detected without EXTRA, not having USB3, I decided to replace the internal WiFi network card (which is not used), by a Gigabit LAN card (https://www.amazon.fr/gp/product/B00B524102/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1). so i added extra.lzma (for loader 1.03b ds3615 DSM 6.2.3 v0.11_test). the pack works because my USB LAN card is now detected. I therefore mounted the mPCI-E card, but it does not seem to be detected: / the component is marked: 8111H when it should be RTL8168C as described on Amazon. so I don't know if it's a driver problem, or if the mPCI-E port isn't working. here is my dmesg, if anyone has any lead i thank them in advance. [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.105 (root@build1) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP Wed Jul 8 03:11:49 CST 2020 [ 0.000000] Command line: syno_hdd_powerup_seq=0 HddHotplug=0 syno_hw_version=DS3615xs vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_port_thaw=1 root=/dev/md0 sn=B3J4N01003 mac1=089E01066986 netif_num=1 vid=0x0011 pid=0x7788 [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] e820: BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: [mem 0x0000000000000100-0x000000000009e7ff] usable [ 0.000000] BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007f4aefff] usable [ 0.000000] BIOS-e820: [mem 0x000000007f4af000-0x000000007f5aefff] reserved [ 0.000000] BIOS-e820: [mem 0x000000007f5af000-0x000000007f6aefff] ACPI NVS [ 0.000000] BIOS-e820: [mem 0x000000007f6af000-0x000000007f6eefff] ACPI data [ 0.000000] BIOS-e820: [mem 0x000000007f6ef000-0x000000007f6effff] usable [ 0.000000] BIOS-e820: [mem 0x000000007f6f0000-0x000000007fffffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000ffe00000-0x00000000ffffffff] reserved [ 0.000000] NX (Execute Disable) protection: active [ 0.000000] SMBIOS 2.7 present. [ 0.000000] DMI: Acer AOD270/JE01_CT , BIOS V1.10 07/23/2013 [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable [ 0.000000] e820: last_pfn = 0x7f6f0 max_arch_pfn = 0x400000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 0FFE00000 mask FFFE00000 write-protect [ 0.000000] 1 base 000000000 mask FC0000000 write-back [ 0.000000] 2 base 040000000 mask FC0000000 write-back [ 0.000000] 3 base 07F800000 mask FFF800000 uncachable [ 0.000000] 4 disabled [ 0.000000] 5 base 07F6F0000 mask FFFFF0000 uncachable [ 0.000000] 6 disabled [ 0.000000] found SMP MP-table at [mem 0x000fe260-0x000fe26f] mapped at [ffff8800000fe260] [ 0.000000] Base memory trampoline at [ffff880000098000] 98000 size 24576 [ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff] [ 0.000000] [mem 0x00000000-0x000fffff] page 4k [ 0.000000] BRK [0x01acb000, 0x01acbfff] PGTABLE [ 0.000000] BRK [0x01acc000, 0x01accfff] PGTABLE [ 0.000000] BRK [0x01acd000, 0x01acdfff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x7f200000-0x7f3fffff] [ 0.000000] [mem 0x7f200000-0x7f3fffff] page 2M [ 0.000000] BRK [0x01ace000, 0x01acefff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x7c000000-0x7f1fffff] [ 0.000000] [mem 0x7c000000-0x7f1fffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x00100000-0x7bffffff] [ 0.000000] [mem 0x00100000-0x001fffff] page 4k [ 0.000000] [mem 0x00200000-0x7bffffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x7f400000-0x7f4aefff] [ 0.000000] [mem 0x7f400000-0x7f4aefff] page 4k [ 0.000000] BRK [0x01acf000, 0x01acffff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x7f6ef000-0x7f6effff] [ 0.000000] [mem 0x7f6ef000-0x7f6effff] page 4k [ 0.000000] BRK [0x01ad0000, 0x01ad0fff] PGTABLE [ 0.000000] RAMDISK: [mem 0x364db000-0x37ffffff] [ 0.000000] ACPI: RSDP 0x00000000000FE020 00024 (v02 ACRSYS) [ 0.000000] ACPI: XSDT 0x000000007F6EE120 0008C (v01 ACRSYS ACRPRDCT 00000001 01000013) [ 0.000000] ACPI: FACP 0x000000007F6ED000 000F4 (v04 ACRSYS ACRPRDCT 00000001 1025 00040000) [ 0.000000] ACPI: DSDT 0x000000007F6E1000 0786E (v02 ACRSYS ACRPRDCT 00000000 1025 00040000) [ 0.000000] ACPI: FACS 0x000000007F675000 00040 [ 0.000000] ACPI: HPET 0x000000007F6EC000 00038 (v01 ACRSYS ACRPRDCT 00000001 1025 00040000) [ 0.000000] ACPI: APIC 0x000000007F6EB000 00078 (v02 ACRSYS ACRPRDCT 00000001 1025 00040000) [ 0.000000] ACPI: MCFG 0x000000007F6EA000 0003C (v01 ACRSYS ACRPRDCT 00000001 1025 00040000) [ 0.000000] ACPI: WDRT 0x000000007F6E9000 00047 (v01 ACRSYS ACRPRDCT 00000000 1025 00040000) [ 0.000000] ACPI: SLIC 0x000000007F6E0000 00176 (v01 ACRSYS ACRPRDCT 00000001 1025 00040000) [ 0.000000] ACPI: BOOT 0x000000007F6DF000 00028 (v01 ACRSYS ACRPRDCT 00000001 1025 00040000) [ 0.000000] ACPI: MSDM 0x000000007F6DE000 00055 (v03 ACRSYS ACRPRDCT 00000001 1025 00040000) [ 0.000000] ACPI: FPDT 0x000000007F6DC000 00090 (v01 ACRSYS ACRPRDCT 00000001 1025 00040000) [ 0.000000] ACPI: SSDT 0x000000007F6DB000 00655 (v01 ACRSYS ACRPRDCT 00003000 1025 00040000) [ 0.000000] ACPI: SSDT 0x000000007F6DA000 00259 (v01 ACRSYS ACRPRDCT 00003000 1025 00040000) [ 0.000000] ACPI: SSDT 0x000000007F6D9000 0020F (v01 ACRSYS ACRPRDCT 00003000 1025 00040000) [ 0.000000] ACPI: WDAT 0x000000007F6D8000 00194 (v01 INSYDE H2O BIOS 00000001 ACPI 00040000) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] [ffffea0000000000-ffffea0001bfffff] PMD -> [ffff88007cc00000-ffff88007e7fffff] on node 0 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x00001000-0x00ffffff] [ 0.000000] DMA32 [mem 0x01000000-0xffffffff] [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x00001000-0x0009dfff] [ 0.000000] node 0: [mem 0x00100000-0x7f4aefff] [ 0.000000] node 0: [mem 0x7f6ef000-0x7f6effff] [ 0.000000] On node 0 totalpages: 521293 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 21 pages reserved [ 0.000000] DMA zone: 3997 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 7081 pages used for memmap [ 0.000000] DMA32 zone: 517296 pages, LIFO batch:31 [ 0.000000] ACPI: PM-Timer IO Port: 0x408 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1]) [ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000 [ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000] PM: Registered nosave memory: 000000007f4af000 - 000000007f5af000 [ 0.000000] PM: Registered nosave memory: 000000007f5af000 - 000000007f6af000 [ 0.000000] PM: Registered nosave memory: 000000007f6af000 - 000000007f6ef000 [ 0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 26 pages/cpu @ffff88007f200000 s76864 r8192 d21440 u524288 [ 0.000000] pcpu-alloc: s76864 r8192 d21440 u524288 alloc=1*2097152 [ 0.000000] pcpu-alloc: [0] 0 1 2 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 514135 [ 0.000000] Kernel command line: syno_hdd_powerup_seq=0 HddHotplug=0 syno_hw_version=DS3615xs vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_port_thaw=1 root=/dev/md0 sn=B3J4N01003 mac1=089E01066986 netif_num=1 vid=0x0011 pid=0x7788 [ 0.000000] Power on seq num: 0 [ 0.000000] Synology Hardware Version: DS3615xs-j [ 0.000000] Vender format version: 2 [ 0.000000] Serial Number: B3J4N01003 [ 0.000000] Mac1: 089E01066986 [ 0.000000] Internal netif num: 1 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] Memory: 2013948k/2087872k available (4944k kernel code, 2700k absent, 71224k reserved, 3707k data, 792k init) [ 0.000000] Kernel/User page tables isolation: disabled [ 0.000000] Hierarchical RCU implementation. [ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32 [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] NR_IRQS:4352 nr_irqs:712 16 [ 0.000000] Console: colour dummy device 80x25 [ 0.000000] console [ttyS0] enabled [ 0.000000] allocated 8388608 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] hpet clockevent registered [ 0.000000] tsc: Fast TSC calibration using PIT [ 0.000000] tsc: Detected 1595.859 MHz processor [ 0.000007] Calibrating delay loop (skipped), value calculated using timer frequency.. 3191.71 BogoMIPS (lpj=1595859) [ 0.000014] pid_max: default: 32768 minimum: 301 [ 0.000098] Security Framework initialized [ 0.000121] AppArmor: AppArmor initialized [ 0.000150] Mount-cache hash table entries: 256 [ 0.000587] Initializing cgroup subsys memory [ 0.000621] Initializing cgroup subsys devices [ 0.000628] Initializing cgroup subsys freezer [ 0.000632] Initializing cgroup subsys blkio [ 0.000688] CPU: Physical Processor ID: 0 [ 0.000692] CPU: Processor Core ID: 0 [ 0.000696] mce: CPU supports 5 MCE banks [ 0.000708] CPU0: Thermal monitoring handled by SMI [ 0.000722] Last level iTLB entries: 4KB 32, 2MB 0, 4MB 0 Last level dTLB entries: 4KB 64, 2MB 0, 4MB 8 tlb_flushall_shift: 6 [ 0.000728] FEATURE SPEC_CTRL Not Present [ 0.000731] FEATURE IBPB_SUPPORT Not Present [ 0.000737] Spectre V2 : Vulnerable [ 0.000874] Freeing SMP alternatives: 24k freed [ 0.000894] ACPI: Core revision 20130328 [ 0.010363] ACPI: All ACPI Tables successfully acquired [ 0.011042] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.021081] smpboot: CPU0: Intel(R) Atom(TM) CPU N2600 @ 1.60GHz (fam: 06, model: 36, stepping: 01) [ 0.123029] Performance Events: PEBS fmt0+, 8-deep LBR, Atom events, Intel PMU driver. [ 0.123043] ... version: 3 [ 0.123047] ... bit width: 40 [ 0.123050] ... generic registers: 2 [ 0.123053] ... value mask: 000000ffffffffff [ 0.123057] ... max period: 000000007fffffff [ 0.123060] ... fixed-purpose events: 3 [ 0.123063] ... event mask: 0000000700000003 [ 0.135195] CPU1: Thermal monitoring handled by SMI [ 0.148680] CPU2: Thermal monitoring handled by SMI [ 0.124134] smpboot: Booting Node 0, Processors #1 #2 #3 OK [ 0.162138] CPU3: Thermal monitoring handled by SMI [ 0.164322] Brought up 4 CPUs [ 0.164334] smpboot: Total of 4 processors activated (12766.87 BogoMIPS) [ 0.165028] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. [ 0.165751] devtmpfs: initialized [ 0.166477] PM: Registering ACPI NVS region [mem 0x7f5af000-0x7f6aefff] (1048576 bytes) [ 0.166933] xor: measuring software checksum speed [ 0.176047] prefetch64-sse: 5400.000 MB/sec [ 0.186053] generic_sse: 4884.000 MB/sec [ 0.186057] xor: using function: prefetch64-sse (5400.000 MB/sec) [ 0.186207] NET: Registered protocol family 16 [ 0.187735] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it [ 0.187742] ACPI: bus type PCI registered [ 0.188160] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.188168] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820 [ 0.188935] PCI: Using configuration type 1 for base access [ 0.206404] bio: create slab <bio-0> at 0 [ 0.223159] raid6: sse2x1 gen() 136 MB/s [ 0.240123] raid6: sse2x1 xor() 708 MB/s [ 0.257147] raid6: sse2x2 gen() 414 MB/s [ 0.274124] raid6: sse2x2 xor() 1152 MB/s [ 0.291193] raid6: sse2x4 gen() 699 MB/s [ 0.308120] raid6: sse2x4 xor() 1328 MB/s [ 0.308126] raid6: using algorithm sse2x4 gen() (699 MB/s) [ 0.308129] raid6: .... xor() 1328 MB/s, rmw enabled [ 0.308133] raid6: using ssse3x2 recovery algorithm [ 0.308250] ACPI: Added _OSI(Module Device) [ 0.308256] ACPI: Added _OSI(Processor Device) [ 0.308264] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.308268] ACPI: Added _OSI(Processor Aggregator Device) [ 0.310888] ACPI: EC: Look up EC in DSDT [ 0.319824] ACPI: Executed 1 blocks of module-level executable AML code [ 0.329375] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored [ 0.338281] ACPI: SSDT 0x000000007F567A90 002E9 (v01 PmRef Cpu0Ist 00003000 INTL 20100121) [ 0.338931] ACPI: Dynamic OEM Table Load: [ 0.338938] ACPI: SSDT 0x0000000000000000 002E9 (v01 PmRef Cpu0Ist 00003000 INTL 20100121) [ 0.339262] ACPI: SSDT 0x000000007F566710 006DB (v01 PmRef Cpu0Cst 00003001 INTL 20100121) [ 0.339884] ACPI: Dynamic OEM Table Load: [ 0.339891] ACPI: SSDT 0x0000000000000000 006DB (v01 PmRef Cpu0Cst 00003001 INTL 20100121) [ 0.345833] ACPI: SSDT 0x000000007F567E10 001CF (v01 PmRef ApIst 00003000 INTL 20100121) [ 0.346526] ACPI: Dynamic OEM Table Load: [ 0.346533] ACPI: SSDT 0x0000000000000000 001CF (v01 PmRef ApIst 00003000 INTL 20100121) [ 0.349644] ACPI: SSDT 0x000000007F565F10 0008D (v01 PmRef ApCst 00003000 INTL 20100121) [ 0.350284] ACPI: Dynamic OEM Table Load: [ 0.350290] ACPI: SSDT 0x0000000000000000 0008D (v01 PmRef ApCst 00003000 INTL 20100121) [ 0.355108] ACPI: Interpreter enabled [ 0.355147] ACPI: (supports S0 S4 S5) [ 0.355153] ACPI: Using IOAPIC for interrupt routing [ 0.355367] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.355610] ACPI: No dock devices found. [ 0.376766] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.376881] \_SB_.PCI0:_OSC invalid UUID [ 0.376886] _OSC request data:1 8 0 [ 0.377000] \_SB_.PCI0:_OSC invalid UUID [ 0.377004] _OSC request data:1 1f 0 [ 0.377016] acpi PNP0A08:00: ACPI _OSC support notification failed, disabling PCIe ASPM [ 0.377022] acpi PNP0A08:00: Unable to request _OSC control (_OSC support mask: 0x08) [ 0.377769] PCI host bridge to bus 0000:00 [ 0.377779] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.377786] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.377792] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.377798] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.377804] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff] [ 0.377810] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000effff] [ 0.377816] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff] [ 0.377822] pci_bus 0000:00: root bus resource [mem 0x7f800000-0x7fffffff] [ 0.377828] pci_bus 0000:00: root bus resource [mem 0x80000000-0xfebfffff] [ 0.377847] pci 0000:00:00.0: [8086:0bf1] type 00 class 0x060000 [ 0.378158] pci 0000:00:02.0: [8086:0be1] type 00 class 0x030000 [ 0.378182] pci 0000:00:02.0: reg 10: [mem 0x86000000-0x860fffff] [ 0.378193] pci 0000:00:02.0: reg 14: [io 0x50d0-0x50d7] [ 0.378549] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300 [ 0.378587] pci 0000:00:1b.0: reg 10: [mem 0x86100000-0x86103fff 64bit] [ 0.378736] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.379063] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400 [ 0.379222] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.379350] pci 0000:00:1c.0: System wakeup disabled by ACPI [ 0.379528] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400 [ 0.379684] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold [ 0.379964] pci 0000:00:1c.2: [8086:27d4] type 01 class 0x060400 [ 0.380119] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold [ 0.380401] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300 [ 0.380508] pci 0000:00:1d.0: reg 20: [io 0x50a0-0x50bf] [ 0.380693] pci 0000:00:1d.0: System wakeup disabled by ACPI [ 0.380913] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300 [ 0.380999] pci 0000:00:1d.1: reg 20: [io 0x5080-0x509f] [ 0.381178] pci 0000:00:1d.1: System wakeup disabled by ACPI [ 0.381353] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300 [ 0.381450] pci 0000:00:1d.2: reg 20: [io 0x5060-0x507f] [ 0.381627] pci 0000:00:1d.2: System wakeup disabled by ACPI [ 0.381803] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300 [ 0.381887] pci 0000:00:1d.3: reg 20: [io 0x5040-0x505f] [ 0.382073] pci 0000:00:1d.3: System wakeup disabled by ACPI [ 0.382272] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320 [ 0.382312] pci 0000:00:1d.7: reg 10: [mem 0x86105000-0x861053ff] [ 0.382495] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.382641] pci 0000:00:1d.7: System wakeup disabled by ACPI [ 0.382853] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401 [ 0.383221] pci 0000:00:1f.0: [8086:27bc] type 00 class 0x060100 [ 0.383650] pci 0000:00:1f.2: [8086:27c1] type 00 class 0x010601 [ 0.383688] pci 0000:00:1f.2: reg 10: [io 0x50c8-0x50cf] [ 0.383708] pci 0000:00:1f.2: reg 14: [io 0x50dc-0x50df] [ 0.383727] pci 0000:00:1f.2: reg 18: [io 0x50c0-0x50c7] [ 0.383746] pci 0000:00:1f.2: reg 1c: [io 0x50d8-0x50db] [ 0.383765] pci 0000:00:1f.2: reg 20: [io 0x5020-0x502f] [ 0.383785] pci 0000:00:1f.2: reg 24: [mem 0x86104000-0x861043ff] [ 0.383868] pci 0000:00:1f.2: PME# supported from D3hot [ 0.384131] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500 [ 0.384217] pci 0000:00:1f.3: reg 20: [io 0x5000-0x501f] [ 0.384818] pci 0000:01:00.0: [10ec:8136] type 00 class 0x020000 [ 0.384895] pci 0000:01:00.0: reg 10: [io 0x4000-0x40ff] [ 0.385027] pci 0000:01:00.0: reg 18: [mem 0x80004000-0x80004fff 64bit pref] [ 0.385108] pci 0000:01:00.0: reg 20: [mem 0x80000000-0x80003fff 64bit pref] [ 0.385465] pci 0000:01:00.0: supports D1 D2 [ 0.385471] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.385615] pci 0000:01:00.0: System wakeup disabled by ACPI [ 0.385857] pci 0000:00:1c.0: PCI bridge to [bus 01] [ 0.385868] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff] [ 0.385878] pci 0000:00:1c.0: bridge window [mem 0x85000000-0x85ffffff] [ 0.385892] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x80ffffff 64bit pref] [ 0.386112] pci 0000:00:1c.1: PCI bridge to [bus 02] [ 0.386123] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff] [ 0.386133] pci 0000:00:1c.1: bridge window [mem 0x84000000-0x84ffffff] [ 0.386147] pci 0000:00:1c.1: bridge window [mem 0x81000000-0x81ffffff 64bit pref] [ 0.386504] pci 0000:03:00.0: [10ec:5209] type 00 class 0xff0000 [ 0.386582] pci 0000:03:00.0: reg 10: [mem 0x83001000-0x83001fff] [ 0.387137] pci 0000:03:00.0: supports D1 D2 [ 0.387142] pci 0000:03:00.0: PME# supported from D1 D2 D3hot [ 0.387268] pci 0000:03:00.0: System wakeup disabled by ACPI [ 0.387516] pci 0000:00:1c.2: PCI bridge to [bus 03] [ 0.387527] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff] [ 0.387537] pci 0000:00:1c.2: bridge window [mem 0x83000000-0x83ffffff] [ 0.387552] pci 0000:00:1c.2: bridge window [mem 0x82000000-0x82ffffff 64bit pref] [ 0.387794] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode) [ 0.387818] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.387825] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.387831] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.387838] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode) [ 0.387844] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000effff] (subtractive decode) [ 0.387850] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode) [ 0.387857] pci 0000:00:1e.0: bridge window [mem 0x7f800000-0x7fffffff] (subtractive decode) [ 0.387863] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xfebfffff] (subtractive decode) [ 0.387910] pci_bus 0000:00: on NUMA node 0 [ 0.388827] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 *7 10 12 14 15), disabled. [ 0.388996] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10, disabled. [ 0.389163] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *11, disabled. [ 0.389328] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10, disabled. [ 0.389502] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled. [ 0.389663] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled. [ 0.389824] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 *7 10 12 14 15), disabled. [ 0.389986] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled. [ 0.390600] ACPI: Enabled 3 GPEs in block 00 to 1F [ 0.390619] acpi root: \_SB_.PCI0 notify handler is installed [ 0.390726] Found 1 acpi root devices [ 0.390826] ACPI: EC: GPE = 0x11, I/O: command/status = 0x66, data = 0x62 [ 0.391406] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none [ 0.391419] vgaarb: loaded [ 0.391422] vgaarb: bridge control possible 0000:00:02.0 [ 0.391927] SCSI subsystem initialized [ 0.391939] ACPI: bus type ATA registered [ 0.392354] libata version 3.00 loaded. [ 0.392764] pps_core: LinuxPPS API ver. 1 registered [ 0.392770] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.392867] PTP clock support registered [ 0.393265] PCI: Using ACPI for IRQ routing [ 0.407887] PCI: pci_cache_line_size set to 64 bytes [ 0.407995] e820: reserve RAM buffer [mem 0x0009e800-0x0009ffff] [ 0.408001] e820: reserve RAM buffer [mem 0x7f4af000-0x7fffffff] [ 0.408006] e820: reserve RAM buffer [mem 0x7f6f0000-0x7fffffff] [ 0.408805] Switching to clocksource hpet [ 0.409122] AppArmor: AppArmor Filesystem Enabled [ 0.409360] pnp: PnP ACPI init [ 0.409389] ACPI: bus type PNP registered [ 0.409754] pnp 00:00: Plug and Play ACPI device, IDs PNP0303 (active) [ 0.410012] pnp 00:01: Plug and Play ACPI device, IDs SYN1b20 SYN1b00 SYN0002 PNP0f13 (active) [ 0.410044] pnp 00:02: [dma 4] [ 0.410216] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.410403] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active) [ 0.410820] system 00:04: [mem 0xfed00000-0xfed003ff] has been reserved [ 0.410831] system 00:04: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active) [ 0.411111] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.411378] system 00:06: [io 0x0680-0x069f] has been reserved [ 0.411387] system 00:06: [io 0x1000-0x1003] has been reserved [ 0.411394] system 00:06: [io 0x1010-0x101f] has been reserved [ 0.411401] system 00:06: [io 0x1004-0x1007] has been reserved [ 0.411408] system 00:06: [io 0x0400-0x047f] could not be reserved [ 0.411414] system 00:06: [io 0x0500-0x057f] has been reserved [ 0.411425] system 00:06: [io 0x0600-0x061f] has been reserved [ 0.411434] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.411729] system 00:07: [io 0x06a0-0x06af] has been reserved [ 0.411737] system 00:07: [io 0x06b0-0x06ff] has been reserved [ 0.411745] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.412013] pnp 00:08: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.412508] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.412518] system 00:09: [mem 0x00000000-0x00003fff] could not be reserved [ 0.412525] system 00:09: [mem 0x00000000-0x00000fff] could not be reserved [ 0.412532] system 00:09: [mem 0x00000000-0x00000fff] could not be reserved [ 0.412539] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved [ 0.412547] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.412949] pnp: PnP ACPI: found 10 devices [ 0.412954] ACPI: bus type PNP unregistered [ 0.434499] pci 0000:00:1c.0: PCI bridge to [bus 01] [ 0.434512] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff] [ 0.434525] pci 0000:00:1c.0: bridge window [mem 0x85000000-0x85ffffff] [ 0.434536] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x80ffffff 64bit pref] [ 0.434550] pci 0000:00:1c.1: PCI bridge to [bus 02] [ 0.434558] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff] [ 0.434570] pci 0000:00:1c.1: bridge window [mem 0x84000000-0x84ffffff] [ 0.434580] pci 0000:00:1c.1: bridge window [mem 0x81000000-0x81ffffff 64bit pref] [ 0.434594] pci 0000:00:1c.2: PCI bridge to [bus 03] [ 0.434602] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff] [ 0.434614] pci 0000:00:1c.2: bridge window [mem 0x83000000-0x83ffffff] [ 0.434624] pci 0000:00:1c.2: bridge window [mem 0x82000000-0x82ffffff 64bit pref] [ 0.434637] pci 0000:00:1e.0: PCI bridge to [bus 04] [ 0.435136] pci 0000:00:1e.0: setting latency timer to 64 [ 0.435147] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.435153] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.435159] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.435165] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff] [ 0.435171] pci_bus 0000:00: resource 8 [mem 0x000e0000-0x000effff] [ 0.435177] pci_bus 0000:00: resource 9 [mem 0x000f0000-0x000fffff] [ 0.435183] pci_bus 0000:00: resource 10 [mem 0x7f800000-0x7fffffff] [ 0.435189] pci_bus 0000:00: resource 11 [mem 0x80000000-0xfebfffff] [ 0.435196] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff] [ 0.435202] pci_bus 0000:01: resource 1 [mem 0x85000000-0x85ffffff] [ 0.435208] pci_bus 0000:01: resource 2 [mem 0x80000000-0x80ffffff 64bit pref] [ 0.435214] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff] [ 0.435220] pci_bus 0000:02: resource 1 [mem 0x84000000-0x84ffffff] [ 0.435226] pci_bus 0000:02: resource 2 [mem 0x81000000-0x81ffffff 64bit pref] [ 0.435232] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff] [ 0.435238] pci_bus 0000:03: resource 1 [mem 0x83000000-0x83ffffff] [ 0.435244] pci_bus 0000:03: resource 2 [mem 0x82000000-0x82ffffff 64bit pref] [ 0.435251] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7] [ 0.435256] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff] [ 0.435262] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff] [ 0.435268] pci_bus 0000:04: resource 7 [mem 0x000c0000-0x000dffff] [ 0.435274] pci_bus 0000:04: resource 8 [mem 0x000e0000-0x000effff] [ 0.435280] pci_bus 0000:04: resource 9 [mem 0x000f0000-0x000fffff] [ 0.435286] pci_bus 0000:04: resource 10 [mem 0x7f800000-0x7fffffff] [ 0.435292] pci_bus 0000:04: resource 11 [mem 0x80000000-0xfebfffff] [ 0.435461] NET: Registered protocol family 2 [ 0.436091] TCP established hash table entries: 16384 (order: 6, 262144 bytes) [ 0.436258] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 0.436410] TCP: Hash tables configured (established 16384 bind 16384) [ 0.436544] TCP: reno registered [ 0.436558] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 0.436592] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 0.436833] NET: Registered protocol family 1 [ 0.437207] RPC: Registered named UNIX socket transport