NoX Posted June 4, 2014 Share #1 Posted June 4, 2014 Hi, Synology is going to release a new version : http://ukdl.synology.com/download/DSM/5.0/4493/ No changelog for now. EDIT : Found changelog. Change Log After updating to this version, DSM will run data scrubbing on RAID 5 volumes and disk groups that were created in DSM 4.1 or earlier versions to improve the stability of RAID 5 volumes. Fixed a security issue in the system kernel. (CVE-2014-0196). Fixed an issue where all web pages could display "No input file specified" when the value of "Customize PHP open_basedir" was set to “none” or empty. Enhanced the stability of iSCSI target service. Quote Link to comment Share on other sites More sharing options...
Poechi Posted June 4, 2014 Share #2 Posted June 4, 2014 (edited) - Edited July 10, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
Schnapps Posted June 4, 2014 Share #3 Posted June 4, 2014 meh, not really important... Quote Link to comment Share on other sites More sharing options...
chrishunter01 Posted June 4, 2014 Share #4 Posted June 4, 2014 NanoBoot 5.0.2.4 works on this latest pat file.... i just tested it. ... press tab after booting NanoBoot then edit pat version... have not tried migrating from 4482 to 4493 tho, to see whether existing files gets affected. will try it out then report afterwards. Quote Link to comment Share on other sites More sharing options...
squallelf Posted June 4, 2014 Share #5 Posted June 4, 2014 wow... seems nanoboot could simulate the real syno device and fool around the syno firmware... Quote Link to comment Share on other sites More sharing options...
Poechi Posted June 4, 2014 Share #6 Posted June 4, 2014 (edited) - Edited July 10, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
chrishunter01 Posted June 4, 2014 Share #7 Posted June 4, 2014 NanoBoot 5.0.2.4 works on this latest pat file.... i just tested it. ... press tab after booting NanoBoot then edit pat version... have not tried migrating from 4482 to 4493 tho, to see whether existing files gets affected. will try it out then report afterwards. Just did an upgrade from 4482 to 4493 and works. Will make some adjusted bootimages. That was fast,.. then i can upgrade now my other machine with data in it. thanks Bro! Quote Link to comment Share on other sites More sharing options...
chung0816 Posted June 4, 2014 Share #8 Posted June 4, 2014 NanoBoot 5.0.2.4 works on this latest pat file.... i just tested it. ... press tab after booting NanoBoot then edit pat version... have not tried migrating from 4482 to 4493 tho, to see whether existing files gets affected. will try it out then report afterwards. Just did an upgrade from 4482 to 4493 and works. Will make some adjusted bootimages. Could you mind to tell me how to adjust the boot images ? 從我的 用 iPad 發送 Quote Link to comment Share on other sites More sharing options...
chung0816 Posted June 4, 2014 Share #9 Posted June 4, 2014 NanoBoot 5.0.2.4 works on this latest pat file.... i just tested it. ... press tab after booting NanoBoot then edit pat version... have not tried migrating from 4482 to 4493 tho, to see whether existing files gets affected. will try it out then report afterwards. Just did an upgrade from 4482 to 4493 and works. Will make some adjusted bootimages. Could you mind to tell me how to adjust the boot images ? 從我的 用 iPad 發送 Quote Link to comment Share on other sites More sharing options...
Poechi Posted June 4, 2014 Share #10 Posted June 4, 2014 (edited) - Edited July 10, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
chung0816 Posted June 4, 2014 Share #11 Posted June 4, 2014 I've created new boot images in different formats for DSM 5.0-4493: .iso .img .vmdk Go to http://www.xpenology.nl/boot-images. Thx your advice, I found how to modify the boot image, thanks so much! 從我的 用 iPad 發送 Quote Link to comment Share on other sites More sharing options...
Trexx Posted June 4, 2014 Share #12 Posted June 4, 2014 Any issues with updating with 5.0.2.2 Nanoboot? I believe it is basically the same as 5.0.2.4 other than some drivers Quote Link to comment Share on other sites More sharing options...
