ed_co Posted April 11 Share #1026 Posted April 11 (edited) On 12/8/2022 at 10:52 PM, IG-88 said: i can't say much about the asm1166, used mine just for testing a little, as i had the jmb585 earlier, it was working fine and i only use 4 of the 5 ports so had no need for 6 ports i've not seen any negative comments about asm1166 and also seen people here using it https://xpenology.com/forum/topic/65408-automated-redpill-loader-arpl/?do=findComment&comment=382342 considering this https://xpenology.com/forum/topic/63475-dsm-7-proxmox-hdd-hibernation-issue/?do=findComment&comment=303430 the asm1166 might be a better choice with synology's kernel as they did not have a special fix in there kernel as it seems to be the case for jmb585 but i never looked into the kernel code belonging to this, might be something unimportant for normal use my two jmb585 run fine for over 2 years now So with your 0.13.9 driver extension for 918+ for Jun's loader 6.2, will work the m.2 sata x6 asm166 controller or the m.2 x5 jmb585 controller?? Need to buy one asap. If both are compatible, any preferences for any of them? Thanks Edited April 11 by ed_co Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 11 Author Share #1027 Posted April 11 On 4/9/2024 at 8:32 PM, ed_co said: Are there any Driver extension jun 1.04b for DSM6.2.3 for 918+? in the 1st post of this thread are links, also for 918+ and one of the links is still working On 4/9/2024 at 8:32 PM, ed_co said: My new hardware is: h610m-itx/ac motheboard (NIC is i219V) with a i3 12100 processor (UHD 730) Link to my question thread: as it has i219 (intel e1000e driver) and i211 (intel igb driver) at least one should work (if you really want to torture yourself with that old 6.2.3 stuff) 1 hour ago, ed_co said: So with your 0.13.9 driver extension for 918+ for Jun's loader 6.2, will work the m.2 sata x6 asm166 controller or the m.2 x5 jmb585 controller? asm1166 and jmb585 are both ahci compatible and will work even without anx eytra drivers as the ahci support is a fixed part in synologys kernel (that is always used with jun's or newer loaders) i'd suggest using a newer loader like arc, support dsm 7.1 (lts) oder 7.2, plenty of drivers and loads of fixes to special conditions arc gets a lot of effort and is well maintained https://github.com/AuxXxilium/AuxXxilium/wiki Quote Link to comment Share on other sites More sharing options...
ed_co Posted April 11 Share #1028 Posted April 11 2 hours ago, IG-88 said: as it has i219 (intel e1000e driver) and i211 (intel igb driver) at least one should work (if you really want to torture yourself with that old 6.2.3 stuff) Haven't mentioned the i211, which is not present in my current motherboard (h610m-itx/ac) 2 hours ago, IG-88 said: i'd suggest using a newer loader like arc, support dsm 7.1 (lts) oder 7.2, plenty of drivers and loads of fixes to special conditions arc gets a lot of effort and is well maintained https://github.com/AuxXxilium/AuxXxilium/wiki Now there are lots of loaders, and it looks like lately ARC is the one that is getting traction (more than ARPL or TCRP). Although not sure if is better or worse. But even ARC has variations like ARC-A, which I am not sure what of them to get. My only worry with the new loaders is having to create another loader every time you have to update to a new version, or you will not be able to load DSM anymore. Which I never saw how this is done and how complex it is. I loved with Jun's loader, you could update any update from the DSM control panel with no problem. Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 12 Author Share #1029 Posted April 12 23 hours ago, ed_co said: I loved with Jun's loader, you could update any update from the DSM control panel with no problem. you just forgot about the fun we had as its quiet some time since you updated your 6.2.3 6.2.2 with its different pcie kernel options or 6.2.3-25xxx (and all after that up to 6.2.4) just to name a few arc-a and arc-c are about a fixed dsm type like RS4021xs+ and SA6400, more automated and arc-c even has a custom kernel option to have more cpu cores usable (also its the one dsm x64 version that has kernel 5.x) just try the normal arc (and read about the limitations and special things of models in his wiki, https://github.com/AuxXxilium/AuxXxilium/wiki/Arc:-Choose-a-Model-|-Platform) but if you want to use 6.2. and jun's laoder just try it. disks should be no problem with ahci controllers, if the last extra gets you nic working then it should be fine you should never expose such old unpatched system directly to the internet as 6.2.3 has a lot of security fixes missing by now Quote Link to comment Share on other sites More sharing options...
