Sonnyboy666 Posted April 28, 2016 Share #1 Posted April 28, 2016 (edited) Hello everyone, the new DSM 5.2-5967 is out now and I just want to know if someone has tested this on a VM or bare-metal machine, yet? Does it work with XPEnoboot 5.2-5644.5? Edited April 28, 2016 by Guest Quote Link to comment Share on other sites More sharing options...
colrojo Posted April 28, 2016 Share #2 Posted April 28, 2016 From 5644u8 It seems to work well Quote Link to comment Share on other sites More sharing options...
brantje Posted April 28, 2016 Share #3 Posted April 28, 2016 Updated a VM, needed to reboot. After reboot everything was running fine. Quote Link to comment Share on other sites More sharing options...
lbn Posted April 28, 2016 Share #4 Posted April 28, 2016 Does Surveillance station 7.0-3775 works as well as on 5644.8 version, or someone got trouble with auto-shutdown etc ? Quote Link to comment Share on other sites More sharing options...
Pollux4092 Posted April 28, 2016 Share #5 Posted April 28, 2016 Did a bare metal install. System did a reboot, after that normal operations. Quote Link to comment Share on other sites More sharing options...
guyp2k Posted April 28, 2016 Share #6 Posted April 28, 2016 New to Xpeneology - installed in Hyper-V last week and running well. Where and how would you install this update, from Xpenology itself or from the boot screen install/update? Thanks Quote Link to comment Share on other sites More sharing options...
brantje Posted April 28, 2016 Share #7 Posted April 28, 2016 Check packages, all seem to work fine. Posted via Xpenology.us Quote Link to comment Share on other sites More sharing options...
guyp2k Posted April 28, 2016 Share #8 Posted April 28, 2016 Thanks, had important updates disabled. Quote Link to comment Share on other sites More sharing options...
Sonnyboy666 Posted April 28, 2016 Author Share #9 Posted April 28, 2016 Tested it myself on HP ProLiant Gen8 bare metal. After reboot everything is working fine. Quote Link to comment Share on other sites More sharing options...
Huberer Posted April 28, 2016 Share #10 Posted April 28, 2016 Some to my system (see sig.). Everything works ok after reboot Quote Link to comment Share on other sites More sharing options...
billy1 Posted April 29, 2016 Share #11 Posted April 29, 2016 Just upgraded on a bare metal machine that was running 5644.8. After a successful upgrade and reboot, looks that everything is running normally (checked a few of my most used packages). Will post an update if anything goes awry in the coming days. Quote Link to comment Share on other sites More sharing options...
imaleecher Posted April 29, 2016 Share #12 Posted April 29, 2016 Just updated to 5.2-5967 successfully via web console. Rebooted and haven't seen any issues. Quote Link to comment Share on other sites More sharing options...
Bhakta Posted April 29, 2016 Share #13 Posted April 29, 2016 I always freak out about doing updates, I think understandably... So no need to update the bootloader? Just use DSM control panel? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Sonnyboy666 Posted April 29, 2016 Author Share #14 Posted April 29, 2016 So no need to update the bootloader? NoJust use DSM control panel? yes Quote Link to comment Share on other sites More sharing options...
BanterBay Posted April 29, 2016 Share #15 Posted April 29, 2016 Thanks folks. I have just updated now. Everything works ok. Quote Link to comment Share on other sites More sharing options...
holybabel Posted April 29, 2016 Share #16 Posted April 29, 2016 Works great with my Intel SS4200 baremetal installation. Quote Link to comment Share on other sites More sharing options...
spart Posted April 29, 2016 Share #17 Posted April 29, 2016 After upgrade on my HP Microserver GEN8, the nfs sharing from server 2012 doesn't work... Quote Link to comment Share on other sites More sharing options...
jrg Posted April 29, 2016 Share #18 Posted April 29, 2016 How is this installed? I tried doing it from the control panel as well as a manual update with the .pat from synology. It stops the update at 22% and doesn't continue. I can't seem to use ssh to do much. Can't read logs in /var. Quote Link to comment Share on other sites More sharing options...
lilobzh Posted April 29, 2016 Share #19 Posted April 29, 2016 Hi Which PAT File (url ?) you use to update in DSM ? Because the automatic update install DSM 6 i suppose. Thank Quote Link to comment Share on other sites More sharing options...
spart Posted April 29, 2016 Share #20 Posted April 29, 2016 Tested it myself on HP ProLiant Gen8 bare metal. After reboot everything is working fine. has been fixed. This is because after reboot the script 'S99mount.sh' which is used to map share folder via nfs has gone. Then I add it again then reboot, now it works! Quote Link to comment Share on other sites More sharing options...
abced Posted April 29, 2016 Share #21 Posted April 29, 2016 Hi Which PAT File (url ?) you use to update in DSM ? Because the automatic update install DSM 6 i suppose. Thank Select only important updates in update settings, and it will stay on 5.2. Quote Link to comment Share on other sites More sharing options...
brantje Posted April 29, 2016 Share #22 Posted April 29, 2016 Hi Which PAT File (url ?) you use to update in DSM ? Because the automatic update install DSM 6 i suppose. Thank Set your update setiings to important updates only. Quote Link to comment Share on other sites More sharing options...
lilobzh Posted April 29, 2016 Share #23 Posted April 29, 2016 oh lol Thank you ^^ Quote Link to comment Share on other sites More sharing options...
imaleecher Posted April 29, 2016 Share #24 Posted April 29, 2016 Is anyone else having issues logging into phpVirtualBox after the update? I can get to web browser login page but cannot log in. I'm getting the following issue: Exception Object ( [message:protected] => Could not connect to host (http://127.0.0.1:18083) [string:Exception:private] => [code:protected] => 64 [file:protected] => /volume1/web/phpvirtualbox/endpoints/api.php [line:protected] => 134 [trace:Exception:private] => Array ( ) [previous:Exception:private] => ) I'm currently running: DSM 5.2-5967 XPEnoboot 5.2-5644.5 phpVirtualBox 5.0.16-105871-3 Quote Link to comment Share on other sites More sharing options...
imaleecher Posted April 29, 2016 Share #25 Posted April 29, 2016 Another thing to note, can anyone select Control Panel > Hardware & Power > Enable UPS support Quote Link to comment Share on other sites More sharing options...
