ingen300 Posted March 30, 2017 #1 Posted March 30, 2017 Hi..... Recently myds has block user using non synology device example xpenology 3615xs dsm5.2. you will found you can't use quick connect service and can't delete the device which been register at myds web site. Quote
dynax Posted March 30, 2017 #2 Posted March 30, 2017 If you have a real Synology box, take a picture of it with MAC address/serial number then contact them. They'll get you sorted out. Until then, don't use quick connect. It will only be a matter of time before all external-access apps calls home for validation when they got sick of the abuse. Quote
brantje Posted March 30, 2017 #3 Posted March 30, 2017 For the DS3615xs there is a site to generate it. Forgot the name >_<. Quote
Salah Posted March 30, 2017 #4 Posted March 30, 2017 http://quickconnector.orgfree.com/index.php Quote
brantje Posted March 30, 2017 #5 Posted March 30, 2017 http://quickconnector.orgfree.com/index.php That one yea. He needs to update the site and add DS3617xs Quote
Aigor Posted March 31, 2017 #7 Posted March 31, 2017 I don't think it's a good idea use quickconnect, if you buy a real synology you pay also to use qc, we are using synology software without paying, so i think it's good thing not use synology systems To reach own synobox via internet need only 2 lines of PAT into router. Quote
fonix232 Posted March 31, 2017 #8 Posted March 31, 2017 1. Stop using Quickconnect, use port forwarding and any freaking domain name. Hell, there are free ones, and DSM includes a DDNS service. Use it! 2. No, they did not ban users. They simply pulled the old DS3615xs serial format from their DB, and since it's invalid, you can't remove it. 3. The quickconnetor.orgfree generator does NOT create valid DS3615xs serials any more. If you want that so much, use this: https://xpenology.github.io/serial_gene ... r_new.html Quote
brantje Posted March 31, 2017 #9 Posted March 31, 2017 Rather than port forwarding to your DSM, it's safer to use VPN . Quote
sliders Posted March 31, 2017 #10 Posted March 31, 2017 hello Please do not use Quickconnect . thank you very much Quote
ingen300 Posted March 31, 2017 Author #11 Posted March 31, 2017 Thanks guys..... i will take note on this.... Quote
Salah Posted March 31, 2017 #12 Posted March 31, 2017 Synology is very aware of this project and went to war with it this month Quote
ordimans Posted April 29, 2017 #13 Posted April 29, 2017 About push, can you confirm it doesn't work on 6.1 Quote
chege Posted April 29, 2017 #14 Posted April 29, 2017 About push, can you confirm it doesn't work on 6.1 To me push notification works with DSM 6.x and android device without using QC. Quote
Schmill Posted May 16, 2017 #15 Posted May 16, 2017 Rather than port forwarding to your DSM, it's safer to use VPN . A VPN is something I have been wanting to setup for a while, but never seem to be able to get it to work. Is there a guide available somewhere? - I've looked through the GUIDES section on here and can't find anything. Quote
chege Posted May 16, 2017 #16 Posted May 16, 2017 Rather than port forwarding to your DSM, it's safer to use VPN . A VPN is something I have been wanting to setup for a while, but never seem to be able to get it to work. Is there a guide available somewhere? - I've looked through the GUIDES section on here and can't find anything. Did you check synology instructions? https://www.synology.com/en-global/know ... /vpn_setup Quote
Schmill Posted May 16, 2017 #17 Posted May 16, 2017 Rather than port forwarding to your DSM, it's safer to use VPN . A VPN is something I have been wanting to setup for a while, but never seem to be able to get it to work. Is there a guide available somewhere? - I've looked through the GUIDES section on here and can't find anything. Did you check synology instructions? https://www.synology.com/en-global/know ... /vpn_setup The one place I didn't look! - Cheers! Sent from my MotoG3 using Tapatalk Quote
