zexx Posted December 15, 2022 Share #101 Posted December 15, 2022 (edited) After patch i see only HEVC , without AAC , what`s wrong with my DSM ? My env: hw (asrock j5040), DSM 7.1.1-42962 Update 2, dva1622 Edited December 15, 2022 by zexx Quote Link to comment Share on other sites More sharing options...
wangsiji Posted December 15, 2022 Share #102 Posted December 15, 2022 On 12/13/2022 at 11:08 PM, rafoloru said: DS3622xs+ DSM 7.1-42661 Update 1 AME 2.0.1-1021 I have a real Serial and MAC address This will only work with AME version 3 1 Quote Link to comment Share on other sites More sharing options...
djdaveyg Posted December 21, 2022 Share #103 Posted December 21, 2022 (edited) Thanks wangsiji and everyone for the input. I've applied the patch, no errors or problems. The issue I have is I cant update to the latest version. If I click install I get a download or installation failed, check your internet connection? I'm running 7.1.1-42962 Update 2. DS920+ Any Ideas? Edited December 21, 2022 by djdaveyg Quote Link to comment Share on other sites More sharing options...
southernsun Posted December 27, 2022 Share #104 Posted December 27, 2022 being a total python rooky here:😐 Could anyone explain how to run a python script? Do I need to copy wangiji code into wordpad and save as *.py and then save it on the synology? Than go into ssh and try to run it? Tutorials I find on running python scripts all are about task scheduling it. Is that needed? Quote Link to comment Share on other sites More sharing options...
southernsun Posted December 28, 2022 Share #105 Posted December 28, 2022 On 12/15/2022 at 9:24 AM, zexx said: After patch i see only HEVC , without AAC , what`s wrong with my DSM ? My env: hw (asrock j5040), DSM 7.1.1-42962 Update 2, dva1622 After running the python script I managed to get the same status as above.... somehow I dont have the option to update to Version 1.0.0-50001. I tried setting surveillance camera to H265 or play a HEVC movie in DS video, but without succes! What could be wrong? I'm running dsm 7.1.1-42962 - Update 1 (DS918+) Quote Link to comment Share on other sites More sharing options...
gericb Posted December 30, 2022 Share #106 Posted December 30, 2022 Adding my voice to the queue on this topic.. Baremetal system using ARPL 0.9, running DSM 7.1.1-42962 Update 2, DS920+ w/REAL SN/MAC's, Intel i350-T2/AM2 Dual Port NIC, Dell OptiPlex 9020 w/i7-4790K I don't know if it mattered the source, but I installed the AME from the Package Center, logged into my Synology account, and as you can see, it is the up to date AME package, and it appears to be activated correctly, so I assume with the ✅ but only HEVC, no AAC. Additionally, I am not seeing/getting any notification of an codec beyond this 1.0.0-00001 version. I have not run any activation scripts, as I assume I wouldn't need to with real SN/MAC....but maybe I missed something. Possibly I need to execute some test sample to get it to upgrade. @pippobimbo "You need real SN and MAC address AND « netif_num » argument in « grub.cfg » must match « macx » arguments." I assume, but I have not checked, that my grub.cfg is correctly configured as I can see in my Control Panel, Network, Network Interface, both NIC ports as being active. Also, there is this, when I issue this terminal command, I get this result. root@TestNAS:~# cat /usr/syno/etc/codec/activation.conf cat: /usr/syno/etc/codec/activation.conf: No such file or directory Any thoughts / suggestion on things to try, or additional steps I can do to help...at this point, it's a test system, nothing critical on it. 🤓 Thanks! Quote Link to comment Share on other sites More sharing options...