module. [ 0.437213] RPC: Registered udp transport module. [ 0.437217] RPC: Registered tcp transport module. [ 0.437220] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.437244] pci 0000:00:02.0: Boot video device [ 0.438650] PCI: CLS 64 bytes, default 64 [ 0.438774] Trying to unpack rootfs image as initramfs... [ 2.915221] Freeing initrd memory: 27796k freed [ 2.942380] ttnptmsrayfraeg: module verification failed: signature and/or required key missing - tainting kernel [ 2.978407] Simple Boot Flag at 0x44 set to 0x1 [ 3.022884] Initialise module verification [ 3.023059] audit: initializing netlink socket (disabled) [ 3.023104] type=2000 audit(1596908479.898:1): initialized [ 3.043782] bounce pool size: 64 pages [ 3.046945] VFS: Disk quotas dquot_6.5.2 [ 3.047043] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 3.047834] NFS: Registering the id_resolver key type [ 3.047870] Key type id_resolver registered [ 3.047876] Key type id_legacy registered [ 3.047931] msgmni has been set to 3987 [ 3.048603] async_tx: api initialized (async) [ 3.048619] Key type asymmetric registered [ 3.048626] Asymmetric key parser 'x509' registered [ 3.049064] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251) [ 3.049077] io scheduler noop registered [ 3.049083] io scheduler deadline registered [ 3.049141] io scheduler cfq registered (default) [ 3.051681] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X [ 3.055068] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X [ 3.058713] pcieport 0000:00:1c.2: irq 42 for MSI/MSI-X [ 3.982212] tsc: Refined TSC clocksource calibration: 1596.000 MHz [ 3.982229] Switching to clocksource tsc [ 5.177582] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 5.185328] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 8250 [ 5.411053] brd: module loaded [ 5.429424] ACPI Warning: 0x0000000000000428-0x000000000000042F SystemIO conflicts with Region \PMIO 1 (20130328/utaddress-249) [ 5.429448] ACPI Warning: 0x0000000000000428-0x000000000000042F SystemIO conflicts with Region \SWC1 2 (20130328/utaddress-249) [ 5.429464] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 5.429474] Unknown LPC device 27bc [ 5.429481] ACPI Warning: 0x0000000000000530-0x000000000000053F SystemIO conflicts with Region \GPIO 1 (20130328/utaddress-249) [ 5.429495] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 5.429502] ACPI Warning: 0x0000000000000500-0x000000000000052F SystemIO conflicts with Region \GPIO 1 (20130328/utaddress-249) [ 5.429515] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 5.429520] lpc_ich: Resource conflict(s) found affecting gpio_ich [ 5.445497] Loading iSCSI transport class v2.0-870. [ 5.535385] rdac: device handler registered [ 5.546473] ahci 0000:00:1f.2: version 3.0 [ 5.546840] ahci 0000:00:1f.2: irq 43 for MSI/MSI-X [ 5.547072] ahci: SSS flag set, parallel bus scan disabled [ 5.547158] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0x3 impl SATA mode [ 5.547173] ahci 0000:00:1f.2: flags: 64bit ncq ilck stag pm led clo pio slum part [ 5.547196] ahci 0000:00:1f.2: setting latency timer to 64 [ 5.598952] scsi0 : ahci [ 5.609793] scsi1 : ahci [ 5.615619] scsi2 : ahci [ 5.622444] scsi3 : ahci [ 5.626645] ata1: SATA max UDMA/133 abar m1024@0x86104000 port 0x86104100 irq 43 [ 5.626660] ata2: SATA max UDMA/133 abar m1024@0x86104000 port 0x86104180 irq 43 [ 5.626666] ata3: DUMMY [ 5.626671] ata4: DUMMY [ 5.656350] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12 [ 5.670790] i8042: Detected active multiplexing controller, rev 1.1 [ 5.674443] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 5.674468] serio: i8042 AUX0 port at 0x60,0x64 irq 12 [ 5.674478] serio: i8042 AUX1 port at 0x60,0x64 irq 12 [ 5.674487] serio: i8042 AUX2 port at 0x60,0x64 irq 12 [ 5.674495] serio: i8042 AUX3 port at 0x60,0x64 irq 12 [ 5.674934] rtc_cmos 00:08: RTC can wake from S4 [ 5.676657] rtc_cmos 00:08: rtc core: registered rtc_cmos as rtc0 [ 5.676730] rtc_cmos 00:08: alarms up to one month, y3k, 242 bytes nvram, hpet irqs [ 5.687562] i2c /dev entries driver [ 5.713323] coretemp coretemp.0: Unable to read TjMax from CPU 0 [ 5.713374] coretemp coretemp.0: Unable to read TjMax from CPU 2 [ 5.713435] md: linear personality registered for level -1 [ 5.713441] md: raid0 personality registered for level 0 [ 5.713446] md: raid1 personality registered for level 1 [ 5.713451] md: raid10 personality registered for level 10 [ 5.717223] md: raid6 personality registered for level 6 [ 5.717233] md: raid5 personality registered for level 5 [ 5.717238] md: raid4 personality registered for level 4 [ 5.717243] md: raidF1 personality registered for level 45 [ 5.721348] device-mapper: ioctl: 4.25.0-ioctl (2013-06-26) initialised: dm-devel@redhat.com [ 5.721364] cpuidle: using governor ladder [ 5.721370] cpuidle: using governor menu [ 5.721641] TCP: cubic registered [ 5.721651] NET: Registered protocol family 17 [ 5.721738] Key type dns_resolver registered [ 5.931337] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 5.937988] ata1.00: ATA-8: ST2000LM003 HN-M201RAD, 2BC10001, max UDMA/133 [ 5.938011] ata1.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [ 5.938016] ata1.00: SN:S321J9FFC00339 [ 5.944728] ata1.00: configured for UDMA/133 [ 5.951478] scsi 0:0:0:0: Direct-Access ST2000LM HN-M201RAD 2BC1 PQ: 0 ANSI: 5 [ 5.952983] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB) [ 5.952994] sd 0:0:0:0: [sda] 4096-byte physical blocks [ 5.953224] sd 0:0:0:0: [sda] Write Protect is off [ 5.953235] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 5.953422] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 6.003490] sda: sda1 sda2 sda3 < sda5 > [ 6.008039] sd 0:0:0:0: [sda] Attached SCSI disk [ 6.260537] ata2: SATA link down (SStatus 0 SControl 300) [ 6.260639] ata3: send port disabled event [ 6.260923] ata4: send port disabled event [ 6.261199] Loading module verification blacklist certificates [ 6.261204] Loading module verification certificates [ 6.261265] MODSIGN: Loaded cert 'Synology SDG kernel module signing key: 7bd0b0d6bcd31651c22ce3978bdc8c8bdc417329' [ 6.267008] MODSIGN: Loaded cert 'Synology Root Certification Authority: f2c075361f168425f8b5ef31b796406c3aab2089' [ 6.267054] MODSIGN: Loaded cert 'Synology Kernel Module Signing Certification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28' [ 6.267104] MODSIGN: Loaded cert 'Synology kernel module signing key: 4646ce54489669338118a3b1286da156ac366fa5' [ 6.267125] registered taskstats version 1 [ 6.267826] rtc_cmos 00:08: setting system clock to 2020-08-08 17:41:23 UTC (1596908483) [ 6.269797] Freeing unused kernel memory: 792k freed [ 6.270304] Write protecting the kernel read-only data: 8192k [ 6.270821] Freeing unused kernel memory: 1188k freed [ 6.274921] Freeing unused kernel memory: 424k freed [ 6.513171] ACPI: bus type USB registered [ 6.513902] usbcore: registered new interface driver usbfs [ 6.514258] usbcore: registered new interface driver hub [ 6.517089] usbcore: registered new interface driver ethub [ 6.523508] usbcore: registered new device driver usb [ 6.587599] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 6.610377] ehci-pci: EHCI PCI platform driver [ 6.610620] ehci-pci 0000:00:1d.7: setting latency timer to 64 [ 6.610641] ehci-pci 0000:00:1d.7: EHCI Host Controller [ 6.610658] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1 [ 6.610719] ehci-pci 0000:00:1d.7: debug port 1 [ 6.614668] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported [ 6.614726] ehci-pci 0000:00:1d.7: irq 17, io mem 0x86105000 [ 6.620755] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 6.621666] hub 1-0:1.0: USB hub found [ 6.621714] hub 1-0:1.0: 8 ports detected [ 6.659765] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 6.689262] uhci_hcd: USB Universal Host Controller Interface driver [ 6.689587] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 6.689602] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 6.689627] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 6.689701] uhci_hcd 0000:00:1d.0: irq 17, io base 0x000050a0 [ 6.690955] hub 2-0:1.0: USB hub found [ 6.690985] hub 2-0:1.0: 2 ports detected [ 6.691443] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 6.691456] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 6.691485] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 [ 6.691579] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00005080 [ 6.693027] hub 3-0:1.0: USB hub found [ 6.693059] hub 3-0:1.0: 2 ports detected [ 6.693591] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 6.693606] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 6.693631] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 [ 6.693773] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00005060 [ 6.701654] hub 4-0:1.0: USB hub found [ 6.701687] hub 4-0:1.0: 2 ports detected [ 6.702238] uhci_hcd 0000:00:1d.3: setting latency timer to 64 [ 6.702254] uhci_hcd 0000:00:1d.3: UHCI Host Controller [ 6.702279] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5 [ 6.702399] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00005040 [ 6.713900] hub 5-0:1.0: USB hub found [ 6.713932] hub 5-0:1.0: 2 ports detected [ 6.889341] usbcore: registered new interface driver usb-storage [ 6.944970] usb 1-2: new high-speed USB device number 2 using ehci-pci [ 6.987656] VMware PVSCSI driver - version 1.0.2.0-k [ 7.013361] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006) [ 7.039990] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006) [ 7.092193] Fusion MPT base driver 3.04.20 [ 7.092201] Copyright (c) 1999-2008 LSI Corporation [ 7.138342] Fusion MPT SPI Host driver 3.04.20 [ 7.165461] Fusion MPT SAS Host driver 3.04.20 [ 7.171354] usb-storage 1-2:1.0: USB Mass Storage device detected [ 7.177720] scsi4 : usb-storage 1-2:1.0 [ 7.207126] Fusion MPT misc device (ioctl) driver 3.04.20 [ 7.207653] mptctl: Registered with Fusion MPT base driver [ 7.207666] mptctl: /dev/mptctl @ (major,minor=10,220) [ 7.240674] megasas: 06.506.00.00-rc1 Sat. Feb. 9 17:00:00 PDT 2013 [ 7.279887] mpt2sas version 20.00.00.00 loaded [ 7.306164] usb 1-3: new high-speed USB device number 3 using ehci-pci [ 7.309374] mpt3sas version 01.100.01.00 loaded [ 7.364291] Adaptec aacraid driver 1.2-0[30200]-ms [ 7.390740] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded [ 7.416863] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014. [ 7.442694] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000. [ 7.469504] 3ware Storage Controller device driver for Linux v1.26.02.003. [ 7.576375] isci: Intel(R) C600 SAS Controller Driver - version 1.1.0 [ 7.579430] Got empty serial number. Generate serial number from product. [ 7.744864] bromolow_synobios: module license 'Synology Inc.' taints kernel. [ 7.744872] Disabling lock debugging due to kernel taint [ 7.746205] 2020-8-8 17:41:25 UTC [ 7.746218] synobios: load, major number 201 [ 7.746232] Brand: Synology [ 7.746238] Model: DS-3615xs [ 7.746248] set group disks wakeup number to 4, spinup time deno 7 [ 7.746271] synobios cpu_arch proc entry initialized [ 7.746278] synobios crypto_hw proc entry initialized [ 7.746288] synobios syno_platform proc entry initialized [ 7.746321] synobios open /dev/ttyS1 success [ 7.765217] synobios: unload [ 7.798578] md: Autodetecting RAID arrays. [ 7.862581] md: invalid raid superblock magic on sda5 [ 7.862856] md: sda5 does not have a valid v0.90 superblock, not importing! [ 7.862877] md: Scanned 3 and added 2 devices. [ 7.862881] md: autorun ... [ 7.862885] md: considering sda1 ... [ 7.862897] md: adding sda1 ... [ 7.862905] md: sda2 has different UUID to sda1 [ 7.862916] md: created md0 [ 7.862921] md: bind<sda1> [ 7.862952] md: running: <sda1> [ 7.863605] md/raid1:md0: active with 1 out of 12 mirrors [ 7.904385] md0: detected capacity change from 0 to 2549940224 [ 7.904683] md: considering sda2 ... [ 7.904697] md: adding sda2 ... [ 7.905772] md: created md1 [ 7.905784] md: bind<sda2> [ 7.905822] md: running: <sda2> [ 7.906569] md/raid1:md1: active with 1 out of 12 mirrors [ 7.926537] md1: detected capacity change from 0 to 2147418112 [ 7.927377] md: ... autorun DONE. [ 7.982045] md0: unknown partition table [ 8.189941] scsi 4:0:0:0: Direct-Access Generic Flash Disk 8.00 PQ: 0 ANSI: 2 [ 8.192841] sd 4:0:0:0: [synoboot] 7987200 512-byte logical blocks: (4.08 GB/3.80 GiB) [ 8.193587] sd 4:0:0:0: [synoboot] Write Protect is off [ 8.193601] sd 4:0:0:0: [synoboot] Mode Sense: 03 00 00 00 [ 8.194338] sd 4:0:0:0: [synoboot] No Caching mode page found [ 8.194705] sd 4:0:0:0: [synoboot] Assuming drive cache: write through [ 8.212595] sd 4:0:0:0: [synoboot] No Caching mode page found [ 8.212947] sd 4:0:0:0: [synoboot] Assuming drive cache: write through [ 8.291666] synoboot: synoboot1 synoboot2 synoboot3 [ 8.296319] sd 4:0:0:0: [synoboot] No Caching mode page found [ 8.296665] sd 4:0:0:0: [synoboot] Assuming drive cache: write through [ 8.297066] sd 4:0:0:0: [synoboot] Attached SCSI removable disk [ 9.237619] EXT4-fs (md0): barriers disabled [ 9.261019] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: [ 11.847328] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1 [ 13.924674] EXT4-fs (md0): re-mounted. Opts: (null) [ 22.188059] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 22.188274] sd 4:0:0:0: Attached scsi generic sg1 type 0 [ 22.769175] md1: unknown partition table [ 22.949884] Adding 2097084k swap on /dev/md1. Priority:-1 extents:1 across:2097084k [ 23.459968] zram: module is from the staging directory, the quality is unknown, you have been warned. [ 23.461966] zram: Created 2 device(s) ... [ 23.504957] Adding 613372k swap on /dev/zram0. Priority:1 extents:1 across:613372k SS [ 23.536631] Adding 613372k swap on /dev/zram1. Priority:1 extents:1 across:613372k SS [ 26.653313] NET: Registered protocol family 10 [ 26.705519] sit: IPv6 over IPv4 tunneling driver [ 27.455813] init: syno-auth-check main process (5511) killed by TERM signal [ 27.870965] ACPI: Requesting acpi_cpufreq [ 27.875933] Monitor-Mwait will be used to enter C-1 state [ 27.875966] Monitor-Mwait will be used to enter C-2 state [ 27.875994] ACPI: acpi_idle registered with cpuidle [ 28.741872] systemd-udevd[5748]: starting version 204 [ 30.727082] fuse init (API version 7.22) [ 30.827471] dca service started, version 1.12.1 [ 30.891315] e1000e: Intel(R) PRO/1000 Network Driver - 3.6.0-NAPI [ 30.891327] e1000e: Copyright(c) 1999 - 2019 Intel Corporation. [ 30.975325] Intel(R) Gigabit Ethernet Linux Driver - version 5.3.5.39 [ 30.975336] Copyright(c) 2007 - 2019 Intel Corporation. [ 31.089505] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.6.3 [ 31.089516] Copyright(c) 1999 - 2019 Intel Corporation. [ 31.136840] i40e: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver - version 2.4.10 [ 31.136852] i40e: Copyright(c) 2013 - 2018 Intel Corporation. [ 31.195959] tn40xx: Tehuti Network Driver, 0.3.6.17.2 [ 31.196248] tn40xx: Supported phys : MV88X3120 MV88X3310 MV88E2010 QT2025 TLK10232 AQR105 MUSTANG [ 31.420963] qed_init called [ 31.421003] QLogic FastLinQ 4xxxx Core Module qed 8.33.9.0 [ 31.421009] creating debugfs root node [ 31.504452] qede_init: QLogic FastLinQ 4xxxx Ethernet Driver qede 8.33.9.0 [ 31.542199] Loading modules backported from Linux version v3.18.1-0-g39ca484 [ 31.542207] Backport generated by backports.git v3.18.1-1-0-g5e9ec4c [ 31.668903] Compat-mlnx-ofed backport release: c22af88 [ 31.668910] Backport based on mlnx_ofed/mlnx-ofa_kernel-4.0.git c22af88 [ 31.668914] compat.git: mlnx_ofed/mlnx-ofa_kernel-4.0.git [ 33.324394] bnx2x: Broadcom NetXtreme II 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.78.17-0 (2013/04/11) [ 33.717171] bio: create slab <bio-1> at 1 [ 33.717719] Btrfs loaded [ 33.748368] exFAT: Version 1.2.9 [ 33.899343] jme: JMicron JMC2XX ethernet driver version 1.0.8 [ 33.925147] sky2: driver version 1.30 [ 33.951928] pch_gbe: EG20T PCH Gigabit Ethernet Driver - version 1.01 [ 33.980084] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.2.42 [ 34.006885] QLogic/NetXen Network Driver v4.0.80 [ 34.021758] Solarflare NET driver v3.2 [ 34.035834] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 34.035842] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 34.049043] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de [ 34.062455] VMware vmxnet3 virtual NIC driver - version 1.1.30.0-k-NAPI [ 34.117823] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3.8.2 [ 34.117831] igbvf: Copyright (c) 1999-2015 Intel Corporation. [ 34.138338] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.6.1 [ 34.138348] Copyright(c) 1999 - 2019 Intel Corporation. [ 34.152971] r8101 Fast Ethernet driver 1.034.03-NAPI loaded [ 34.153316] r8101 0000:01:00.0: irq 44 for MSI/MSI-X [ 34.174311] r8101: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625. [ 34.174327] eth0: Identified chip type is 'RTL8105E'. [ 34.174352] r8101 Copyright (C) 2019 Realtek NIC software team <nicfae@realtek.com> This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>. This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>. [ 34.255956] usbcore: registered new interface driver ax88179_178a [ 34.269359] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0 [ 34.269377] ACPI: Power Button [PWRB] [ 34.269534] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1 [ 34.269548] ACPI: Sleep Button [SLPB] [ 34.269714] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input2 [ 34.269897] ACPI: Lid Switch [LID] [ 34.270078] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3 [ 34.270092] ACPI: Power Button [PWRF] [ 34.326715] Atheros(R) L2 Ethernet Driver - version 2.2.3 [ 34.326723] Copyright (c) 2007 Atheros Corporation. [ 34.341407] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI [ 34.341415] e100: Copyright(c) 1999-2006 Intel Corporation [ 34.363415] ixgb: Intel(R) PRO/10GbE Network Driver - version 1.0.135-k2-NAPI [ 34.363424] ixgb: Copyright (c) 1999-2008 Intel Corporation. [ 34.467825] Brocade 10G Ethernet driver - version: 3.1.2.1 [ 34.482277] vxge: Copyright(c) 2002-2010 Exar Corp. [ 34.482287] vxge: Driver version: 2.5.3.22640-k [ 34.498156] usbcore: registered new interface driver aqc111 [ 34.514074] usbcore: registered new interface driver asix [ 34.529623] usbcore: registered new interface driver cx82310_eth [ 34.544062] et131x: module is from the staging directory, the quality is unknown, you have been warned. [ 34.565545] i40evf: Intel(R) 40-10 Gigabit Virtual Function Network Driver - version 3.6.15 [ 34.565555] Copyright(c) 2013 - 2018 Intel Corporation. [ 34.579217] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 34.592740] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 34.592832] usbcore: registered new interface driver pegasus [ 34.606064] usbcore: registered new interface driver plusb [ 34.620011] usbcore: registered new interface driver r8152 [ 34.633691] usbcore: registered new interface driver rtl8150 [ 34.810328] 2020-8-8 17:41:52 UTC [ 34.810342] synobios: load, major number 201 [ 34.810355] Brand: Synology [ 34.810361] Model: DS-3615xs [ 34.810371] set group disks wakeup number to 4, spinup time deno 7 [ 34.810388] synobios cpu_arch proc entry initialized [ 34.810396] synobios crypto_hw proc entry initialized [ 34.810406] synobios syno_platform proc entry initialized [ 34.810439] synobios open /dev/ttyS1 success [ 37.630614] eth0: 0xffffc90013c52000, 08:9e:01:06:69:86, IRQ 44 [ 37.788583] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 39.804145] r8101: eth0: link up [ 39.804247] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 40.630531] md: md2 stopped. [ 40.632564] md: bind<sda5> [ 40.659783] md/raid1:md2: active with 1 out of 1 mirrors [ 40.678376] md2: detected capacity change from 0 to 1995451662336 [ 40.679179] md2: unknown partition table [ 41.470759] bio: create slab <bio-2> at 2 [ 41.489113] init: dhcp-client (eth0) main process (8207) killed by TERM signal [ 44.595510] EXT4-fs (dm-0): barriers disabled [ 44.702450] EXT4-fs (dm-0): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,data=writeback,oldalloc [ 52.264736] usbcore: registered new interface driver usblp [ 52.950908] usbcore: registered new interface driver usbhid [ 52.950916] usbhid: USB HID core driver [ 55.570656] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_init RODSP server started, login_key(089e01066986). [ 55.631069] iSCSI:extent_pool.c:766:ep_init syno_extent_pool successfully initialized [ 55.783509] iSCSI:target_core_device.c:617:se_dev_align_max_sectors Rounding down aligned max_sectors from 4294967295 to 4294967288 [ 55.784092] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully [ 56.006009] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plugin for fileio is enabled. [ 56.006027] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled. [ 56.006079] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled. [ 56.006117] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled. [ 56.006124] iSCSI:target_core_ep.c:793:ep_attach_hba ODX Token Manager is enabled. [ 59.633150] FAT-fs (synoboot2): fat_set_state: set=1 process=synopkicompatsy pid=12437 [ 59.639358] FAT-fs (synoboot2): fat_set_state: set=0 process=synopkicompatsy pid=12437 [ 63.423427] ata1.00: configured for UDMA/133 [ 63.423450] ata1: EH complete [ 65.584405] warning: `nginx' uses 32-bit capabilities (legacy support in use) [ 66.454057] loop: module loaded [ 82.457661] init: synoscheduler-vmtouch main process (4893) killed by TERM signal [ 82.874352] init: synoscheduler-vmtouch main process (14796) killed by TERM signal [ 95.532971] init: synocontentextractd main process ended, respawning [ 112.729617] perf interrupt took too long (2550 > 5000), lowering kernel.perf_event_max_sample_rate to 50000 [ 643.677509] perf interrupt took too long (5011 > 10000), lowering kernel.perf_event_max_sample_rate to 25000 Quote Link to comment Share on other sites More sharing options...
IG-88 Posted August 9, 2020 Author Share #440 Posted August 9, 2020 (edited) 14 hours ago, lolvince said: [ 34.152971] r8101 Fast Ethernet driver 1.034.03-NAPI loaded [ 34.153316] r8101 0000:01:00.0: irq 44 for MSI/MSI-X [ 34.174311] r8101: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625. [ 34.174327] eth0: Identified chip type is 'RTL8105E'. [ 34.174352] r8101 Copyright (C) 2019 Realtek NIC software team <nicfae@realtek.com> This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>. This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>. thats your internal 100MBit nic as eth0 but there is no 2nd nic as eth1 and also i dont see the r8168 driver to detect a hardware (like 8168 or 8111) next lower level is the pci(e) devices (you could also do a lspci on the console) realtek pci vendor id is 10ec so there are two pcie devices present 14 hours ago, lolvince said: [ 0.384818] pci 0000:01:00.0: [10ec:8136] type 00 class 0x020000 [ 0.384895] pci 0000:01:00.0: reg 10: [io 0x4000-0x40ff] [ 0.385027] pci 0000:01:00.0: reg 18: [mem 0x80004000-0x80004fff 64bit pref] [ 0.385108] pci 0000:01:00.0: reg 20: [mem 0x80000000-0x80003fff 64bit pref] [ 0.385465] pci 0000:01:00.0: supports D1 D2 [ 0.385471] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.385615] pci 0000:01:00.0: System wakeup disabled by ACPI ... [ 0.386504] pci 0000:03:00.0: [10ec:5209] type 00 class 0xff0000 [ 0.386582] pci 0000:03:00.0: reg 10: [mem 0x83001000-0x83001fff] [ 0.387137] pci 0000:03:00.0: supports D1 D2 [ 0.387142] pci 0000:03:00.0: PME# supported from D1 D2 D3hot [ 0.387268] pci 0000:03:00.0: System wakeup disabled by ACPI device id's for vendor realtek 8136 is "RTL810xE PCI Express Fast Ethernet controller", thats your old 100Mbit (also detrected be the driver) 5209 is "RTS5209 PCI Express Card Reader", thats not your new nic conclusion: if there is no pcie device then the mini card is not recognised/detected by the system you could double check by booting a recovery/live linux from usb and check with lspci it there is a 3rd realtek device found in theory it would need to be 10ec:8168 it its a 8168c or 8111 source: https://devicehunt.com/view/type/pci/vendor/10EC Edited August 9, 2020 by IG-88 Quote Link to comment Share on other sites More sharing options...
-iliya- Posted August 9, 2020 Share #441 Posted August 9, 2020 (edited) Hi, please help me with add 16x HDD MB Asus P7F7-E WS Supercomputer Adaptec ASR 71605 in HBA mode install 3617 DSM 6.2.3 internal sata work from 1 to 8 port edit Synoinfo.conf in /etc and /etc.default maxdisks="36" internalportcfg="fffffffff" usbportcfg="ff000000000" esataportcfg="0x0000" but after restart syno need migration and all my edit's reset. i try to edit synoinfo.conf for 24 internal hdd - but adaptec disks start from 16 positions also try o use this tuto but i cant find maxdisks and internalportcfg in jun.patch maybe need edit grub.conf , but i don't understand what need a edits. Edited August 9, 2020 by -iliya- Quote Link to comment Share on other sites More sharing options...
