martymoose Posted July 30, 2023 Share #976 Posted July 30, 2023 9 hours ago, Lestat said: I belive that is how my bios is set up but will double check when I get home And will try the direct boot Thanks I had no luck with the ds3615 and the others only luck I had had ds918+ which now I have now toasted found it ran very slow Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 30, 2023 Share #977 Posted July 30, 2023 16 hours ago, Peter Suh said: ARPL also has a function corresponding to TCRP JOT. Remember “Boot direct”. Try this first. A sata boot instead of usb won't do you any favors either. I don't know why, but there is a high probability of encountering a bug that unconditionally crashes the mount. I Cant see the option in your picture there is no advanced option or switch direct boot in the options menu Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 30, 2023 Author Share #978 Posted July 30, 2023 1 minute ago, Lestat said: I Cant see the option in your picture there is no advanced option or switch direct boot in the options menu It's ARPL-i18n https://github.com/wjz304/arpl-i18n/releases/tag/23.7.5 1 Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 30, 2023 Share #979 Posted July 30, 2023 do i use that image file to the usb in place of your tinycore-redpill.v0.9.4.3-2.m-shell.img? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 30, 2023 Author Share #980 Posted July 30, 2023 (edited) 3 minutes ago, Lestat said: do i use that image file to the usb in place of your tinycore-redpill.v0.9.4.3-2.m-shell.img? ARPL is a completely different loader than TCRP. Forget my M SHELL for a moment and re-install the image of ARPL to your USB stick again. ARPL is also provided as a menu method, so it is very easy. Edited July 30, 2023 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 30, 2023 Share #981 Posted July 30, 2023 have used the img you posted but still cant see the switch direct boot option Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 30, 2023 Author Share #982 Posted July 30, 2023 8 minutes ago, Lestat said: have used the img you posted but still cant see the switch direct boot option When I used the "development tool" at the bottom, the corresponding menu was activated. Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 30, 2023 Share #983 Posted July 30, 2023 thank you for taking the time to help trying it again i tried making the build the loader with out the direct boot and the server was not seen by windows am now trying it with switch direct boot true now i know how to get to the setting Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 30, 2023 Author Share #984 Posted July 30, 2023 (edited) 10 minutes ago, Lestat said: thank you for taking the time to help trying it again i tried making the build the loader with out the direct boot and the server was not seen by windows am now trying it with switch direct boot true now i know how to get to the setting Not using "direct boot" from ARPL is not supported by older AMDs. Same situation as TCRP FRIEND kernel doesn't support it. In fact, after you failed TCRP M SHELL's JOT mode, I made some changes to M SHELL's kernel loading process. Trying to mount the FAT partition in question at a slightly earlier point in ARPL, In the case of TCRP, this timing was slightly delayed. However, I improved this so that M SHELL also tries to mount the FAT partition at the same time as ARPL. To be precise, it is to give a slight delay so that this partition mounts. The boot-wait addon does the job. Edited July 30, 2023 by Peter Suh Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 30, 2023 Share #985 Posted July 30, 2023 (edited) N40L Bios settings C1E disabled and AHCI set IDE Combined mode dose not exist on my bios and the switch direct boot to true ds3622xs+ dsm 7.2-64570 update 1 is running fine will your installer now work the same? Do you want me to test your installer now to see if it works before i start to put things back on my server? Edited July 30, 2023 by Lestat Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 30, 2023 Author Share #986 Posted July 30, 2023 8 minutes ago, Lestat said: N40L Bios settings C1E disabled and AHCI set IDE Combined mode dose not exist on my bios and the switch direct boot to true ds3622xs+ dsm 7.2-64570 update 1 is running fine will your installer now work the same? Do you want me to test your installer now to see if it works before i start to put things back on my server? There are no more things to check beforehand. I just want the disk to install without any file corruption. 1 Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 30, 2023 Share #987 Posted July 30, 2023 would it still be the same loader 0.9.4.3-2 that you will use with your updated settings or will there be a new one? aprl-i18n is good but i find your interface a lot easer to follow Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 30, 2023 Share #988 Posted July 30, 2023 dose the method we have used stop other things using the usb ports on the server i only ask as i have a ups and its no longer detected when i plug in the usb cable have also just tried it with a external hard drive and this is not detected both using different usb ports Quote Link to comment Share on other sites More sharing options...
blue max Posted July 30, 2023 Share #989 Posted July 30, 2023 (edited) I tried the APRL loader and no luck. Went back to yours Peter and once again, only get this far... IMG_1961 (2).HEIC Edited July 30, 2023 by blue max Quote Link to comment Share on other sites More sharing options...