gericb Posted December 30, 2022 Share #107 Posted December 30, 2022 On 5/4/2022 at 10:34 PM, Nemesis said: 2022-05-05T05:32:51+02:00 Xpenology synocloudserviceauth[32079]: cloudservice_register_api_key.cpp:293 Register api key failed: Auth Fail 2022-05-05T05:32:53+02:00 Xpenology [Login MyDS Account] Run Config Backup login hook 2022-05-05T05:32:53+02:00 Xpenology license_server_login[32126]: api.cpp:542 Not Login yet 2022-05-05T05:32:53+02:00 Xpenology license_server_login[32126]: user.cpp:43 Failed to logout 2022-05-05T05:32:54+02:00 Xpenology license_server_login[32126]: api.cpp:562 API failed: POST /v1/user/login, response: {"data":{},"errno":256,"lineno":136,"status":false} 2022-05-05T05:32:54+02:00 Xpenology license_server_login[32126]: user.cpp:178 SLSendAPI fail Question - how did you produce this listing? Thank You Quote Link to comment Share on other sites More sharing options...
gericb Posted December 30, 2022 Share #108 Posted December 30, 2022 While I was poking around, I just found this... it would seem to explain at least, why there is no activated codec for AAC, no longer directly supported, according to Synology. At least this is how I am interpreting things in conjunction with talks here about the AME. 1 Quote Link to comment Share on other sites More sharing options...
nemesis122 Posted December 31, 2022 Share #109 Posted December 31, 2022 it is en easy thing you need : Orignal MAC Adress from a synolgy NAS exactly the same Modell and the Serialnumber set both in the loader config and all is working. BUT when you set not your phiscial MAC Adress from your Networkcard there is en issue with VirtualMaschineManager Quote Link to comment Share on other sites More sharing options...
Goby Posted December 31, 2022 Share #110 Posted December 31, 2022 I guess we need to find somewhere to download the package 1.0.0.5001wich should contained AAC codec. I looked around but didn't find it. If someboby has it it would be very usefull. Le 27/12/2022 à 12:13, southernsun a dit : being a total python rooky here:😐 Could anyone explain how to run a python script? Do I need to copy wangiji code into wordpad and save as *.py and then save it on the synology? Than go into ssh and try to run it? Tutorials I find on running python scripts all are about task scheduling it. Is that needed? I have the same question. Thnaks for your help. Quote Link to comment Share on other sites More sharing options...
sam juan Posted January 5, 2023 Share #111 Posted January 5, 2023 On 12/21/2022 at 6:05 AM, djdaveyg said: Thanks wangsiji and everyone for the input. I've applied the patch, no errors or problems. The issue I have is I cant update to the latest version. If I click install I get a download or installation failed, check your internet connection? I'm running 7.1.1-42962 Update 2. DS920+ Any Ideas? did you find any solution to this? i have the same, but it looks like HEIC thumbnail is created/working. Quote Link to comment Share on other sites More sharing options...
sam juan Posted January 9, 2023 Share #112 Posted January 9, 2023 On 12/30/2022 at 10:36 AM, gericb said: Adding my voice to the queue on this topic.. Baremetal system using ARPL 0.9, running DSM 7.1.1-42962 Update 2, DS920+ w/REAL SN/MAC's, Intel i350-T2/AM2 Dual Port NIC, Dell OptiPlex 9020 w/i7-4790K I don't know if it mattered the source, but I installed the AME from the Package Center, logged into my Synology account, and as you can see, it is the up to date AME package, and it appears to be activated correctly, so I assume with the ✅ but only HEVC, no AAC. Additionally, I am not seeing/getting any notification of an codec beyond this 1.0.0-00001 version. I have not run any activation scripts, as I assume I wouldn't need to with real SN/MAC....but maybe I missed something. Possibly I need to execute some test sample to get it to upgrade. @pippobimbo "You need real SN and MAC address AND « netif_num » argument in « grub.cfg » must match « macx » arguments." I assume, but I have not checked, that my grub.cfg is correctly configured as I can see in my Control Panel, Network, Network Interface, both NIC ports as being active. Also, there is this, when I issue this terminal command, I get this result. root@TestNAS:~# cat /usr/syno/etc/codec/activation.conf cat: /usr/syno/etc/codec/activation.conf: No such file or directory Any thoughts / suggestion on things to try, or additional steps I can do to help...at this point, it's a test system, nothing critical on it. 🤓 Thanks! did you get a solution to this? i tried in a different box and got the same. no option to update. fake SN/mac. tnx Quote Link to comment Share on other sites More sharing options...
