C-Fu Posted January 14, 2020 Share #1 Posted January 14, 2020 (edited) I'm at loss here, dunno what to do tl;dr version: I need to either recreate my SHR1 pool, or at least let me mount the drives so I can transfer my files. Story begins with this: 13 drives in total, including one cache SSD. Two crashes at the same time?? That's like.... a very rare possibility right? Well whatever. Everything's read-only now. Fine, I'll just back whatever's important via rclone + gdrive. That's gonna take me a while. Then something weird happened... I could repair, and the 2.73/3TB drive came up normal. But a different drive crashed now. Weird. And stupid of me, I didn't think and clicked deactivate with the 9.10/10TB drive. And now I have no idea how to reactive the drive again. After a few restarts, this happened. The crashed 10TB is not there anymore, which is understandable, but everything's... normal...? But all shares are gone I took out the usb and plug in ubuntu live usb. # cat /proc/mdstat Personalities : [raid0] [raid1] [raid6] [raid5] [raid4] md4 : active (auto-read-only) raid5 sdj6[0] sdl6[3] sdo6[2] sdk6[1] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/4] [UUU_U] md2 : inactive sdm5[10](S) sdj5[7](S) sdd5[0](S) sde5[1](S) sdp5[14](S) sdo5[9](S) sdl5[11](S) sdn5[13](S) sdi5[5](S) sdf5[2](S) sdh5[4](S) sdk5[8](S) 35105225472 blocks super 1.2 md5 : active (auto-read-only) raid1 sdl7[0] 3905898432 blocks super 1.2 [2/1] [U_] md3 : active raid0 sdc1[0] 234426432 blocks super 1.2 64k chunks unused devices: <none> # mdadm -Asf && vgchange -ay mdadm: Found some drive for an array that is already active: /dev/md/5 mdadm: giving up. mdadm: Found some drive for an array that is already active: /dev/md/4 mdadm: giving up. Drive list: 250GB SSD sdc /dev/sdc1 223.57 3TB sdd /dev/sdd1 2.37GB /dev/sdd2 2.00GB /dev/sdd5 2.72TB 3TB sde /dev/sde1 2.37GB /dev/sde2 2.00GB /dev/sde5 2.72TB 3TB sdf /dev/sdf1 2.37GB /dev/sdf2 2.00GB /dev/sdf5 2.72TB 3TB sdh /dev/sdh1 2.37GB /dev/sdh2 2.00GB /dev/sdh5 2.72TB 3TB sdi /dev/sdi1 2.37GB /dev/sdi2 2.00GB /dev/sdi5 2.72TB 5TB sdj /dev/sdj1 2.37GB /dev/sdj2 2.00GB /dev/sdj5 2.72TB /dev/sdj6 2.73TB 5TB sdk /dev/sdk1 2.37GB /dev/sdk2 2.00GB /dev/sdk5 2.72TB /dev/sdk6 2.73TB 10TB sdl /dev/sdl1 2.37GB /dev/sdl2 2.00GB /dev/sdl5 2.72TB /dev/sdl6 2.73TB /dev/sdl7 3.64TB 3TB sdm /dev/sdm1 2.37GB /dev/sdm2 2.00GB /dev/sdm5 2.72TB 3TB sdn /dev/sdn1 2.37GB /dev/sdn2 2.00GB /dev/sdn5 2.72TB 5TB sdo /dev/sdo1 2.37GB /dev/sdo2 2.00GB /dev/sdo5 2.72TB /dev/sdo6 2.73TB 10TB sdp /dev/sdp1 2.37GB /dev/sdp2 2.00GB /dev/sdp5 2.72TB /dev/sdp6 2.73TB /dev/sdp7 3.64TB Can anybody help me? I just want to access my data, how can I do that? Relevant thread of mine (tl;dr version: it worked, for a few months at least) Edited January 14, 2020 by C-Fu Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 15, 2020 Author Share #2 Posted January 15, 2020 (edited) Nobody? 😪 I have no idea what this means, but I think it's important. HELP! sdn WDC WD100EMAZ-00 10TB homelab:4 10.92TB homelab:5 3.64TB sdk ST6000VN0033-2EE homelab:4 10.92TB sdj WDC WD100EMAZ-00 10TB homelab:4 10.92TB homelab:5 3.64TB sdi ST6000VN0041-2EL homelab:4 10.92TB sdh ST6000VN0041-2EL homelab:4 10.92TB sda KINGSTON SV300S3 [SSD CACHE] homelab:3 223.57GB # fdisk -l Disk /dev/sda: 223.6 GiB, 240057409536 bytes, 468862128 sectors Disk model: KINGSTON SV300S3 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x696935dc Device Boot Start End Sectors Size Id Type /dev/sda1 2048 468857024 468854977 223.6G fd Linux raid autodetect Disk /dev/sdb: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Disk model: WDC WD30EFRX-68A Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 43C8C355-AE0A-42DC-97CC-508B0FB4EF37 Device Start End Sectors Size Type /dev/sdb1 2048 4982527 4980480 2.4G Linux RAID /dev/sdb2 4982528 9176831 4194304 2G Linux RAID /dev/sdb5 9453280 5860326239 5850872960 2.7T Linux RAID Disk /dev/sde: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Disk model: WDC WD30EFRX-68A Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 48A13430-10A1-4050-BA78-723DB398CE87 Device Start End Sectors Size Type /dev/sde1 2048 4982527 4980480 2.4G Linux RAID /dev/sde2 4982528 9176831 4194304 2G Linux RAID /dev/sde5 9453280 5860326239 5850872960 2.7T Linux RAID Disk /dev/sdc: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Disk model: WDC WD30EFRX-68A Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 0600DFFC-A576-4242-976A-3ACAE5284C4C Device Start End Sectors Size Type /dev/sdc1 2048 4982527 4980480 2.4G Linux RAID /dev/sdc2 4982528 9176831 4194304 2G Linux RAID /dev/sdc5 9453280 5860326239 5850872960 2.7T Linux RAID Disk /dev/sdd: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Disk model: WDC WD30EFRX-68A Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 58B43CB1-1F03-41D3-A734-014F59DE34E8 Device Start End Sectors Size Type /dev/sdd1 2048 4982527 4980480 2.4G Linux RAID /dev/sdd2 4982528 9176831 4194304 2G Linux RAID /dev/sdd5 9453280 5860326239 5850872960 2.7T Linux RAID [-----------------------THE LIVE USB DEBIAN/UBUNTU------------] Disk /dev/sdf: 14.9 GiB, 16008609792 bytes, 31266816 sectors Disk model: Cruzer Fit Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xf85f7a50 Device Boot Start End Sectors Size Id Type /dev/sdf1 * 2048 31162367 31160320 14.9G 83 Linux /dev/sdf2 31162368 31262719 100352 49M ef EFI (FAT-12/16/32) Disk /dev/loop0: 2.2 GiB, 2326040576 bytes, 4543048 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/sdj: 9.1 TiB, 10000831348736 bytes, 19532873728 sectors Disk model: WDC WD100EMAZ-00 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 1713E819-3B9A-4CE3-94E8-5A3DBF1D5983 Device Start End Sectors Size Type /dev/sdj1 2048 4982527 4980480 2.4G Linux RAID /dev/sdj2 4982528 9176831 4194304 2G Linux RAID /dev/sdj5 9453280 5860326239 5850872960 2.7T Linux RAID /dev/sdj6 5860342336 11720838239 5860495904 2.7T Linux RAID /dev/sdj7 11720854336 19532653311 7811798976 3.7T Linux RAID Disk /dev/sdg: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Disk model: WDC WD30PURX-64P Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 1D5B8B09-8D4A-4729-B089-442620D3D507 Device Start End Sectors Size Type /dev/sdg1 2048 4982527 4980480 2.4G Linux RAID /dev/sdg2 4982528 9176831 4194304 2G Linux RAID /dev/sdg5 9453280 5860326239 5850872960 2.7T Linux RAID Disk /dev/sdn: 9.1 TiB, 10000831348736 bytes, 19532873728 sectors Disk model: WDC WD100EMAZ-00 Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: EA537505-55B5-4C27-A7CA-C7BBB7E7B56F Device Start End Sectors Size Type /dev/sdn1 2048 4982527 4980480 2.4G Linux RAID /dev/sdn2 4982528 9176831 4194304 2G Linux RAID /dev/sdn5 9453280 5860326239 5850872960 2.7T Linux RAID /dev/sdn6 5860342336 11720838239 5860495904 2.7T Linux RAID /dev/sdn7 11720854336 19532653311 7811798976 3.7T Linux RAID Disk /dev/sdl: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Disk model: WDC WD30PURX-64P Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: A3E39D34-4297-4BE9-B4FD-3A21EFC38071 Device Start End Sectors Size Type /dev/sdl1 2048 4982527 4980480 2.4G Linux RAID /dev/sdl2 4982528 9176831 4194304 2G Linux RAID /dev/sdl5 9453280 5860326239 5850872960 2.7T Linux RAID Disk /dev/sdm: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Disk model: WDC WD30PURX-64P Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 54D81C51-AB85-4DE2-AA16-263DF1C6BB8A Device Start End Sectors Size Type /dev/sdm1 2048 4982527 4980480 2.4G Linux RAID /dev/sdm2 4982528 9176831 4194304 2G Linux RAID /dev/sdm5 9453280 5860326239 5850872960 2.7T Linux RAID Disk /dev/sdh: 5.5 TiB, 6001175126016 bytes, 11721045168 sectors Disk model: ST6000VN0041-2EL Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 849E02B2-2734-496B-AB52-A572DF8FE63F Device Start End Sectors Size Type /dev/sdh1 2048 4982527 4980480 2.4G Linux RAID /dev/sdh2 4982528 9176831 4194304 2G Linux RAID /dev/sdh5 9453280 5860326239 5850872960 2.7T Linux RAID /dev/sdh6 5860342336 11720838239 5860495904 2.7T Linux RAID Disk /dev/sdk: 5.5 TiB, 6001175126016 bytes, 11721045168 sectors Disk model: ST6000VN0033-2EE Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 09CB7303-C2E7-46F8-ADA0-D4853F25CB00 Device Start End Sectors Size Type /dev/sdk1 2048 4982527 4980480 2.4G Linux RAID /dev/sdk2 4982528 9176831 4194304 2G Linux RAID /dev/sdk5 9453280 5860326239 5850872960 2.7T Linux RAID /dev/sdk6 5860342336 11720838239 5860495904 2.7T Linux RAID Disk /dev/sdi: 5.5 TiB, 6001175126016 bytes, 11721045168 sectors Disk model: ST6000VN0041-2EL Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 423D33B4-90CE-4E34-9C40-6E06D1F50C0C Device Start End Sectors Size Type /dev/sdi1 2048 4982527 4980480 2.4G Linux RAID /dev/sdi2 4982528 9176831 4194304 2G Linux RAID /dev/sdi5 9453280 5860326239 5850872960 2.7T Linux RAID /dev/sdi6 5860342336 11720838239 5860495904 2.7T Linux RAID Disk /dev/md126: 3.7 TiB, 3999639994368 bytes, 7811796864 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/md125: 10.9 TiB, 12002291351552 bytes, 23441975296 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 65536 bytes / 262144 bytes Disk /dev/md124: 223.6 GiB, 240052666368 bytes, 468852864 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 65536 bytes / 65536 bytes # cat /proc/mdstat Personalities : [raid1] [raid0] [raid6] [raid5] [raid4] md124 : active raid0 sda1[0] 234426432 blocks super 1.2 64k chunks md125 : active (auto-read-only) raid5 sdk6[2] sdj6[3] sdi6[1] sdh6[0] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/4] [UUU_U] md126 : active (auto-read-only) raid1 sdj7[0] 3905898432 blocks super 1.2 [2/1] [U_] unused devices: <none> # mdadm --detail /dev/md125 /dev/md125: Version : 1.2 Creation Time : Sun Sep 22 21:55:04 2019 Raid Level : raid5 Array Size : 