ed_co Posted April 12 Share #1030 Posted April 12 @IG-88 or anyone else. Small stupid question about ARC: does it support more than 4 disks with DS918+ model? I hope not, I have 16 disks in Jun's DS918+ Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 13 Author Share #1031 Posted April 13 11 hours ago, ed_co said: ARC: does it support more than 4 disks with DS918+ model? I hope not, I have 16 disks in Jun's DS918+ i use arpl with a dva1622 and 6 disks (original has 2) and arc with 3622 and 13 disks (original 12), no problems, in the graphics you see a box with the original amount of slots but in using there is just the "normal" and old 26 disk limit, you will see all disks in HDD/SSD listing of disks you might want to change from 918+ to something newer as 918+ might loose its support and might not get updates as long as newer models (the guarantee is about 5 years, anything above that depends) depending on the features you need (like intel quick sync video) there might be some limits of models you can choose in the loader there is also a model specific cpu thread limit in the kernel but as you use a low spec cpu for you new system that wont be much of a problem, only thing with new er intel cpu's might be that the old 4.x kernel in its original form does not support 12th gen intel qsv and it depends on the loader how far that support is working as it needs extra drivers from the loader, so you might need to read up on that in the loaders doku or here in the forum (i use a older intel cpu with the dva1622 that is working with syno's original i915 driver so i'm not that much up to knowing whats the best solution now, dva1622 comes with a nice feature set ootb when the i915 supports the cpu but there was also some interesting stuff going on with sa6400 and its 5.0 kernel with i915 extended drives, initially here https://github.com/jim3ma but i guess some of it might have found its way to other loaders by now) in genral it does nor matter if the original unit has a amd or intel cpu for just the basic NAS stuff, only when using KVM based VMM from synology or specific things like intel qsv it becomes important (as kernels per from synology are tailored for cpu's to some degree and the most obvious is the thread limit) i'd suggest to use a different usb thumb drive and a single empty disk (maybe two to connect to the last sata port to see how far it gets) to do some tests (you can keep the original usb and he disks you use now offline (just disconnect the disks), play with the loaders model until you find your sweet spot and then use that configured loader to upgrade to the new model and dsm version (7.1 is still fine and as its a LTS version it will get updates at least as long as 7.2)m when creating a system from scratch with empty disks the partitions layout for system and swap will be different with 7.1/7.2 but upgrading from 6.2 and keeping the older smaller partitions is supported by synology so there is no real need to start from scatch for 7.x https://kb.synology.com/en-global/DSM/tutorial/What_kind_of_CPU_does_my_NAS_have 1 Quote Link to comment Share on other sites More sharing options...
ed_co Posted April 14 Share #1032 Posted April 14 @IG-88I was thinking installing ark doing something like this: Although not sure how possible it is... If I could do this changing and then when I port it to dsm 7.2.1 maybe changing to a different model (like from dsm-918+ to sa6400) could be easier? Quote Link to comment Share on other sites More sharing options...
ed_co Posted April 16 Share #1033 Posted April 16 On 4/13/2024 at 12:45 PM, IG-88 said: ...but as you use a low spec cpu for you new system that wont be much of a problem... BTW, I just changed from the i3 12100 to an i5 12400 6 cores/12 threads I guess, I don't need too much more for my needs Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 18 Author Share #1034 Posted April 18 On 4/16/2024 at 3:09 AM, ed_co said: BTW, I just changed from the i3 12100 to an i5 12400 6 cores/12 threads might add some addition thinking about the 8 thread limit in 918/920 6/12 usually relutis in half real core and half HT virtual cores and as as HT "virtual" core has about 25% of a real core, what you get in a 8 thread limit scenario is the performance of ~5 cores (4 x real 4 x 25% of a real core) disabling HT in bis will 6 core performance so without a different model having a higher thread limit baked into the kernel you will see no gain of the better cpu and often these models dont have intel quick sync support (i915 driver) dva1622 also has a 8 thread limit, not sure arc loader as sa6400 has i915 driver, usually i915 cant be easily added by just compiling some modules for the kernel as the most synology kernel miss the part the needs to be in the kernel to load i915 as module arc seems to have i915 drivers for sa6400 so i guess you might be able to use arc as sa6400 wit your cpu if you dont need intel qsv the there are a lot option for the model, and 3622 is most common as it the successor of 3615/3617 On 4/14/2024 at 6:15 AM, ed_co said: was thinking installing ark doing something like this: On 4/14/2024 at 6:15 AM, ed_co said: Although not sure how possible it is... If I could do this changing and then when I port it to dsm 7.2.1 maybe changing to a different model cant say much about this as i never done it that way (i use syno's migration assistant as i had a old and new system parallel), i dont think 6.2.4 would be needed, most people here did 6.2.3 to 7.0 or even 7.1 or 7.2, 6.2.4 never was atractiv in any way as it already neede redpill loader to work and most people wanting to risk some new loader woul have used 7.0 as it offered some new stuff for the risk of using a new loader the update report section is a source of information for that this entry is 6.2.3 to 7.2.1 https://xpenology.com/forum/topic/69680-dsm-721-69057/?do=findComment&comment=451137 Quote Link to comment Share on other sites More sharing options...