lipz Posted January 14, 2023 Share #113 Posted January 14, 2023 (edited) On 1/6/2023 at 6:41 AM, sam juan said: did you find any solution to this? i have the same, but it looks like HEIC thumbnail is created/working. Can I ask you about the system and synocodectool-patch you use? because my system can't created HEIC thumbnail My system Automated Redpill Loader 1.0-beta9 // DS923+ // DSM 7.1.1-42962 Update 2 // wirgen/synocodectool-patch // wangsiji patch script On Page 4 // fake SN/mac. Thank you very much Edited January 14, 2023 by lipz Quote Link to comment Share on other sites More sharing options...
gericb Posted January 15, 2023 Share #114 Posted January 15, 2023 On 12/31/2022 at 10:09 AM, nemesis122 said: it is en easy thing you need : Orignal MAC Adress from a synolgy NAS exactly the same Modell and the Serialnumber set both in the loader config and all is working. BUT when you set not your phiscial MAC Adress from your Networkcard there is en issue with VirtualMaschineManager Not entirely sure what you are saying here...but as I posted earlier above, I am using a real SN/2 Mac for the exact model in question, a 920+. Clearly my "loader config" is set right, as once the system comes up, I can see and have 2 active ethernet ports, and correctly showing the real MAC's that was encoded into the "loader config". The fact that I can get the AME to successfully install/active is a good thing, no given visual GUI errors, but also no prompt to to update the codec beyond what was display...this latter point is what is confusing that I am initially Additionally, back on 30-DEC, I had asked you how you produced this listing you shared, would you mind clarifying? 🤓 Thanks Quote Link to comment Share on other sites More sharing options...
sam juan Posted January 16, 2023 Share #115 Posted January 16, 2023 On 1/14/2023 at 9:35 AM, lipz said: Can I ask you about the system and synocodectool-patch you use? because my system can't created HEIC thumbnail My system Automated Redpill Loader 1.0-beta9 // DS923+ // DSM 7.1.1-42962 Update 2 // wirgen/synocodectool-patch // wangsiji patch script On Page 4 // fake SN/mac. Thank you very much box1: arpl 1.0-beta2/ds3622xs+/dsm 7.1.1-42962 update3/wangsiji patch script On Page 4 // fake SN/mac/atom d525 - HEIC ok, but no face recognition box2: arpl 1.0-beta2/ds3622xs+/dsm 7.1.1-42962 update2/wangsiji patch script On Page 4 // fake SN/mac/i3-2130 - HEIC and face recognition are both ok i cannot update both to codec 1.0.0-50001 though from 1.0.0-00001, there is button to install but failed. 1 Quote Link to comment Share on other sites More sharing options...
horschtl Posted February 10, 2023 Share #116 Posted February 10, 2023 On 12/21/2022 at 3:05 PM, djdaveyg said: Thanks wangsiji and everyone for the input. I've applied the patch, no errors or problems. The issue I have is I cant update to the latest version. If I click install I get a download or installation failed, check your internet connection? I'm running 7.1.1-42962 Update 2. DS920+ Any Ideas? were you able to fix this? Quote Link to comment Share on other sites More sharing options...