11720987648 (11178.00 GiB 12002.29 GB) Used Dev Size : 2930246912 (2794.50 GiB 3000.57 GB) Raid Devices : 5 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sat Jan 11 20:50:35 2020 State : clean, degraded Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Consistency Policy : resync Name : homelab:4 UUID : 648fc239:67ee3f00:fa9d25fe:ef2f8cb0 Events : 7035 Number Major Minor RaidDevice State 0 8 118 0 active sync /dev/sdh6 1 8 134 1 active sync /dev/sdi6 2 8 166 2 active sync /dev/sdk6 - 0 0 3 removed 3 8 150 4 active sync /dev/sdj6 # lvm vgscan Reading all physical volumes. This may take a while... Couldn't find device with uuid xreQ41-E5FU-YC9V-cTHA-QBb0-Cr3U-tcvkZf. Found volume group "vg1" using metadata type lvm2 lvm> vgs vg1 Couldn't find device with uuid xreQ41-E5FU-YC9V-cTHA-QBb0-Cr3U-tcvkZf. VG #PV #LV #SN Attr VSize VFree vg1 3 2 0 wz-pn- <47.25t 916.00m lvm> lvmdiskscan /dev/loop0 [ <2.17 GiB] /dev/sdf1 [ <14.86 GiB] /dev/sdf2 [ 49.00 MiB] /dev/md124 [ <223.57 GiB] /dev/md125 [ <10.92 TiB] LVM physical volume /dev/md126 [ <3.64 TiB] LVM physical volume 0 disks 4 partitions 0 LVM physical volume whole disks 2 LVM physical volumes lvm> pvscan Couldn't find device with uuid xreQ41-E5FU-YC9V-cTHA-QBb0-Cr3U-tcvkZf. PV [unknown] VG vg1 lvm2 [32.69 TiB / 0 free] PV /dev/md125 VG vg1 lvm2 [<10.92 TiB / 0 free] PV /dev/md126 VG vg1 lvm2 [<3.64 TiB / 916.00 MiB free] Total: 3 [<47.25 TiB] / in use: 3 [<47.25 TiB] / in no VG: 0 [0 ] lvm> lvs Couldn't find device with uuid xreQ41-E5FU-YC9V-cTHA-QBb0-Cr3U-tcvkZf. LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert syno_vg_reserved_area vg1 -wi-----p- 12.00m volume_1 vg1 -wi-----p- <47.25t lvm> vgdisplay Couldn't find device with uuid xreQ41-E5FU-YC9V-cTHA-QBb0-Cr3U-tcvkZf. --- Volume group --- VG Name vg1 System ID Format lvm2 Metadata Areas 2 Metadata Sequence No 12 VG Access read/write VG Status resizable MAX LV 0 Cur LV 2 Open LV 0 Max PV 0 Cur PV 3 Act PV 2 VG Size <47.25 TiB PE Size 4.00 MiB Total PE 12385768 Alloc PE / Size 12385539 / <47.25 TiB Free PE / Size 229 / 916.00 MiB VG UUID 2n0Cav-enzK-3ouC-02ve-tYKn-jsP5-PxfYQp Edited January 15, 2020 by C-Fu Quote Link to comment Share on other sites More sharing options...
flyride Posted January 15, 2020 Share #3 Posted January 15, 2020 I apologize if this may seem unkind, but you need to get very methodical and organized, and resist the urge to do something quickly. There's a thing that happens, folks sort of throw themselves at this problem and end up potentially doing damage without really doing research. That leads to a low likelihood of data recovery, and at best recovery with a lot of corruption and data loss. If your data is intact, it will patiently wait for you. I don't know why you decided to boot up Ubuntu but you must understand that all the device ID's are probably different and nothing will match up. It actually looks like some of the info you posted is from DSM and some of it is from Ubuntu. So pretty much we have to ignore it and start over to have any chance of figuring things out. If you want help, PUT EVERYTHING BACK EXACTLY THE WAY IT WAS, boot up in DSM, and get shell access. Then: Summarize exactly what potentially destructive steps you took. You posted that you clicked Repair, and then Deactivate. Specifically where, affecting what? Anything else? cat /proc/mdstat Using each of the arrays returned by mdstat: mdadm --detail /dev/<array> ls /dev/sd* ls /dev/md* ls /dev/vg* Please post the results (that is if you want help... on your own you can do what you wish, of course). There is no guarantee that your data is recoverable - there is no concrete evidence of anything yet. 1 Quote Link to comment Share on other sites More sharing options...
flyride Posted January 15, 2020 Share #4 Posted January 15, 2020 One more thing, did you just walk up to the system and see the two crashed drives? Or was there some system operation happening at the time? If something caused the problem, it would help to know what it was. Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #5 Posted January 16, 2020 (edited) 11 hours ago, flyride said: I apologize if this may seem unkind, but you need to get very methodical and organized, and resist the urge to do something quickly. If your data is intact, it will patiently wait for you. I don't know why you decided to boot up Ubuntu but you must understand that all the device ID's are probably different and nothing will match up. It actually looks like some of the info you posted is from DSM and some of it is from Ubuntu. So pretty much we have to ignore it and start over to have any chance of figuring things out. Thing is, as I said earlier First, nothing out of the ordinary happened. Then two drives out of nowhere started crashing. Drives (Some?) data was still accessible. My mistake was I deactivated the 10TB. So I backed up whatever that I could