ed_co Posted April 24 Share #1035 Posted April 24 (edited) On 4/18/2024 at 10:39 PM, IG-88 said: this entry is 6.2.3 to 7.2.1 https://xpenology.com/forum/topic/69680-dsm-721-69057/?do=findComment&comment=451137 Unfortunatelly is not a guide and is using ARPL, not Arc On 4/18/2024 at 10:39 PM, IG-88 said: if you dont need intel qsv the there are a lot option for the model, and 3622 is most common as it the successor of 3615/3617 Ideally I woud like to have the intel qsv, and sa6400 should have it, right? On 4/13/2024 at 12:45 PM, IG-88 said: i use arpl with a dva1622 Why you chosing this model? @IG-88 Couple of more questions: - Very important! I guess you used all the loaders out there, what is the best for you: TCRP (looks like you don't use this one currently, why?), ARPL, Arc? - And last question, what is the procedure to update a new version of DSM with Arc in major DSM versions? Is more complicated in TCRP/ARPL? Thanks for the reply!! Edited April 24 by ed_co Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 24 Author Share #1036 Posted April 24 17 hours ago, ed_co said: nfortunatelly is not a guide and is using ARPL, not Arc its about dsm being able to "convert" its settings from a aolder ds, version to a more recent one without additional steps (recommanded by synology) the loader is not much involved here as long as it can make dsm run (redpill kernl module on all loaders we unse 6.2.4 an any 7.x) as long as the loader has anough drivers to support the hardware in question ... (ahci sata is part of syno's kernel so any ahci compatible controller will work, so in most cases its about network driver support) 17 hours ago, ed_co said: Ideally I woud like to have the intel qsv, and sa6400 should have it, right? as far as i have seen yes, but i use dva1622 for now (as sa6400 pretty new), sa6400 might have better intel qsv support as its kernel 5.x based and its i915 driver support newer hardware ootb then what comes with kernel 4.x try arc or arc-c for sa6400 https://github.com/AuxXxilium/AuxXxilium/wiki/Arc:-Choose-a-Model-|-Platform#epyc7002---dt only downside might be not beeing able to use VMM with intel cpu (i guess that, not testes it myself and might never do that as if i need really might vm's to run i would choose a "real hypervisor" system like proxmox (esxi by now sees to be out of the race because of broadcom ditching the free version) 17 hours ago, ed_co said: On 4/13/2024 at 12:45 PM, IG-88 said: i use arpl with a dva1622 Why you chosing this model? more free survailance cam's by default, native intel qsv build in by synology as the system in it original is using gemini lake (with the right cpu that is supported ootb its also easy to use jellyfin or plex, , "AI" stuff ootb in survailance station in the end i do not use any of that, still options i "could" use (lucky me i had not have to spend all the mony synology asks for a real 1622), but with the loaders you can switch models any time and and dsm will be able to convert everything (usually) as all is x64 based (some specifics about sas hba's or cpu dependent features like intel qsv and amd vmm support) arpl is on hold for at least a year (and might never come back), arc is good supported,lots of features and easy to use as its menu based (and the wiki is helpful too - people should use it more often), it might get confusing with all the options but there is the wiki, youtube, this forum and discord ... 17 hours ago, ed_co said: - And last question, what is the procedure to update a new version of DSM with Arc in major DSM versions? Is more complicated in TCRP/ARPL? nothing different in result, as long as the loader is configured the right way (model) you will not see much difference as dsm is doing your jobs and somem things like care for some special problems might not be different between maintained loaders as its open source and new knowledge about how to fix quirks are shared and might find there way in your specific loader overtime (but in most cases you find the loader that work now for you and you look for new stuff 2 years after the or even later) Quote Link to comment Share on other sites More sharing options...
