Hello there!
I really need your help to save my data on my volume.
I have an xpenology on 6.1 using Junboot 1.02b with disks in AHCI in bios.
There is one volume with 4 disks on a Raid SHR (with data protection of 1 disk).
The Overview says DANGER, the status is Crashed with 2 failed disks
The HDD view says that Disk1 is in Warning, Disk2 is Normal, Disk 3 is Initialised, Normal and Disk 4 is normal
I did not delete any data on the drive. I think there is a way to recover it, that is why I am contacting you.
It is stupid but all my life and kids videos are on those drives. I though I was covered with 1 faulty disk tolerance. Lesson learned.
How can i recover that? Those 2 drives are now back but not in the RAID...
I appreciate your help, thanks.
admin@DiskStation:/$ cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF                                         1]
md2 : active raid5 sdb5[2] sdd5[4]
      8776594944 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/2] [__UU]
md1 : active raid1 sdb2[1] sdc2[0] sdd2[2]
      2097088 blocks [12/3] [UUU_________]
md0 : active raid1 sdb1[2] sdc1[0] sdd1[3]
      2490176 blocks [12/3] [U_UU________]
unused devices: <none>
image.thumb.png.39b3ecfaaa5578110c327ff97a43549f.pngimage.png.1e3e1eb6e23fe0c59aabeb1044d965aa.png
Forgot to add this :
- DSM Version : 6.1 (la derniere je pense)
- Loader JunMod v1.02b
- Installation sur une mobo sur laquelle j ai fait un reset bios depuis, mais j ai remis en AHCI les disques > Asus PQ5 SE2. j ai 4 HDD.
- extra.lzma: NO
Forgot to add this : (and now in englishe heheh)
- DSM Version : 6.1.6.15266 update 1
- Installed on a motherboard on which I reseted the bios but since I put back the AHCI mode for the HD > Asus PQ5 SE2 with 4 HD
- extra.lzma: NO
It's to bad to hear that. While waiting for other guys to help, I would suggest to turn off the NAS if you still leave it on ...
Just to remind that, NAS is not a backup. For me, most of my photos and videos are sync'ed to Google Photos as they are free and unlimited. I also have them backed up on my PC and the other version on the NAS.
you might want to read this, its a good way of understanding the process for recovering a raid system
https://xpenology.com/forum/topic/24525-help-save-my-55tb-shr1-or-mount-it-via-ubuntu/
a easy estimate about the potential loss of data will be to know the sequence number of the disks, to get something you can access again you would need to force one of the disks into the raid set - meaning loss of data, - and then rebuild the redundancy disk
but before doing this you need to know what caused the problem and make sure it does not happen again, as in the case above seen it will be a fruitless effort trying to repair a unstable system
in a "real" recovery where your date would be worth money you would clone all disks and work with copy's or image files on a proven stable hardware, professional would not try to repair on a system with unknown's
this will tell you more about the state of the disks
mdadm --detail /dev/md2
mdadm --examine /dev/sd[abcd]5 | egrep 'Event|/dev/sd'
also check log files and check s.m.a.r.t. status of the disks, you need to know how it happened
are you sure? i can tell you from personal experience that even a 2 disk redundancy is not enough and there can be also file system corruptions
just to make sure - you need backup, not more redundancy
btw. did you ever thought about possible "other" scenarios? theft, fire, ...
in some cases it just needs one big usb disk to cover the most valuable data or maybe cloud storage like this
https://www.backblaze.com/blog/synology-cloud-backup-guide/
https://www.backblaze.com/b2/partner-synology.html
(i followed them over the years because of the storage pod designs and disk statistics - having data in the cloud is not my thing but might be a option for some people)
Edited by IG-88
a easy estimate about the potential loss of date will be to know the sequence number of the disks, to get something you can access again you would need to force one of the disks into the raid set - meaning loss of data, - and then rebuild the redundancy disk
Hi IG-88,
I will try to follow the commands given by Flyride (And hope he joins this thread too) that will give you an understanding of my situation. I am not that worried because I did not mess the data, it is a combination of bad lucks.
First, a bit of background story.
I moved to another place the server. Then i restarted it and totally forgot that I add to plug 2 RJ45 cables to its intel network card to see it on the network as the connection where binded to have a better speed. So I kept on rebooting it and could not see it. My bad is that I forgot to replug both network cable. So I took of the network cart thinking it was ******* up and went for the default one that i used previously. It now works like this.
