zeroxia Posted May 28, 2023 Share #126 Posted May 28, 2023 Can you update the patch script to support the newer AME version? Thanks! Quote Synology version: DS920+ DSM 7.2-64561 AME Version: 3.1.0-3005 libsynoame-license.so info: root@dayu:/var/packages/CodecPack/target/usr/lib# ls -l libsynoame-license.so -rw-r--r-- 1 CodecPack CodecPack 95779 May 28 00:38 libsynoame-license.so root@dayu:/var/packages/CodecPack/target/usr/lib# md5sum libsynoame-license.so bc48ac350efc3d065807173d4000b610 libsynoame-license.so The file packed in .tar.gz is attached here. license.so.tar.gz 2 Quote Link to comment Share on other sites More sharing options...
IG-88 Posted May 29, 2023 Share #127 Posted May 29, 2023 On 5/27/2023 at 11:16 PM, aarnet said: Where can I download old versions packages? https://archive.synology.com/download/Package/CodecPack Quote Link to comment Share on other sites More sharing options...
nike wang Posted May 31, 2023 Share #128 Posted May 31, 2023 (edited) On 2023/5/28 at PM1点11分, zeroxia said: 你能更新补丁脚本以支持更新的 AME 版本吗?谢谢! libsynoame-license.so 信息: 打包在 .tar.gz 中的文件附在此处。 许可证.so.tar.gz 35.3 KB · 12 次下载 Hello boss, can you provide an updated AME.py file or explain how to modify the old. py file? My system has been updated to 7.2, but the old file is no longer usable. I am looking forward to hearing from you! Edited May 31, 2023 by nike wang Quote Link to comment Share on other sites More sharing options...
steven vaughan Posted June 4, 2023 Share #129 Posted June 4, 2023 On 5/31/2023 at 3:31 AM, nike wang said: Hello boss, can you provide an updated AME.py file or explain how to modify the old. py file? My system has been updated to 7.2, but the old file is no longer usable. I am looking forward to hearing from you! SAME!!! I'm on 7.2 and it broke my cameras ability to use H265 Quote Link to comment Share on other sites More sharing options...
AleAmadoC Posted June 7, 2023 Share #130 Posted June 7, 2023 On 6/7/2023 at 11:32 PM, sania-owner said: why not use white SNs which solve this problem? [...] Because if a serial number is used multiple times it get blacklisted by synology, there is no way we can get white numbers for all xpenology people out there witouth giving the same "white" to other users. Quote Link to comment Share on other sites More sharing options...
killerzac Posted June 21, 2023 Share #131 Posted June 21, 2023 Here is the latest AME patch for version 1.1.0-51005 I'm replicating Wangsiji's work. enjoy. codecpatch.sh amepatch.py 7 Quote Link to comment Share on other sites More sharing options...
Sundevill Posted June 21, 2023 Share #132 Posted June 21, 2023 (edited) 1 hour ago, killerzac said: Here is the latest AME patch for version 1.1.0-51005 I'm replicating Wangsiji's work. enjoy. codecpatch.sh 15.56 kB · 4 downloads amepatch.py 2.15 kB · 5 downloads /volume1/homes$ sudo ./codecpatch.sh -p Detected DSM version: 7.2 64570-0 Patch for DSM Version (7.2 64570-0) not found. Patch is available for versions: 3622xy only version 7.2 64570-0 Patch 7.2 64570-1 https://archive.synology.com/download/Os/DSM/7.2-64570-1 Edited June 21, 2023 by Sundevill Quote Link to comment Share on other sites More sharing options...
dj_nsk Posted June 21, 2023 Share #133 Posted June 21, 2023 If you are ready to switch to another bootloader, then look here: https://github.com/AuxXxilium/arc in the menu: Addons/amepatch 1 Quote Link to comment Share on other sites More sharing options...
killerzac Posted June 22, 2023 Share #134 Posted June 22, 2023 On 6/21/2023 at 10:16 AM, killerzac said: Here is the latest AME patch for version 1.1.0-51005 I'm replicating Wangsiji's work. enjoy. codecpatch.sh 15.56 kB · 12 downloads amepatch.py 2.15 kB · 11 downloads FYI, this is AME 3.1.0 - 3005 Quote Link to comment Share on other sites More sharing options...