IG-88 Posted August 9, 2020 Author Share #442 Posted August 9, 2020 (edited) 5 hours ago, -iliya- said: Hi, please help me with add 16x HDD MB Asus P7F7-E WS Supercomputer Adaptec ASR 71605 in HBA mode install 3617 DSM 6.2.3 internal sata work from 1 to 8 port edit Synoinfo.conf in /etc and /etc.default maxdisks="36" internalportcfg="fffffffff" usbportcfg="ff000000000" esataportcfg="0x0000" but after restart syno need migration and all my edit's reset. https://xpenology.com/forum/topic/27070-36-bay-nas-drives-starting-at-11-instead-of-1-103b-with-ds3617/?do=findComment&comment=138361 and source for the "safe" (but afaik untested) numbers https://xpenology.com/forum/topic/8057-physical-drive-limits-of-an-emulated-synology-machine/page/3/?tab=comments#comment-87213 you should start with a running system and modifying synoinfo.conf, if that works out the patch in the loader can be added as long as you cant get it to work on a running system its pointless to try to mod the patch i'd say try the 35, thats supposed a save number and should cover the sixteen ports above port 16 one of the problems might be that (iirc) the system partitions (system and swap as raid1) are only stored on the 1st 12 disks if there is any confusion with the ports and it try's to find system partitions on port 9-12 and they start in reality at port 16 there might be a problem 5 hours ago, -iliya- said: i try to edit synoinfo.conf for 24 internal hdd - but adaptec disks start from 16 positions thats a little bit strange as the board only has 6+2 sata ports, with the added 16 ports the total number would be within the proven 24 can you provide a dmesg? maybe it can be seen what kind of device it finds that block the ports 9-16 its possible to remap single ports from one position to another bat doing this with 16 ports might be a lot of text and might gets confusing, i never used that stuff in grub.cfg maybe you can try this first You issue is caused by my implementation of stable Sas disk naming, the disk name is simply derived from sas remote phy id plus SasIdxMap as start position. I think ports directly connected to hba card are 0-7, and external expansion cards inside your enclosure will start from 8 You can try to set SasIdxMap=0xfffffff8, that is -8 to move start position to 0 https://xpenology.com/forum/topic/12952-dsm-62-loader/?do=findComment&comment=93862 but i guess it needs to be SasIdxMap=0xfffffffx in your case? and the x needs to a number i have not yet edit: for reference i extracted all values from quicknicks 3.0 loader as he had it preconfigured in a file (named "post") interestingly the internalportcfg value for maxdisks=64 is just 63 disks and the last disk is just one usb disk i also noticed a piece of code that might be important as it relates to >26 disks, that one would be needed to check further, might be important to use more then 24 disks if [ "${current_maxdisks}" -gt 26 ] && [ "${current_no_disk_swap}" != "yes" ]; then xpenoUpdateSynoinfo ${synocfg_root} no_disk_swap yes xpenoUpdateSynoinfo ${synocfg_root_def} no_disk_swap yes elif [ "${current_maxdisks}" -lt 26 ] && [ "${current_no_disk_swap}" = "yes" ]; then xpenoUpdateSynoinfo ${synocfg_root} no_disk_swap no xpenoUpdateSynoinfo ${synocfg_root_def} no_disk_swap no fi if [ "${current_no_disk_swap1}" -eq 1 ]; then echo "no_disk_swap=${current_no_disk_swap}" fi Spoiler maxdisks=64 internalportcfg="0x7fffffffffffffff" esataportcfg="0x0000000000000000" usbportcfg="0x8000000000000000" maxdisks=60 internalportcfg="0xfffffffffffffff" esataportcfg="0x3000000000000000" usbportcfg="0x6000000000000000" maxdisks=58 internalportcfg="0x3ffffffffffffff" esataportcfg="0x3c00000000000000" usbportcfg="0x6000000000000000" maxdisks=56 internalportcfg="0xffffffffffffff" esataportcfg="0xff00000000000000" usbportcfg="0xf0000000000000000" maxdisks=55 internalportcfg="0x7fffffffffffff" esataportcfg="0x7f10000000000000" usbportcfg="0x18000000000000000" maxdisks=52 internalportcfg="0xfffffffffffff" esataportcfg="0xff0000000000000" usbportcfg="0xf000000000000000" maxdisks=50 internalportcfg="0x3ffffffffffff" esataportcfg="0x3fc000000000000" usbportcfg="0xc00000000000000" maxdisks=48 internalportcfg="0xffffffffffff" esataportcfg="0xff000000000000" usbportcfg="0xf00000000000000" maxdisks=45 internalportcfg="0x1fffffffffff" esataportcfg="0x1fe00000000000" usbportcfg="0x60000000000000" maxdisks=44 internalportcfg="0xfffffffffff" esataportcfg="0xff00000000000" usbportcfg="0xf0000000000000" maxdisks=40 internalportcfg="0xffffffffff" esataportcfg="0xff0000000000" usbportcfg="0xf000000000000" maxdisks=36 internalportcfg="0xfffffffff" esataportcfg="0xff000000000" usbportcfg="0xf00000000000" maxdisks=35 internalportcfg="0x7ffffffff" esataportcfg="0x7f100000000" usbportcfg="0x180000000000" maxdisks=32 internalportcfg="0xffffffff" esataportcfg="0xff00000000" usbportcfg="0xf0000000000" maxdisks=30 internalportcfg="0x3fffffff" esataportcfg="0x3fc0000000" usbportcfg="0xc000000000" maxdisks=28 internalportcfg="0xfffffff" esataportcfg="0xff0000000" usbportcfg="0xf000000000" maxdisks=26 internalportcfg="0x3ffffff" esataportcfg="0x3fc000000" usbportcfg="0xc00000000" maxdisks=25 internalportcfg="0x1ffffff" esataportcfg="0x1fe000000" usbportcfg="0x600000000" maxdisks=24 internalportcfg="0xffffff" esataportcfg="0xff000000" usbportcfg="0xf00000000" maxdisks=20 internalportcfg="0xfffff" esataportcfg="0xff00000" usbportcfg="0xf0000000" maxdisks=16 internalportcfg="0xffff" esataportcfg="0xff0000" usbportcfg="0xf000000" maxdisks=12 internalportcfg="0xfff" esataportcfg="0xff000" usbportcfg="0x300000" Edited August 9, 2020 by IG-88 1 Quote Link to comment Share on other sites More sharing options...
-iliya- Posted August 9, 2020 Share #443 Posted August 9, 2020 18 минут назад, IG-88 сказал: can you provide a dmesg? Скрытый текст [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.105 (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP Wed Jul 8 03:19:42 CST 2020 [ 0.000000] Command line: syno_hdd_powerup_seq=0 HddHotplug=0 syno_hw_version=DS3617xs vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_port_thaw=1 root=/dev/md0 sn=1960ODN006200 mac1=001132A12369 mac2=001132A1236A mac3=001132A1236B mac4=001132A1236C netif_num=4 vid=0x13fe pid=0x4100 [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] e820: BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: [mem 0x0000000000000100-0x000000000009a3ff] usable [ 0.000000] BIOS-e820: [mem 0x000000000009a400-0x000000000009ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ede6ffff] usable [ 0.000000] BIOS-e820: [mem 0x00000000ede70000-0x00000000ede87fff] ACPI data [ 0.000000] BIOS-e820: [mem 0x00000000ede88000-0x00000000ededbfff] ACPI NVS [ 0.000000] BIOS-e820: [mem 0x00000000ededc000-0x00000000edffffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000040fffffff] usable [ 0.000000] NX (Execute Disable) protection: active [ 0.000000] SMBIOS 2.6 present. [ 0.000000] DMI: System manufacturer System Product Name/P7F7-E WS SUPERCOMPUTER, BIOS 0802 06/01/2011 [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable [ 0.000000] e820: last_pfn = 0x410000 max_arch_pfn = 0x400000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-DFFFF write-protect [ 0.000000] E0000-E7FFF write-through [ 0.000000] E8000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask C00000000 write-back [ 0.000000] 1 base 400000000 mask FF0000000 write-back [ 0.000000] 2 base 0F0000000 mask FF0000000 uncachable [ 0.000000] 3 base 0EE000000 mask FFE000000 uncachable [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] e820: update [mem 0xee000000-0xffffffff] usable ==> reserved [ 0.000000] e820: last_pfn = 0xede70 max_arch_pfn = 0x400000000 [ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [ffff8800000ff780] [ 0.000000] Base memory trampoline at [ffff880000094000] 94000 size 24576 [ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff] [ 0.000000] [mem 0x00000000-0x000fffff] page 4k [ 0.000000] BRK [0x01ac4000, 0x01ac4fff] PGTABLE [ 0.000000] BRK [0x01ac5000, 0x01ac5fff] PGTABLE [ 0.000000] BRK [0x01ac6000, 0x01ac6fff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x40fe00000-0x40fffffff] [ 0.000000] [mem 0x40fe00000-0x40fffffff] page 2M [ 0.000000] BRK [0x01ac7000, 0x01ac7fff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x40c000000-0x40fdfffff] [ 0.000000] [mem 0x40c000000-0x40fdfffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x400000000-0x40bffffff] [ 0.000000] [mem 0x400000000-0x40bffffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x00100000-0xede6ffff] [ 0.000000] [mem 0x00100000-0x001fffff] page 4k [ 0.000000] [mem 0x00200000-0xeddfffff] page 2M [ 0.000000] [mem 0xede00000-0xede6ffff] page 4k [ 0.000000] init_memory_mapping: [mem 0x100000000-0x3ffffffff] [ 0.000000] [mem 0x100000000-0x3ffffffff] page 2M [ 0.000000] BRK [0x01ac8000, 0x01ac8fff] PGTABLE [ 0.000000] BRK [0x01ac9000, 0x01ac9fff] PGTABLE [ 0.000000] RAMDISK: [mem 0x366ba000-0x37ffffff] [ 0.000000] ACPI: RSDP 0x00000000000FB7F0 00024 (v02 ACPIAM) [ 0.000000] ACPI: XSDT 0x00000000EDE70100 0006C (v01 060111 XSDT1425 20110601 MSFT 00000097) [ 0.000000] ACPI: FACP 0x00000000EDE70290 000F4 (v03 060111 FACP1425 20110601 MSFT 00000097) [ 0.000000] ACPI: DSDT 0x00000000EDE704A0 0FB3A (v01 W0063 W0063001 00000001 INTL 20060113) [ 0.000000] ACPI: FACS 0x00000000EDE88000 00040 [ 0.000000] ACPI: APIC 0x00000000EDE70390 000CC (v01 060111 APIC1425 20110601 MSFT 00000097) [ 0.000000] ACPI: MCFG 0x00000000EDE70460 0003C (v01 060111 OEMMCFG 20110601 MSFT 00000097) [ 0.000000] ACPI: OEMB 0x00000000EDE88040 00072 (v01 060111 OEMB1425 20110601 MSFT 00000097) [ 0.000000] ACPI: HPET 0x00000000EDE7FFE0 00038 (v01 060111 OEMHPET 20110601 MSFT 00000097) [ 0.000000] ACPI: DMAR 0x00000000EDE880C0 00090 (v01 AMI OEMDMAR 00000001 MSFT 00000097) [ 0.000000] ACPI: ASPT 0x00000000EDE80280 00034 (v06 060111 PerfTune 20110601 MSFT 00000097) [ 0.000000] ACPI: OSFR 0x00000000EDE802C0 000B0 (v01 060111 OEMOSFR 20110601 MSFT 00000097) [ 0.000000] ACPI: SSDT 0x00000000EDE8AE10 00363 (v01 DpgPmm CpuPm 00000012 INTL 20060113) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] [ffffea0000000000-ffffea000e3fffff] PMD -> [ffff8803ff600000-ffff88040d7fffff] on node 0 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x00001000-0x00ffffff] [ 0.000000] DMA32 [mem 0x01000000-0xffffffff] [ 0.000000] Normal [mem 0x100000000-0x40fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x00001000-0x00099fff] [ 0.000000] node 0: [mem 0x00100000-0xede6ffff] [ 0.000000] node 0: [mem 0x100000000-0x40fffffff] [ 0.000000] On node 0 totalpages: 4185609 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 21 pages reserved [ 0.000000] DMA zone: 3993 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 13267 pages used for memmap [ 0.000000] DMA32 zone: 970352 pages, LIFO batch:31 [ 0.000000] Normal zone: 43904 pages used for memmap [ 0.000000] Normal zone: 3211264 pages, LIFO batch:31 [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x03] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x05] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x88] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x89] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x8a] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x8b] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x8c] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x8d] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x8e] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x8f] disabled) [ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000 [ 0.000000] smpboot: Allowing 16 CPUs, 8 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009a000 - 000000000009b000 [ 0.000000] PM: Registered nosave memory: 000000000009b000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000 [ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000 [ 0.000000] PM: Registered nosave memory: 00000000ede70000 - 00000000ede88000 [ 0.000000] PM: Registered nosave memory: 00000000ede88000 - 00000000ededc000 [ 0.000000] PM: Registered nosave memory: 00000000ededc000 - 00000000ee000000 [ 0.000000] PM: Registered nosave memory: 00000000ee000000 - 00000000fee00000 [ 0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000 [ 0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000ff800000 [ 0.000000] PM: Registered nosave memory: 00000000ff800000 - 0000000100000000 [ 0.000000] e820: [mem 0xee000000-0xfedfffff] available for PCI devices [ 0.000000] setup_percpu: NR_CPUS:16 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 26 pages/cpu @ffff88040fc00000 s76864 r8192 d21440 u131072 [ 0.000000] pcpu-alloc: s76864 r8192 d21440 u131072 alloc=1*2097152 [ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4128361 [ 0.000000] Kernel command line: syno_hdd_powerup_seq=0 HddHotplug=0 syno_hw_version=DS3617xs vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_port_thaw=1 root=/dev/md0 sn=1960ODN006200 mac1=001132A12369 mac2=001132A1236A mac3=001132A1236B mac4=001132A1236C netif_num=4 vid=0x13fe pid=0x4100 [ 0.000000] Power on seq num: 0 [ 0.000000] Synology Hardware Version: DS3617xs-j [ 0.000000] Vender format version: 2 [ 0.000000] Serial Number: 1960ODN006200 [ 0.000000] Mac1: 001132A12369 [ 0.000000] Mac2: 001132A1236A [ 0.000000] Mac3: 001132A1236B [ 0.000000] Mac4: 001132A1236C [ 0.000000] Internal netif num: 4 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes) [ 0.000000] Memory: 16381496k/17039360k available (4904k kernel code, 296924k absent, 360940k reserved, 3715k data, 792k init) [ 0.000000] Kernel/User page tables isolation: disabled [ 0.000000] Hierarchical RCU implementation. [ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32 [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:4352 nr_irqs:808 16 [ 0.000000] Console: colour dummy device 80x25 [ 0.000000] console [ttyS0] enabled [ 0.000000] allocated 67108864 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] hpet clockevent registered [ 0.000000] tsc: Fast TSC calibration using PIT [ 0.000000] tsc: Detected 2942.667 MHz processor [ 0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 5885.33 BogoMIPS (lpj=2942667) [ 0.000005] pid_max: default: 32768 minimum: 301 [ 0.000028] Security Framework initialized [ 0.000033] AppArmor: AppArmor initialized [ 0.000040] Mount-cache hash table entries: 256 [ 0.000179] Initializing cgroup subsys memory [ 0.000187] Initializing cgroup subsys devices [ 0.000189] Initializing cgroup subsys freezer [ 0.000190] Initializing cgroup subsys blkio [ 0.000206] CPU: Physical Processor ID: 0 [ 0.000207] CPU: Processor Core ID: 0 [ 0.000210] mce: CPU supports 9 MCE banks [ 0.000217] CPU0: Thermal monitoring enabled (TM1) [ 0.000224] Last level iTLB entries: 4KB 512, 2MB 7, 4MB 7 Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32 tlb_flushall_shift: 6 [ 0.000225] FEATURE SPEC_CTRL Not Present [ 0.000226] FEATURE IBPB_SUPPORT Not Present [ 0.000227] Spectre V2 : Vulnerable [ 0.000284] Freeing SMP alternatives: 24k freed [ 0.000289] ACPI: Core revision 20130328 [ 0.003497] ACPI: All ACPI Tables successfully acquired [ 0.003543] dmar: Host address width 36 [ 0.003545] dmar: DRHD base: 0x000000fed90000 flags: 0x1 [ 0.003550] dmar: IOMMU 0: reg_base_addr fed90000 ver 1:0 cap c90780106f0462 ecap f020e3 [ 0.003551] dmar: RMRR base: 0x000000000e4000 end: 0x000000000e7fff [ 0.003553] dmar: RMRR base: 0x000000edeec000 end: 0x000000edefffff [ 0.003649] Switched APIC routing to physical flat. [ 0.004031] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.014033] smpboot: CPU0: Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz (fam: 06, model: 1e, stepping: 05) [ 0.115673] Performance Events: PEBS fmt1+, 16-deep LBR, Nehalem events, Intel PMU driver. [ 0.115678] perf_event_intel: CPU erratum AAJ80 worked around [ 0.115679] perf_event_intel: CPUID marked event: 'bus cycles' unavailable [ 0.115680] ... version: 3 [ 0.115681] ... bit width: 48 [ 0.115682] ... generic registers: 4 [ 0.115683] ... value mask: 0000ffffffffffff [ 0.115684] ... max period: 000000007fffffff [ 0.115684] ... fixed-purpose events: 3 [ 0.115685] ... event mask: 000000070000000f [ 0.115882] smpboot: Booting Node 0, Processors #1 #2 #3 #4 #5 #6 #7 [ 0.208880] Brought up 8 CPUs [ 0.208883] smpboot: Total of 8 processors activated (47082.67 BogoMIPS) [ 0.213576] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. [ 0.213812] devtmpfs: initialized [ 0.213994] PM: Registering ACPI NVS region [mem 0xede88000-0xededbfff] (344064 bytes) [ 0.214095] xor: measuring software checksum speed [ 0.223651] prefetch64-sse: 12180.000 MB/sec [ 0.233648] generic_sse: 10732.000 MB/sec [ 0.233649] xor: using function: prefetch64-sse (12180.000 MB/sec) [ 0.233691] NET: Registered protocol family 16 [ 0.233969] ACPI: bus type PCI registered [ 0.234049] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) [ 0.234051] PCI: not using MMCONFIG [ 0.234052] PCI: Using configuration type 1 for base access [ 0.236761] bio: create slab <bio-0> at 0 [ 0.253653] raid6: sse2x1 gen() 7246 MB/s [ 0.270647] raid6: sse2x1 xor() 5638 MB/s [ 0.287643] raid6: sse2x2 gen() 8539 MB/s [ 0.304637] raid6: sse2x2 xor() 6505 MB/s [ 0.321637] raid6: sse2x4 gen() 9527 MB/s [ 0.338633] raid6: sse2x4 xor() 7253 MB/s [ 0.338634] raid6: using algorithm sse2x4 gen() (9527 MB/s) [ 0.338635] raid6: .... xor() 7253 MB/s, rmw enabled [ 0.338636] raid6: using ssse3x2 recovery algorithm [ 0.338666] ACPI: Added _OSI(Module Device) [ 0.338667] ACPI: Added _OSI(Processor Device) [ 0.338668] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.338670] ACPI: Added _OSI(Processor Aggregator Device) [ 0.339573] ACPI: EC: Look up EC in DSDT [ 0.340464] ACPI: Executed 1 blocks of module-level executable AML code [ 0.346618] ACPI BIOS Bug: Warning: Incorrect checksum in table [OEMB] - 0xBF, should be 0xBE (20130328/tbutils-320) [ 0.349651] ACPI: SSDT 0x00000000EDE88150 0265C (v01 DpgPmm P001Ist 00000011 INTL 20060113) [ 0.349945] ACPI: Dynamic OEM Table Load: [ 0.349947] ACPI: SSDT 0x0000000000000000 0265C (v01 DpgPmm P001Ist 00000011 INTL 20060113) [ 0.350016] ACPI: SSDT 0x00000000EDE8A7B0 00659 (v01 PmRef P001Cst 00003001 INTL 20060113) [ 0.350240] ACPI: Dynamic OEM Table Load: [ 0.350241] ACPI: SSDT 0x0000000000000000 00659 (v01 PmRef P001Cst 00003001 INTL 20060113) [ 0.350468] ACPI: Interpreter enabled [ 0.350478] ACPI: (supports S0 S4 S5) [ 0.350479] ACPI: Using IOAPIC for interrupt routing [ 0.350492] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) [ 0.350952] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in ACPI motherboard resources [ 0.351026] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.351099] ACPI: No dock devices found. [ 0.358020] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.358150] acpi PNP0A08:00: Requesting ACPI _OSC control (0x1d) [ 0.358271] acpi PNP0A08:00: ACPI _OSC request failed (AE_SUPPORT), returned control mask: 0x0d [ 0.358272] ACPI _OSC control for PCIe not granted, disabling ASPM [ 0.358364] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge [ 0.358391] PCI host bridge to bus 0000:00 [ 0.358393] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.358395] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.358396] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.358397] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.358399] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff] [ 0.358400] pci_bus 0000:00: root bus resource [mem 0xee000000-0xf7ffffff] [ 0.358402] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed8ffff] [ 0.358410] pci 0000:00:00.0: [8086:d131] type 00 class 0x060000 [ 0.358505] pci 0000:00:03.0: [8086:d138] type 01 class 0x060400 [ 0.358547] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold [ 0.358588] pci 0000:00:03.0: System wakeup disabled by ACPI [ 0.358623] pci 0000:00:08.0: [8086:d155] type 00 class 0x088000 [ 0.358723] pci 0000:00:08.1: [8086:d156] type 00 class 0x088000 [ 0.358820] pci 0000:00:08.2: [8086:d157] type 00 class 0x088000 [ 0.358915] pci 0000:00:08.3: [8086:d158] type 00 class 0x088000 [ 0.359006] pci 0000:00:10.0: [8086:d150] type 00 class 0x088000 [ 0.359090] pci 0000:00:10.1: [8086:d151] type 00 class 0x088000 [ 0.359190] pci 0000:00:16.0: [8086:3b64] type 00 class 0x078000 [ 0.359217] pci 0000:00:16.0: reg 10: [mem 0xf70ff000-0xf70ff00f 64bit] [ 0.359305] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold [ 0.359386] pci 0000:00:1a.0: [8086:3b3c] type 00 class 0x0c0320 [ 0.359405] pci 0000:00:1a.0: reg 10: [mem 0xf70fe000-0xf70fe3ff] [ 0.359487] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold [ 0.359527] pci 0000:00:1a.0: System wakeup disabled by ACPI [ 0.359564] pci 0000:00:1b.0: [8086:3b56] type 00 class 0x040300 [ 0.359577] pci 0000:00:1b.0: reg 10: [mem 0xf70f8000-0xf70fbfff 64bit] [ 0.359641] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.359756] pci 0000:00:1c.0: [8086:3b42] type 01 class 0x060400 [ 0.359816] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.359859] pci 0000:00:1c.0: System wakeup disabled by ACPI [ 0.359895] pci 0000:00:1c.4: [8086:3b4a] type 01 class 0x060400 [ 0.359956] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold [ 0.359999] pci 0000:00:1c.4: System wakeup disabled by ACPI [ 0.360033] pci 0000:00:1c.5: [8086:3b4c] type 01 class 0x060400 [ 0.360093] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold [ 0.360133] pci 0000:00:1c.5: System wakeup disabled by ACPI [ 0.360167] pci 0000:00:1c.6: [8086:3b4e] type 01 class 0x060400 [ 0.360229] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold [ 0.360269] pci 0000:00:1c.6: System wakeup disabled by ACPI [ 0.360303] pci 0000:00:1c.7: [8086:3b50] type 01 class 0x060400 [ 0.360363] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold [ 0.360404] pci 0000:00:1c.7: System wakeup disabled by ACPI [ 0.360442] pci 0000:00:1d.0: [8086:3b34] type 00 class 0x0c0320 [ 0.360461] pci 0000:00:1d.0: reg 10: [mem 0xf70fd000-0xf70fd3ff] [ 0.360540] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold [ 0.360582] pci 0000:00:1d.0: System wakeup disabled by ACPI [ 0.360614] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401 [ 0.360690] pci 0000:00:1e.0: System wakeup disabled by ACPI [ 0.360727] pci 0000:00:1f.0: [8086:3b16] type 00 class 0x060100 [ 0.360887] pci 0000:00:1f.2: [8086:3b22] type 00 class 0x010601 [ 0.360903] pci 0000:00:1f.2: reg 10: [io 0xa880-0xa887] [ 0.360910] pci 0000:00:1f.2: reg 14: [io 0xa800-0xa803] [ 0.360917] pci 0000:00:1f.2: reg 18: [io 0xa480-0xa487] [ 0.360923] pci 0000:00:1f.2: reg 1c: [io 0xa400-0xa403] [ 0.360929] pci 0000:00:1f.2: reg 20: [io 0xa080-0xa09f] [ 0.360936] pci 0000:00:1f.2: reg 24: [mem 0xf70f7000-0xf70f77ff] [ 0.360975] pci 0000:00:1f.2: PME# supported from D3hot [ 0.361042] pci 0000:00:1f.3: [8086:3b30] type 00 class 0x0c0500 [ 0.361055] pci 0000:00:1f.3: reg 10: [mem 0xf70fc000-0xf70fc0ff 64bit] [ 0.361073] pci 0000:00:1f.3: reg 20: [io 0xffe0-0xffff] [ 0.361193] pci 0000:01:00.0: [10de:05b1] type 01 class 0x060400 [ 0.361242] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold [ 0.362646] pci 0000:00:03.0: PCI bridge to [bus 01-04] [ 0.362652] pci 0000:00:03.0: bridge window [io 0xb000-0xbfff] [ 0.362657] pci 0000:00:03.0: bridge window [mem 0xf7100000-0xf79fffff] [ 0.362741] pci 0000:02:00.0: [10de:05b1] type 01 class 0x060400 [ 0.362784] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold [ 0.362828] pci 0000:02:02.0: [10de:05b1] type 01 class 0x060400 [ 0.362871] pci 0000:02:02.0: PME# supported from D0 D3hot D3cold [ 0.362925] pci 0000:01:00.0: PCI bridge to [bus 02-04] [ 0.362929] pci 0000:01:00.0: bridge window [io 0xb000-0xbfff] [ 0.362932] pci 0000:01:00.0: bridge window [mem 0xf7100000-0xf79fffff] [ 0.362993] pci 0000:03:00.0: [9005:028c] type 00 class 0x010400 [ 0.363008] pci 0000:03:00.0: reg 10: [mem 0xf7200000-0xf72fffff 64bit] [ 0.363020] pci 0000:03:00.0: reg 18: [mem 0xf71ff000-0xf71ff3ff 64bit] [ 0.363028] pci 0000:03:00.0: reg 20: [io 0xb800-0xb8ff] [ 0.363043] pci 0000:03:00.0: reg 30: [mem 0xf7100000-0xf717ffff pref] [ 0.363085] pci 0000:03:00.0: PME# supported from D0 D1 D3hot [ 0.364652] pci 0000:02:00.0: PCI bridge to [bus 03] [ 0.364660] pci 0000:02:00.0: bridge window [io 0xb000-0xbfff] [ 0.364666] pci 0000:02:00.0: bridge window [mem 0xf7100000-0xf72fffff] [ 0.364755] pci 0000:04:00.0: [19a2:0700] type 00 class 0x020000 [ 0.364779] pci 0000:04:00.0: reg 14: [mem 0xf79e0000-0xf79e3fff] [ 0.364795] pci 0000:04:00.0: reg 18: [mem 0xf7580000-0xf759ffff 64bit] [ 0.364811] pci 0000:04:00.0: reg 20: [mem 