via rclone from a different machine, accessing via SMB and NFS. Then I rebooted. It presented the option to repair. I clicked repair, and when everything's done a drive was labelled clean, and a different one labelled as crashed. I freaked out, and continued to do the backup. Soon after all shares are gone. I did mdadm -Asf && vgchange -ay in DSM. I booted ubuntu live because I read multiple times that you can just pop in your drives in ubuntu and you can (easily?) mount the drives to access whatever data that's there. That's all. So if I can mount any/all of the drives in ubuntu and proceed to back up what's left, at this stage I'd be more than happy 😁 I didn't physically alter anything on the server other than changing USB to ubuntu. I will post whatever commands you asked, and unkind or not, at this stage I appreciate any reply 😁 /volume1$ cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md2 : active raid5 sdb5[0] sdl5[7] sdk5[5] sdf5[4] sdd5[2] sdc5[1] 35105225472 blocks super 1.2 level 5, 64k chunk, algorithm 2 [13/6] [UUU_UU_U_____] md4 : active raid5 sdl6[0] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/1] [U____] md1 : active raid1 sdl2[6] sdk2[5] sdf2[4] sdd2[2] sdc2[1] sdb2[0] 2097088 blocks [12/6] [UUU_UUU_____] md0 : active raid1 sdb1[1] sdc1[2] sdd1[3] sdf1[5] sdk1[6] sdl1[7] sdm1[8] sdn1[10] sdo1[0] sdp1[4] 2490176 blocks [12/10] [UUUUUUUUU_U_] unused devices: <none> root@homelab:~# mdadm --detail /dev/md2 /dev/md2: Version : 1.2 Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Used Dev Size : 2925435456 (2789.91 GiB 2995.65 GB) Raid Devices : 13 Total Devices : 6 Persistence : Superblock is persistent Update Time : Thu Jan 16 15:36:17 2020 State : clean, FAILED Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : homelab:2 (local to host homelab) UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Events : 370905 Number Major Minor RaidDevice State 0 8 21 0 active sync /dev/sdb5 1 8 37 1 active sync /dev/sdc5 2 8 53 2 active sync /dev/sdd5 - 0 0 3 removed 4 8 85 4 active sync /dev/sdf5 5 8 165 5 active sync /dev/sdk5 - 0 0 6 removed 7 8 181 7 active sync /dev/sdl5 - 0 0 8 removed - 0 0 9 removed - 0 0 10 removed - 0 0 11 removed - 0 0 12 removed root@homelab:~# mdadm --detail /dev/md4 /dev/md4: Version : 1.2 Creation Time : Sun Sep 22 21:55:04 2019 Raid Level : raid5 Array Size : 11720987648 (11178.00 GiB 12002.29 GB) Used Dev Size : 2930246912 (2794.50 GiB 3000.57 GB) Raid Devices : 5 Total Devices : 1 Persistence : Superblock is persistent Update Time : Thu Jan 16 15:36:17 2020 State : clean, FAILED Active Devices : 1 Working Devices : 1 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : homelab:4 (local to host homelab) UUID : 648fc239:67ee3f00:fa9d25fe:ef2f8cb0 Events : 7040 Number Major Minor RaidDevice State 0 8 182 0 active sync /dev/sdl6 - 0 0 1 removed - 0 0 2 removed - 0 0 3 removed - 0 0 4 removed root@homelab:~# mdadm --detail /dev/md1 /dev/md1: Version : 0.90 Creation Time : Thu Jan 16 15:35:53 2020 Raid Level : raid1 Array Size : 2097088 (2047.94 MiB 2147.42 MB) Used Dev Size : 2097088 (2047.94 MiB 2147.42 MB) Raid Devices : 12 Total Devices : 6 Preferred Minor : 1 Persistence : Superblock is persistent Update Time : Thu Jan 16 15:36:44 2020 State : active, degraded Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 UUID : 000ab602:c505dcb2:cc8c244d:4f76664d (local to host homelab) Events : 0.25 Number Major Minor RaidDevice State 0 8 18 0 active sync /dev/sdb2 1 8 34 1 active sync /dev/sdc2 2 8 50 2 active sync /dev/sdd2 - 0 0 3 removed 4 8 82 4 active sync /dev/sdf2 5 8 162 5 active sync /dev/sdk2 6 8 178 6 active sync /dev/sdl2 - 0 0 7 removed - 0 0 8 removed - 0 0 9 removed - 0 0 10 removed - 0 0 11 removed root@homelab:~# mdadm --detail /dev/md0 /dev/md0: Version : 0.90 Creation Time : Sun Sep 22 21:01:46 2019 Raid Level : raid1 Array Size : 2490176 (2.37 GiB 2.55 GB) Used Dev Size : 2490176 (2.37 GiB 2.55 GB) Raid Devices : 12 Total Devices : 10 Preferred Minor : 0 Persistence : Superblock is persistent Update Time : Thu Jan 16 15:48:30 2020 State : clean, degraded Active Devices : 10 Working Devices : 10 Failed Devices : 0 Spare Devices : 0 UUID : f36dde6e:8c6ec8e5:3017a5a8:c86610be Events : 0.522691 Number Major Minor RaidDevice State 0 8 225 0 active sync /dev/sdo1 1 8 17 1 active sync /dev/sdb1 2 8 33 2 active sync /dev/sdc1 3 8 49 3 active sync /dev/sdd1 4 8 241 4 active sync /dev/sdp1 5 8 81 5 active sync /dev/sdf1 6 8 161 6 active sync /dev/sdk1 7 8 177 7 active sync /dev/sdl1 8 8 193 8 active sync /dev/sdm1 - 0 0 9 removed 10 8 209 10 active sync /dev/sdn1 - 0 0 11 removed root@homelab:~# ls /dev/sd* /dev/sda /dev/sdb2 /dev/sdc2 /dev/sdd2 /dev/sdf2 /dev/sdk2 /dev/sdl2 /dev/sdm1 /dev/sdn /dev/sdn6 /dev/sdo5 /dev/sdp1 /dev/sdq1 /dev/sdr1 /dev/sdr7 /dev/sda1 /dev/sdb5 /dev/sdc5 /dev/sdd5 /dev/sdf5 /dev/sdk5 /dev/sdl5 /dev/sdm2 /dev/sdn1 /dev/sdo /dev/sdo6 /dev/sdp2 /dev/sdq2 /dev/sdr2 /dev/sdb /dev/sdc /dev/sdd /dev/sdf /dev/sdk /dev/sdl /dev/sdl6 /dev/sdm5 /dev/sdn2 /dev/sdo1 /dev/sdo7 /dev/sdp5 /dev/sdq5 /dev/sdr5 /dev/sdb1 /dev/sdc1 /dev/sdd1 /dev/sdf1 /dev/sdk1 /dev/sdl1 /dev/sdm /dev/sdm6 /dev/sdn5 /dev/sdo2 /dev/sdp /dev/sdq /dev/sdr /dev/sdr6 root@homelab:~# ls /dev/md* /dev/md0 /dev/md1 /dev/md2 /dev/md4 root@homelab:~# ls /dev/vg* /dev/vga_arbiter Note that when I pop the synoboot usb back, it asks me to migrate, and since all files are read-only, I can't restore my synoinfo.conf back to the original - 20 drives, 4 usb, 2 esata. Again I appreciate any reply, thank you! Edited January 16, 2020 by C-Fu Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #6 Posted January 16, 2020 "Note that when I pop the synoboot usb back, it asks me to migrate, and since all files are read-only, I can't restore my synoinfo.conf back to the original - 20 drives, 4 usb, 2 esata." Can you explain this further? You said at the beginning you had 12 data drives and one cache drive. synoinfo.conf is stored on the root filesystem, which is /dev/md0 and is still functional. Why can't you modify synoinfo.conf directly as needed? If you are saying drives are not accessible, we need to fix that before anything else. Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #7 Posted January 16, 2020 1 hour ago, flyride said: "Note that when I pop the synoboot usb back, it asks me to migrate, and since all files are read-only, I can't restore my synoinfo.conf back to the original - 20 drives, 4 usb, 2 esata." Can you explain this further? You said at the beginning you had 12 data drives and one cache drive. synoinfo.conf is stored on the root filesystem, which is /dev/md0 and is still functional. Why can't you modify synoinfo.conf directly as needed? If you are saying drives are not accessible, we need to fix that before anything else. It means that when this whole thing started (and the 2 crashed drives), everything went into read-only mode. I have no idea why. My synoinfo.conf was still as is, I didn't change anything since after the first installation. Now when I pop the xpe usb back, it asks me to migrate, and thus wiping out my synoinfo and reverting to the default ds3617xs setting. Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #8 Posted January 16, 2020 I am getting lost in your explanation. If your arrays are crashed, they will be read-only or unavailable, so that can be expected. You keep saying "pop the xpe usb back." I'm assuming you did that only once and it is still installed. Right? So is the following true? 1. You tried to boot up DSM and it asked to migrate. 2. You decided to perform the migration installation 3. The system then booted up to the state you post above 4. You don't remove the boot loader USB, it stays in place Please confirm whether the above list is true. And when you reboot, does it try to migrate again or come back to the state you posted? Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #9 Posted January 16, 2020 (edited) 2 hours ago, flyride said: I am getting lost in your explanation. If your arrays are crashed, they will be read-only or unavailable, so that can be expected. You keep saying "pop the xpe usb back." I'm assuming you did that only once and it is still installed. Right? So is the following true? 1. You tried to boot up DSM and it asked to migrate. 2. You decided to perform the migration installation 3. The system then booted up to the state you post above 4. You don't remove the boot loader USB, it stays in place Please confirm whether the above list is true. And when you reboot, does it try to migrate again or come back to the state you posted? All are true. It didn't ask to migrate again after rebooting. But this happened. Before rebooting, all disks showed Normal in Disk Allocation Status. mdstat after rebooting (md2 and md0 are different than before reboot): # cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md2 : active raid5 sdb5[0] sdl5[7] sdk5[5] sdf5[4] sde5[3] sdd5[2] sdc5[1] 35105225472 blocks super 1.2 level 5, 64k chunk, algorithm 2 [13/7] [UUUUUU_U_____] md4 : active raid5 sdl6[0] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/1] [U____] md1 : active raid1 sdl2[6] sdk2[5] sdf2[4] sde2[3] sdd2[2] sdc2[1] sdb2[0] 2097088 blocks [12/7] [UUUUUUU_____] md0 : active raid1 sdb1[1] sdc1[2] sdd1[3] sdf1[5] sdk1[6] sdl1[7] sdm1[8] sdn1[0] sdo1[10] sdp1[4] 2490176 blocks [12/10] [UUUUUUUUU_U_] unused devices: <none> root@homelab:~# mdadm --detail /dev/md2 /dev/md2: Version : 1.2 Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Used Dev Size : 2925435456 (2789.91 GiB 2995.65 GB) Raid Devices : 13 Total Devices : 7 Persistence : Superblock is persistent Update Time : Fri Jan 17 02:11:28 2020 State : clean, FAILED Active Devices : 7 Working Devices : 7 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : homelab:2 (local to host homelab) UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Events : 370911 Number Major Minor RaidDevice State 0 8 21 0 active sync /dev/sdb5 1 8 37 1 active sync /dev/sdc5 2 8 53 2 active sync /dev/sdd5 3 8 69 3 active sync /dev/sde5 4 8 85 4 active sync /dev/sdf5 5 8 165 5 active sync /dev/sdk5 - 0 0 6 removed 7 8 181 7 active sync /dev/sdl5 - 0 0 8 removed - 0 0 9 removed - 0 0 10 removed - 0 0 11 removed - 0 0 12 removed root@homelab:~# mdadm --detail /dev/md0 /dev/md0: Version : 0.90 Creation Time : Sun Sep 22 21:01:46 2019 Raid Level : raid1 Array Size : 2490176 (2.37 GiB 2.55 GB) Used Dev Size : 2490176 (2.37 GiB 2.55 GB) Raid Devices : 12 Total Devices : 10 Preferred Minor : 0 Persistence : Superblock is persistent Update Time : Fri Jan 17 02:18:37 2020 State : clean, degraded Active Devices : 10 Working Devices : 10 Failed Devices : 0 Spare Devices : 0 UUID : f36dde6e:8c6ec8e5:3017a5a8:c86610be Events : 0.536737 Number Major Minor RaidDevice State 0 8 209 0 active sync /dev/sdn1 1 8 17 1 active sync /dev/sdb1 2 8 33 2 active sync /dev/sdc1 3 8 49 3 active sync /dev/sdd1 4 8 241 4 active sync /dev/sdp1 5 8 81 5 active sync /dev/sdf1 6 8 161 6 active sync /dev/sdk1 7 8 177 7 active sync /dev/sdl1 8 8 193 8 active sync /dev/sdm1 - 0 0 9 removed 10 8 225 10 active sync /dev/sdo1 - 0 0 11 removed OK lemme rephrase. Post #4 says I used the ubuntu usb. Post #5 you asked me to use the xpe usb and run those commands. Post #6 states when I put the xpe usb back it asked me to migrate. I migrated, and hence lost my edited synoinfo.conf and it defaults to 6 used disks, etc. I can't make any changes since everything is in read-only mode. xpe usb is the same one that I've been using since the very beginning. Edited January 16, 2020 by C-Fu Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #10 Posted January 16, 2020 Got it, thanks for the clarification. It's unfortunate that a migration installation occurred, but as long as it doesn't keep happening we can continue. According to the mdstat you posted, the root filesystem is NOT in read-only mode (in fact I don't think DSM will boot successfully if it is in read-only mode). So you should be able to edit /etc.defaults/synoinfo.conf and restore your disk mask configuration. Are you editing as sudo? Once you can boot DSM "normally" with no migration installation and your disks are back in the layout they were at the beginning, please come back and post these again: cat /proc/mdstat Using each of the arrays returned by mdstat: mdadm --detail /dev/<array> ls /dev/sd* ls /dev/md* Don't be concerned about disks and volumes being crashed for now, let's just get the disks addressable in the way they were at the beginning. Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #11 Posted January 16, 2020 (edited) 35 minutes ago, flyride said: Don't be concerned about disks and volumes being crashed for now, let's just get the disks addressable in the way they were at the beginning. synoinfo.conf editing works! Not sure why it works after reboot, but meh doesn't matter 😁 3 drives have System Partition Failed now. Anyways.. md2, md4, md5, md1, md0. # ls /dev/sd* /dev/sda /dev/sdb2 /dev/sdc2 /dev/sdd2 /dev/sde2 /dev/sdf2 /dev/sdk2 /dev/sdl2 /dev/sdm1 /dev/sdn /dev/sdn6 /dev/sdo2 /dev/sdp1 /dev/sdq1 /dev/sdr1 /dev/sdr7 /dev/sda1 /dev/sdb5 /dev/sdc5 /dev/sdd5 /dev/sde5 /dev/sdf5 /dev/sdk5 /dev/sdl5 /dev/sdm2 /dev/sdn1 /dev/sdn7 /dev/sdo5 /dev/sdp2 /dev/sdq2 /dev/sdr2 /dev/sdb /dev/sdc /dev/sdd /dev/sde /dev/sdf /dev/sdk /dev/sdl /dev/sdl6 /dev/sdm5 /dev/sdn2 /dev/sdo /dev/sdo6 /dev/sdp5 /dev/sdq5 /dev/sdr5 /dev/sdb1 /dev/sdc1 /dev/sdd1 /dev/sde1 /dev/sdf1 /dev/sdk1 /dev/sdl1 /dev/sdm /dev/sdm6 /dev/sdn5 /dev/sdo1 /dev/sdp /dev/sdq /dev/sdr /dev/sdr6 root@homelab:~# cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md2 : active raid5 sdb5[0] sdp5[10] sdn5[11] sdo5[9] sdm5[8] sdl5[7] sdk5[5] sdf5[4] sde5[3] sdd5[2] sdc5[1] 35105225472 blocks super 1.2 level 5, 64k chunk, algorithm 2 [13/11] [UUUUUU_UUU_UU] md4 : active raid5 sdl6[0] sdn6[3] sdo6[2] sdm6[1] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/4] [UUU_U] md5 : active raid1 sdn7[0] 3905898432 blocks super 1.2 [2/1] [U_] md1 : active raid1 sdr2[12] sdq2[11] sdp2[10] sdo2[9] sdn2[8] sdm2[7] sdl2[6] sdk2[5] sdf2[4] sde2[3] sdd2[2] sdc2[1] sdb2[0] 2097088 blocks [24/13] [UUUUUUUUUUUUU___________] md0 : active raid1 sdb1[1] sdc1[2] sdd1[3] sdf1[5] sdk1[6] sdl1[7] sdm1[8] sdn1[0] sdo1[10] sdp1[4] 2490176 blocks [12/10] [UUUUUUUUU_U_] unused devices: <none> /dev/md2: Version : 1.2 Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Used Dev Size : 2925435456 (2789.91 GiB 2995.65 GB) Raid Devices : 13 Total Devices : 11 Persistence : Superblock is persistent Update Time : Fri Jan 17 03:26:11 2020 State : clean, FAILED Active Devices : 11 Working Devices : 11 