AleAmadoC Posted June 22, 2023 Share #135 Posted June 22, 2023 Confirmed Working on 7.2 Update 1 Tested on DS723+ Using only amepatch.py method Best Regards 1 Quote Link to comment Share on other sites More sharing options...
wiuempe Posted June 23, 2023 Share #136 Posted June 23, 2023 I checked on a fresh 7.2 from redpill. The method from @killerzac works, but you have to execute in this order: 1. install AME 2. running codecpatch -p and selecting path 2. In this case, path 1 I already had patched, I don't know if this affects the method or not. 3. opening ame - it asks for login - I guess this is optional. 4. running amepatch 5. opening AME 6. both codecs are there! 2 Quote Link to comment Share on other sites More sharing options...
wiuempe Posted June 23, 2023 Share #137 Posted June 23, 2023 But this dont fix problem in SS9, when you have camera with support H.265 and want to live play: "The H.265, MPEG4, and MxPEG video formats are only supported on Synology Surveillance Station Client" Quote Link to comment Share on other sites More sharing options...
wiuempe Posted June 24, 2023 Share #138 Posted June 24, 2023 ok, SS9 has H.265 playback disabled in the browser version. Most likely, this is due to the fact that different browsers on different systems support H.265 differently. But, the recommended solution: the Synology Surveillance Station Client works very well, and the SS9 interface looks identical to the browser version and has the same features. For mobile devices, H.265 viewing works on DS Cam. Unfortunately, Synology Surveillance Station Client does not have a Linux version available, but Wine runs it without a problem: https://davejansen.com/synology-surveillance-station-on-linux/ Quote Link to comment Share on other sites More sharing options...
donchico Posted June 24, 2023 Share #139 Posted June 24, 2023 On 12/15/2022 at 11:09 PM, wangsiji said: This will only work with AME version 3 can i have please Quote Link to comment Share on other sites More sharing options...
donchico Posted June 24, 2023 Share #140 Posted June 24, 2023 Can I have H.265 patch for DS3622xs+ DSM7.1.1-42962 Update 6 Please Quote Link to comment Share on other sites More sharing options...
juand666 Posted June 27, 2023 Share #141 Posted June 27, 2023 On 6/23/2023 at 5:54 AM, wiuempe said: I checked on a fresh 7.2 from redpill. The method from @killerzac works, but you have to execute in this order: 1. install AME 2. running codecpatch -p and selecting path 2. In this case, path 1 I already had patched, I don't know if this affects the method or not. 3. opening ame - it asks for login - I guess this is optional. 4. running amepatch 5. opening AME 6. both codecs are there! to me only appears HEVC Quote Link to comment Share on other sites More sharing options...
surgeon2 Posted July 3, 2023 Share #142 Posted July 3, 2023 В 27.06.2023 в 20:11, juand666 сказал: codecpatch -p Not working for me: -ash: ./codecpatch.sh: /bin/sh^M: bad interpreter: No such file or directory Quote Link to comment Share on other sites More sharing options...
killerzac Posted July 6, 2023 Share #143 Posted July 6, 2023 (edited) On 6/24/2023 at 6:59 AM, wiuempe said: ok, SS9 has H.265 playback disabled in the browser version. Most likely, this is due to the fact that different browsers on different systems support H.265 differently. But, the recommended solution: the Synology Surveillance Station Client works very well, and the SS9 interface looks identical to the browser version and has the same features. For mobile devices, H.265 viewing works on DS Cam. Unfortunately, Synology Surveillance Station Client does not have a Linux version available, but Wine runs it without a problem: https://davejansen.com/synology-surveillance-station-on-linux/ Hi, I'm afraid the codectool does not have H.265.( it is known as HEVC ). I have checked on the binary, these are the only supported codec. Quote LOAD:000000000000C360 off_C360 dq offset aAacDec ; DATA XREF: main+3C8↑o LOAD:000000000000C360 ; main+8D5↑o LOAD:000000000000C360 ; "aac_dec" LOAD:000000000000C368 dq offset aAacEnc ; "aac_enc" LOAD:000000000000C370 dq offset aVc1Dec ; "vc1_dec" LOAD:000000000000C378 dq offset aVc1Enc ; "vc1_enc" LOAD:000000000000C380 dq offset aH264Dec ; "h264_dec" LOAD:000000000000C388 dq offset aH264Enc ; "h264_enc" LOAD:000000000000C390 dq offset aMpeg4part2Dec ; "mpeg4part2_dec" LOAD:000000000000C398 dq offset aMpeg4part2Enc ; "mpeg4part2_enc" LOAD:000000000000C3A0 dq offset aHevcDec ; "hevc_dec" LOAD:000000000000C3A8 dq offset aHevcEnc ; "hevc_enc" LOAD:000000000000C3B0 dq offset aAc3Dec ; "ac3_dec" LOAD:000000000000C3B8 align 20h Edited July 6, 2023 by killerzac Quote Link to comment Share on other sites More sharing options...