0xf7460000-0xf747ffff 64bit] [ 0.364822] pci 0000:04:00.0: reg 30: [mem 0xf7380000-0xf73fffff pref] [ 0.364872] pci 0000:04:00.0: PME# supported from D3hot D3cold [ 0.364938] pci 0000:04:00.1: [19a2:0700] type 00 class 0x020000 [ 0.364963] pci 0000:04:00.1: reg 14: [mem 0xf79e4000-0xf79e7fff] [ 0.364979] pci 0000:04:00.1: reg 18: [mem 0xf75c0000-0xf75dffff 64bit] [ 0.364994] pci 0000:04:00.1: reg 20: [mem 0xf75a0000-0xf75bffff 64bit] [ 0.365005] pci 0000:04:00.1: reg 30: [mem 0xf7480000-0xf74fffff pref] [ 0.365055] pci 0000:04:00.1: PME# supported from D3hot D3cold [ 0.366659] pci 0000:02:02.0: PCI bridge to [bus 04] [ 0.366669] pci 0000:02:02.0: bridge window [mem 0xf7300000-0xf79fffff] [ 0.366771] pci 0000:09:00.0: [10b5:8608] type 01 class 0x060400 [ 0.366784] pci 0000:09:00.0: reg 10: [mem 0xf7de0000-0xf7dfffff] [ 0.366859] pci 0000:09:00.0: PME# supported from D0 D3hot D3cold [ 0.366894] pci 0000:09:00.0: System wakeup disabled by ACPI [ 0.368659] pci 0000:00:1c.0: PCI bridge to [bus 09-0e] [ 0.368665] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff] [ 0.368671] pci 0000:00:1c.0: bridge window [mem 0xf7d00000-0xf7ffffff] [ 0.368778] pci 0000:0a:01.0: [10b5:8608] type 01 class 0x060400 [ 0.368866] pci 0000:0a:01.0: PME# supported from D0 D3hot D3cold [ 0.368945] pci 0000:0a:05.0: [10b5:8608] type 01 class 0x060400 [ 0.369033] pci 0000:0a:05.0: PME# supported from D0 D3hot D3cold [ 0.369110] pci 0000:0a:07.0: [10b5:8608] type 01 class 0x060400 [ 0.369198] pci 0000:0a:07.0: PME# supported from D0 D3hot D3cold [ 0.369233] pci 0000:0a:07.0: System wakeup disabled by ACPI [ 0.369279] pci 0000:0a:09.0: [10b5:8608] type 01 class 0x060400 [ 0.369367] pci 0000:0a:09.0: PME# supported from D0 D3hot D3cold [ 0.369401] pci 0000:0a:09.0: System wakeup disabled by ACPI [ 0.369457] pci 0000:09:00.0: PCI bridge to [bus 0a-0e] [ 0.369463] pci 0000:09:00.0: bridge window [io 0xe000-0xefff] [ 0.369467] pci 0000:09:00.0: bridge window [mem 0xf7e00000-0xf7ffffff] [ 0.369568] pci 0000:0b:00.0: [1033:0194] type 00 class 0x0c0330 [ 0.369593] pci 0000:0b:00.0: reg 10: [mem 0xf7efe000-0xf7efffff 64bit] [ 0.369722] pci 0000:0b:00.0: PME# supported from D0 D3hot D3cold [ 0.371673] pci 0000:0a:01.0: PCI bridge to [bus 0b] [ 0.371686] pci 0000:0a:01.0: bridge window [mem 0xf7e00000-0xf7efffff] [ 0.371797] pci 0000:0c:00.0: [1b4b:9123] type 00 class 0x010601 [ 0.371813] pci 0000:0c:00.0: reg 10: [io 0xec00-0xec07] [ 0.371824] pci 0000:0c:00.0: reg 14: [io 0xe880-0xe883] [ 0.371836] pci 0000:0c:00.0: reg 18: [io 0xe800-0xe807] [ 0.371847] pci 0000:0c:00.0: reg 1c: [io 0xe480-0xe483] [ 0.371858] pci 0000:0c:00.0: reg 20: [io 0xe400-0xe40f] [ 0.371869] pci 0000:0c:00.0: reg 24: [mem 0xf7fff000-0xf7fff7ff] [ 0.371881] pci 0000:0c:00.0: reg 30: [mem 0xf7fe0000-0xf7feffff pref] [ 0.371935] pci 0000:0c:00.0: PME# supported from D3hot [ 0.373670] pci 0000:0a:05.0: PCI bridge to [bus 0c] [ 0.373680] pci 0000:0a:05.0: bridge window [io 0xe000-0xefff] [ 0.373686] pci 0000:0a:05.0: bridge window [mem 0xf7f00000-0xf7ffffff] [ 0.373779] pci 0000:0a:07.0: PCI bridge to [bus 0d] [ 0.373864] pci 0000:0a:09.0: PCI bridge to [bus 0e] [ 0.373955] pci 0000:00:1c.4: PCI bridge to [bus 08] [ 0.373958] pci 0000:00:1c.4: bridge window [io 0x1000-0x1fff] [ 0.373961] pci 0000:00:1c.4: bridge window [mem 0xee000000-0xee1fffff] [ 0.373965] pci 0000:00:1c.4: bridge window [mem 0xee200000-0xee3fffff 64bit pref] [ 0.374037] pci 0000:07:00.0: [11c1:5901] type 00 class 0x0c0010 [ 0.374059] pci 0000:07:00.0: reg 10: [mem 0xf7cff000-0xf7cfffff 64bit] [ 0.374167] pci 0000:07:00.0: supports D1 D2 [ 0.374168] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.375675] pci 0000:00:1c.5: PCI bridge to [bus 07] [ 0.375681] pci 0000:00:1c.5: bridge window [io 0x2000-0x2fff] [ 0.375686] pci 0000:00:1c.5: bridge window [mem 0xf7c00000-0xf7cfffff] [ 0.375694] pci 0000:00:1c.5: bridge window [mem 0xee400000-0xee5fffff 64bit pref] [ 0.375782] pci 0000:06:00.0: [10ec:8168] type 00 class 0x020000 [ 0.375797] pci 0000:06:00.0: reg 10: [io 0xd800-0xd8ff] [ 0.375822] pci 0000:06:00.0: reg 18: [mem 0xf6fff000-0xf6ffffff 64bit pref] [ 0.375839] pci 0000:06:00.0: reg 20: [mem 0xf6ff8000-0xf6ffbfff 64bit pref] [ 0.375850] pci 0000:06:00.0: reg 30: [mem 0xf7bf0000-0xf7bfffff pref] [ 0.375910] pci 0000:06:00.0: supports D1 D2 [ 0.375911] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.377677] pci 0000:00:1c.6: PCI bridge to [bus 06] [ 0.377684] pci 0000:00:1c.6: bridge window [io 0xd000-0xdfff] [ 0.377689] pci 0000:00:1c.6: bridge window [mem 0xf7b00000-0xf7bfffff] [ 0.377697] pci 0000:00:1c.6: bridge window [mem 0xf6f00000-0xf6ffffff 64bit pref] [ 0.377784] pci 0000:05:00.0: [10ec:8168] type 00 class 0x020000 [ 0.377799] pci 0000:05:00.0: reg 10: [io 0xc800-0xc8ff] [ 0.377825] pci 0000:05:00.0: reg 18: [mem 0xf6eff000-0xf6efffff 64bit pref] [ 0.377841] pci 0000:05:00.0: reg 20: [mem 0xf6ef8000-0xf6efbfff 64bit pref] [ 0.377852] pci 0000:05:00.0: reg 30: [mem 0xf7af0000-0xf7afffff pref] [ 0.377911] pci 0000:05:00.0: supports D1 D2 [ 0.377913] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.379681] pci 0000:00:1c.7: PCI bridge to [bus 05] [ 0.379687] pci 0000:00:1c.7: bridge window [io 0xc000-0xcfff] [ 0.379693] pci 0000:00:1c.7: bridge window [mem 0xf7a00000-0xf7afffff] [ 0.379700] pci 0000:00:1c.7: bridge window [mem 0xf6e00000-0xf6efffff 64bit pref] [ 0.379776] pci 0000:00:1e.0: PCI bridge to [bus 0f] (subtractive decode) [ 0.379784] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.379786] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.379787] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.379789] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode) [ 0.379790] pci 0000:00:1e.0: bridge window [mem 0xee000000-0xf7ffffff] (subtractive decode) [ 0.379791] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfed8ffff] (subtractive decode) [ 0.379818] pci 0000:00:03.0: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 128 [ 0.379823] pci 0000:01:00.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.379828] pci 0000:02:00.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.379834] pci 0000:03:00.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 512 [ 0.379840] pci 0000:02:02.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.379848] pci 0000:04:00.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 512 [ 0.379856] pci 0000:04:00.1: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 512 [ 0.379861] pci 0000:00:1c.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.379869] pci 0000:09:00.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.379876] pci 0000:0a:01.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.379886] pci 0000:0b:00.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512 [ 0.379893] pci 0000:0a:05.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.379902] pci 0000:0c:00.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 512 [ 0.379909] pci 0000:0a:07.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.379916] pci 0000:0a:09.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.379922] pci 0000:00:1c.4: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.379927] pci 0000:00:1c.5: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.379937] pci 0000:07:00.0: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 2048 [ 0.379942] pci 0000:00:1c.6: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.379950] pci 0000:06:00.0: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 512 [ 0.379956] pci 0000:00:1c.7: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.379964] pci 0000:05:00.0: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 512 [ 0.379965] pci_bus 0000:00: on NUMA node 0 [ 0.380428] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12 14 15), disabled. [ 0.380467] ACPI: PCI Interrupt Link [LNKB] (IRQs *5), disabled. [ 0.380503] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12 14 *15), disabled. [ 0.380541] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12 14 15), disabled. [ 0.380579] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled. [ 0.380616] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12 *14 15), disabled. [ 0.380654] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 6 7 10 11 12 14 15), disabled. [ 0.380696] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 6 *7 10 11 12 14 15), disabled. [ 0.380780] ACPI: Enabled 2 GPEs in block 00 to 3F [ 0.380785] acpi root: \_SB_.PCI0 notify handler is installed [ 0.380819] Found 1 acpi root devices [ 0.380842] ACPI: EC: GPE = 0x18, I/O: command/status = 0x66, data = 0x62 [ 0.380933] vgaarb: loaded [ 0.381027] SCSI subsystem initialized [ 0.381029] ACPI: bus type ATA registered [ 0.381092] libata version 3.00 loaded. [ 0.381151] pps_core: LinuxPPS API ver. 1 registered [ 0.381152] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.381167] PTP clock support registered [ 0.381231] PCI: Using ACPI for IRQ routing [ 0.382270] PCI: Discovered peer bus 3f [ 0.382271] PCI: root bus 3f: using default resources [ 0.382272] PCI: Probing PCI hardware (bus 3f) [ 0.382300] PCI host bridge to bus 0000:3f [ 0.382302] pci_bus 0000:3f: root bus resource [io 0x0000-0xffff] [ 0.382304] pci_bus 0000:3f: root bus resource [mem 0x00000000-0xfffffffff] [ 0.382305] pci_bus 0000:3f: No busn resource found for root bus, will use [bus 3f-ff] [ 0.382310] pci 0000:3f:00.0: [8086:2c51] type 00 class 0x060000 [ 0.382350] pci 0000:3f:00.1: [8086:2c81] type 00 class 0x060000 [ 0.382388] pci 0000:3f:02.0: [8086:2c90] type 00 class 0x060000 [ 0.382422] pci 0000:3f:02.1: [8086:2c91] type 00 class 0x060000 [ 0.382459] pci 0000:3f:03.0: [8086:2c98] type 00 class 0x060000 [ 0.382497] pci 0000:3f:03.1: [8086:2c99] type 00 class 0x060000 [ 0.382532] pci 0000:3f:03.4: [8086:2c9c] type 00 class 0x060000 [ 0.382568] pci 0000:3f:04.0: [8086:2ca0] type 00 class 0x060000 [ 0.382603] pci 0000:3f:04.1: [8086:2ca1] type 00 class 0x060000 [ 0.382638] pci 0000:3f:04.2: [8086:2ca2] type 00 class 0x060000 [ 0.382673] pci 0000:3f:04.3: [8086:2ca3] type 00 class 0x060000 [ 0.382710] pci 0000:3f:05.0: [8086:2ca8] type 00 class 0x060000 [ 0.382744] pci 0000:3f:05.1: [8086:2ca9] type 00 class 0x060000 [ 0.382779] pci 0000:3f:05.2: [8086:2caa] type 00 class 0x060000 [ 0.382816] pci 0000:3f:05.3: [8086:2cab] type 00 class 0x060000 [ 0.382858] pci_bus 0000:3f: busn_res: [bus 3f-ff] end is updated to 3f [ 0.382860] PCI: pci_cache_line_size set to 64 bytes [ 0.382949] e820: reserve RAM buffer [mem 0x0009a400-0x0009ffff] [ 0.382951] e820: reserve RAM buffer [mem 0xede70000-0xefffffff] [ 0.383118] HPET: 8 timers in total, 6 timers will be used for per-cpu timer [ 0.383138] Spurious HPET timer interrupt on HPET timer 2 [ 0.383146] hpet: hpet2 irq 40 for MSI [ 0.383179] hpet: hpet3 irq 41 for MSI [ 0.383217] hpet: hpet4 irq 42 for MSI [ 0.383252] hpet: hpet5 irq 43 for MSI [ 0.383285] hpet: hpet6 irq 44 for MSI [ 0.383315] hpet: hpet7 irq 45 for MSI [ 0.383357] Switching to clocksource hpet [ 0.383444] AppArmor: AppArmor Filesystem Enabled [ 0.383477] pnp: PnP ACPI init [ 0.383482] ACPI: bus type PNP registered [ 0.383534] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved [ 0.383536] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.383561] pnp 00:01: [dma 4] [ 0.383589] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.383626] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.383656] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.383688] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.383833] system 00:05: [io 0x0290-0x029f] has been reserved [ 0.383836] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.384009] system 00:06: [io 0x04d0-0x04d1] has been reserved [ 0.384011] system 00:06: [io 0x0800-0x087f] could not be reserved [ 0.384013] system 00:06: [io 0x0500-0x057f] has been reserved [ 0.384015] system 00:06: [io 0x0600-0x0607] has been reserved [ 0.384017] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.384018] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved [ 0.384020] system 00:06: [mem 0xfed40000-0xfed8ffff] has been reserved [ 0.384022] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.384094] pnp 00:07: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.384246] pnp 00:08: [dma 0 disabled] [ 0.384316] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.384431] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.384433] system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.384435] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.384533] system 00:0a: [mem 0xf8000000-0xfbffffff] has been reserved [ 0.384536] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.384706] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.384708] system 00:0b: [mem 0x000c0000-0x000cffff] could not be reserved [ 0.384710] system 00:0b: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.384712] system 00:0b: [mem 0x00100000-0xedffffff] could not be reserved [ 0.384713] system 00:0b: [mem 0xfed90000-0xffffffff] could not be reserved [ 0.384715] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.384801] pnp: PnP ACPI: found 12 devices [ 0.384802] ACPI: bus type PNP unregistered [ 0.393132] pci 0000:02:00.0: PCI bridge to [bus 03] [ 0.393135] pci 0000:02:00.0: bridge window [io 0xb000-0xbfff] [ 0.393139] pci 0000:02:00.0: bridge window [mem 0xf7100000-0xf72fffff] [ 0.393145] pci 0000:02:02.0: PCI bridge to [bus 04] [ 0.393148] pci 0000:02:02.0: bridge window [mem 0xf7300000-0xf79fffff] [ 0.393154] pci 0000:01:00.0: PCI bridge to [bus 02-04] [ 0.393156] pci 0000:01:00.0: bridge window [io 0xb000-0xbfff] [ 0.393159] pci 0000:01:00.0: bridge window [mem 0xf7100000-0xf79fffff] [ 0.393165] pci 0000:00:03.0: PCI bridge to [bus 01-04] [ 0.393167] pci 0000:00:03.0: bridge window [io 0xb000-0xbfff] [ 0.393170] pci 0000:00:03.0: bridge window [mem 0xf7100000-0xf79fffff] [ 0.393175] pci 0000:0a:01.0: PCI bridge to [bus 0b] [ 0.393179] pci 0000:0a:01.0: bridge window [mem 0xf7e00000-0xf7efffff] [ 0.393187] pci 0000:0a:05.0: PCI bridge to [bus 0c] [ 0.393190] pci 0000:0a:05.0: bridge window [io 0xe000-0xefff] [ 0.393195] pci 0000:0a:05.0: bridge window [mem 0xf7f00000-0xf7ffffff] [ 0.393203] pci 0000:0a:07.0: PCI bridge to [bus 0d] [ 0.393214] pci 0000:0a:09.0: PCI bridge to [bus 0e] [ 0.393226] pci 0000:09:00.0: PCI bridge to [bus 0a-0e] [ 0.393228] pci 0000:09:00.0: bridge window [io 0xe000-0xefff] [ 0.393233] pci 0000:09:00.0: bridge window [mem 0xf7e00000-0xf7ffffff] [ 0.393241] pci 0000:00:1c.0: PCI bridge to [bus 09-0e] [ 0.393243] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff] [ 0.393246] pci 0000:00:1c.0: bridge window [mem 0xf7d00000-0xf7ffffff] [ 0.393252] pci 0000:00:1c.4: PCI bridge to [bus 08] [ 0.393254] pci 0000:00:1c.4: bridge window [io 0x1000-0x1fff] [ 0.393258] pci 0000:00:1c.4: bridge window [mem 0xee000000-0xee1fffff] [ 0.393261] pci 0000:00:1c.4: bridge window [mem 0xee200000-0xee3fffff 64bit pref] [ 0.393265] pci 0000:00:1c.5: PCI bridge to [bus 07] [ 0.393267] pci 0000:00:1c.5: bridge window [io 0x2000-0x2fff] [ 0.393271] pci 0000:00:1c.5: bridge window [mem 0xf7c00000-0xf7cfffff] [ 0.393273] pci 0000:00:1c.5: bridge window [mem 0xee400000-0xee5fffff 64bit pref] [ 0.393278] pci 0000:00:1c.6: PCI bridge to [bus 06] [ 0.393280] pci 0000:00:1c.6: bridge window [io 0xd000-0xdfff] [ 0.393283] pci 0000:00:1c.6: bridge window [mem 0xf7b00000-0xf7bfffff] [ 0.393286] pci 0000:00:1c.6: bridge window [mem 0xf6f00000-0xf6ffffff 64bit pref] [ 0.393290] pci 0000:00:1c.7: PCI bridge to [bus 05] [ 0.393292] pci 0000:00:1c.7: bridge window [io 0xc000-0xcfff] [ 0.393296] pci 0000:00:1c.7: bridge window [mem 0xf7a00000-0xf7afffff] [ 0.393299] pci 0000:00:1c.7: bridge window [mem 0xf6e00000-0xf6efffff 64bit pref] [ 0.393303] pci 0000:00:1e.0: PCI bridge to [bus 0f] [ 0.393733] pci 0000:00:1e.0: setting latency timer to 64 [ 0.393736] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.393737] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.393739] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.393740] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff] [ 0.393741] pci_bus 0000:00: resource 8 [mem 0xee000000-0xf7ffffff] [ 0.393743] pci_bus 0000:00: resource 9 [mem 0xfc000000-0xfed8ffff] [ 0.393744] pci_bus 0000:01: resource 0 [io 0xb000-0xbfff] [ 0.393745] pci_bus 0000:01: resource 1 [mem 0xf7100000-0xf79fffff] [ 0.393747] pci_bus 0000:02: resource 0 [io 0xb000-0xbfff] [ 0.393748] pci_bus 0000:02: resource 1 [mem 0xf7100000-0xf79fffff] [ 0.393750] pci_bus 0000:03: resource 0 [io 0xb000-0xbfff] [ 0.393751] pci_bus 0000:03: resource 1 [mem 0xf7100000-0xf72fffff] [ 0.393752] pci_bus 0000:04: resource 1 [mem 0xf7300000-0xf79fffff] [ 0.393754] pci_bus 0000:09: resource 0 [io 0xe000-0xefff] [ 0.393755] pci_bus 0000:09: resource 1 [mem 0xf7d00000-0xf7ffffff] [ 0.393756] pci_bus 0000:0a: resource 0 [io 0xe000-0xefff] [ 0.393758] pci_bus 0000:0a: resource 1 [mem 0xf7e00000-0xf7ffffff] [ 0.393759] pci_bus 0000:0b: resource 1 [mem 0xf7e00000-0xf7efffff] [ 0.393760] pci_bus 0000:0c: resource 0 [io 0xe000-0xefff] [ 0.393762] pci_bus 0000:0c: resource 1 [mem 0xf7f00000-0xf7ffffff] [ 0.393763] pci_bus 0000:08: resource 0 [io 0x1000-0x1fff] [ 0.393764] pci_bus 0000:08: resource 1 [mem 0xee000000-0xee1fffff] [ 0.393766] pci_bus 0000:08: resource 2 [mem 0xee200000-0xee3fffff 64bit pref] [ 0.393767] pci_bus 0000:07: resource 0 [io 0x2000-0x2fff] [ 0.393769] pci_bus 0000:07: resource 1 [mem 0xf7c00000-0xf7cfffff] [ 0.393770] pci_bus 0000:07: resource 2 [mem 0xee400000-0xee5fffff 64bit pref] [ 0.393771] pci_bus 0000:06: resource 0 [io 0xd000-0xdfff] [ 0.393773] pci_bus 0000:06: resource 1 [mem 0xf7b00000-0xf7bfffff] [ 0.393774] pci_bus 0000:06: resource 2 [mem 0xf6f00000-0xf6ffffff 64bit pref] [ 0.393775] pci_bus 0000:05: resource 0 [io 0xc000-0xcfff] [ 0.393777] pci_bus 0000:05: resource 1 [mem 0xf7a00000-0xf7afffff] [ 0.393778] pci_bus 0000:05: resource 2 [mem 0xf6e00000-0xf6efffff 64bit pref] [ 0.393779] pci_bus 0000:0f: resource 4 [io 0x0000-0x0cf7] [ 0.393781] pci_bus 0000:0f: resource 5 [io 0x0d00-0xffff] [ 0.393782] pci_bus 0000:0f: resource 6 [mem 0x000a0000-0x000bffff] [ 0.393783] pci_bus 0000:0f: resource 7 [mem 0x000d0000-0x000dffff] [ 0.393785] pci_bus 0000:0f: resource 8 [mem 0xee000000-0xf7ffffff] [ 0.393786] pci_bus 0000:0f: resource 9 [mem 0xfc000000-0xfed8ffff] [ 0.393787] pci_bus 0000:3f: resource 4 [io 0x0000-0xffff] [ 0.393789] pci_bus 0000:3f: resource 5 [mem 0x00000000-0xfffffffff] [ 0.393857] NET: Registered protocol family 2 [ 0.394061] TCP established hash table entries: 131072 (order: 9, 2097152 bytes) [ 0.394586] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) [ 0.394841] TCP: Hash tables configured (established 131072 bind 65536) [ 0.394858] TCP: reno registered [ 0.394861] UDP hash table entries: 8192 (order: 6, 262144 bytes) [ 0.394954] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes) [ 0.395112] NET: Registered protocol family 1 [ 0.395220] RPC: Registered named UNIX socket transport module. [ 0.395222] RPC: Registered udp transport module. [ 0.395222] RPC: Registered tcp transport module. [ 0.395223] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.395585] PCI: CLS 32 bytes, default 64 [ 0.395613] Trying to unpack rootfs image as initramfs... [ 0.705597] Freeing initrd memory: 25880k freed [ 0.708764] rvmilh: module verification failed: signature and/or required key missing - tainting kernel [ 0.722704] DMAR: No ATSR found [ 0.722731] IOMMU 0 0xfed90000: using Queued invalidation [ 0.722732] IOMMU passthrough mode = 1 [ 0.722745] IOMMU: hardware identity mapping for device 0000:00:00.0 [ 0.722746] IOMMU: hardware identity mapping for device 0000:00:03.0 [ 0.722747] IOMMU: hardware identity mapping for device 0000:00:08.0 [ 0.722749] IOMMU: hardware identity mapping for device 0000:00:08.1 [ 0.722750] IOMMU: hardware identity mapping for device 0000:00:08.2 [ 0.722751] IOMMU: hardware identity mapping for device 0000:00:08.3 [ 0.722752] IOMMU: hardware identity mapping for device 0000:00:10.0 [ 0.722754] IOMMU: hardware identity mapping for device 0000:00:10.1 [ 0.722755] IOMMU: hardware identity mapping for device 0000:00:16.0 [ 0.722756] IOMMU: hardware identity mapping for device 0000:00:1a.0 [ 0.722757] IOMMU: hardware identity mapping for device 0000:00:1b.0 [ 0.722759] IOMMU: hardware identity mapping for device 0000:00:1c.0 [ 0.722760] IOMMU: hardware identity mapping for device 0000:00:1c.4 [ 0.722761] IOMMU: hardware identity mapping for device 0000:00:1c.5 [ 0.722762] IOMMU: hardware identity mapping for device 0000:00:1c.6 [ 0.722764] IOMMU: hardware identity mapping for device 0000:00:1c.7 [ 0.722765] IOMMU: hardware identity mapping for device 0000:00:1d.0 [ 0.722766] IOMMU: hardware identity mapping for device 0000:00:1f.0 [ 0.722768] IOMMU: hardware identity mapping for device 0000:00:1f.2 [ 0.722769] IOMMU: hardware identity mapping for device 0000:00:1f.3 [ 0.722770] IOMMU: hardware identity mapping for device 0000:01:00.0 [ 0.722772] IOMMU: hardware identity mapping for device 0000:02:00.0 [ 0.722773] IOMMU: hardware identity mapping for device 0000:02:02.0 [ 0.722774] IOMMU: hardware identity mapping for device 0000:03:00.0 [ 0.722776] IOMMU: hardware identity mapping for device 0000:04:00.0 [ 0.722777] IOMMU: hardware identity mapping for device 0000:04:00.1 [ 0.722779] IOMMU: hardware identity mapping for device 0000:09:00.0 [ 0.722780] IOMMU: hardware identity mapping for device 0000:0a:01.0 [ 0.722781] IOMMU: hardware identity mapping for device 0000:0a:05.0 [ 0.722782] IOMMU: hardware identity mapping for device 0000:0a:07.0 [ 0.722784] IOMMU: hardware identity mapping for device 0000:0a:09.0 [ 0.722785] IOMMU: hardware identity mapping for device 0000:0b:00.0 [ 0.722787] IOMMU: hardware identity mapping for device 0000:0c:00.0 [ 0.722788] IOMMU: hardware identity mapping for device 0000:07:00.0 [ 0.722790] IOMMU: hardware identity mapping for device 0000:06:00.0 [ 0.722792] IOMMU: hardware identity mapping for device 0000:05:00.0 [ 0.722793] IOMMU: hardware identity mapping for device 0000:3f:00.0 [ 0.722794] IOMMU: hardware identity mapping for device 0000:3f:00.1 [ 0.722796] IOMMU: hardware identity mapping for device 0000:3f:02.0 [ 0.722797] IOMMU: hardware identity mapping for device 0000:3f:02.1 [ 0.722798] IOMMU: hardware identity mapping for device 0000:3f:03.0 [ 0.722799] IOMMU: hardware identity mapping for device 0000:3f:03.1 [ 0.722801] IOMMU: hardware identity mapping for device 0000:3f:03.4 [ 0.722802] IOMMU: hardware identity mapping for device 0000:3f:04.0 [ 0.722803] IOMMU: hardware identity mapping for device 0000:3f:04.1 [ 0.722804] IOMMU: hardware identity mapping for device 0000:3f:04.2 [ 0.722805] IOMMU: hardware identity mapping for device 0000:3f:04.3 [ 0.722807] IOMMU: hardware identity mapping for device 0000:3f:05.0 [ 0.722808] IOMMU: hardware identity mapping for device 0000:3f:05.1 [ 0.722809] IOMMU: hardware identity mapping for device 0000:3f:05.2 [ 0.722810] IOMMU: hardware identity mapping for device 0000:3f:05.3 [ 0.722811] IOMMU: Setting RMRR: [ 0.722812] Ignoring identity map for HW passthrough device 0000:00:1a.0 [0xedeec000 - 0xedefffff] [ 0.722813] Ignoring identity map for HW passthrough device 0000:00:1d.0 [0xedeec000 - 0xedefffff] [ 0.722814] Ignoring identity map for HW passthrough device 0000:00:1a.0 [0xe4000 - 0xe7fff] [ 0.722815] Ignoring identity map for HW passthrough device 0000:00:1d.0 [0xe4000 - 0xe7fff] [ 0.722817] IOMMU: Prepare 0-16MiB unity mapping for LPC [ 0.722818] Ignoring identity map for HW passthrough device 0000:00:1f.0 [0x0 - 0xffffff] [ 0.722842] PCI-DMA: Intel(R) Virtualization Technology for Directed I/O [ 0.732184] Initialise module verification [ 0.732238] audit: initializing netlink socket (disabled) [ 0.732250] type=2000 audit(1596973014.615:1): initialized [ 0.734644] bounce pool size: 64 pages [ 0.734842] VFS: Disk quotas dquot_6.5.2 [ 0.734872] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.735113] NFS: Registering the id_resolver key type [ 0.735121] Key type id_resolver registered [ 0.735123] Key type id_legacy registered [ 0.735136] msgmni has been set to 32174 [ 0.735651] async_tx: api initialized (async) [ 0.735654] Key type asymmetric registered [ 0.735656] Asymmetric key parser 'x509' registered [ 0.735741] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251) [ 0.735744] io scheduler noop registered [ 0.735745] io scheduler deadline registered [ 0.735758] io scheduler cfq registered (default) [ 