ed_co Posted April 25 Share #1037 Posted April 25 3 hours ago, IG-88 said: but with the loaders you can switch models any time and and dsm will be able to convert everything (usually) as all is x64 based That's very interesting. So change the model is doable, but has to be DSM converted, you mean like from 6.2.3 to 7.X.X? This is because every DSM is always a different OS depending on the hardware and is not a common OS for all, right? If so, it is a pity there is no project trying to unify all the DSM OS's and create just one to be compatible with all the hardware at the same time, and is just matter of installing, and no loader needed anymore... could be somewhat doable? Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 25 Author Share #1038 Posted April 25 19 hours ago, ed_co said: you mean like from 6.2.3 to 7.X.X? This is because every DSM is always a different OS depending on the hardware and is not a common OS for all, right? no, all the dsm is the same and are just complied with different kernel options and different settings from syno's config files (a little simplified) the kernel in x64 based units comes with different settings but will run anyway even if a amd based unit like sa6400 is used with a intel cpu, its not that much different 20 hours ago, ed_co said: If so, it is a pity there is no project trying to unify all the DSM OS's and create just one to be compatible with all the hardware at the same time, and is just matter of installing, and no loader needed anymore... could be somewhat doable? the loaders pretty much do exactly that, synology intends to make model based dsm version just run on that hardare, the loader is circumventing that by "emulating" or spoofing that hardware and making it run on any hardware you have, for more or less most x64 based models (does not make much sense to have 2 slot based unit supported when there s a bigger one with the same hardware and features) as for changing models ist pertty much all you can see in the loader you can chenge from one to another, its even a "offical" synology dsm feature and you will find lists of hardware you can migrate to from one to another, luse case ist like your 918+ out of support of support you the hardware is dead and you buy a new or bigger unit like ds923+ you can just insert the disks of you old unit ito the new hardware an the loader in that unit (usb dom) will recognise the old different system on the disk and the installtion (config files) will be converted tio the new dsm installtion that will end on the disks when "migrating" to the new hardware, thats called drive or hdd migration" https://kb.synology.com/en-global/DSM/tutorial/How_to_migrate_between_Synology_NAS_DSM_6_0_HDD Quote Link to comment Share on other sites More sharing options...
Elvis1 Posted Thursday at 10:29 AM Share #1039 Posted Thursday at 10:29 AM Hello, I have a quick Question. Does anybody have this driver for the ds6515? Unfortunately, the downloads from these two hosters are no longer available. On 4/20/2020 at 2:56 AM, IG-88 said: extra.lzma for loader 1.03b ds3615 DSM 6.2.3 v0.12.1_test, added virtio/9p, CDROM drivers, nic Killer E2500 lhttps://pixeldrain.com/u/Rx4tV6ay https://gofile.io/d/RnX1QA SHA256: E72820BF648CFD7F6075DEEB1208A3E0D8A61F38289AE17AC7E355910B9B0E0E Quote Link to comment Share on other sites More sharing options...
Elvis1 Posted Sunday at 08:42 AM Share #1040 Posted Sunday at 08:42 AM On 5/9/2024 at 12:29 PM, Elvis1 said: Hello, I have a quick Question. Does anybody have this driver for the ds6515? Unfortunately, the downloads from these two hosters are no longer available. Maybe I'm blind but I don't see a way to edit my post right now? So sorry for my double post. I meant of course for the ds3615! Does anyone else have this driver or can someone renew the links for it, that would be very nice. Thx Quote Link to comment Share on other sites More sharing options...
IG-88 Posted Sunday at 10:50 AM Author Share #1041 Posted Sunday at 10:50 AM 2 hours ago, Elvis1 said: I meant of course for the ds3615! Does anyone else have this driver or can someone renew the links for it, that would be very nice. check the links in the 1st post 1st 3615 was still working (test to read as link) but some one had replaced it with a zippyshare that was expired already, i reinserted the link as the text was (pixeldrain link) 2nd 3615 was still working (at least the pixeldrain) i removed all non working link and checked the one already there 1 Quote Link to comment Share on other sites More sharing options...
Elvis1 Posted Sunday at 03:42 PM Share #1042 Posted Sunday at 03:42 PM Thank you very much. Everything is working again. Thank you for your time i really appreciate it Quote Link to comment Share on other sites More sharing options...