SpiderPOH Posted February 11, 2023 Share #117 Posted February 11, 2023 (edited) Patch will NOT WORK Patching Checking whether patch is successful... Patch is unsuccessful, retcode = 256 DS1621+ DSM 7.1.1-42962 Update 3 and if i try second time i will see this Patching MD5 mismatch Edited February 11, 2023 by SpiderPOH Quote Link to comment Share on other sites More sharing options...
xpeno1 Posted February 20, 2023 Share #118 Posted February 20, 2023 (edited) I am on: Esxi VM DVA3221 with DSM 7.1.1-42962 Update 2 Thank you @wangsiji !!!! For the script that work!!!!!!!! Support him: Note: Using "Johanzorz" message script. (haven't try "wangsiji" original script or check for difference lol but it is working why try to fix when it work!!!) --Edit to hide Serial#... was random not official...-- Edited February 20, 2023 by xpeno1 Quote Link to comment Share on other sites More sharing options...
JayB Posted April 4, 2023 Share #119 Posted April 4, 2023 Where do you guys get real SN/MACs? Quote Link to comment Share on other sites More sharing options...
Jeffrey Ooi Posted May 8, 2023 Share #120 Posted May 8, 2023 Hi all, I am very new to all this. I would like to know does anymore manage to get it works on DSM 7.2 RC? Thank you ~Jeffrey Quote Link to comment Share on other sites More sharing options...
AleAmadoC Posted May 10, 2023 Share #121 Posted May 10, 2023 (edited) Patch worked till version 7.1.1 On version 7.2, I get MD5 mismatch So don't update to 7.2 Yet, Also if your using DVA1622, be sure your serial number is rigth: 2260UBR###### Replace # with any number value, nJoy Edited May 10, 2023 by AleAmadoC 1 Quote Link to comment Share on other sites More sharing options...
Jeffrey Ooi Posted May 11, 2023 Share #122 Posted May 11, 2023 13 hours ago, AleAmadoC said: Patch worked till version 7.1.1 On version 7.2, I get MD5 mismatch So don't update to 7.2 Yet, Also if your using DVA1622, be sure your serial number is rigth: 2260UBR###### Replace # with any number value, nJoy Hello AleAmadoC, Thanks for the replied and noted. Thank you ~Jeffrey Quote Link to comment Share on other sites More sharing options...
stanleyhalim Posted May 16, 2023 Share #123 Posted May 16, 2023 Hi all, i’m quite new in this, can anyone help to make guide step by step, requirement, what to avoid, to make the patch working. Please.. help a lot for newbie like me 😊👍 Quote Link to comment Share on other sites More sharing options...
AleAmadoC Posted May 25, 2023 Share #124 Posted May 25, 2023 (edited) On 5/16/2023 at 1:47 AM, stanleyhalim said: Hi all, i’m quite new in this, can anyone help to make guide step by step, requirement, what to avoid, to make the patch working. Please.. help a lot for newbie like me 😊👍 Well this is how I do it, in Windows. (Just the first time) 1.- Download the script and save it in a temp folder like (C:\Temp\ame.py), or create a file in C:\Temp\ame.py and paste the script contents in it. 2.- I use and app called hfs.exe (google it "hfs web server") which create a web server for fast purposes. 3.- Run hfs then right click on the home/hose icon, add file and select the script from c:\temp\ame.py that will create a web link. On all the DSM I need to patch, remember all have to ve connected to the same network as your computer. 1.- Install AME 2.- Activate ssh access to your synology (Control Panel, Terminal & SNMP) 3.- Use any ssh tool to connect to it. If you in windows 10 or up, you can use powershell -> ssh adminuser@dsmip ex: ssh admin@192.168.1.30 4.- Grant root privileges running "sudo su" witouth quotes, it will ask you for your password again. 5.- Get the file with wget using the link provided in hfs. -> wget http://192.168.1.25:8081/ame.py (This is my ip yours may vary) 6.- Run the script -> python ame.py And that's it, I hope this helps, Edited May 25, 2023 by AleAmadoC Quote Link to comment Share on other sites More sharing options...
aarnet Posted May 27, 2023 Share #125 Posted May 27, 2023 В 01.01.2023 в 02:03, Goby сказал: I guess we need to find somewhere to download the package 1.0.0.5001wich should contained AAC codec. Where can I download old versions packages? Does anyone know ? Quote Link to comment Share on other sites More sharing options...