0.736192] pcieport 0000:09:00.0: irq 47 for MSI/MSI-X [ 0.736347] pcieport 0000:0a:01.0: irq 48 for MSI/MSI-X [ 0.736536] pcieport 0000:0a:05.0: irq 49 for MSI/MSI-X [ 0.736778] pcieport 0000:0a:07.0: irq 50 for MSI/MSI-X [ 0.736922] pcieport 0000:0a:09.0: irq 51 for MSI/MSI-X [ 0.937222] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.958244] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.958382] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 8250 [ 0.980293] brd: module loaded [ 0.983633] ACPI Warning: 0x0000000000000828-0x000000000000082F SystemIO conflicts with Region \PMRG 1 (20130328/utaddress-249) [ 0.983640] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 0.983643] Unknown LPC device 3b16 [ 0.983645] ACPI Warning: 0x0000000000000530-0x000000000000053F SystemIO conflicts with Region \GPS1 1 (20130328/utaddress-249) [ 0.983648] ACPI Warning: 0x0000000000000530-0x000000000000053F SystemIO conflicts with Region \GPS0 2 (20130328/utaddress-249) [ 0.983652] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 0.983653] ACPI Warning: 0x0000000000000500-0x000000000000052F SystemIO conflicts with Region \GPS1 1 (20130328/utaddress-249) [ 0.983656] ACPI Warning: 0x0000000000000500-0x000000000000052F SystemIO conflicts with Region \GPS0 2 (20130328/utaddress-249) [ 0.983659] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 0.983741] lpc_ich: Resource conflict(s) found affecting gpio_ich [ 0.984419] Loading iSCSI transport class v2.0-870. [ 0.990118] rdac: device handler registered [ 0.992428] ahci 0000:00:1f.2: version 3.0 [ 0.992572] ahci 0000:00:1f.2: irq 52 for MSI/MSI-X [ 0.992620] ahci: SSS flag set, parallel bus scan disabled [ 1.003407] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x3f impl SATA mode [ 1.003415] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ems sxs apst [ 1.003423] ahci 0000:00:1f.2: setting latency timer to 64 [ 1.018733] scsi0 : ahci [ 1.019015] scsi1 : ahci [ 1.020721] scsi2 : ahci [ 1.021306] scsi3 : ahci [ 1.021961] scsi4 : ahci [ 1.022736] scsi5 : ahci [ 1.023417] ata1: SATA max UDMA/133 abar m2048@0xf70f7000 port 0xf70f7100 irq 52 [ 1.023421] ata2: SATA max UDMA/133 abar m2048@0xf70f7000 port 0xf70f7180 irq 52 [ 1.023423] ata3: SATA max UDMA/133 abar m2048@0xf70f7000 port 0xf70f7200 irq 52 [ 1.023426] ata4: SATA max UDMA/133 abar m2048@0xf70f7000 port 0xf70f7280 irq 52 [ 1.023428] ata5: SATA max UDMA/133 abar m2048@0xf70f7000 port 0xf70f7300 irq 52 [ 1.023431] ata6: SATA max UDMA/133 abar m2048@0xf70f7000 port 0xf70f7380 irq 52 [ 1.023550] ahci 0000:0c:00.0: irq 53 for MSI/MSI-X [ 1.023569] ahci 0000:0c:00.0: controller can do FBS, turning on CAP_FBS [ 1.034469] ahci 0000:0c:00.0: AHCI 0001.0200 32 slots 8 ports 6 Gbps 0xff impl SATA mode [ 1.034472] ahci 0000:0c:00.0: flags: 64bit ncq fbs pio [ 1.042599] scsi6 : ahci [ 1.043168] scsi7 : ahci [ 1.044105] scsi8 : ahci [ 1.045277] scsi9 : ahci [ 1.046277] scsi10 : ahci [ 1.046527] scsi11 : ahci [ 1.047402] scsi12 : ahci [ 1.048032] scsi13 : ahci [ 1.048708] ata7: SATA max UDMA/133 abar m2048@0xf7fff000 port 0xf7fff100 irq 53 [ 1.048712] ata8: SATA max UDMA/133 abar m2048@0xf7fff000 port 0xf7fff180 irq 53 [ 1.048716] ata9: SATA max UDMA/133 abar m2048@0xf7fff000 port 0xf7fff200 irq 53 [ 1.048719] ata10: SATA max UDMA/133 abar m2048@0xf7fff000 port 0xf7fff280 irq 53 [ 1.048722] ata11: SATA max UDMA/133 abar m2048@0xf7fff000 port 0xf7fff300 irq 53 [ 1.048725] ata12: SATA max UDMA/133 abar m2048@0xf7fff000 port 0xf7fff380 irq 53 [ 1.048728] ata13: SATA max UDMA/133 abar m2048@0xf7fff000 port 0xf7fff400 irq 53 [ 1.048731] ata14: SATA max UDMA/133 abar m2048@0xf7fff000 port 0xf7fff480 irq 53 [ 1.052008] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 1.054743] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.054748] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.054832] rtc_cmos 00:02: RTC can wake from S4 [ 1.055449] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0 [ 1.055478] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs [ 1.055610] i2c /dev entries driver [ 1.056958] md: linear personality registered for level -1 [ 1.056961] md: raid0 personality registered for level 0 [ 1.056962] md: raid1 personality registered for level 1 [ 1.056964] md: raid10 personality registered for level 10 [ 1.057682] md: raid6 personality registered for level 6 [ 1.057684] md: raid5 personality registered for level 5 [ 1.057685] md: raid4 personality registered for level 4 [ 1.057687] md: raidF1 personality registered for level 45 [ 1.057802] device-mapper: ioctl: 4.25.0-ioctl (2013-06-26) initialised: dm-devel@redhat.com [ 1.057805] cpuidle: using governor ladder [ 1.057806] cpuidle: using governor menu [ 1.057897] TCP: cubic registered [ 1.057899] NET: Registered protocol family 17 [ 1.057921] Key type dns_resolver registered [ 1.328373] ata1: SATA link down (SStatus 0 SControl 300) [ 1.356398] ata9: SATA link down (SStatus 0 SControl 300) [ 1.356435] ata10: SATA link down (SStatus 0 SControl 300) [ 1.356470] ata13: SATA link down (SStatus 0 SControl 300) [ 1.356501] ata14: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 1.356530] ata12: SATA link down (SStatus 0 SControl 300) [ 1.356559] ata7: SATA link down (SStatus 0 SControl 300) [ 1.356609] ata11: SATA link down (SStatus 0 SControl 300) [ 1.356632] ata14.00: ATAPI: MARVELL VIRTUALL, 1.09, max UDMA/66 [ 1.356655] ata8: SATA link down (SStatus 0 SControl 300) [ 1.356833] ata14.00: configured for UDMA/66 [ 1.726364] tsc: Refined TSC clocksource calibration: 2942.464 MHz [ 1.726370] Switching to clocksource tsc [ 1.788359] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 1.788492] ata2.00: ATA-11: Patriot Burst, SBFM61.3, max UDMA/133 [ 1.788494] ata2.00: 937703088 sectors, multi 16: LBA48 NCQ (depth 31/32), AA [ 1.788495] ata2.00: SN:FEB4078B030805189192 [ 1.788619] ata2.00: configured for UDMA/133 [ 1.788632] ata2.00: Find SSD disks. [Patriot Burst] [ 1.788790] scsi 1:0:0:0: Direct-Access Patriot Burst SBFM PQ: 0 ANSI: 5 [ 1.789027] sd 1:0:0:0: [sdb] 937703088 512-byte logical blocks: (480 GB/447 GiB) [ 1.789080] sd 1:0:0:0: [sdb] Write Protect is off [ 1.789083] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 1.789102] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.789533] sdb: sdb1 sdb2 sdb3 [ 1.790907] sd 1:0:0:0: [sdb] Attached SCSI disk [ 2.093350] ata3: SATA link down (SStatus 0 SControl 300) [ 2.398343] ata4: SATA link down (SStatus 0 SControl 300) [ 2.703336] ata5: SATA link down (SStatus 0 SControl 300) [ 3.008329] ata6: SATA link down (SStatus 0 SControl 300) [ 3.008433] ata14.00: Find SSD disks. [MARVELL VIRTUALL] [ 3.010330] ata14.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 [ 3.016857] ata14.00: irq_stat 0x40000001 [ 3.020871] scsi 13:0:0:0: CDB: [ 3.020872] cdb[0]=0x12: 12 01 00 00 fc 00 [ 3.020878] ata14.00: cmd a0/00:00:00:fc:00/00:00:00:00:00/a0 tag 2 pio 252 in res 00/00:00:00:00:00/00:00:00:00:00/00 Emask 0x3 (HSM violation) [ 3.035986] ata14: hard resetting link [ 3.342334] ata14: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 3.342652] ata14.00: configured for UDMA/66 [ 3.342745] ata14: EH complete [ 3.344420] scsi 13:0:0:0: Processor Marvell 91xx Config 1.01 PQ: 0 ANSI: 5 [ 3.344744] Loading module verification blacklist certificates [ 3.344746] Loading module verification certificates [ 3.344769] MODSIGN: Loaded cert 'Synology SDG kernel module signing key: 7bd0b0d6bcd31651c22ce3978bdc8c8bdc417329' [ 3.345728] MODSIGN: Loaded cert 'Synology Root Certification Authority: f2c075361f168425f8b5ef31b796406c3aab2089' [ 3.345739] MODSIGN: Loaded cert 'Synology Kernel Module Signing Certification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28' [ 3.345747] MODSIGN: Loaded cert 'Synology kernel module signing key: 4646ce54489669338118a3b1286da156ac366fa5' [ 3.345753] registered taskstats version 1 [ 3.346266] rtc_cmos 00:02: setting system clock to 2020-08-09 11:36:57 UTC (1596973017) [ 3.346866] Freeing unused kernel memory: 792k freed [ 3.346972] Write protecting the kernel read-only data: 8192k [ 3.347079] Freeing unused kernel memory: 1228k freed [ 3.347953] Freeing unused kernel memory: 476k freed [ 3.403596] ACPI: bus type USB registered [ 3.403713] usbcore: registered new interface driver usbfs [ 3.403778] usbcore: registered new interface driver hub [ 3.403885] usbcore: registered new interface driver ethub [ 3.403981] usbcore: registered new device driver usb [ 3.414009] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.417175] ehci-pci: EHCI PCI platform driver [ 3.417279] ehci-pci 0000:00:1a.0: setting latency timer to 64 [ 3.417294] ehci-pci 0000:00:1a.0: EHCI Host Controller [ 3.417304] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1 [ 3.417315] ehci-pci 0000:00:1a.0: debug port 2 [ 3.417327] 32bit 0000:00:1a.0 uses non-identity mapping [ 3.421244] ehci-pci 0000:00:1a.0: cache line size of 32 is not supported [ 3.421258] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf70fe000 [ 3.426334] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00 [ 3.426552] hub 1-0:1.0: USB hub found [ 3.426556] hub 1-0:1.0: 2 ports detected [ 3.426668] ehci-pci 0000:00:1d.0: setting latency timer to 64 [ 3.426676] ehci-pci 0000:00:1d.0: EHCI Host Controller [ 3.426680] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 3.426690] ehci-pci 0000:00:1d.0: debug port 2 [ 3.426699] 32bit 0000:00:1d.0 uses non-identity mapping [ 3.430599] ehci-pci 0000:00:1d.0: cache line size of 32 is not supported [ 3.430616] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf70fd000 [ 3.436321] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00 [ 3.436556] hub 2-0:1.0: USB hub found [ 3.436559] hub 2-0:1.0: 2 ports detected [ 3.441000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.445005] uhci_hcd: USB Universal Host Controller Interface driver [ 3.449499] xhci_hcd 0000:0b:00.0: xHCI Host Controller [ 3.449505] xhci_hcd 0000:0b:00.0: new USB bus registered, assigned bus number 3 [ 3.649576] 32bit 0000:0b:00.0 uses non-identity mapping [ 3.649665] xhci_hcd 0000:0b:00.0: irq 54 for MSI/MSI-X [ 3.649670] xhci_hcd 0000:0b:00.0: irq 55 for MSI/MSI-X [ 3.649674] xhci_hcd 0000:0b:00.0: irq 56 for MSI/MSI-X [ 3.649679] xhci_hcd 0000:0b:00.0: irq 57 for MSI/MSI-X [ 3.649683] xhci_hcd 0000:0b:00.0: irq 58 for MSI/MSI-X [ 3.649687] xhci_hcd 0000:0b:00.0: irq 59 for MSI/MSI-X [ 3.649691] xhci_hcd 0000:0b:00.0: irq 60 for MSI/MSI-X [ 3.649695] xhci_hcd 0000:0b:00.0: irq 61 for MSI/MSI-X [ 3.649905] xHCI xhci_add_endpoint called for root hub [ 3.649906] xHCI xhci_check_bandwidth called for root hub [ 3.649971] hub 3-0:1.0: USB hub found [ 3.649978] hub 3-0:1.0: 2 ports detected [ 3.650020] xhci_hcd 0000:0b:00.0: xHCI Host Controller [ 3.650023] xhci_hcd 0000:0b:00.0: new USB bus registered, assigned bus number 4 [ 3.650149] xHCI xhci_add_endpoint called for root hub [ 3.650150] xHCI xhci_check_bandwidth called for root hub [ 3.650224] hub 4-0:1.0: USB hub found [ 3.650236] hub 4-0:1.0: 2 ports detected [ 3.676380] usbcore: registered new interface driver usb-storage [ 3.688833] VMware PVSCSI driver - version 1.0.2.0-k [ 3.692237] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006) [ 3.695691] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006) [ 3.706181] Fusion MPT base driver 3.04.20 [ 3.706183] Copyright (c) 1999-2008 LSI Corporation [ 3.712740] Fusion MPT SPI Host driver 3.04.20 [ 3.716145] Fusion MPT SAS Host driver 3.04.20 [ 3.719545] Fusion MPT misc device (ioctl) driver 3.04.20 [ 3.719633] mptctl: Registered with Fusion MPT base driver [ 3.719635] mptctl: /dev/mptctl @ (major,minor=10,220) [ 3.723119] megasas: 06.506.00.00-rc1 Sat. Feb. 9 17:00:00 PDT 2013 [ 3.729413] mpt2sas version 20.00.00.00 loaded [ 3.736507] mpt3sas version 22.00.02.00 loaded [ 3.744915] broadwell_synobios: module license 'Synology Inc.' taints kernel. [ 3.744917] Disabling lock debugging due to kernel taint [ 3.745257] 2020-8-9 11:36:58 UTC [ 3.745260] synobios: load, major number 201 [ 3.745262] Brand: Synology [ 3.745264] Model: DS-3617xs [ 3.745267] set group disks wakeup number to 4, spinup time deno 7 [ 3.745270] synobios cpu_arch proc entry initialized [ 3.745271] synobios crypto_hw proc entry initialized [ 3.745273] synobios syno_platform proc entry initialized [ 3.745280] synobios open /dev/ttyS1 success [ 3.748816] synobios: unload [ 3.749315] usb 1-1: new high-speed USB device number 2 using ehci-pci [ 3.755400] md: Autodetecting RAID arrays. [ 3.755864] md: invalid raid superblock magic on sdb3 [ 3.761078] md: sdb3 does not have a valid v0.90 superblock, not importing! [ 3.761083] md: Scanned 3 and added 2 devices. [ 3.761084] md: autorun ... [ 3.761085] md: considering sdb1 ... [ 3.761087] md: adding sdb1 ... [ 3.761089] md: sdb2 has different UUID to sdb1 [ 3.761092] md: created md0 [ 3.761093] md: bind<sdb1> [ 3.761101] md: running: <sdb1> [ 3.761232] md/raid1:md0: active with 1 out of 12 mirrors [ 3.761734] md0: detected capacity change from 0 to 2549940224 [ 3.761826] md: considering sdb2 ... [ 3.761829] md: adding sdb2 ... [ 3.761994] md: created md1 [ 3.761996] md: bind<sdb2> [ 3.762002] md: running: <sdb2> [ 3.762129] md/raid1:md1: active with 1 out of 12 mirrors [ 3.763659] md1: detected capacity change from 0 to 2147418112 [ 3.763719] md: ... autorun DONE. [ 3.771816] md0: unknown partition table [ 3.884682] Got empty serial number. Generate serial number from product. [ 3.884995] hub 1-1:1.0: USB hub found [ 3.885053] hub 1-1:1.0: 6 ports detected [ 4.008309] usb 2-1: new high-speed USB device number 2 using ehci-pci [ 4.018414] EXT4-fs (md0): barriers disabled [ 4.018768] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: [ 4.143684] Got empty serial number. Generate serial number from product. [ 4.143696] drivers/usb/core/hub.c (2696) Same device found. Change serial to ffffffd1ffffffb2ffffffdbffffffa0 [ 4.143990] hub 2-1:1.0: USB hub found [ 4.144055] hub 2-1:1.0: 8 ports detected [ 4.429439] usb 2-1.8: new high-speed USB device number 3 using ehci-pci [ 4.527499] usb-storage 2-1.8:1.0: USB Mass Storage device detected [ 4.527544] scsi14 : usb-storage 2-1.8:1.0 [ 5.533088] scsi 14:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 4 [ 5.534088] sd 14:0:0:0: [synoboot] 7579008 512-byte logical blocks: (3.88 GB/3.61 GiB) [ 5.534710] sd 14:0:0:0: [synoboot] Write Protect is off [ 5.534714] sd 14:0:0:0: [synoboot] Mode Sense: 23 00 00 00 [ 5.535331] sd 14:0:0:0: [synoboot] No Caching mode page found [ 5.541163] sd 14:0:0:0: [synoboot] Assuming drive cache: write through [ 5.550954] sd 14:0:0:0: [synoboot] No Caching mode page found [ 5.556789] sd 14:0:0:0: [synoboot] Assuming drive cache: write through [ 5.569977] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 5.569981] GPT:102399 != 7579007 [ 5.569983] GPT:Alternate GPT header not at the end of the disk. [ 5.569985] GPT:102399 != 7579007 [ 5.569987] GPT: Use GNU Parted to correct GPT errors. [ 5.570004] synoboot: synoboot1 synoboot2 synoboot3 [ 5.572581] sd 14:0:0:0: [synoboot] No Caching mode page found [ 5.578417] sd 14:0:0:0: [synoboot] Assuming drive cache: write through [ 5.585035] sd 14:0:0:0: [synoboot] Attached SCSI removable disk [ 6.089104] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1 [ 6.493544] EXT4-fs (md0): re-mounted. Opts: (null) [ 7.847654] sd 1:0:0:0: Attached scsi generic sg0 type 0 [ 7.847698] scsi 13:0:0:0: Attached scsi generic sg1 type 3 [ 7.847740] sd 14:0:0:0: Attached scsi generic sg2 type 0 [ 7.933205] md1: unknown partition table [ 7.952016] Adding 2097084k swap on /dev/md1. Priority:-1 extents:1 across:2097084k [ 8.032299] zram: module is from the staging directory, the quality is unknown, you have been warned. [ 8.032844] zram: Created 4 device(s) ... [ 8.041523] Adding 2470908k swap on /dev/zram0. Priority:1 extents:1 across:2470908k SS [ 8.049114] Adding 2470908k swap on /dev/zram1. Priority:1 extents:1 across:2470908k SS [ 8.056684] Adding 2470908k swap on /dev/zram2. Priority:1 extents:1 across:2470908k SS [ 8.064210] Adding 2470908k swap on /dev/zram3. Priority:1 extents:1 across:2470908k SS [ 8.403776] NET: Registered protocol family 10 [ 8.412425] sit: IPv6 over IPv4 tunneling driver [ 8.465335] init: syno-auth-check main process (5569) killed by TERM signal [ 8.529322] ACPI: Requesting acpi_cpufreq [ 8.529601] Monitor-Mwait will be used to enter C-1 state [ 8.529607] Monitor-Mwait will be used to enter C-2 state [ 8.529619] ACPI: acpi_idle registered with cpuidle [ 8.910045] fuse init (API version 7.22) [ 8.924554] dca service started, version 1.12.1 [ 8.929955] e1000e: Intel(R) PRO/1000 Network Driver - 3.3.4-NAPI [ 8.929959] e1000e: Copyright(c) 1999 - 2016 Intel Corporation. [ 8.939517] Intel(R) Gigabit Ethernet Network Driver - version 5.3.5.3 [ 8.939521] Copyright (c) 2007-2015 Intel Corporation. [ 9.159271] be2net 0000:04:00.0: irq 62 for MSI/MSI-X [ 9.159286] be2net 0000:04:00.0: irq 63 for MSI/MSI-X [ 9.159298] be2net 0000:04:00.0: irq 64 for MSI/MSI-X [ 9.159309] be2net 0000:04:00.0: irq 65 for MSI/MSI-X [ 9.159336] be2net 0000:04:00.0: enabled 4 MSI-x vector(s) [ 9.221233] be2net 0000:04:00.0: created 4 RSS queue(s) and 1 default RX queue [ 9.278869] be2net 0000:04:00.0: created 1 TX queue(s) [ 9.288483] be2net 0000:04:00.0: device doesn't support SRIOV [ 9.290271] be2net 0000:04:00.0: Emulex OneConnect: PF port 0 [ 9.431277] be2net 0000:04:00.1: irq 66 for MSI/MSI-X [ 9.431293] be2net 0000:04:00.1: irq 67 for MSI/MSI-X [ 9.431305] be2net 0000:04:00.1: irq 68 for MSI/MSI-X [ 9.431316] be2net 0000:04:00.1: irq 69 for MSI/MSI-X [ 9.431348] be2net 0000:04:00.1: enabled 4 MSI-x vector(s) [ 9.481223] be2net 0000:04:00.1: created 4 RSS queue(s) and 1 default RX queue [ 9.539261] be2net 0000:04:00.1: created 1 TX queue(s) [ 9.548876] be2net 0000:04:00.1: device doesn't support SRIOV [ 9.550419] be2net 0000:04:00.1: Emulex OneConnect: PF port 1 [ 9.556191] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.1.3 [ 9.556194] Copyright(c) 1999 - 2017 Intel Corporation. [ 9.562220] i40e: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver - version 2.4.10 [ 9.562223] i40e: Copyright(c) 2013 - 2018 Intel Corporation. [ 9.572017] tn40xx: Tehuti Network Driver, 0.3.6.17.2 [ 9.577087] tn40xx: Supported phys : MV88X3120 MV88X3310 MV88E2010 QT2025 TLK10232 AQR105 MUSTANG [ 9.589830] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded [ 9.589939] r8168 0000:06:00.0: irq 70 for MSI/MSI-X [ 9.591351] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625. [ 9.591361] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com> This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>. This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>. [ 9.591374] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded [ 9.591464] r8168 0000:05:00.0: irq 71 for MSI/MSI-X [ 9.592663] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625. [ 9.592666] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com> This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>. This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>. [ 9.612580] qed_init called [ 9.612583] QLogic FastLinQ 4xxxx Core Module qed 8.33.9.0 [ 9.612584] creating debugfs root node [ 9.618664] qede_init: QLogic FastLinQ 4xxxx Ethernet Driver qede 8.33.9.0 [ 9.624013] Loading modules backported from Linux version v3.18.1-0-g39ca484 [ 9.624015] Backport generated by backports.git v3.18.1-1-0-g5e9ec4c [ 9.652451] Compat-mlnx-ofed backport release: c22af88 [ 9.652453] Backport based on mlnx_ofed/mlnx-ofa_kernel-4.0.git c22af88 [ 9.652454] compat.git: mlnx_ofed/mlnx-ofa_kernel-4.0.git [ 9.984451] bnx2x: QLogic 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.713.00 ($DateTime: 2015/07/28 00:13:30 $) [ 10.030327] bio: create slab <bio-1> at 1 [ 10.030467] Btrfs loaded [ 10.035236] exFAT: Version 1.2.9 [ 10.061077] jme: JMicron JMC2XX ethernet driver version 1.0.8 [ 10.066408] sky2: driver version 1.30 [ 10.071759] pch_gbe: EG20T PCH Gigabit Ethernet Driver - version 1.01 [ 10.077377] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.2.42 [ 10.082875] QLogic/NetXen Network Driver v4.0.80 [ 10.085773] Solarflare NET driver v3.2 [ 10.088605] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 10.088607] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 10.091632] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de [ 10.094601] VMware vmxnet3 virtual NIC driver - version 1.1.30.0-k-NAPI [ 10.103853] cnic: Broadcom NetXtreme II CNIC Driver cnic v2.5.16 (Dec 05, 2012) [ 10.134165] usbcore: registered new interface driver ax88179_178a [ 10.138036] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0 [ 10.138044] ACPI: Power Button [PWRB] [ 10.138222] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1 [ 10.138228] ACPI: Power Button [PWRF] [ 10.181481] 2020-8-9 11:37:4 UTC [ 10.181485] synobios: load, major number 201 [ 10.181487] Brand: Synology [ 10.181489] Model: DS-3617xs [ 10.181490] set group disks wakeup number to 4, spinup time deno 7 [ 10.181493] synobios cpu_arch proc entry initialized [ 10.181494] synobios crypto_hw proc entry initialized [ 10.181496] synobios syno_platform proc entry initialized [ 10.181502] synobios open /dev/ttyS1 success [ 10.404180] systemd-udevd[6844]: starting version 204 [ 12.182474] init: dhcp-client (eth0) main process (8914) killed by TERM signal [ 13.167659] eth2: 0xffffc90007476000, 00:11:32:a1:23:6b, IRQ 71 [ 13.238960] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready [ 13.250292] init: dhcp-client (eth1) main process (9354) killed by TERM signal [ 14.264450] eth3: 0xffffc90007474000, 00:11:32:a1:23:6c, IRQ 70 [ 14.335820] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready [ 15.501491] md: md2 stopped. [ 15.502132] md: bind<sdb3> [ 15.502819] md/raid1:md2: active with 1 out of 1 mirrors [ 15.504436] md2: detected capacity change from 0 to 475166212096 [ 15.504597] md2: unknown partition table [ 15.805501] BTRFS: device label 2020.06.30-18:59:28 v25426 devid 1 transid 988 /dev/md2 [ 15.806130] BTRFS info (device md2): enabling auto syno reclaim space [ 15.806134] BTRFS info (device md2): use ssd allocation scheme [ 15.806136] BTRFS info (device md2): using free space tree [ 15.806136] BTRFS: has skinny extents [ 16.237319] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_init RODSP server started, login_key(001132a12369). [ 16.244096] iSCSI:extent_pool.c:766:ep_init syno_extent_pool successfully initialized [ 16.251755] usbcore: registered new interface driver usblp [ 16.259287] iSCSI:target_core_device.c:617:se_dev_align_max_sectors Rounding down aligned max_sectors from 4294967295 to 4294967288 [ 16.259418] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully [ 16.263952] usbcore: registered new interface driver usbhid [ 16.263954] usbhid: USB HID core driver [ 16.278334] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plugin for fileio is enabled. [ 16.278339] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled. [ 16.278351] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled. [ 16.278359] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled. [ 16.278361] iSCSI:target_core_ep.c:793:ep_attach_hba ODX Token Manager is enabled. [ 16.574197] FAT-fs (synoboot2): fat_set_state: set=1 process=synopkicompatsy pid=11591 [ 16.578186] FAT-fs (synoboot2): fat_set_state: set=0 process=synopkicompatsy pid=11591 [ 16.640977] FAT-fs (synoboot2): fat_set_state: set=1 process=synopkicompatsy pid=11591 [ 16.686563] FAT-fs (synoboot2): fat_set_state: set=0 process=synopkicompatsy pid=11591 [ 16.886355] warning: `nginx' uses 32-bit capabilities (legacy support in use) [ 17.342506] r8168: eth3: link up [ 17.342522] IPv6: ADDRCONF(NETDEV_CHANGE): eth3: link becomes ready [ 17.453432] loop: module loaded [ 18.413312] init: dhcp-client (eth3) main process (10528) killed by TERM signal [ 18.679473] ata2.00: configured for UDMA/133 [ 18.679478] ata2: EH complete [ 19.547315] init: scsi_plugin_server main process (11279) killed by TERM signal [ 20.293175] init: iscsi_pluginserverd main process (13330) killed by TERM signal [ 20.293893] init: iscsi_pluginengined main process (13329) killed by TERM signal [ 20.301730] init: scsi_plugin_server main process (13335) killed by TERM signal [ 24.729666] init: scsi_plugin_server main process (13610) killed by TERM signal [ 47.966690] init: scsi_plugin_server main process (15113) killed by TERM signal [ 48.032786] init: nmbd main process (16213) killed by TERM signal Quote Link to comment Share on other sites More sharing options...