killerzac Posted July 6, 2023 Share #144 Posted July 6, 2023 On 7/3/2023 at 8:17 PM, surgeon2 said: Not working for me: -ash: ./codecpatch.sh: /bin/sh^M: bad interpreter: No such file or directory this is due to the windows way of appending ^M at the end of each line. You can always use editor to convert file back to UTF-8 Quote Link to comment Share on other sites More sharing options...
killerzac Posted July 6, 2023 Share #145 Posted July 6, 2023 (edited) On 6/24/2023 at 7:21 PM, donchico said: Can I have H.265 patch for DS3622xs+ DSM7.1.1-42962 Update 6 Please I'm afraid H.265 is not in the binary. H.265 is actually HEVC by the codectool. Please look at my previous comment If you want, I can only do a normal patch for DS3622xs+ DSM7.1.1-42962 Update 6. you can enable the encoding by adding the following to the license file, I have not tried it myself. last script doesn't have "hevc_enc" in the license file. Quote {"success":true,"activated_codec":["hevc_enc","hevc_dec","ac3_dec","h264_dec","h264_enc","aac_dec","aac_enc","mpeg4part2_dec","vc1_dec","vc1_enc"],"token":"123456789987654abc"}' Edited July 6, 2023 by killerzac Quote Link to comment Share on other sites More sharing options...
surgeon2 Posted July 16, 2023 Share #146 Posted July 16, 2023 В 06.07.2023 в 18:09, killerzac сказал: in the license file Where is this file in DSM7.1.1-42962 Update 6? Quote Link to comment Share on other sites More sharing options...
killerzac Posted July 17, 2023 Share #147 Posted July 17, 2023 On 7/16/2023 at 12:33 PM, surgeon2 said: Where is this file in DSM7.1.1-42962 Update 6? /usr/syno/etc/codec/activation.conf Quote Link to comment Share on other sites More sharing options...
surgeon2 Posted July 17, 2023 Share #148 Posted July 17, 2023 1 час назад, killerzac сказал: /usr/syno/etc/codec/activation.conf cat: /usr/syno/etc/codec/activation.conf: No such file or directory Also, AME shows me only HEVC. Could you share your activation.conf, pretty please? Quote Link to comment Share on other sites More sharing options...
ner0 Posted July 24, 2023 Share #149 Posted July 24, 2023 I can play HEVC videos now, but the CPU is maxed out, this is expected, right? I suppose DSM can't access any HW acceleration technology and the CPU ends up doing all the heavy lifting. Correct me if I'm wrong because I'd be interested in playing HEVC files without lighting the CPU on fire. Quote Link to comment Share on other sites More sharing options...
dj_nsk Posted July 24, 2023 Share #150 Posted July 24, 2023 20 минут назад, ner0 сказал: I can play HEVC videos now, but the CPU is maxed out, this is expected, right? I suppose DSM can't access any HW acceleration technology and the CPU ends up doing all the heavy lifting. Correct me if I'm wrong because I'd be interested in playing HEVC files without lighting the CPU on fire. You need: CPU + integrated GPU DS918+ or DS920+ (see here - transcoding) valid SN/MAC or synocodectool-patch 1 Quote Link to comment Share on other sites More sharing options...
