Advanced Media Extension will not activate dsm7.1-42661
phone guy
6 hours ago, zexx said:
Hi
my os - Synology DSM 7.2-64570 Update 3 (DVA1622)
files attached
Thanks
libsynoame-license.so 93.53 kB · 1 download synoame-bin-check-license 12.06 kB · 1 download
Hi zexx,
I have checked both the binaries. Everything is as expected and nothing is unusual. synoame-bin-check-license is patched.
I managed to execute my amepatch.py on a new install of DVA1622. Everything is working correctly. can you try to uninstall AME and reinstall ?
maybe  synoame.log will be usefull:
2023-09-22T14:36:36+03:00 jim synoscgi_SYNO.AME.License_1_check[29086]: license_manager.cpp:34 Failed to get "uuid" from "SLGetUUID()"
2023-09-22T14:36:36+03:00 jim synoscgi_SYNO.AME.License_1_check[29086]: license.cpp:42 Not login sa
2023-09-22T14:55:46+03:00 jim synoame-bin-auto-install-needed-codec[15568]: license_manager.cpp:34 Failed to get "uuid" from "SLGetUUID()"
2023-09-22T14:55:46+03:00 jim synoame-bin-auto-install-needed-codec[15568]: auto-install-needed-codec.cpp:17 Failed to create "LicenseManager"
2023-09-22T14:59:10+03:00 jim synoscgi_SYNO.AME.License_1_check[3441]: license_manager.cpp:34 Failed to get "uuid" from "SLGetUUID()"
2023-09-22T14:59:10+03:00 jim synoscgi_SYNO.AME.License_1_check[3441]: license.cpp:42 Not login sa
2023-09-22T14:59:13+03:00 jim synoscgi_SYNO.AME.License_1_check[3816]: license_manager.cpp:34 Failed to get "uuid" from "SLGetUUID()"
2023-09-22T14:59:13+03:00 jim synoscgi_SYNO.AME.License_1_check[3816]: license.cpp:42 Not login sa
2023-09-22T15:00:25+03:00 jim synoscgi_SYNO.AME.License_1_check[10021]: license_manager.cpp:34 Failed to get "uuid" from "SLGetUUID()"
2023-09-22T15:00:25+03:00 jim synoscgi_SYNO.AME.License_1_check[10021]: license.cpp:42 Not login sa
maybe something wrong with SN/MAC ? i installed OS using arpl-i18n-23.9.1.img , how i can validate SN/MAC pair ?
Edited by zexx
1 hour ago, zexx said:
I have seen exact same entries on my log before activating the patch for AME. These are normal entries. FYI, I'm using random MAC address generated by my ESXi and the VMware workstation for the clean install DVA1622. SN is also auto generated by arpl. No custom setting here.
23 hours ago, zexx said:
I uninstalled AME2 , rebooted and  tried to reproduce:
Unfortunately, I was not able to replicate your errors on my DVA1622. have installed both mediaserver and the videostation so I can get as close as possible to your setup. I'm still getting successful patch. Here is my screenshot.Screenshot2023-09-26110209.png.3580786e7045744583ff86f7ae69073a.png
Your setup must have some condition which breaks the library. Do you have any addons from arpl ? I didn't have any, plain vanilla setup in my arpl test.
are you able to test this library? I have added an additional NOP to the library. Since I'm not able to debug the the condition myself and replicate your errors. I'm only able to guess wildly the condition in the library. You have to test the libsynoame-license.so from the attachment I have added. Replace the existing library ( I'm not 100% it will work, give it a try. )
some details:
# strace ./synoame-bin-check-license  2>&1 | grep netif
openat(AT_FDCWD, "/proc/sys/kernel/syno_internal_netif_num", O_RDONLY) = 3
without parameter "netif_num=X" in cmdline syno_internal_netif_num will return "-1"  , i think that this check should be added to patches
On 9/28/2023 at 12:47 PM, zexx said:
some details:
Then If I do this:
I will have -1 result?
and If I do this:
I will have 0 result?
It's correct this?
On 9/28/2023 at 11:47 AM, zexx said:
some details:
easy patch request, can be done. However, question is do we need this ? I didn't put in netif_num in the parameters. How did mine work ?
Edited by killerzac
On 9/16/2023 at 8:08 AM, veersrag said:
i was able to get AME 1.0.0-00001 with HEVC green tick
but now i get this error in photo station
-The file cannot be displayed due to a conversion failure. IMG_0845.HEIC
unable to patch codecpatch.sh is the above issue related to codecpatch.sh?
i am on DSM 7.1.1-42962 Update 6
codecpatchfix.sh: command not found
thxs
same here.
On 7/24/2023 at 6:27 AM, dj_nsk said:
You need:
codec patch file from the above quote and AME 3.0 patch from wangsiji solves my Synology photos transcoding issues, thxs for all your work @wirgen @wangsiji and @dj_nsk for posting the links!
wangsiji AME 3.0 patch i got from here
https://xpenology.com/forum/topic/65643-ame-30-patcher/
now after the codec patch, videos take a longer time to load on mobile and mobile web browser I do not see any delay in pc/tv and also ended up with AAC grayed out in AME 1.0.0-00001 and won't update to 1.0.0-50001
Edited by veersrag
added a link
good morning, did you manage to resolve this? i have exactly the same issue. Im unable to login to synology account INSIDE dsm. For example control panel > synology account. Or: Package center > Advanced Media Extensions > Open > Login with synology account. When i click, nothing happens.
Im on ARC 23.10.5
On 9/28/2023 at 7:36 PM, zexx said:
Thanks for help, problem was fixed by adding "netif_num=2" to cmdline (looks like arpl-i18n skip this parameter by default)
Also  i can confirm, that on  DSM 7.2.1-69057  patches also works:
How did you make it work? I clean installed 7.2.1 few days ago and couldn't get the codec to work
Hello everybody,
I have the problem Codec AAC now disable.
New Version (1.0.0-50001) for HEVC and AAC-Codec is ready to installation.
aber Install Button => Download or installation failed. Check your internet connection and try again
Have anyone a Solution?
Thanks
Regards Dreamscape
Edited by Dreamscape
On 10/26/2023 at 10:45 PM, Dreamscape said:
Hello everybody,
Thanks
Regards Dreamscape
You will need to use my Wrapper and use the AAC codec like EAC3 or DTS... With my Wrapper you will be able to play it.
https://github.com/darknebular/Wrapper_VideoStation
Regards.
Edited by darknebular
I'm on 7.2.1 and I got
Patching
MD5 match version AME 1.1.0-51005 date: 21/06/2023
Checking whether patch is successful...
Patch is unsuccessful, retcode = 256
and now im getting
Patching
MD5 mismatch, not matching any version of AME
any solution? i only need heic and hevc for synology photo
Edited by Andrushencia
Can someone write all the commands to enter in the SSH console from start to finish? I tried several times and unfortunately it stops at the installation option. I can't move on. Regards
Quote
Hello everybody,
Thanks
Regards Dreamscape
Regards.
Edited November 2 by darknebular
Edited by Miodek