-iliya- Posted August 9, 2020 Share #444 Posted August 9, 2020 32 минуты назад, IG-88 сказал: board only has 6+2 sata ports yes, blue port sata 1-6 but 2x white sata ports is a - ata14.00: ATAPI: MARVELL VIRTUALL, 1.09, max UDMA/66 maybe in this a problem? Quote Link to comment Share on other sites More sharing options...
IG-88 Posted August 9, 2020 Author Share #445 Posted August 9, 2020 (edited) 17 minutes ago, -iliya- said: maybe in this a problem? no, more like what make it to be placed that way [ 1.003407] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x3f impl SATA mode ok the 6 onboard sata [ 1.034469] ahci 0000:0c:00.0: AHCI 0001.0200 32 slots 8 ports 6 Gbps 0xff impl SATA mode 8 ports? where does that come from, thats the device giving the headaches edit: [ 0.371797] pci 0000:0c:00.0: [1b4b:9123] type 00 class 0x010601 thats the onboard marvell, it takes 8 ports and then places 2 "virtual" ports in addition i'd say try to disable in bios and see what happens Edited August 9, 2020 by IG-88 Quote Link to comment Share on other sites More sharing options...
-iliya- Posted August 9, 2020 Share #446 Posted August 9, 2020 4 минуты назад, IG-88 сказал: 8 ports? where does that come from, thats the device giving the headaches i try to disable in bios marvel controller and set as not installed for ports 3-6 temporary remove adaptec and try boot. Скрытый текст [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.105 (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP Wed Jul 8 03:19:42 CST 2020 [ 0.000000] Command line: syno_hdd_powerup_seq=0 HddHotplug=0 syno_hw_version=DS3617xs vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_port_thaw=1 root=/dev/md0 sn=1960ODN006200 mac1=001132A12369 mac2=001132A1236A mac3=001132A1236B mac4=001132A1236C netif_num=4 vid=0x13fe pid=0x4100 [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] e820: BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: [mem 0x0000000000000100-0x000000000009dfff] usable [ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000dde6ffff] usable [ 0.000000] BIOS-e820: [mem 0x00000000dde70000-0x00000000dde87fff] ACPI data [ 0.000000] BIOS-e820: [mem 0x00000000dde88000-0x00000000ddedbfff] ACPI NVS [ 0.000000] BIOS-e820: [mem 0x00000000ddedc000-0x00000000ddffffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041fffffff] usable [ 0.000000] NX (Execute Disable) protection: active [ 0.000000] SMBIOS 2.6 present. [ 0.000000] DMI: System manufacturer System Product Name/P7F7-E WS SUPERCOMPUTER, BIOS 0802 06/01/2011 [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable [ 0.000000] e820: last_pfn = 0x420000 max_arch_pfn = 0x400000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-D3FFF write-protect [ 0.000000] D4000-DFFFF uncachable [ 0.000000] E0000-E7FFF write-through [ 0.000000] E8000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask C00000000 write-back [ 0.000000] 1 base 400000000 mask FE0000000 write-back [ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable [ 0.000000] 3 base 0DE000000 mask FFE000000 uncachable [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] e820: update [mem 0xde000000-0xffffffff] usable ==> reserved [ 0.000000] e820: last_pfn = 0xdde70 max_arch_pfn = 0x400000000 [ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [ffff8800000ff780] [ 0.000000] Base memory trampoline at [ffff880000098000] 98000 size 24576 [ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff] [ 0.000000] [mem 0x00000000-0x000fffff] page 4k [ 0.000000] BRK [0x01ac4000, 0x01ac4fff] PGTABLE [ 0.000000] BRK [0x01ac5000, 0x01ac5fff] PGTABLE [ 0.000000] BRK [0x01ac6000, 0x01ac6fff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x41fe00000-0x41fffffff] [ 0.000000] [mem 0x41fe00000-0x41fffffff] page 2M [ 0.000000] BRK [0x01ac7000, 0x01ac7fff] PGTABLE [ 0.000000] init_memory_mapping: [mem 0x41c000000-0x41fdfffff] [ 0.000000] [mem 0x41c000000-0x41fdfffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x400000000-0x41bffffff] [ 0.000000] [mem 0x400000000-0x41bffffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x00100000-0xdde6ffff] [ 0.000000] [mem 0x00100000-0x001fffff] page 4k [ 0.000000] [mem 0x00200000-0xdddfffff] page 2M [ 0.000000] [mem 0xdde00000-0xdde6ffff] page 4k [ 0.000000] init_memory_mapping: [mem 0x100000000-0x3ffffffff] [ 0.000000] [mem 0x100000000-0x3ffffffff] page 2M [ 0.000000] BRK [0x01ac8000, 0x01ac8fff] PGTABLE [ 0.000000] BRK [0x01ac9000, 0x01ac9fff] PGTABLE [ 0.000000] RAMDISK: [mem 0x36412000-0x37ffffff] [ 0.000000] ACPI: RSDP 0x00000000000FB7F0 00024 (v02 ACPIAM) [ 0.000000] ACPI: XSDT 0x00000000DDE70100 0006C (v01 060111 XSDT1425 20110601 MSFT 00000097) [ 0.000000] ACPI: FACP 0x00000000DDE70290 000F4 (v03 060111 FACP1425 20110601 MSFT 00000097) [ 0.000000] ACPI: DSDT 0x00000000DDE704A0 0FB3A (v01 W0063 W0063001 00000001 INTL 20060113) [ 0.000000] ACPI: FACS 0x00000000DDE88000 00040 [ 0.000000] ACPI: APIC 0x00000000DDE70390 000CC (v01 060111 APIC1425 20110601 MSFT 00000097) [ 0.000000] ACPI: MCFG 0x00000000DDE70460 0003C (v01 060111 OEMMCFG 20110601 MSFT 00000097) [ 0.000000] ACPI: OEMB 0x00000000DDE88040 00072 (v01 060111 OEMB1425 20110601 MSFT 00000097) [ 0.000000] ACPI: HPET 0x00000000DDE7FFE0 00038 (v01 060111 OEMHPET 20110601 MSFT 00000097) [ 0.000000] ACPI: DMAR 0x00000000DDE880C0 00090 (v01 AMI OEMDMAR 00000001 MSFT 00000097) [ 0.000000] ACPI: ASPT 0x00000000DDE80280 00034 (v06 060111 PerfTune 20110601 MSFT 00000097) [ 0.000000] ACPI: OSFR 0x00000000DDE802C0 000B0 (v01 060111 OEMOSFR 20110601 MSFT 00000097) [ 0.000000] ACPI: SSDT 0x00000000DDE8AE10 00363 (v01 DpgPmm CpuPm 00000012 INTL 20060113) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] [ffffea0000000000-ffffea000e7fffff] PMD -> [ffff88040f600000-ffff88041d7fffff] on node 0 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x00001000-0x00ffffff] [ 0.000000] DMA32 [mem 0x01000000-0xffffffff] [ 0.000000] Normal [mem 0x100000000-0x41fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x00001000-0x0009dfff] [ 0.000000] node 0: [mem 0x00100000-0xdde6ffff] [ 0.000000] node 0: [mem 0x100000000-0x41fffffff] [ 0.000000] On node 0 totalpages: 4185613 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 21 pages reserved [ 0.000000] DMA zone: 3997 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 12371 pages used for memmap [ 0.000000] DMA32 zone: 904816 pages, LIFO batch:31 [ 0.000000] Normal zone: 44800 pages used for memmap [ 0.000000] Normal zone: 3276800 pages, LIFO batch:31 [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x03] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x05] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x88] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x89] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x8a] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x8b] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x8c] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x8d] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x8e] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x8f] disabled) [ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000 [ 0.000000] smpboot: Allowing 16 CPUs, 8 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000 [ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000 [ 0.000000] PM: Registered nosave memory: 00000000dde70000 - 00000000dde88000 [ 0.000000] PM: Registered nosave memory: 00000000dde88000 - 00000000ddedc000 [ 0.000000] PM: Registered nosave memory: 00000000ddedc000 - 00000000de000000 [ 0.000000] PM: Registered nosave memory: 00000000de000000 - 00000000fee00000 [ 0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000 [ 0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000ff800000 [ 0.000000] PM: Registered nosave memory: 00000000ff800000 - 0000000100000000 [ 0.000000] e820: [mem 0xde000000-0xfedfffff] available for PCI devices [ 0.000000] setup_percpu: NR_CPUS:16 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 26 pages/cpu @ffff88041fc00000 s76864 r8192 d21440 u131072 [ 0.000000] pcpu-alloc: s76864 r8192 d21440 u131072 alloc=1*2097152 [ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4128365 [ 0.000000] Kernel command line: syno_hdd_powerup_seq=0 HddHotplug=0 syno_hw_version=DS3617xs vender_format_version=2 console=ttyS0,115200n8 withefi elevator=elevator quiet syno_port_thaw=1 root=/dev/md0 sn=1960ODN006200 mac1=001132A12369 mac2=001132A1236A mac3=001132A1236B mac4=001132A1236C netif_num=4 vid=0x13fe pid=0x4100 [ 0.000000] Power on seq num: 0 [ 0.000000] Synology Hardware Version: DS3617xs-j [ 0.000000] Vender format version: 2 [ 0.000000] Serial Number: 1960ODN006200 [ 0.000000] Mac1: 001132A12369 [ 0.000000] Mac2: 001132A1236A [ 0.000000] Mac3: 001132A1236B [ 0.000000] Mac4: 001132A1236C [ 0.000000] Internal netif num: 4 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes) [ 0.000000] Memory: 16378792k/17301504k available (4904k kernel code, 559052k absent, 363660k reserved, 3715k data, 792k init) [ 0.000000] Kernel/User page tables isolation: disabled [ 0.000000] Hierarchical RCU implementation. [ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32 [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:4352 nr_irqs:808 16 [ 0.000000] Console: colour dummy device 80x25 [ 0.000000] console [ttyS0] enabled [ 0.000000] allocated 67108864 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] hpet clockevent registered [ 0.000000] tsc: Fast TSC calibration using PIT [ 0.000000] tsc: Detected 2942.479 MHz processor [ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5884.95 BogoMIPS (lpj=2942479) [ 0.000005] pid_max: default: 32768 minimum: 301 [ 0.000028] Security Framework initialized [ 0.000033] AppArmor: AppArmor initialized [ 0.000040] Mount-cache hash table entries: 256 [ 0.000177] Initializing cgroup subsys memory [ 0.000185] Initializing cgroup subsys devices [ 0.000187] Initializing cgroup subsys freezer [ 0.000188] Initializing cgroup subsys blkio [ 0.000205] CPU: Physical Processor ID: 0 [ 0.000205] CPU: Processor Core ID: 0 [ 0.000208] mce: CPU supports 9 MCE banks [ 0.000216] CPU0: Thermal monitoring enabled (TM1) [ 0.000222] Last level iTLB entries: 4KB 512, 2MB 7, 4MB 7 Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32 tlb_flushall_shift: 6 [ 0.000224] FEATURE SPEC_CTRL Not Present [ 0.000224] FEATURE IBPB_SUPPORT Not Present [ 0.000226] Spectre V2 : Vulnerable [ 0.000283] Freeing SMP alternatives: 24k freed [ 0.000287] ACPI: Core revision 20130328 [ 0.003495] ACPI: All ACPI Tables successfully acquired [ 0.003542] dmar: Host address width 36 [ 0.003543] dmar: DRHD base: 0x000000fed90000 flags: 0x1 [ 0.003548] dmar: IOMMU 0: reg_base_addr fed90000 ver 1:0 cap c90780106f0462 ecap f020e3 [ 0.003550] dmar: RMRR base: 0x000000000e4000 end: 0x000000000e7fff [ 0.003551] dmar: RMRR base: 0x000000ddeec000 end: 0x000000ddefffff [ 0.003647] Switched APIC routing to physical flat. [ 0.004027] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.014028] smpboot: CPU0: Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz (fam: 06, model: 1e, stepping: 05) [ 0.115675] Performance Events: PEBS fmt1+, 16-deep LBR, Nehalem events, Intel PMU driver. [ 0.115680] perf_event_intel: CPU erratum AAJ80 worked around [ 0.115681] perf_event_intel: CPUID marked event: 'bus cycles' unavailable [ 0.115682] ... version: 3 [ 0.115683] ... bit width: 48 [ 0.115684] ... generic registers: 4 [ 0.115685] ... value mask: 0000ffffffffffff [ 0.115685] ... max period: 000000007fffffff [ 0.115686] ... fixed-purpose events: 3 [ 0.115687] ... event mask: 000000070000000f [ 0.115883] smpboot: Booting Node 0, Processors #1 #2 #3 #4 #5 #6 #7 [ 0.208970] Brought up 8 CPUs [ 0.208974] smpboot: Total of 8 processors activated (47079.66 BogoMIPS) [ 0.213671] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. [ 0.213903] devtmpfs: initialized [ 0.214086] PM: Registering ACPI NVS region [mem 0xdde88000-0xddedbfff] (344064 bytes) [ 0.214188] xor: measuring software checksum speed [ 0.223652] prefetch64-sse: 12180.000 MB/sec [ 0.233650] generic_sse: 10736.000 MB/sec [ 0.233651] xor: using function: prefetch64-sse (12180.000 MB/sec) [ 0.233692] NET: Registered protocol family 16 [ 0.233971] ACPI: bus type PCI registered [ 0.234050] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) [ 0.234051] PCI: not using MMCONFIG [ 0.234052] PCI: Using configuration type 1 for base access [ 0.236763] bio: create slab <bio-0> at 0 [ 0.253654] raid6: sse2x1 gen() 7253 MB/s [ 0.270649] raid6: sse2x1 xor() 5636 MB/s [ 0.287651] raid6: sse2x2 gen() 8550 MB/s [ 0.304644] raid6: sse2x2 xor() 6501 MB/s [ 0.321644] raid6: sse2x4 gen() 9539 MB/s [ 0.338640] raid6: sse2x4 xor() 7251 MB/s [ 0.338641] raid6: using algorithm sse2x4 gen() (9539 MB/s) [ 0.338642] raid6: .... xor() 7251 MB/s, rmw enabled [ 0.338643] raid6: using ssse3x2 recovery algorithm [ 0.338673] ACPI: Added _OSI(Module Device) [ 0.338674] ACPI: Added _OSI(Processor Device) [ 0.338675] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.338676] ACPI: Added _OSI(Processor Aggregator Device) [ 0.339579] ACPI: EC: Look up EC in DSDT [ 0.340466] ACPI: Executed 1 blocks of module-level executable AML code [ 0.346594] ACPI BIOS Bug: Warning: Incorrect checksum in table [OEMB] - 0xCF, should be 0xCE (20130328/tbutils-320) [ 0.349742] ACPI: SSDT 0x00000000DDE88150 0265C (v01 DpgPmm P001Ist 00000011 INTL 20060113) [ 0.350036] ACPI: Dynamic OEM Table Load: [ 0.350038] ACPI: SSDT 0x0000000000000000 0265C (v01 DpgPmm P001Ist 00000011 INTL 20060113) [ 0.350111] ACPI: SSDT 0x00000000DDE8A7B0 00659 (v01 PmRef P001Cst 00003001 INTL 20060113) [ 0.350337] ACPI: Dynamic OEM Table Load: [ 0.350339] ACPI: SSDT 0x0000000000000000 00659 (v01 PmRef P001Cst 00003001 INTL 20060113) [ 0.350566] ACPI: Interpreter enabled [ 0.350576] ACPI: (supports S0 S4 S5) [ 0.350578] ACPI: Using IOAPIC for interrupt routing [ 0.350592] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) [ 0.351043] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in ACPI motherboard resources [ 0.351123] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.351196] ACPI: No dock devices found. [ 0.358156] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.358286] acpi PNP0A08:00: Requesting ACPI _OSC control (0x1d) [ 0.358410] acpi PNP0A08:00: ACPI _OSC request failed (AE_SUPPORT), returned control mask: 0x0d [ 0.358411] ACPI _OSC control for PCIe not granted, disabling ASPM [ 0.358503] acpi PNP0A08:00: ignoring host bridge window [mem 0x000d0000-0x000dffff] (conflicts with Adapter ROM [mem 0x000cf000-0x000d07ff]) [ 0.358505] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge [ 0.358531] PCI host bridge to bus 0000:00 [ 0.358533] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.358535] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.358536] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.358538] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.358539] pci_bus 0000:00: root bus resource [mem 0xde000000-0xf7ffffff] [ 0.358540] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed8ffff] [ 0.358548] pci 0000:00:00.0: [8086:d131] type 00 class 0x060000 [ 0.358644] pci 0000:00:03.0: [8086:d138] type 01 class 0x060400 [ 0.358686] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold [ 0.358727] pci 0000:00:03.0: System wakeup disabled by ACPI [ 0.358771] pci 0000:00:08.0: [8086:d155] type 00 class 0x088000 [ 0.358868] pci 0000:00:08.1: [8086:d156] type 00 class 0x088000 [ 0.358966] pci 0000:00:08.2: [8086:d157] type 00 class 0x088000 [ 0.359060] pci 0000:00:08.3: [8086:d158] type 00 class 0x088000 [ 0.359155] pci 0000:00:10.0: [8086:d150] type 00 class 0x088000 [ 0.359239] pci 0000:00:10.1: [8086:d151] type 00 class 0x088000 [ 0.359342] pci 0000:00:16.0: [8086:3b64] type 00 class 0x078000 [ 0.359368] pci 0000:00:16.0: reg 10: [mem 0xf5fff000-0xf5fff00f 64bit] [ 0.359457] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold [ 0.359541] pci 0000:00:1a.0: [8086:3b3c] type 00 class 0x0c0320 [ 0.359559] pci 0000:00:1a.0: reg 10: [mem 0xf5ffe000-0xf5ffe3ff] [ 0.359643] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold [ 0.359683] pci 0000:00:1a.0: System wakeup disabled by ACPI [ 0.359720] pci 0000:00:1c.0: [8086:3b42] type 01 class 0x060400 [ 0.359779] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.359820] pci 0000:00:1c.0: System wakeup disabled by ACPI [ 0.359858] pci 0000:00:1c.4: [8086:3b4a] type 01 class 0x060400 [ 0.359920] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold [ 0.359960] pci 0000:00:1c.4: System wakeup disabled by ACPI [ 0.359996] pci 0000:00:1c.6: [8086:3b4e] type 01 class 0x060400 [ 0.360057] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold [ 0.360100] pci 0000:00:1c.6: System wakeup disabled by ACPI [ 0.360134] pci 0000:00:1c.7: [8086:3b50] type 01 class 0x060400 [ 0.360195] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold [ 0.360236] pci 0000:00:1c.7: System wakeup disabled by ACPI [ 0.360274] pci 0000:00:1d.0: [8086:3b34] type 00 class 0x0c0320 [ 0.360293] pci 0000:00:1d.0: reg 10: [mem 0xf5ffd000-0xf5ffd3ff] [ 0.360374] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold [ 0.360415] pci 0000:00:1d.0: System wakeup disabled by ACPI [ 0.360449] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401 [ 0.360523] pci 0000:00:1e.0: System wakeup disabled by ACPI [ 0.360559] pci 0000:00:1f.0: [8086:3b16] type 00 class 0x060100 [ 0.360734] pci 0000:00:1f.2: [8086:3b22] type 00 class 0x010601 [ 0.360751] pci 0000:00:1f.2: reg 10: [io 0xb880-0xb887] [ 0.360757] pci 0000:00:1f.2: reg 14: [io 0xb800-0xb803] [ 0.360764] pci 0000:00:1f.2: reg 18: [io 0xb480-0xb487] [ 0.360770] pci 0000:00:1f.2: reg 1c: [io 0xb400-0xb403] [ 0.360777] pci 0000:00:1f.2: reg 20: [io 0xb080-0xb09f] [ 0.360783] pci 0000:00:1f.2: reg 24: [mem 0xf5ffb000-0xf5ffb7ff] [ 0.360822] pci 0000:00:1f.2: PME# supported from D3hot [ 0.360891] pci 0000:00:1f.3: [8086:3b30] type 00 class 0x0c0500 [ 0.360904] pci 0000:00:1f.3: reg 10: [mem 0xf5ffc000-0xf5ffc0ff 64bit] [ 0.360921] pci 0000:00:1f.3: reg 20: [io 0xffe0-0xffff] [ 0.361044] pci 0000:01:00.0: [10de:05b1] type 01 class 0x060400 [ 0.361095] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold [ 0.363102] pci 0000:00:03.0: PCI bridge to [bus 01-04] [ 0.363108] pci 0000:00:03.0: bridge window [io 0xc000-0xcfff] [ 0.363113] pci 0000:00:03.0: bridge window [mem 0xf6000000-0xf7bfffff] [ 0.363120] pci 0000:00:03.0: bridge window [mem 0xe0000000-0xf4dfffff 64bit pref] [ 0.363196] pci 0000:02:00.0: [10de:05b1] type 01 class 0x060400 [ 0.363239] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold [ 0.363285] pci 0000:02:02.0: [10de:05b1] type 01 class 0x060400 [ 0.363328] pci 0000:02:02.0: PME# supported from D0 D3hot D3cold [ 0.363384] pci 0000:01:00.0: PCI bridge to [bus 02-04] [ 0.363389] pci 0000:01:00.0: bridge window [io 0xc000-0xcfff] [ 0.363392] pci 0000:01:00.0: bridge window [mem 0xf6000000-0xf7bfffff] [ 0.363396] pci 0000:01:00.0: bridge window [mem 0xe0000000-0xf4dfffff 64bit pref] [ 0.363452] pci 0000:03:00.0: [10de:1380] type 00 class 0x030000 [ 0.363465] pci 0000:03:00.0: reg 10: [mem 0xf6000000-0xf6ffffff] [ 0.363478] pci 0000:03:00.0: reg 14: [mem 0xe0000000-0xefffffff 64bit pref] [ 0.363492] pci 0000:03:00.0: reg 1c: [mem 0xf2000000-0xf3ffffff 64bit pref] [ 0.363501] pci 0000:03:00.0: reg 24: [io 0xcc00-0xcc7f] [ 0.363510] pci 0000:03:00.0: reg 30: [mem 0xf7400000-0xf747ffff pref] [ 0.363611] pci 0000:03:00.1: [10de:0fbc] type 00 class 0x040300 [ 0.363624] pci 0000:03:00.1: reg 10: [mem 0xf74fc000-0xf74fffff] [ 0.366118] pci 0000:02:00.0: PCI bridge to [bus 03] [ 0.366126] pci 0000:02:00.0: bridge window [io 0xc000-0xcfff] [ 0.366131] pci 0000:02:00.0: bridge window [mem 0xf6000000-0xf74fffff] [ 0.366139] pci 0000:02:00.0: bridge window [mem 0xe0000000-0xf3ffffff 64bit pref] [ 0.366238] pci 0000:04:00.0: [19a2:0700] type 00 class 0x020000 [ 0.366262] pci 0000:04:00.0: reg 14: [mem 0xf7be0000-0xf7be3fff] [ 0.366279] pci 0000:04:00.0: reg 18: [mem 0xf7780000-0xf779ffff 64bit] [ 0.366295] pci 0000:04:00.0: reg 20: [mem 0xf7660000-0xf767ffff 64bit] [ 0.366305] pci 0000:04:00.0: reg 30: [mem 0xf7580000-0xf75fffff pref] [ 0.366357] pci 0000:04:00.0: PME# supported from D3hot D3cold [ 0.366422] pci 0000:04:00.1: [19a2:0700] type 00 class 0x020000 [ 0.366447] pci 0000:04:00.1: reg 14: [mem 0xf7be4000-0xf7be7fff] [ 0.366463] pci 0000:04:00.1: reg 18: [mem 0xf77c0000-0xf77dffff 64bit] [ 0.366479] pci 0000:04:00.1: reg 20: [mem 0xf77a0000-0xf77bffff 64bit] [ 0.366490] pci 0000:04:00.1: reg 30: [mem 0xf7680000-0xf76fffff pref] [ 0.366540] pci 0000:04:00.1: PME# supported from D3hot D3cold [ 0.368122] pci 0000:02:02.0: PCI bridge to [bus 04] [ 0.368132] pci 0000:02:02.0: bridge window [mem 0xf7500000-0xf7bfffff] [ 0.368215] pci 0000:08:00.0: [10b5:8608] type 01 class 0x060400 [ 0.368229] pci 0000:08:00.0: reg 10: [mem 0xf7ee0000-0xf7efffff] [ 0.368303] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold [ 0.368338] pci 0000:08:00.0: System wakeup disabled by ACPI [ 0.370126] pci 0000:00:1c.0: PCI bridge to [bus 08-0d] [ 0.370136] pci 0000:00:1c.0: bridge window [mem 0xf7e00000-0xf7ffffff] [ 0.370229] pci 0000:09:01.0: [10b5:8608] type 01 class 0x060400 [ 0.370317] pci 0000:09:01.0: PME# supported from D0 D3hot D3cold [ 0.370397] pci 0000:09:05.0: [10b5:8608] type 01 class 0x060400 [ 0.370485] pci 0000:09:05.0: PME# supported from D0 D3hot D3cold [ 0.370562] pci 0000:09:07.0: [10b5:8608] type 01 class 0x060400 [ 0.370650] pci 0000:09:07.0: PME# supported from D0 D3hot D3cold [ 0.370685] pci 0000:09:07.0: System wakeup disabled by ACPI [ 0.370731] pci 0000:09:09.0: [10b5:8608] type 01 class 0x060400 [ 0.370819] pci 0000:09:09.0: PME# supported from D0 D3hot D3cold [ 0.370854] pci 0000:09:09.0: System wakeup disabled by ACPI [ 0.370916] pci 0000:08:00.0: PCI bridge to [bus 09-0d] [ 0.370925] pci 0000:08:00.0: bridge window [mem 0xf7f00000-0xf7ffffff] [ 0.371024] pci 0000:0a:00.0: [1033:0194] type 00 class 0x0c0330 [ 0.371049] pci 0000:0a:00.0: reg 10: [mem 0xf7ffe000-0xf7ffffff 64bit] [ 0.371176] pci 0000:0a:00.0: PME# supported from D0 D3hot D3cold [ 0.373141] pci 0000:09:01.0: PCI bridge to [bus 0a] [ 0.373150] pci 0000:09:01.0: bridge window [mem 0xf7f00000-0xf7ffffff] [ 0.373230] pci 0000:09:05.0: PCI bridge to [bus 0b] [ 0.373315] pci 0000:09:07.0: PCI bridge to [bus 0c] [ 0.373400] pci 0000:09:09.0: PCI bridge to [bus 0d] [ 0.373490] pci 0000:00:1c.4: PCI bridge to [bus 07] [ 0.373494] pci 0000:00:1c.4: bridge window [io 0x1000-0x1fff] [ 0.373497] pci 0000:00:1c.4: bridge window [mem 0xde000000-0xde1fffff] [ 0.373501] pci 0000:00:1c.4: bridge window [mem 0xde200000-0xde3fffff 64bit pref] [ 0.373569] pci 0000:06:00.0: [10ec:8168] type 00 class 0x020000 [ 0.373585] pci 0000:06:00.0: reg 10: [io 0xe800-0xe8ff] [ 0.373610] pci 0000:06:00.0: reg 18: [mem 0xf4fff000-0xf4ffffff 64bit pref] [ 0.373627] pci 0000:06:00.0: reg 20: [mem 0xf4ff8000-0xf4ffbfff 64bit pref] [ 0.373637] pci 0000:06:00.0: reg 30: [mem 0xf7df0000-0xf7dfffff pref] [ 0.373697] pci 0000:06:00.0: supports D1 D2 [ 0.373699] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.376137] pci 0000:00:1c.6: PCI bridge to [bus 06] [ 0.376144] pci 0000:00:1c.6: bridge window [io 0xe000-0xefff] [ 0.376149] pci 0000:00:1c.6: bridge window [mem 0xf7d00000-0xf7dfffff] [ 0.376157] pci 0000:00:1c.6: bridge window [mem 0xf4f00000-0xf4ffffff 64bit pref] [ 0.376264] pci 0000:05:00.0: [10ec:8168] type 00 class 0x020000 [ 0.376279] pci 0000:05:00.0: reg 10: [io 0xd800-0xd8ff] [ 0.376305] pci 0000:05:00.0: reg 18: [mem 0xf4eff000-0xf4efffff 64bit pref] [ 0.376321] pci 0000:05:00.0: reg 20: [mem 0xf4ef8000-0xf4efbfff 64bit pref] [ 0.376331] pci 0000:05:00.0: reg 30: [mem 0xf7cf0000-0xf7cfffff pref] [ 0.376392] pci 0000:05:00.0: supports D1 D2 [ 0.376393] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.378149] pci 0000:00:1c.7: PCI bridge to [bus 05] [ 0.378156] pci 0000:00:1c.7: bridge window [io 0xd000-0xdfff] [ 0.378161] pci 0000:00:1c.7: bridge window [mem 0xf7c00000-0xf7cfffff] [ 0.378169] pci 0000:00:1c.7: bridge window [mem 0xf4e00000-0xf4efffff 64bit pref] [ 0.378267] pci 0000:00:1e.0: PCI bridge to [bus 0e] (subtractive decode) [ 0.378275] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.378276] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.378277] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.378279] pci 0000:00:1e.0: bridge window [mem 0xde000000-0xf7ffffff] (subtractive decode) [ 0.378280] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfed8ffff] (subtractive decode) [ 0.378303] pci 0000:00:03.0: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 128 [ 0.378309] pci 0000:01:00.