In moving the network card, I broke a sata connector of a drive. The one that is now in partition failed state.
I also have a drive that is physically getting damage with SMART errors... i tried to repair that but got stuck at 90%.
Then I recreated a USB key with same JunMod, i booted on it but did not install the PAT of synology. I took of this new USB and reverted to the previous one...
So now I boot in the NAS but I do not see data.
So there are 4 drives and here is the results of the commands
root@DiskStation:~# cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1]
md1 : active raid1 sdb2[0] sdc2[1] sdd2[2]
md0 : active raid1 sdb1[2] sdd1[3]
      2490176 blocks [12/2] [__UU________]
root@DiskStation:~# mdadm --detail /dev/md2
/dev/md2:
        Version : 1.2
  Creation Time : Mon May 13 08:39:01 2013
     Raid Level : raid5
     Array Size : 8776594944 (8370.01 GiB 8987.23 GB)
  Used Dev Size : 2925531648 (2790.00 GiB 2995.74 GB)
   Raid Devices : 4
  Total Devices : 2
    Persistence : Superblock is persistent
    Update Time : Sat Apr  4 16:00:56 2020
          State : clean, FAILED
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
         Layout : left-symmetric
     Chunk Size : 64K
           UUID : 75762e2e:4629b4db:259f216e:a39c266d
         Events : 15401
    Number   Major   Minor   RaidDevice State
       -       0        0        0      removed
       -       0        0        1      removed
       2       8       21        2      active sync   /dev/sdb5
       4       8       53        3      active sync   /dev/sdd5
root@DiskStation:~# mdadm --detail /dev/md1
/dev/md1:
        Version : 0.90
  Creation Time : Sun Mar 29 11:48:30 2020
     Raid Level : raid1
     Array Size : 2097088 (2047.94 MiB 2147.42 MB)
  Used Dev Size : 2097088 (2047.94 MiB 2147.42 MB)
   Raid Devices : 12
  Total Devices : 3
Preferred Minor : 1
    Update Time : Sat Apr  4 15:59:32 2020
          State : clean, degraded
 Active Devices : 3
Working Devices : 3
 Failed Devices : 0
  Spare Devices : 0
           UUID : 147c15b1:a7d68154:3017a5a8:c86610be (local to host DiskStation)
         Events : 0.26
       0       8       18        0      active sync   /dev/sdb2
       1       8       34        1      active sync   /dev/sdc2
       2       8       50        2      active sync   /dev/sdd2
       -       0        0        3      removed
       -       0        0        4      removed
       -       0        0        5      removed
       -       0        0        6      removed
       -       0        0        7      removed
       -       0        0        8      removed
       -       0        0        9      removed
       -       0        0       10      removed
       -       0        0       11      removed
root@DiskStation:~# mdadm --detail /dev/md0
/dev/md0:
        Version : 0.90
  Creation Time : Sat Jun  4 18:58:23 2016
     Raid Level : raid1
     Array Size : 2490176 (2.37 GiB 2.55 GB)
  Used Dev Size : 2490176 (2.37 GiB 2.55 GB)
   Raid Devices : 12
  Total Devices : 2
Preferred Minor : 0
    Update Time : Sat Apr  4 16:17:00 2020
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
           UUID : b46ca73c:a07c1c08:3017a5a8:c86610be (local to host DiskStation)
         Events : 0.2615542
       -       0        0        0      removed
       -       0        0        1      removed
       2       8       17        2      active sync   /dev/sdb1
       3       8       49        3      active sync   /dev/sdd1
       -       0        0        4      removed
       -       0        0        5      removed
       -       0        0        6      removed
       -       0        0        7      removed
       -       0        0        8      removed
       -       0        0        9      removed
       -       0        0       10      removed
       -       0        0       11      removed
root@DiskStation:~# ls /dev/sd*
/dev/sda  /dev/sdb1  /dev/sdb5  /dev/sdc1  /dev/sdc5  /dev/sdd1  /dev/sdd5
