DSM Loader - Confirmed working Hardware
Re: DSM Loader - Confirmed working Hardware
Postby holybabel » 13 Nov 2016 17:41
Intel SS4200 HomeServer , Intel ICH7R SATA controller, Intel C2D E4500, 2GB RAM - SHR Raid with 3x2TB WD Green
Updated from 5.2 with Jun's Baremetal V 1.01 + DSM 6.0.2-8451 Update 3
Till now everything works fine.
holybabel
Postby Polanskiman » 14 Nov 2016 01:55
F5BJR wrote:
Polanskiman wrote:See my signature.
Confirm that the WLAN is running
There is no need to confirm. Most internal WLAN won't work in DSM and there is nothing new about it since Synology does not include internal wireless cards in their machines. Even under 5.2 Trantor refused to compile WLAN drivers.
An internal WLAN NIC is not expected to work in DSM and I do not consider its lack of functionality as an abnormality.
Those who wish to compile internal WLAN drivers can do so if they really need internal WLAN to work.
Forum Moderator
MB: Gigabyte H97N-WIFI (rev. 1.0) CPU: Intel G3220 PSU: Seasonic Platinum-860 HDD: WD RED 2 x 2TB RAM: 16GB
BOOT USB: SanDisk Ultra Fit 16GB LOADER: Jun's v1.01 loader DSM: DSM 6.0.2-8451 Update 9 HOWTO: Tutorial DSM 6.0
User avatar
Polanskiman
Postby F5BJR » 14 Nov 2016 03:13
An internal WLAN NIC is not expected to work in DSM and I do not consider its lack on functionality as an abnormality.
Hum : Even under 5.2 Trantor refused to compile WLAN drivers.
F5BJR
Postby Polanskiman » 14 Nov 2016 04:00
F5BJR wrote:
Polanskiman wrote:
F5BJR wrote:Confirm that the WLAN is running
You might as well read by yourself >>> viewtopic.php?f=2&t=1361#p6528. I've copied/pasted it below for you convenience:
Trantor wrote:This thread is for requesting drivers for hardware (net, storage) which are not supported by XPEnology yet.
The purpose of this it to regroup drivers request in order to improve XPEnology in the next repack.
Please test with the latest build and check HARDWARE SUPPORTED LIST before asking for driver !
Please do not request WIFI drivers
Please give most informations as you can (brand, chip, revision...).
If you can test your hardware with ubuntu livecd to get modules infos and/or give manufacturer download link.
If he ultimately decided to compile WLAN drivers then good for those who benefited from it. The basic logic concept still stands though and you might well try to understand it. Internal WLAN NICs are not part of Synology's hardware features.
Forum Moderator
User avatar
Polanskiman
Postby F5BJR » 14 Nov 2016 09:51
Hum: Even under 5.2 Trantor refused to compile WLAN drivers.
But others could do it on the condition of finding the right information
So who can tell us how to compile a driver ?
I have consulted the developer-guide.pdf which, say, indicates how ... but that is badly conceived and even false:
The first command to do is to prepare the installation of the Toolkit (page 9) not work
mkdir -p toolkit
git clone {{book.external ... ... (already an error)
It starts well !!!
In addition nothing says that you need to install chroot and probably lots of other things before you start anything (it looks like you have to know everything before)
So where do we find accurate, detailed documentation that makes it possible to compile something and this using the DiskStation itself ?
Is this a open secret that story?
F5BJR
Postby JMRR » 14 Nov 2016 10:53
You could call synology and ask them. Thy are the only ones who has all knowlage!
JMRR
Postby F5BJR » 14 Nov 2016 12:06
JMRR wrote:You could call synology and ask them. Thy are the only ones who has all knowlage!
Sorry, I cannot contact support because i have no product with DSM 6 and no serial number ...
F5BJR
Postby vrx » 15 Nov 2016 09:51
Asrock Q1900ITX and Jun's V1.01 working
vrx
Postby tamamma » 17 Feb 2017 07:37
What about Cores? How many cores are used? Does support PLEX transcoding?
Tnx
hotshots wrote:MB: ASRock N3700
RAM: Kingston ValueRAM DDR3L-1600 SO-DIMM CL11 Single 4GB
HDD: 4xWD Red WD60EFRX (SHR)
Jun's Baremetal V 1.01 + DSM 6.0.2-8451 Update 2
Issues:
CPU Frequeny locked to 1.6 GHz
Thermal-Status always 40°C
(I guess right I/O driver is missing)
tamamma
Previous
x