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.378314] pci 0000:02:00.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.378321] pci 0000:03:00.0: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 512 [ 0.378328] pci 0000:03:00.1: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 512 [ 0.378333] pci 0000:02:02.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.378341] pci 0000:04:00.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 512 [ 0.378349] pci 0000:04:00.1: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 512 [ 0.378355] pci 0000:00:1c.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.378362] pci 0000:08:00.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.378370] pci 0000:09:01.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.378380] pci 0000:0a:00.0: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512 [ 0.378388] pci 0000:09:05.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.378395] pci 0000:09:07.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.378402] pci 0000:09:09.0: PCI-E Max Payload Size set to 128/ 512 (was 128), Max Read Rq 128 [ 0.378408] pci 0000:00:1c.4: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.378413] pci 0000:00:1c.6: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.378421] pci 0000:06:00.0: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 512 [ 0.378427] pci 0000:00:1c.7: PCI-E Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128 [ 0.378435] pci 0000:05:00.0: PCI-E Max Payload Size set to 128/ 256 (was 128), Max Read Rq 512 [ 0.378436] pci_bus 0000:00: on NUMA node 0 [ 0.378898] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12 14 15), disabled. [ 0.378937] ACPI: PCI Interrupt Link [LNKB] (IRQs *5), disabled. [ 0.378973] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12 14 *15), disabled. [ 0.379011] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12 14 15), disabled. [ 0.379049] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled. [ 0.379086] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12 *14 15), disabled. [ 0.379124] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled. [ 0.379165] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 6 7 10 11 12 14 15), disabled. [ 0.379250] ACPI: Enabled 2 GPEs in block 00 to 3F [ 0.379255] acpi root: \_SB_.PCI0 notify handler is installed [ 0.379288] Found 1 acpi root devices [ 0.379311] ACPI: EC: GPE = 0x18, I/O: command/status = 0x66, data = 0x62 [ 0.379409] vgaarb: device added: PCI:0000:03:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.379411] vgaarb: loaded [ 0.379412] vgaarb: bridge control possible 0000:03:00.0 [ 0.379508] SCSI subsystem initialized [ 0.379510] ACPI: bus type ATA registered [ 0.379572] libata version 3.00 loaded. [ 0.379633] pps_core: LinuxPPS API ver. 1 registered [ 0.379634] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.379648] PTP clock support registered [ 0.379712] PCI: Using ACPI for IRQ routing [ 0.380772] PCI: Discovered peer bus 3f [ 0.380773] PCI: root bus 3f: using default resources [ 0.380774] PCI: Probing PCI hardware (bus 3f) [ 0.380804] PCI host bridge to bus 0000:3f [ 0.380806] pci_bus 0000:3f: root bus resource [io 0x0000-0xffff] [ 0.380808] pci_bus 0000:3f: root bus resource [mem 0x00000000-0xfffffffff] [ 0.380809] pci_bus 0000:3f: No busn resource found for root bus, will use [bus 3f-ff] [ 0.380814] pci 0000:3f:00.0: [8086:2c51] type 00 class 0x060000 [ 0.380852] pci 0000:3f:00.1: [8086:2c81] type 00 class 0x060000 [ 0.380889] pci 0000:3f:02.0: [8086:2c90] type 00 class 0x060000 [ 0.380924] pci 0000:3f:02.1: [8086:2c91] type 00 class 0x060000 [ 0.380962] pci 0000:3f:03.0: [8086:2c98] type 00 class 0x060000 [ 0.380997] pci 0000:3f:03.1: [8086:2c99] type 00 class 0x060000 [ 0.381033] pci 0000:3f:03.4: [8086:2c9c] type 00 class 0x060000 [ 0.381069] pci 0000:3f:04.0: [8086:2ca0] type 00 class 0x060000 [ 0.381105] pci 0000:3f:04.1: [8086:2ca1] type 00 class 0x060000 [ 0.381141] pci 0000:3f:04.2: [8086:2ca2] type 00 class 0x060000 [ 0.381179] pci 0000:3f:04.3: [8086:2ca3] type 00 class 0x060000 [ 0.381215] pci 0000:3f:05.0: [8086:2ca8] type 00 class 0x060000 [ 0.381250] pci 0000:3f:05.1: [8086:2ca9] type 00 class 0x060000 [ 0.381285] pci 0000:3f:05.2: [8086:2caa] type 00 class 0x060000 [ 0.381320] pci 0000:3f:05.3: [8086:2cab] type 00 class 0x060000 [ 0.381363] pci_bus 0000:3f: busn_res: [bus 3f-ff] end is updated to 3f [ 0.381365] PCI: pci_cache_line_size set to 64 bytes [ 0.381446] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff] [ 0.381448] e820: reserve RAM buffer [mem 0xdde70000-0xdfffffff] [ 0.381618] HPET: 8 timers in total, 6 timers will be used for per-cpu timer [ 0.381638] Spurious HPET timer interrupt on HPET timer 2 [ 0.381647] hpet: hpet2 irq 40 for MSI [ 0.381678] hpet: hpet3 irq 41 for MSI [ 0.381712] hpet: hpet4 irq 42 for MSI [ 0.381747] hpet: hpet5 irq 43 for MSI [ 0.381783] hpet: hpet6 irq 44 for MSI [ 0.381814] hpet: hpet7 irq 45 for MSI [ 0.381854] Switching to clocksource hpet [ 0.381940] AppArmor: AppArmor Filesystem Enabled [ 0.381973] pnp: PnP ACPI init [ 0.381978] ACPI: bus type PNP registered [ 0.382040] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved [ 0.382043] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.382068] pnp 00:01: [dma 4] [ 0.382099] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.382139] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.382173] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.382212] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.382362] system 00:05: [io 0x0290-0x029f] has been reserved [ 0.382364] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.382535] system 00:06: [io 0x04d0-0x04d1] has been reserved [ 0.382537] system 00:06: [io 0x0800-0x087f] could not be reserved [ 0.382539] system 00:06: [io 0x0500-0x057f] has been reserved [ 0.382541] system 00:06: [io 0x0600-0x0607] has been reserved [ 0.382542] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.382544] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved [ 0.382546] system 00:06: [mem 0xfed40000-0xfed8ffff] has been reserved [ 0.382548] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.382625] pnp 00:07: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.382769] pnp 00:08: [dma 0 disabled] [ 0.382845] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.382961] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.382964] system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.382966] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.383072] system 00:0a: [mem 0xf8000000-0xfbffffff] has been reserved [ 0.383074] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.383253] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.383255] system 00:0b: [mem 0x000c0000-0x000cffff] could not be reserved [ 0.383257] system 00:0b: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.383259] system 00:0b: [mem 0x00100000-0xddffffff] could not be reserved [ 0.383260] system 00:0b: [mem 0xfed90000-0xffffffff] could not be reserved [ 0.383262] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.383350] pnp: PnP ACPI: found 12 devices [ 0.383351] ACPI: bus type PNP unregistered [ 0.392038] pci 0000:02:00.0: PCI bridge to [bus 03] [ 0.392041] pci 0000:02:00.0: bridge window [io 0xc000-0xcfff] [ 0.392045] pci 0000:02:00.0: bridge window [mem 0xf6000000-0xf74fffff] [ 0.392047] pci 0000:02:00.0: bridge window [mem 0xe0000000-0xf3ffffff 64bit pref] [ 0.392052] pci 0000:02:02.0: PCI bridge to [bus 04] [ 0.392055] pci 0000:02:02.0: bridge window [mem 0xf7500000-0xf7bfffff] [ 0.392061] pci 0000:01:00.0: PCI bridge to [bus 02-04] [ 0.392063] pci 0000:01:00.0: bridge window [io 0xc000-0xcfff] [ 0.392066] pci 0000:01:00.0: bridge window [mem 0xf6000000-0xf7bfffff] [ 0.392069] pci 0000:01:00.0: bridge window [mem 0xe0000000-0xf4dfffff 64bit pref] [ 0.392073] pci 0000:00:03.0: PCI bridge to [bus 01-04] [ 0.392075] pci 0000:00:03.0: bridge window [io 0xc000-0xcfff] [ 0.392078] pci 0000:00:03.0: bridge window [mem 0xf6000000-0xf7bfffff] [ 0.392080] pci 0000:00:03.0: bridge window [mem 0xe0000000-0xf4dfffff 64bit pref] [ 0.392084] pci 0000:09:01.0: PCI bridge to [bus 0a] [ 0.392089] pci 0000:09:01.0: bridge window [mem 0xf7f00000-0xf7ffffff] [ 0.392097] pci 0000:09:05.0: PCI bridge to [bus 0b] [ 0.392109] pci 0000:09:07.0: PCI bridge to [bus 0c] [ 0.392120] pci 0000:09:09.0: PCI bridge to [bus 0d] [ 0.392132] pci 0000:08:00.0: PCI bridge to [bus 09-0d] [ 0.392136] pci 0000:08:00.0: bridge window [mem 0xf7f00000-0xf7ffffff] [ 0.392144] pci 0000:00:1c.0: PCI bridge to [bus 08-0d] [ 0.392148] pci 0000:00:1c.0: bridge window [mem 0xf7e00000-0xf7ffffff] [ 0.392154] pci 0000:00:1c.4: PCI bridge to [bus 07] [ 0.392156] pci 0000:00:1c.4: bridge window [io 0x1000-0x1fff] [ 0.392159] pci 0000:00:1c.4: bridge window [mem 0xde000000-0xde1fffff] [ 0.392162] pci 0000:00:1c.4: bridge window [mem 0xde200000-0xde3fffff 64bit pref] [ 0.392167] pci 0000:00:1c.6: PCI bridge to [bus 06] [ 0.392169] pci 0000:00:1c.6: bridge window [io 0xe000-0xefff] [ 0.392172] pci 0000:00:1c.6: bridge window [mem 0xf7d00000-0xf7dfffff] [ 0.392175] pci 0000:00:1c.6: bridge window [mem 0xf4f00000-0xf4ffffff 64bit pref] [ 0.392179] pci 0000:00:1c.7: PCI bridge to [bus 05] [ 0.392181] pci 0000:00:1c.7: bridge window [io 0xd000-0xdfff] [ 0.392185] pci 0000:00:1c.7: bridge window [mem 0xf7c00000-0xf7cfffff] [ 0.392188] pci 0000:00:1c.7: bridge window [mem 0xf4e00000-0xf4efffff 64bit pref] [ 0.392192] pci 0000:00:1e.0: PCI bridge to [bus 0e] [ 0.392566] pci 0000:00:1e.0: setting latency timer to 64 [ 0.392569] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.392570] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.392571] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.392573] pci_bus 0000:00: resource 7 [mem 0xde000000-0xf7ffffff] [ 0.392574] pci_bus 0000:00: resource 8 [mem 0xfc000000-0xfed8ffff] [ 0.392576] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff] [ 0.392577] pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf7bfffff] [ 0.392578] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf4dfffff 64bit pref] [ 0.392580] pci_bus 0000:02: resource 0 [io 0xc000-0xcfff] [ 0.392581] pci_bus 0000:02: resource 1 [mem 0xf6000000-0xf7bfffff] [ 0.392582] pci_bus 0000:02: resource 2 [mem 0xe0000000-0xf4dfffff 64bit pref] [ 0.392584] pci_bus 0000:03: resource 0 [io 0xc000-0xcfff] [ 0.392585] pci_bus 0000:03: resource 1 [mem 0xf6000000-0xf74fffff] [ 0.392586] pci_bus 0000:03: resource 2 [mem 0xe0000000-0xf3ffffff 64bit pref] [ 0.392588] pci_bus 0000:04: resource 1 [mem 0xf7500000-0xf7bfffff] [ 0.392589] pci_bus 0000:08: resource 1 [mem 0xf7e00000-0xf7ffffff] [ 0.392591] pci_bus 0000:09: resource 1 [mem 0xf7f00000-0xf7ffffff] [ 0.392592] pci_bus 0000:0a: resource 1 [mem 0xf7f00000-0xf7ffffff] [ 0.392594] pci_bus 0000:07: resource 0 [io 0x1000-0x1fff] [ 0.392595] pci_bus 0000:07: resource 1 [mem 0xde000000-0xde1fffff] [ 0.392596] pci_bus 0000:07: resource 2 [mem 0xde200000-0xde3fffff 64bit pref] [ 0.392598] pci_bus 0000:06: resource 0 [io 0xe000-0xefff] [ 0.392599] pci_bus 0000:06: resource 1 [mem 0xf7d00000-0xf7dfffff] [ 0.392600] pci_bus 0000:06: resource 2 [mem 0xf4f00000-0xf4ffffff 64bit pref] [ 0.392602] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff] [ 0.392603] pci_bus 0000:05: resource 1 [mem 0xf7c00000-0xf7cfffff] [ 0.392604] pci_bus 0000:05: resource 2 [mem 0xf4e00000-0xf4efffff 64bit pref] [ 0.392606] pci_bus 0000:0e: resource 4 [io 0x0000-0x0cf7] [ 0.392607] pci_bus 0000:0e: resource 5 [io 0x0d00-0xffff] [ 0.392608] pci_bus 0000:0e: resource 6 [mem 0x000a0000-0x000bffff] [ 0.392610] pci_bus 0000:0e: resource 7 [mem 0xde000000-0xf7ffffff] [ 0.392611] pci_bus 0000:0e: resource 8 [mem 0xfc000000-0xfed8ffff] [ 0.392612] pci_bus 0000:3f: resource 4 [io 0x0000-0xffff] [ 0.392614] pci_bus 0000:3f: resource 5 [mem 0x00000000-0xfffffffff] [ 0.392684] NET: Registered protocol family 2 [ 0.392889] TCP established hash table entries: 131072 (order: 9, 2097152 bytes) [ 0.393406] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) [ 0.393662] TCP: Hash tables configured (established 131072 bind 65536) [ 0.393679] TCP: reno registered [ 0.393682] UDP hash table entries: 8192 (order: 6, 262144 bytes) [ 0.393775] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes) [ 0.393942] NET: Registered protocol family 1 [ 0.394060] RPC: Registered named UNIX socket transport module. [ 0.394062] RPC: Registered udp transport module. [ 0.394062] RPC: Registered tcp transport module. [ 0.394063] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.394340] pci 0000:03:00.0: Boot video device [ 0.394431] PCI: CLS 32 bytes, default 64 [ 0.394458] Trying to unpack rootfs image as initramfs... [ 1.152445] Freeing initrd memory: 28600k freed [ 1.155961] hndnmvthuuuuf: module verification failed: signature and/or required key missing - tainting kernel [ 1.170097] DMAR: No ATSR found [ 1.170121] IOMMU 0 0xfed90000: using Queued invalidation [ 1.170122] IOMMU passthrough mode = 1 [ 1.170135] IOMMU: hardware identity mapping for device 0000:00:00.0 [ 1.170137] IOMMU: hardware identity mapping for device 0000:00:03.0 [ 1.170138] IOMMU: hardware identity mapping for device 0000:00:08.0 [ 1.170139] IOMMU: hardware identity mapping for device 0000:00:08.1 [ 1.170141] IOMMU: hardware identity mapping for device 0000:00:08.2 [ 1.170142] IOMMU: hardware identity mapping for device 0000:00:08.3 [ 1.170143] IOMMU: hardware identity mapping for device 0000:00:10.0 [ 1.170145] IOMMU: hardware identity mapping for device 0000:00:10.1 [ 1.170146] IOMMU: hardware identity mapping for device 0000:00:16.0 [ 1.170147] IOMMU: hardware identity mapping for device 0000:00:1a.0 [ 1.170148] IOMMU: hardware identity mapping for device 0000:00:1c.0 [ 1.170150] IOMMU: hardware identity mapping for device 0000:00:1c.4 [ 1.170151] IOMMU: hardware identity mapping for device 0000:00:1c.6 [ 1.170152] IOMMU: hardware identity mapping for device 0000:00:1c.7 [ 1.170154] IOMMU: hardware identity mapping for device 0000:00:1d.0 [ 1.170155] IOMMU: hardware identity mapping for device 0000:00:1f.0 [ 1.170157] IOMMU: hardware identity mapping for device 0000:00:1f.2 [ 1.170158] IOMMU: hardware identity mapping for device 0000:00:1f.3 [ 1.170160] IOMMU: hardware identity mapping for device 0000:01:00.0 [ 1.170161] IOMMU: hardware identity mapping for device 0000:02:00.0 [ 1.170163] IOMMU: hardware identity mapping for device 0000:02:02.0 [ 1.170164] IOMMU: hardware identity mapping for device 0000:03:00.0 [ 1.170166] IOMMU: hardware identity mapping for device 0000:03:00.1 [ 1.170167] IOMMU: hardware identity mapping for device 0000:04:00.0 [ 1.170169] IOMMU: hardware identity mapping for device 0000:04:00.1 [ 1.170170] IOMMU: hardware identity mapping for device 0000:08:00.0 [ 1.170172] IOMMU: hardware identity mapping for device 0000:09:01.0 [ 1.170173] IOMMU: hardware identity mapping for device 0000:09:05.0 [ 1.170175] IOMMU: hardware identity mapping for device 0000:09:07.0 [ 1.170176] IOMMU: hardware identity mapping for device 0000:09:09.0 [ 1.170177] IOMMU: hardware identity mapping for device 0000:0a:00.0 [ 1.170179] IOMMU: hardware identity mapping for device 0000:06:00.0 [ 1.170181] IOMMU: hardware identity mapping for device 0000:05:00.0 [ 1.170183] IOMMU: hardware identity mapping for device 0000:3f:00.0 [ 1.170184] IOMMU: hardware identity mapping for device 0000:3f:00.1 [ 1.170185] IOMMU: hardware identity mapping for device 0000:3f:02.0 [ 1.170187] IOMMU: hardware identity mapping for device 0000:3f:02.1 [ 1.170188] IOMMU: hardware identity mapping for device 0000:3f:03.0 [ 1.170189] IOMMU: hardware identity mapping for device 0000:3f:03.1 [ 1.170190] IOMMU: hardware identity mapping for device 0000:3f:03.4 [ 1.170192] IOMMU: hardware identity mapping for device 0000:3f:04.0 [ 1.170193] IOMMU: hardware identity mapping for device 0000:3f:04.1 [ 1.170194] IOMMU: hardware identity mapping for device 0000:3f:04.2 [ 1.170196] IOMMU: hardware identity mapping for device 0000:3f:04.3 [ 1.170197] IOMMU: hardware identity mapping for device 0000:3f:05.0 [ 1.170198] IOMMU: hardware identity mapping for device 0000:3f:05.1 [ 1.170199] IOMMU: hardware identity mapping for device 0000:3f:05.2 [ 1.170201] IOMMU: hardware identity mapping for device 0000:3f:05.3 [ 1.170201] IOMMU: Setting RMRR: [ 1.170202] Ignoring identity map for HW passthrough device 0000:00:1a.0 [0xddeec000 - 0xddefffff] [ 1.170204] Ignoring identity map for HW passthrough device 0000:00:1d.0 [0xddeec000 - 0xddefffff] [ 1.170204] Ignoring identity map for HW passthrough device 0000:00:1a.0 [0xe4000 - 0xe7fff] [ 1.170205] Ignoring identity map for HW passthrough device 0000:00:1d.0 [0xe4000 - 0xe7fff] [ 1.170207] IOMMU: Prepare 0-16MiB unity mapping for LPC [ 1.170208] Ignoring identity map for HW passthrough device 0000:00:1f.0 [0x0 - 0xffffff] [ 1.170232] PCI-DMA: Intel(R) Virtualization Technology for Directed I/O [ 1.179503] Initialise module verification [ 1.179553] audit: initializing netlink socket (disabled) [ 1.179566] type=2000 audit(1596977869.062:1): initialized [ 1.182118] bounce pool size: 64 pages [ 1.182332] VFS: Disk quotas dquot_6.5.2 [ 1.182362] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.183111] NFS: Registering the id_resolver key type [ 1.183117] Key type id_resolver registered [ 1.183118] Key type id_legacy registered [ 1.183129] msgmni has been set to 32174 [ 1.183408] async_tx: api initialized (async) [ 1.183411] Key type asymmetric registered [ 1.183412] Asymmetric key parser 'x509' registered [ 1.183511] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251) [ 1.183514] io scheduler noop registered [ 1.183515] io scheduler deadline registered [ 1.183528] io scheduler cfq registered (default) [ 1.183967] pcieport 0000:08:00.0: irq 47 for MSI/MSI-X [ 1.184120] pcieport 0000:09:01.0: irq 48 for MSI/MSI-X [ 1.184480] pcieport 0000:09:05.0: irq 49 for MSI/MSI-X [ 1.184648] pcieport 0000:09:07.0: irq 50 for MSI/MSI-X [ 1.184801] pcieport 0000:09:09.0: irq 51 for MSI/MSI-X [ 1.385169] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.406242] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.406358] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 8250 [ 1.426044] brd: module loaded [ 1.428498] ACPI Warning: 0x0000000000000828-0x000000000000082F SystemIO conflicts with Region \PMRG 1 (20130328/utaddress-249) [ 1.428506] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 1.428509] Unknown LPC device 3b16 [ 1.428511] ACPI Warning: 0x0000000000000530-0x000000000000053F SystemIO conflicts with Region \GPS1 1 (20130328/utaddress-249) [ 1.428514] ACPI Warning: 0x0000000000000530-0x000000000000053F SystemIO conflicts with Region \GPS0 2 (20130328/utaddress-249) [ 1.428518] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 1.428520] ACPI Warning: 0x0000000000000500-0x000000000000052F SystemIO conflicts with Region \GPS1 1 (20130328/utaddress-249) [ 1.428523] ACPI Warning: 0x0000000000000500-0x000000000000052F SystemIO conflicts with Region \GPS0 2 (20130328/utaddress-249) [ 1.428526] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 1.429214] lpc_ich: Resource conflict(s) found affecting gpio_ich [ 1.430473] Loading iSCSI transport class v2.0-870. [ 1.438442] rdac: device handler registered [ 1.439646] ahci 0000:00:1f.2: version 3.0 [ 1.439786] ahci 0000:00:1f.2: irq 52 for MSI/MSI-X [ 1.439834] ahci: SSS flag set, parallel bus scan disabled [ 1.450919] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x3f impl SATA mode [ 1.450927] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ems sxs apst [ 1.450936] ahci 0000:00:1f.2: setting latency timer to 64 [ 1.466869] scsi0 : ahci [ 1.467614] scsi1 : ahci [ 1.467864] scsi2 : ahci [ 1.468389] scsi3 : ahci [ 1.469168] scsi4 : ahci [ 1.469754] scsi5 : ahci [ 1.470707] ata1: SATA max UDMA/133 abar m2048@0xf5ffb000 port 0xf5ffb100 irq 52 [ 1.470710] ata2: SATA max UDMA/133 abar m2048@0xf5ffb000 port 0xf5ffb180 irq 52 [ 1.470713] ata3: SATA max UDMA/133 abar m2048@0xf5ffb000 port 0xf5ffb200 irq 52 [ 1.470715] ata4: SATA max UDMA/133 abar m2048@0xf5ffb000 port 0xf5ffb280 irq 52 [ 1.470717] ata5: SATA max UDMA/133 abar m2048@0xf5ffb000 port 0xf5ffb300 irq 52 [ 1.470719] ata6: SATA max UDMA/133 abar m2048@0xf5ffb000 port 0xf5ffb380 irq 52 [ 1.473967] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 1.477187] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.477192] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.477290] rtc_cmos 00:02: RTC can wake from S4 [ 1.477490] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0 [ 1.477518] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs [ 1.477579] i2c /dev entries driver [ 1.478264] md: linear personality registered for level -1 [ 1.478266] md: raid0 personality registered for level 0 [ 1.478268] md: raid1 personality registered for level 1 [ 1.478269] md: raid10 personality registered for level 10 [ 1.478753] md: raid6 personality registered for level 6 [ 1.478756] md: raid5 personality registered for level 5 [ 1.478757] md: raid4 personality registered for level 4 [ 1.478758] md: raidF1 personality registered for level 45 [ 1.478929] device-mapper: ioctl: 4.25.0-ioctl (2013-06-26) initialised: dm-devel@redhat.com [ 1.478932] cpuidle: using governor ladder [ 1.478933] cpuidle: using governor menu [ 1.479029] TCP: cubic registered [ 1.479032] NET: Registered protocol family 17 [ 1.479053] Key type dns_resolver registered [ 1.775853] ata1: SATA