/dev/sdb  /dev/sdb2  /dev/sdc   /dev/sdc2  /dev/sdd   /dev/sdd2
root@DiskStation:~# ls /dev/md*
/dev/md0  /dev/md1  /dev/md2
root@DiskStation:~# ls /dev/vg*
/dev/vga_arbiter
mdadm --examine /dev/sd[bcdefklmnopqr]5 >>/tmp/raid.status
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Array UUID : 75762e2e:4629b4db:259f216e:a39c266d
     Raid Level : raid5
   Raid Devices : 4
 Avail Dev Size : 5851063680 (2790.00 GiB 2995.74 GB)
  Used Dev Size : 5851063296 (2790.00 GiB 2995.74 GB)
    Data Offset : 2048 sectors
   Super Offset : 8 sectors
   Unused Space : before=1968 sectors, after=384 sectors
          State : clean
    Device UUID : 7eee55dc:dbbf5609:e737801d:87903b6c
       Checksum : b039a921 - correct
         Events : 15401
     Chunk Size : 64K
   Device Role : Active device 2
   Array State : ..AA ('A' == active, '.' == missing, 'R' == replacing)
/dev/sdc5:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x2
     Raid Level : raid5
   Raid Devices : 4
Recovery Offset : 0 sectors
          State : clean
    Device UUID : 6ba575e4:53121f53:a8fe4876:173d11a9
    Update Time : Sun Mar 22 14:01:34 2020
       Checksum : 17b3f446 - correct
         Events : 15357
     Chunk Size : 64K
   Device Role : Active device 1
   Array State : AAAA ('A' == active, '.' == missing, 'R' == replacing)
/dev/sdd5:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : fb417ce4:fcdd58fb:72d35e06:9d7098b5
       Checksum : dc9d9663 - correct
         Events : 15401
     Chunk Size : 64K
   Device Role : Active device 3
and this command below does not do anything - or I dont know how to use it:
# mdadm --examine /dev/sd[bcdefklmnopqr]5 | egrep 'Event|/dev/sd'
What is the next step you think?
Also, you are fully right, I will backup outside this NAS now. Probably with the service you point at me.
Please continue helping/guiding me.
Thanks
Before you do anything else, heed IG-88's advice to understand what happened and hopefully determine that it won't happen again.  From what you have posted, DSM cannot see any data on disk #1 (/dev/sda). There is an incomplete Warning message that might tell us more about /dev/sda.  Also disk #3 (/dev/sdc) MIGHT have data on it but we aren't sure yet.  In order to effect a recovery, one of those two drives has to be functional and contain data.
So first, please investigate and report on the circumstances that caused the failure. Also, consider power-cycling the NAS and/or reset the drive connector on disk #1.  Once /dev/sda is up and running (or you are absolutely certain that it won't come up), complete the last investigation step IG-88 proposed.
You only have four drives.  So adapt the last command as follows:
# mdadm --examine /dev/sd[abcd]5 | egrep 'Event|/dev/sd'
Edited by flyride
i alreday gave you commands matching your system above (abcd)
the examine you did from the other thread does not contain "a" so its missing "/dev/sda" informations
so please do execute this to get the information about the state of the disks
it also seems you cut some output lines at the beginning from the command? (the part where it say's /dev/sdb5)
please be careful, sloppiness might have heavy consequences, be very careful when doing such stuff some of the commands cant be undone so easily
it important to be precise
from what we have now it would be possible to do a recovery of the raid with /dev/sdc but lets see what /dev/sda has to offer
maybe nothing at all for /dev/sda because
did not show any partitions for /dev/sda, there should be /dev/sda1 /dev/sda2 /dev/sda5
but what we have from /dev/sdc might be enough
the loss would be 44 x 64k, 2,75 MByte
Edited by IG-88
Thanks for of you for stepping up and helping me like this. Really appreciated. You guessed from what I wrote that I do not always understand what I do as I am not experienced in this. So I will try my best! I also add difficulty copying the message from raid.status with VI. That might explain why the message got cut.