Poechi Posted June 4, 2014 Share #13 Posted June 4, 2014 (edited) - Edited July 10, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
fantomel Posted June 4, 2014 Share #14 Posted June 4, 2014 migrated from 4082 nanoboot to 4493 with esxi image without problems Quote Link to comment Share on other sites More sharing options...
Poechi Posted June 4, 2014 Share #15 Posted June 4, 2014 (edited) - Edited July 10, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
Spooky1 Posted June 4, 2014 Share #16 Posted June 4, 2014 I've created new boot images in different formats for DSM 5.0-4493: .iso .img .vmdk Go to http://www.xpenology.nl/boot-images. Thx, work great ! Quote Link to comment Share on other sites More sharing options...
cstout Posted June 4, 2014 Share #17 Posted June 4, 2014 I am eager to try this upgrade for my off-site box. Would someone please tell me if I have the upgrade process correct? -Download the latest "NB_x64_5024_DSM_50-4493_Xpenology_nl.iso" and block copy it over to a usb drive. -Boot up the new drive and choose update option? -Open web browser (or use Synology Assistant?) and upload the new 4493 firmware? -Use clean install instead of upgrade Am I close? My Xpenology box is one that went from Trantor's to Gnoboot's and now I'm excited to try Nanoboot. Quote Link to comment Share on other sites More sharing options...
XPEH Posted June 4, 2014 Share #18 Posted June 4, 2014 I am eager to try this upgrade for my off-site box. Would someone please tell me if I have the upgrade process correct? -Download the latest "NB_x64_5024_DSM_50-4493_Xpenology_nl.iso" and block copy it over to a usb drive. -Boot up the new drive and choose update option? You need to use .img for USB, not .iso -Open web browser (or use Synology Assistant?) and upload the new 4493 firmware? -Use clean install instead of upgrade Am I close? My Xpenology box is one that went from Trantor's to Gnoboot's and now I'm excited to try Nanoboot. Quote Link to comment Share on other sites More sharing options...
cstout Posted June 4, 2014 Share #19 Posted June 4, 2014 @XPEH, thank you. I didn't even catch that I downloaded the wrong files. Long day. Thanks. Quote Link to comment Share on other sites More sharing options...
Trexx Posted June 4, 2014 Share #20 Posted June 4, 2014 Any issues with updating with 5.0.2.2 Nanoboot? I believe it is basically the same as 5.0.2.4 other than some drivers Shoudn't be a problem. I am assuming you are referring to leveraging the DSM upgrade function in the gui. Quote Link to comment Share on other sites More sharing options...
zeekworld Posted June 5, 2014 Share #21 Posted June 5, 2014 I have a question. I am running Nanoboot-5.0.2.4 DSM 5.0-4482 X64 on my VM esxi and would like to upgrade to the latest 4493. I have downloaded the new images Nanoboot 4493. What are the steps to perform the upgrade without loosing all my config and files? Thanks Quote Link to comment Share on other sites More sharing options...
chanquete69 Posted June 5, 2014 Share #22 Posted June 5, 2014 One question for the one that have upgraded. I've used your image and could upgrade my N54L to the 4493 version. No data nor configuration lost. But if I open Synology Assistant again, I see my XPenology as "Not configured"! Is that appearing to you too? With older versions I can see my XPenology as "Ready". I can use it normally, access my apps, shares, etc. Quote Link to comment Share on other sites More sharing options...
yabba235 Posted June 5, 2014 Share #23 Posted June 5, 2014 Hi ! Can anybody trying upgrade from 4482 to 4493 from gnoboot 10.5 ? Unfortunally on my system ( Readynas Pro 2 ) nanoboot don't work Reg. Quote Link to comment Share on other sites More sharing options...
Poechi Posted June 5, 2014 Share #24 Posted June 5, 2014 (edited) - Edited July 10, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
Poechi Posted June 5, 2014 Share #25 Posted June 5, 2014 (edited) - Edited July 10, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