sliders Posted July 30, 2023 Share #990 Posted July 30, 2023 hello Lestat , use tinycore-redpill.v0.9.3.0-1.m-shell.img https://github.com/PeterSuh-Q3/tinycore-redpill/releases/tag/v0.9.3.0-1 Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 30, 2023 Share #991 Posted July 30, 2023 3 hours ago, sliders said: hello Lestat , use tinycore-redpill.v0.9.3.0-1.m-shell.img https://github.com/PeterSuh-Q3/tinycore-redpill/releases/tag/v0.9.3.0-1 Is that to get the usb working again as I may have found a work around here https://mariushosting.com/synology-how-to-add-usb-support-on-dsm-7/ Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 30, 2023 Author Share #992 Posted July 30, 2023 9 hours ago, Lestat said: would it still be the same loader 0.9.4.3-2 that you will use with your updated settings or will there be a new one? aprl-i18n is good but i find your interface a lot easer to follow If you already have a separate USB loader for M SHELL that is still archived, you do not need to re-record it. New features of the module are automatically referenced through github in real time whenever the loader is built, and used during build. There is nothing special to do. However, if it is already working well in ARPL, please use it. If you want, you can also test the TCRP additionally. Success is not guaranteed. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 30, 2023 Author Share #993 Posted July 30, 2023 8 hours ago, Lestat said: dose the method we have used stop other things using the usb ports on the server i only ask as i have a ups and its no longer detected when i plug in the usb cable have also just tried it with a external hard drive and this is not detected both using different usb ports Only the REDPILL bootloader should be connected to the USB port of the PC used for XPE. If two or more bootloaders are connected or if another USB stick is co-attached, it will affect kernel booting. It was the first time I knew that it affected even the UPS using the USB port. I have to ask N40L / N54L users who use UPS in the Korean community where I am active. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 30, 2023 Author Share #994 Posted July 30, 2023 5 hours ago, sliders said: hello Lestat , use tinycore-redpill.v0.9.3.0-1.m-shell.img https://github.com/PeterSuh-Q3/tinycore-redpill/releases/tag/v0.9.3.0-1 M SHELL uses APRL-i18n, pocopico's TCRP and img's image, so the meaning is a bit different. M SHELL is when entering TCRP Loader Build that enters the TCRP Linux X terminal. It always automatically downloads and maintains the latest version. At the time of building the loader, it is also checked and kept up to date. The redpill module or Addon used during loader build uses the latest state through Github. So M SHELL should in fact see that the shared imgs of a release do not differ between versions. Since the other two loaders are changed only when the user directly downloads the latest version through the Internet, it may be meaningful to burn the shared img file of the latest release, which is a little different from M SHELL. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 31, 2023 Author Share #995 Posted July 31, 2023 3 hours ago, Lestat said: Is that to get the usb working again as I may have found a work around here https://mariushosting.com/synology-how-to-add-usb-support-on-dsm-7/ Are these third party drivers required for the UPS to work? Or are you planning to use another USB dongle? Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 31, 2023 Share #996 Posted July 31, 2023 (edited) its to get the ups to work only from what i understand the after DSM7 there are no native drivers installed for the usb sockets on the n40l that is why the ups is not working Edited July 31, 2023 by Lestat Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 31, 2023 Author Share #997 Posted July 31, 2023 15 minutes ago, Lestat said: its to get the ups to work only from what i understand the after DSM7 there are no native drivers installed for the usb sockets on the n40l that is why the ups is not working So the UPS wasn't interfering with the booting of the USB bootloader? Isn't that right? Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 31, 2023 Share #998 Posted July 31, 2023 no the server is up and running plugging the ups in and its not seen by the server at first i was thinking it may be due to the boot loader and how it works thats why i asked the question but it now looks like synology removed the drivers for the usb ports that the n40l has Quote Link to comment Share on other sites More sharing options...
Lestat Posted July 31, 2023 Share #999 Posted July 31, 2023 (edited) UPS still not working after a tried the steps above its a Cyber Power VP1200ELCD and shows compatible with the DS3266sx+ on the synology web site so at a loss with that i tried your loader again i got to recover then i got failed it never asked me for a file just started counting 1% stopped at 2% using synology assistant i can click on recover system then it did ask for the pat file but got the same problem as before gets to 57% then fails Edited July 31, 2023 by Lestat update Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 31, 2023 Author Share #1000 Posted July 31, 2023 10 minutes ago, Lestat said: UPS still not working after a tried the steps above its a Cyber Power VP1200ELCD and shows compatible with the DS3266sx+ on the synology web site so at a loss with that i tried your loader again i got to recover then i got failed it never asked me for a file just started counting 1% stopped at 2% using synology assistant i can click on recover system then it did ask for the pat file but got the same problem as before gets to 57% then fails Now that you have started using ARPL, please continue your UPS issues and inquiries on ARPL to the topics below. wjz304 will definitely give you a nice and definitive answer. Quote Link to comment Share on other sites More sharing options...