link down (SStatus 0 SControl 300) [ 2.174874] tsc: Refined TSC clocksource calibration: 2942.464 MHz [ 2.174880] Switching to clocksource tsc [ 2.235847] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 2.235989] ata2.00: ATA-11: Patriot Burst, SBFM61.3, max UDMA/133 [ 2.235994] ata2.00: 937703088 sectors, multi 16: LBA48 NCQ (depth 31/32), AA [ 2.235996] ata2.00: SN:FEB4078B030805189192 [ 2.236128] ata2.00: configured for UDMA/133 [ 2.236135] ata2.00: Find SSD disks. [Patriot Burst] [ 2.236294] scsi 1:0:0:0: Direct-Access Patriot Burst SBFM PQ: 0 ANSI: 5 [ 2.236535] sd 1:0:0:0: [sdb] 937703088 512-byte logical blocks: (480 GB/447 GiB) [ 2.236598] sd 1:0:0:0: [sdb] Write Protect is off [ 2.236600] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 2.236622] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 2.237051] sdb: sdb1 sdb2 sdb3 [ 2.239578] sd 1:0:0:0: [sdb] Attached SCSI disk [ 2.540832] ata3: SATA link down (SStatus 0 SControl 300) [ 2.845830] ata4: SATA link down (SStatus 0 SControl 300) [ 3.150823] ata5: SATA link down (SStatus 0 SControl 300) [ 3.455816] ata6: SATA link down (SStatus 0 SControl 300) [ 3.455847] Loading module verification blacklist certificates [ 3.455849] Loading module verification certificates [ 3.455891] MODSIGN: Loaded cert 'Synology SDG kernel module signing key: 7bd0b0d6bcd31651c22ce3978bdc8c8bdc417329' [ 3.456759] MODSIGN: Loaded cert 'Synology Root Certification Authority: f2c075361f168425f8b5ef31b796406c3aab2089' [ 3.456768] MODSIGN: Loaded cert 'Synology Kernel Module Signing Certification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28' [ 3.456777] MODSIGN: Loaded cert 'Synology kernel module signing key: 4646ce54489669338118a3b1286da156ac366fa5' [ 3.456783] registered taskstats version 1 [ 3.457258] rtc_cmos 00:02: setting system clock to 2020-08-09 12:57:52 UTC (1596977872) [ 3.457766] Freeing unused kernel memory: 792k freed [ 3.457859] Write protecting the kernel read-only data: 8192k [ 3.457958] Freeing unused kernel memory: 1228k freed [ 3.458751] Freeing unused kernel memory: 476k freed [ 3.514513] ACPI: bus type USB registered [ 3.514631] usbcore: registered new interface driver usbfs [ 3.514687] usbcore: registered new interface driver hub [ 3.514778] usbcore: registered new interface driver ethub [ 3.514863] usbcore: registered new device driver usb [ 3.525009] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.528249] ehci-pci: EHCI PCI platform driver [ 3.528351] ehci-pci 0000:00:1a.0: setting latency timer to 64 [ 3.528366] ehci-pci 0000:00:1a.0: EHCI Host Controller [ 3.528370] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1 [ 3.528381] ehci-pci 0000:00:1a.0: debug port 2 [ 3.528392] 32bit 0000:00:1a.0 uses non-identity mapping [ 3.532290] ehci-pci 0000:00:1a.0: cache line size of 32 is not supported [ 3.532309] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf5ffe000 [ 3.537840] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00 [ 3.538075] hub 1-0:1.0: USB hub found [ 3.538079] hub 1-0:1.0: 2 ports detected [ 3.538194] ehci-pci 0000:00:1d.0: setting latency timer to 64 [ 3.538201] ehci-pci 0000:00:1d.0: EHCI Host Controller [ 3.538205] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 3.538215] ehci-pci 0000:00:1d.0: debug port 2 [ 3.538225] 32bit 0000:00:1d.0 uses non-identity mapping [ 3.542143] ehci-pci 0000:00:1d.0: cache line size of 32 is not supported [ 3.542155] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf5ffd000 [ 3.547813] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00 [ 3.548034] hub 2-0:1.0: USB hub found [ 3.548037] hub 2-0:1.0: 2 ports detected [ 3.552570] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.556630] uhci_hcd: USB Universal Host Controller Interface driver [ 3.561137] xhci_hcd 0000:0a:00.0: xHCI Host Controller [ 3.561142] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 3 [ 3.761199] 32bit 0000:0a:00.0 uses non-identity mapping [ 3.761289] xhci_hcd 0000:0a:00.0: irq 53 for MSI/MSI-X [ 3.761294] xhci_hcd 0000:0a:00.0: irq 54 for MSI/MSI-X [ 3.761298] xhci_hcd 0000:0a:00.0: irq 55 for MSI/MSI-X [ 3.761302] xhci_hcd 0000:0a:00.0: irq 56 for MSI/MSI-X [ 3.761306] xhci_hcd 0000:0a:00.0: irq 57 for MSI/MSI-X [ 3.761310] xhci_hcd 0000:0a:00.0: irq 58 for MSI/MSI-X [ 3.761315] xhci_hcd 0000:0a:00.0: irq 59 for MSI/MSI-X [ 3.761319] xhci_hcd 0000:0a:00.0: irq 60 for MSI/MSI-X [ 3.761534] xHCI xhci_add_endpoint called for root hub [ 3.761536] xHCI xhci_check_bandwidth called for root hub [ 3.761602] hub 3-0:1.0: USB hub found [ 3.761610] hub 3-0:1.0: 2 ports detected [ 3.761653] xhci_hcd 0000:0a:00.0: xHCI Host Controller [ 3.761656] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 4 [ 3.761789] xHCI xhci_add_endpoint called for root hub [ 3.761790] xHCI xhci_check_bandwidth called for root hub [ 3.761882] hub 4-0:1.0: USB hub found [ 3.761894] hub 4-0:1.0: 2 ports detected [ 3.784825] usbcore: registered new interface driver usb-storage [ 3.798810] vmw_pvscsi: Unknown symbol __dynamic_dev_dbg (err 0) [ 3.802001] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006) [ 3.805450] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006) [ 3.812318] Fusion MPT base driver 3.04.20 [ 3.812320] Copyright (c) 1999-2008 LSI Corporation [ 3.818885] Fusion MPT SPI Host driver 3.04.20 [ 3.822264] Fusion MPT SAS Host driver 3.04.20 [ 3.825661] Fusion MPT misc device (ioctl) driver 3.04.20 [ 3.825738] mptctl: Registered with Fusion MPT base driver [ 3.825740] mptctl: /dev/mptctl @ (major,minor=10,220) [ 3.829163] megasas: 06.506.00.00-rc1 Sat. Feb. 9 17:00:00 PDT 2013 [ 3.832989] mpt2sas version 20.00.00.00 loaded [ 3.837077] mpt3sas version 22.00.02.00 loaded [ 3.844072] Adaptec aacraid driver 1.2-0[30200]-ms [ 3.847622] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded [ 3.851021] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014. [ 3.854402] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000. [ 3.857772] 3ware Storage Controller device driver for Linux v1.26.02.003. [ 3.860808] usb 1-1: new high-speed USB device number 2 using ehci-pci [ 3.871509] isci: Intel(R) C600 SAS Controller Driver - version 1.1.0 [ 3.891075] broadwell_synobios: module license 'Synology Inc.' taints kernel. [ 3.891078] Disabling lock debugging due to kernel taint [ 3.891412] 2020-8-9 12:57:52 UTC [ 3.891415] synobios: load, major number 201 [ 3.891417] Brand: Synology [ 3.891419] Model: DS-3617xs [ 3.891420] set group disks wakeup number to 4, spinup time deno 7 [ 3.891423] synobios cpu_arch proc entry initialized [ 3.891424] synobios crypto_hw proc entry initialized [ 3.891425] synobios syno_platform proc entry initialized [ 3.891431] synobios open /dev/ttyS1 success [ 3.895018] synobios: unload [ 3.901536] md: Autodetecting RAID arrays. [ 3.902011] md: invalid raid superblock magic on sdb3 [ 3.907146] md: sdb3 does not have a valid v0.90 superblock, not importing! [ 3.907151] md: Scanned 3 and added 2 devices. [ 3.907152] md: autorun ... [ 3.907153] md: considering sdb1 ... [ 3.907156] md: adding sdb1 ... [ 3.907158] md: sdb2 has different UUID to sdb1 [ 3.907161] md: created md0 [ 3.907162] md: bind<sdb1> [ 3.907170] md: running: <sdb1> [ 3.907305] md/raid1:md0: active with 1 out of 12 mirrors [ 3.907807] md0: detected capacity change from 0 to 2549940224 [ 3.907900] md: considering sdb2 ... [ 3.907904] md: adding sdb2 ... [ 3.908081] md: created md1 [ 3.908082] md: bind<sdb2> [ 3.908087] md: running: <sdb2> [ 3.908225] md/raid1:md1: active with 1 out of 12 mirrors [ 3.909742] md1: detected capacity change from 0 to 2147418112 [ 3.909808] md: ... autorun DONE. [ 3.917745] md0: unknown partition table [ 3.996104] Got empty serial number. Generate serial number from product. [ 3.996430] hub 1-1:1.0: USB hub found [ 3.996478] hub 1-1:1.0: 6 ports detected [ 4.111156] EXT4-fs (md0): barriers disabled [ 4.111484] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: [ 4.119796] usb 2-1: new high-speed USB device number 2 using ehci-pci [ 4.255110] Got empty serial number. Generate serial number from product. [ 4.255121] drivers/usb/core/hub.c (2696) Same device found. Change serial to ffffffd1ffffffb2ffffffdbffffffa0 [ 4.255419] hub 2-1:1.0: USB hub found [ 4.255480] hub 2-1:1.0: 8 ports detected [ 4.540867] usb 2-1.6: new low-speed USB device number 3 using ehci-pci [ 4.642611] Got empty serial number. Generate serial number from product. [ 4.728871] usb 2-1.8: new high-speed USB device number 4 using ehci-pci [ 4.827177] usb-storage 2-1.8:1.0: USB Mass Storage device detected [ 4.827215] scsi6 : usb-storage 2-1.8:1.0 [ 5.831511] scsi 6:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 4 [ 5.832518] sd 6:0:0:0: [synoboot] 7579008 512-byte logical blocks: (3.88 GB/3.61 GiB) [ 5.833135] sd 6:0:0:0: [synoboot] Write Protect is off [ 5.833139] sd 6:0:0:0: [synoboot] Mode Sense: 23 00 00 00 [ 5.833766] sd 6:0:0:0: [synoboot] No Caching mode page found [ 5.839511] sd 6:0:0:0: [synoboot] Assuming drive cache: write through [ 5.849259] sd 6:0:0:0: [synoboot] No Caching mode page found [ 5.855009] sd 6:0:0:0: [synoboot] Assuming drive cache: write through [ 5.871423] synoboot: synoboot1 synoboot2 synoboot3 [ 5.874011] sd 6:0:0:0: [synoboot] No Caching mode page found [ 5.879765] sd 6:0:0:0: [synoboot] Assuming drive cache: write through [ 5.886297] sd 6:0:0:0: [synoboot] Attached SCSI removable disk [ 6.181736] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1 [ 6.530405] EXT4-fs (md0): re-mounted. Opts: (null) [ 7.863168] sd 1:0:0:0: Attached scsi generic sg0 type 0 [ 7.863212] sd 6:0:0:0: Attached scsi generic sg1 type 0 [ 7.948533] md1: unknown partition table [ 7.968396] Adding 2097084k swap on /dev/md1. Priority:-1 extents:1 across:2097084k [ 8.048680] zram: module is from the staging directory, the quality is unknown, you have been warned. [ 8.049288] zram: Created 4 device(s) ... [ 8.057868] Adding 2470908k swap on /dev/zram0. Priority:1 extents:1 across:2470908k SS [ 8.065453] Adding 2470908k swap on /dev/zram1. Priority:1 extents:1 across:2470908k SS [ 8.073068] Adding 2470908k swap on /dev/zram2. Priority:1 extents:1 across:2470908k SS [ 8.080610] Adding 2470908k swap on /dev/zram3. Priority:1 extents:1 across:2470908k SS [ 8.680805] NET: Registered protocol family 10 [ 8.689500] sit: IPv6 over IPv4 tunneling driver [ 8.737840] init: syno-auth-check main process (5578) killed by TERM signal [ 8.811208] ACPI: Requesting acpi_cpufreq [ 8.811472] Monitor-Mwait will be used to enter C-1 state [ 8.811479] Monitor-Mwait will be used to enter C-2 state [ 8.811486] ACPI: acpi_idle registered with cpuidle [ 9.196485] fuse init (API version 7.22) [ 9.210651] dca service started, version 1.12.1 [ 9.213969] e1000e: Intel(R) PRO/1000 Network Driver - 3.6.0-NAPI [ 9.213974] e1000e: Copyright(c) 1999 - 2019 Intel Corporation. [ 9.221690] Intel(R) Gigabit Ethernet Linux Driver - version 5.3.5.39 [ 9.221695] Copyright(c) 2007 - 2019 Intel Corporation. [ 9.439719] be2net 0000:04:00.0: irq 61 for MSI/MSI-X [ 9.439734] be2net 0000:04:00.0: irq 62 for MSI/MSI-X [ 9.439745] be2net 0000:04:00.0: irq 63 for MSI/MSI-X [ 9.439757] be2net 0000:04:00.0: irq 64 for MSI/MSI-X [ 9.439778] be2net 0000:04:00.0: enabled 4 MSI-x vector(s) [ 9.499678] be2net 0000:04:00.0: created 4 RSS queue(s) and 1 default RX queue [ 9.558709] be2net 0000:04:00.0: created 1 TX queue(s) [ 9.568317] be2net 0000:04:00.0: device doesn't support SRIOV [ 9.569602] be2net 0000:04:00.0: Emulex OneConnect: PF port 0 [ 9.710768] be2net 0000:04:00.1: irq 65 for MSI/MSI-X [ 9.710783] be2net 0000:04:00.1: irq 66 for MSI/MSI-X [ 9.710794] be2net 0000:04:00.1: irq 67 for MSI/MSI-X [ 9.710806] be2net 0000:04:00.1: irq 68 for MSI/MSI-X [ 9.710839] be2net 0000:04:00.1: enabled 4 MSI-x vector(s) [ 9.760713] be2net 0000:04:00.1: created 4 RSS queue(s) and 1 default RX queue [ 9.818848] be2net 0000:04:00.1: created 1 TX queue(s) [ 9.828457] be2net 0000:04:00.1: device doesn't support SRIOV [ 9.830564] be2net 0000:04:00.1: Emulex OneConnect: PF port 1 [ 9.834186] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.6.3 [ 9.834191] Copyright(c) 1999 - 2019 Intel Corporation. [ 9.837906] i40e: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver - version 2.4.10 [ 9.837909] i40e: Copyright(c) 2013 - 2018 Intel Corporation. [ 9.841681] tn40xx: Tehuti Network Driver, 0.3.6.17.2 [ 9.846742] tn40xx: Supported phys : MV88X3120 MV88X3310 MV88E2010 QT2025 TLK10232 AQR105 MUSTANG [ 9.859223] r8168 Gigabit Ethernet driver 8.047.04-NAPI loaded [ 9.859325] r8168 0000:06:00.0: irq 69 for MSI/MSI-X [ 9.860521] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625. [ 9.860526] r8168 Copyright (C) 2019 Realtek NIC software team <nicfae@realtek.com> This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>. This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>. [ 9.860533] r8168 Gigabit Ethernet driver 8.047.04-NAPI loaded [ 9.860600] r8168 0000:05:00.0: irq 70 for MSI/MSI-X [ 9.861702] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625. [ 9.861705] r8168 Copyright (C) 2019 Realtek NIC software team <nicfae@realtek.com> This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>. This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>. [ 9.880875] qed_init called [ 9.880878] QLogic FastLinQ 4xxxx Core Module qed 8.33.9.0 [ 9.880879] creating debugfs root node [ 9.886643] qede_init: QLogic FastLinQ 4xxxx Ethernet Driver qede 8.33.9.0 [ 9.891854] Loading modules backported from Linux version v3.18.1-0-g39ca484 [ 9.891856] Backport generated by backports.git v3.18.1-1-0-g5e9ec4c [ 9.920435] Compat-mlnx-ofed backport release: c22af88 [ 9.920438] Backport based on mlnx_ofed/mlnx-ofa_kernel-4.0.git c22af88 [ 9.920439] compat.git: mlnx_ofed/mlnx-ofa_kernel-4.0.git [ 10.242529] bnx2x: Broadcom NetXtreme II 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.78.17-0 (2013/04/11) [ 10.288516] bio: create slab <bio-1> at 1 [ 10.288656] Btrfs loaded [ 10.293527] exFAT: Version 1.2.9 [ 10.325576] jme: JMicron JMC2XX ethernet driver version 1.0.8 [ 10.332221] sky2: driver version 1.30 [ 10.339643] pch_gbe: EG20T PCH Gigabit Ethernet Driver - version 1.01 [ 10.347247] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.2.42 [ 10.354416] QLogic/NetXen Network Driver v4.0.80 [ 10.358431] Solarflare NET driver v3.2 [ 10.362329] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI [ 10.362334] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 10.365871] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de [ 10.369571] VMware vmxnet3 virtual NIC driver - version 1.1.30.0-k-NAPI [ 10.384276] igbvf: Intel(R) Gigabit Virtual Function Driver - 2.3.8.2 [ 10.384281] igbvf: Copyright (c) 1999-2015 Intel Corporation. [ 10.389883] ixgbevf: Intel(R) 10GbE PCI Express Virtual Function Driver - version 4.6.1 [ 10.389888] Copyright(c) 1999 - 2019 Intel Corporation. [ 10.414217] usbcore: registered new interface driver ax88179_178a [ 10.417388] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0 [ 10.417396] ACPI: Power Button [PWRB] [ 10.417514] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1 [ 10.417521] ACPI: Power Button [PWRF] [ 10.429327] Atheros(R) L2 Ethernet Driver - version 2.2.3 [ 10.429332] Copyright (c) 2007 Atheros Corporation. [ 10.433177] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI [ 10.433182] e100: Copyright(c) 1999-2006 Intel Corporation [ 10.438754] ixgb: Intel(R) PRO/10GbE Network Driver - version 1.0.135-k2-NAPI [ 10.438759] ixgb: Copyright (c) 1999-2008 Intel Corporation. [ 10.462456] Brocade 10G Ethernet driver - version: 3.1.2.1 [ 10.466326] vxge: Copyright(c) 2002-2010 Exar Corp. [ 10.466331] vxge: Driver version: 2.5.3.22640-k [ 10.470362] usbcore: registered new interface driver aqc111 [ 10.474111] usbcore: registered new interface driver asix [ 10.477626] usbcore: registered new interface driver cx82310_eth [ 10.480893] et131x: module is from the staging directory, the quality is unknown, you have been warned. [ 10.486201] i40evf: Intel(R) 40-10 Gigabit Virtual Function Network Driver - version 3.6.15 [ 10.486203] Copyright(c) 2013 - 2018 Intel Corporation. [ 10.489961] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 10.493634] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 10.493795] usbcore: registered new interface driver pegasus [ 10.497538] usbcore: registered new interface driver plusb [ 10.501586] usbcore: registered new interface driver r8152 [ 10.505312] usbcore: registered new interface driver rtl8150 [ 10.550097] 2020-8-9 12:57:59 UTC [ 10.550100] synobios: load, major number 201 [ 10.550103] Brand: Synology [ 10.550105] Model: DS-3617xs [ 10.550106] set group disks wakeup number to 4, spinup time deno 7 [ 10.550109] synobios cpu_arch proc entry initialized [ 10.550110] synobios crypto_hw proc entry initialized [ 10.550112] synobios syno_platform proc entry initialized [ 10.550118] synobios open /dev/ttyS1 success [ 10.681672] systemd-udevd[6866]: starting version 204 [ 12.588398] init: dhcp-client (eth0) main process (9238) killed by TERM signal [ 13.561843] eth2: 0xffffc9000758c000, 00:11:32:a1:23:6b, IRQ 70 [ 13.633174] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready [ 13.645160] init: dhcp-client (eth1) main process (9681) killed by TERM signal [ 14.657219] eth3: 0xffffc9000758a000, 00:11:32:a1:23:6c, IRQ 69 [ 14.728742] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready [ 15.910192] md: md2 stopped. [ 15.910850] md: bind<sdb3> [ 15.911425] md/raid1:md2: active with 1 out of 1 mirrors [ 15.912000] md2: detected capacity change from 0 to 475166212096 [ 15.912170] md2: unknown partition table [ 16.227170] BTRFS: device label 2020.06.30-18:59:28 v25426 devid 1 transid 1029 /dev/md2 [ 16.227736] BTRFS info (device md2): enabling auto syno reclaim space [ 16.227742] BTRFS info (device md2): use ssd allocation scheme [ 16.227743] BTRFS info (device md2): using free space tree [ 16.227744] BTRFS: has skinny extents [ 16.658400] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_init RODSP server started, login_key(001132a12369). [ 16.666768] iSCSI:extent_pool.c:766:ep_init syno_extent_pool successfully initialized [ 16.681496] iSCSI:target_core_device.c:617:se_dev_align_max_sectors Rounding down aligned max_sectors from 4294967295 to 4294967288 [ 16.681621] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully [ 16.685624] usbcore: registered new interface driver usblp [ 16.699711] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plugin for fileio is enabled. [ 16.699716] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled. [ 16.699728] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled. [ 16.699734] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled. [ 16.699735] iSCSI:target_core_ep.c:793:ep_attach_hba ODX Token Manager is enabled. [ 16.704818] usbcore: registered new interface driver usbhid [ 16.704821] usbhid: USB HID core driver [ 16.709555] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/input/input2 [ 16.709622] hid-generic 0003:046D:C31D.0001: input: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1d.0-1.6/input0 [ 16.711286] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.1/input/input3 [ 16.711328] Get empty minor:104 [ 16.711366] hid-generic 0003:046D:C31D.0002: input,hiddev0: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1d.0-1.6/input1 [ 16.998872] FAT-fs (synoboot2): fat_set_state: set=1 process=synopkicompatsy pid=12333 [ 17.005258] FAT-fs (synoboot2): fat_set_state: set=0 process=synopkicompatsy pid=12333 [ 17.355707] warning: `nginx' uses 32-bit capabilities (legacy support in use) [ 17.923045] loop: module loaded [ 19.098004] ata2.00: configured for UDMA/133 [ 19.098012] ata2: EH complete [ 22.903418] init: dhcp-client (eth0) main process (9515) killed by TERM signal [ 23.057253] init: synoscheduler-vmtouch main process (5000) killed by TERM signal [ 25.235191] init: scsi_plugin_server main process (11936) killed by TERM signal [ 25.286049] init: nmbd main process (14705) killed by TERM signal [ 28.275056] init: scsi_plugin_server main process (14677) killed by TERM signal [ 49.149356] init: scsi_plugin_server main process (15821) killed by TERM signal [ 49.256365] init: nmbd main process (17385) killed by TERM signal [ 49.354429] init: iscsi_pluginserverd main process (17333) killed by TERM signal [ 49.355412] init: iscsi_pluginengined main process (17329) killed by TERM signal [ 49.367997] init: scsi_plugin_server main process (17337) killed by TERM signal [ 74.971752] init: smbd main process (12971) killed by TERM signal [ 81.030640] init: synoscheduler-vmtouch main process (13775) killed by TERM signal Quote Link to comment Share on other sites More sharing options...
IG-88 Posted August 9, 2020 Author Share #447 Posted August 9, 2020 (edited) looks normal now, as 6 ports and then nothing in the way, when adding the 16 port controller it should now end up as port 7-22 Edited August 9, 2020 by IG-88 Quote Link to comment Share on other sites More sharing options...
-iliya- Posted August 9, 2020 Share #448 Posted August 9, 2020 (edited) 41 минуту назад, IG-88 сказал: looks normal now, as 6 ports and then nothing in the way, when adding the 16 port controller it should now end up as port 7-22 yes, all 16 disk is show i edit synoinfo.conf maxdisks="24" esataportcfg="ff00000000" usbportcfg="ff000000" internalportcfg="ffffff" Скрытый текст how to write this into jun.patch or grub.conf ? so that after the update they are not dumped in synoinfo Edited August 9, 2020 by -iliya- Quote Link to comment Share on other sites More sharing options...
IG-88 Posted August 9, 2020 Author Share #449 Posted August 9, 2020 (edited) there something in the tutorial section but beside editing jun.patch and synoinfo_override.conf you need to repack the extra/extra2 https://xpenology.com/forum/topic/14358-tutorial-modifying-104b-loader-to-default-to-24-drives/ imho its incomplete that way but when it works for some people ... one things that i would do more/different for my extra/extra2 usbportcfg needs to be changed too when going to 24 instead of 16 and thats something that needs to be added to jun's patch instead of just change something that is already there the original value looks like this usbportcfg="0x30000" the four zeros are equivalent to 16 so it goes well with jun's patch but when going to 24 the usb ports need to be shifted to above 24 to prevent overlapping with the internal ports so to be correct for 24 internal disks it should be this usbportcfg="0x3000000" or maybe make it 8 usb ports (just two as synologys original is a little low for normal systems) usbportcfg="0xff000000" Edited August 9, 2020 by IG-88 1 Quote Link to comment Share on other sites More sharing options...
-iliya- Posted August 9, 2020 Share #450 Posted August 9, 2020 6 часов назад, IG-88 сказал: imho Adaptec is work a strange - don't show disk serial and firmware, Info and SMART don't work - error i try set 1 hdd as HOT Spare - error. which controller is better for syno for 16 drives ? Quote Link to comment Share on other sites More sharing options...