Here is the commands IG88 wanted me to write originally :
/dev/md2:
        Version : 1.2
     Raid Level : raid5
   Raid Devices : 4
  Total Devices : 2
    Update Time : Sat Apr  4 19:33:15 2020
 Active Devices : 2
Working Devices : 2
 Failed Devices : 0
  Spare Devices : 0
     Chunk Size : 64K
         Events : 15405
       -       0        0        0      removed
       -       0        0        1      removed
root@DiskStation:~# mdadm --examine /dev/sd[abcd]5 | egrep 'Event|/dev/sd'
/dev/sdb5:
         Events : 15405
/dev/sdc5:
         Events : 15357
/dev/sdd5:
         Events : 15405
Here is the second one :
root@DiskStation:~# vi /tmp/raid.status
/dev/sdb5:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
       Checksum : b039dae8 - correct
         Events : 15405
     Chunk Size : 64K
/dev/sdc5:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x2
     Raid Level : raid5
   Raid Devices : 4
          State : clean
         Events : 15357
     Chunk Size : 64K
/dev/sdd5:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
       Checksum : dc9dc82a - correct
         Events : 15405
     Chunk Size : 64K
"/tmp/raid.status" 85L, 2674C
and the latest command to be sure
/dev/sda  /dev/sdb  /dev/sdb1  /dev/sdb2  /dev/sdb5  /dev/sdc  /dev/sdc1  /dev/sdc2  /dev/sdc5  /dev/sdd  /dev/sdd1  /dev/sdd2  /dev/sdd5
1 hour ago, IG-88 said:
if flyride has some time to help you here its good for you, he's defiantly better at this then i am
I dont know if it is important but as a reminder,  I did a SMART extended on the "broken" disk- it is now failing.... slowly...
For good news, you have a simple RAID (not SHR).  The array you are concerned with is /dev/md2.  Anything relating to /dev/vg* or managing LVM does not apply to you.
What is the next step guys?
When you say something like this, be very specific as to which disk it is.  Is it disk #1 or disk #3? (please answer)
/dev/sdb5: Events : 15405
/dev/sdc5: Events : 15357
/dev/sdd5: Events : 15405
This is not too bad, there might be some modest data corruption (IG-88 quantified), but most files would be ok.
Do you know if your filesystem is btrfs or ext4?  (please answer)
And please answer the two questions I asked in the first place.
Hi Flyride an
Sorry for not being precise enought. I am in a learning process now, and to be honest, it is not that simple :-)
So, you asked me to be specific about the disk I did a smart test on. The problem here is that I can get the disk model and serial from DSM so the model is WD30EZRX-00MMMB0 and the serial is WD-WCAWZ2266285 but that is all I can get. I tried hwinfo --disk, sudoblkid, lsblk -f, command but they do not work. I do not know how to recover the UUID as I think it is what you need no? What I am sure of it that in DSM this is stated as Disk1.
Regarding the filesytem, I had to do some research. The RAID type was SHR but the filesystem I can not find it, I am sorry. Do you know a command to find that? I cannot find it...
Regarding the Warning of Disk 1 it is about the SMART test and it says Warning, Failing (see below)
Regarding what caused the failure, it is probably because after I moved the server I broke the SATA cable, it lost the drive. I tried to repair the cable and plugged it in. Then it was discovered and there was a system partition failed and I repaired - but the repair stopped in the middle I think, I restarted it.
Thanks Flyride for spending time on helping a stranger! Really appreciated. Can I get you a drink ;-)
Well it looks like that drive 1 is not worth trying to use.  Lots of bad sectors and no partitions with obvious data on them.
Let's try restarting your array in degraded mode using the remaining drives.
# mdadm --force --assemble /dev/md2 /dev/sd[bcd]5
Post the output exactly.
I do not get anything from that command. What I am doing wrong?
The pound sign I typed was to represent the operating system prompt and so you knew the command was to be run with elevated privilege. When you entered the command with a preceding pound sign, you made it into a comment and exactly nothing was done.
Please do not click that repair button right now. It won’t be helpful.
Shame on me. I should have noticed that. Sorry.
Update
root@DiskStation:~# mdadm --force --assemble /dev/md2 /dev/sd[bcd]5
mdadm: --force does not set the mode, and so cannot be the first option.
should it be assemble first??
mdadm  --assemble --force /dev/md2 /dev/sd[bcd]5
OK, I did teh assemble before and it seemed to be OK
root@DiskStation:~# mdadm  --assemble --force /dev/md2 /dev/sd[bcd]5
mdadm: /dev/sdb5 is busy - skipping
mdadm: /dev/sdd5 is busy - skipping
mdadm: Found some drive for an array that is already active: /dev/md2
mdadm: giving up.
And then
Yes, it's hard to do all this remotely and from memory.
# mdadm --stop /dev/md2
then
Sorry for the false start.
then
Good to hear that. At least it proves I have done good homework LOL.
After the stop mdadm i get this
mdadm: /dev/md2 assembled from 2 drives - not enough to start the array.
Is it bad? Now I will go and do some research about it... scary