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : homelab:2 (local to host homelab) UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Events : 370917 Number Major Minor RaidDevice State 0 8 21 0 active sync /dev/sdb5 1 8 37 1 active sync /dev/sdc5 2 8 53 2 active sync /dev/sdd5 3 8 69 3 active sync /dev/sde5 4 8 85 4 active sync /dev/sdf5 5 8 165 5 active sync /dev/sdk5 - 0 0 6 removed 7 8 181 7 active sync /dev/sdl5 8 8 197 8 active sync /dev/sdm5 9 8 229 9 active sync /dev/sdo5 - 0 0 10 removed 11 8 213 11 active sync /dev/sdn5 10 8 245 12 active sync /dev/sdp5 /dev/md4: Version : 1.2 Creation Time : Sun Sep 22 21:55:04 2019 Raid Level : raid5 Array Size : 11720987648 (11178.00 GiB 12002.29 GB) Used Dev Size : 2930246912 (2794.50 GiB 3000.57 GB) Raid Devices : 5 Total Devices : 4 Persistence : Superblock is persistent Update Time : Fri Jan 17 03:26:11 2020 State : clean, degraded Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : homelab:4 (local to host homelab) UUID : 648fc239:67ee3f00:fa9d25fe:ef2f8cb0 Events : 7052 Number Major Minor RaidDevice State 0 8 182 0 active sync /dev/sdl6 1 8 198 1 active sync /dev/sdm6 2 8 230 2 active sync /dev/sdo6 - 0 0 3 removed 3 8 214 4 active sync /dev/sdn6 /dev/md5: Version : 1.2 Creation Time : Tue Sep 24 19:36:08 2019 Raid Level : raid1 Array Size : 3905898432 (3724.96 GiB 3999.64 GB) Used Dev Size : 3905898432 (3724.96 GiB 3999.64 GB) Raid Devices : 2 Total Devices : 1 Persistence : Superblock is persistent Update Time : Fri Jan 17 03:26:06 2020 State : clean, degraded Active Devices : 1 Working Devices : 1 Failed Devices : 0 Spare Devices : 0 Name : homelab:5 (local to host homelab) UUID : ae55eeff:e6a5cc66:2609f5e0:2e2ef747 Events : 223792 Number Major Minor RaidDevice State 0 8 215 0 active sync /dev/sdn7 - 0 0 1 removed /dev/md1: Version : 0.90 Creation Time : Fri Jan 17 03:25:58 2020 Raid Level : raid1 Array Size : 2097088 (2047.94 MiB 2147.42 MB) Used Dev Size : 2097088 (2047.94 MiB 2147.42 MB) Raid Devices : 24 Total Devices : 13 Preferred Minor : 1 Persistence : Superblock is persistent Update Time : Fri Jan 17 03:26:49 2020 State : active, degraded Active Devices : 13 Working Devices : 13 Failed Devices : 0 Spare Devices : 0 UUID : 846f27e4:bf628296:cc8c244d:4f76664d (local to host homelab) Events : 0.20 Number Major Minor RaidDevice State 0 8 18 0 active sync /dev/sdb2 1 8 34 1 active sync /dev/sdc2 2 8 50 2 active sync /dev/sdd2 3 8 66 3 active sync /dev/sde2 4 8 82 4 active sync /dev/sdf2 5 8 162 5 active sync /dev/sdk2 6 8 178 6 active sync /dev/sdl2 7 8 194 7 active sync /dev/sdm2 8 8 210 8 active sync /dev/sdn2 9 8 226 9 active sync /dev/sdo2 10 8 242 10 active sync /dev/sdp2 11 65 2 11 active sync /dev/sdq2 12 65 18 12 active sync /dev/sdr2 - 0 0 13 removed - 0 0 14 removed - 0 0 15 removed - 0 0 16 removed - 0 0 17 removed - 0 0 18 removed - 0 0 19 removed - 0 0 20 removed - 0 0 21 removed - 0 0 22 removed - 0 0 23 removed /dev/md0: Version : 0.90 Creation Time : Sun Sep 22 21:01:46 2019 Raid Level : raid1 Array Size : 2490176 (2.37 GiB 2.55 GB) Used Dev Size : 2490176 (2.37 GiB 2.55 GB) Raid Devices : 12 Total Devices : 10 Preferred Minor : 0 Persistence : Superblock is persistent Update Time : Fri Jan 17 03:42:39 2020 State : active, degraded Active Devices : 10 Working Devices : 10 Failed Devices : 0 Spare Devices : 0 UUID : f36dde6e:8c6ec8e5:3017a5a8:c86610be Events : 0.539389 Number Major Minor RaidDevice State 0 8 209 0 active sync /dev/sdn1 1 8 17 1 active sync /dev/sdb1 2 8 33 2 active sync /dev/sdc1 3 8 49 3 active sync /dev/sdd1 4 8 241 4 active sync /dev/sdp1 5 8 81 5 active sync /dev/sdf1 6 8 161 6 active sync /dev/sdk1 7 8 177 7 active sync /dev/sdl1 8 8 193 8 active sync /dev/sdm1 - 0 0 9 removed 10 8 225 10 active sync /dev/sdo1 - 0 0 11 removed Edited January 16, 2020 by C-Fu Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #12 Posted January 16, 2020 11 minutes ago, C-Fu said: 3 drives have System Partition Failed now. Don't worry about that, it's not important. This is a better state than before. First, let's grab all the critical information about the broken array: # mdadm --examine /dev/sd[bcdefklmnopqr]5 >>/tmp/raid.status Then, # mdadm --examine /dev/sd[bcdefklmnopqr]5 | egrep 'Event|/dev/sd' and post the result. Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #13 Posted January 16, 2020 6 minutes ago, flyride said: # mdadm --examine /dev/sd[bcdefklmnopqr]5 >>/tmp/raid.status # cat /tmp/raid.status # cat /tmp/raid.status /dev/sdb5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : a8109f74:46bc8509:6fc3bca8:9fddb6a7 Update Time : Fri Jan 17 03:26:11 2020 Checksum : b2b47a7 - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 0 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdc5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : 8dfdc601:e01f8a98:9a8e78f1:a7951260 Update Time : Fri Jan 17 03:26:11 2020 Checksum : 286f1b5a - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 1 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdd5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : f98bc050:a4b46deb:c3168fa0:08d90061 Update Time : Fri Jan 17 03:26:11 2020 Checksum : 7a510a15 - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 2 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sde5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : 1e2742b7:d1847218:816c7135:cdf30c07 Update Time : Fri Jan 17 03:26:11 2020 Checksum : 48c5e5ea - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 3 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdf5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : ce60c47e:14994160:da4d1482:fd7901f2 Update Time : Fri Jan 17 03:26:11 2020 Checksum : 8fae9b68 - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 4 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdk5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : 706c5124:d647d300:733fb961:e5cd8127 Update Time : Fri Jan 17 03:26:11 2020 Checksum : eaf29b4c - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 5 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdl5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : 6993b9eb:8ad7c80f:dc17268f:a8efa73d Update Time : Fri Jan 17 03:26:11 2020 Checksum : 4e34c29 - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 7 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdm5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : 2f1247d1:a536d2ad:ba2eb47f:a7eaf237 Update Time : Fri Jan 17 03:26:11 2020 Checksum : 73533be8 - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 8 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdn5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : 73610f83:fb3cf895:c004147e:b4de2bfe Update Time : Fri Jan 17 03:26:11 2020 Checksum : d1da5b98 - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 11 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdo5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : 1b4ab27d:bb7488fa:a6cc1f75:d21d1a83 Update Time : Fri Jan 17 03:26:11 2020 Checksum : ad078302 - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 9 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdp5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : a64f01c2:76c56102:38ad7c4e:7bce88d1 Update Time : Fri Jan 17 03:26:11 2020 Checksum : 20fb6a8c - correct Events : 370917 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 12 Array State : AAAAAA.AAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdq5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=0 sectors State : clean Device UUID : 5cc6456d:bfc950bf:1baf6fef:aabec947 Update Time : Fri Jan 10 19:44:10 2020 Checksum : a0630221 - correct Events : 370871 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 6 Array State : AAAAAAAAAA.AA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdr5: Magic : a92b4efc Version : 1.2 Feature Map : 0x2 Array UUID : 43699871:217306be:dc16f5e8:dcbe1b0d Name : homelab:2 (local to host homelab) Creation Time : Sun Sep 22 21:55:03 2019 Raid Level : raid5 Raid Devices : 13 Avail Dev Size : 5850870912 (2789.91 GiB 2995.65 GB) Array Size : 35105225472 (33478.95 GiB 35947.75 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Recovery Offset : 78633768 sectors Unused Space : before=1968 sectors, after=0 sectors State : active Device UUID : d0a4607c:b970d906:02920f5c:ad5204d1 Update Time : Fri Jan 3 03:01:29 2020 Checksum : f185b28c - correct Events : 370454 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 10 Array State : AAAAAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) Quote # mdadm --examine /dev/sd[bcdefklmnopqr]5 | egrep 'Event|/dev/sd' # mdadm --examine /dev/sd[bcdefklmnopqr]5 | egrep 'Event|/dev/sd' /dev/sdb5: Events : 370917 /dev/sdc5: Events : 370917 /dev/sdd5: Events : 370917 /dev/sde5: Events : 370917 /dev/sdf5: Events : 370917 /dev/sdk5: Events : 370917 /dev/sdl5: Events : 370917 /dev/sdm5: Events : 370917 /dev/sdn5: Events : 370917 /dev/sdo5: Events : 370917 /dev/sdp5: Events : 370917 /dev/sdq5: Events : 370871 /dev/sdr5: Events : 370454 Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #14 Posted January 16, 2020 Ok good. Here comes a critical part. Note that the assemble command does NOT have the "r" in it. # mdadm --stop /dev/md2 Then # mdadm --assemble --force /dev/md2 /dev/sd[bcdefklmnopq]5 Then # cat /proc/mdstat and post the result. Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #15 Posted January 16, 2020 6 minutes ago, flyride said: Ok good. Here comes a critical part. Note that the assemble command does NOT have the "r" in it. It means that it's not running right? Just trying to learn and understand at the same time 😁 root@homelab:~# mdadm --stop /dev/md2 mdadm: stopped /dev/md2 root@homelab:~# root@homelab:~# mdadm --assemble --force /dev/md2 /dev/sd[bcdefklmnopq]5 mdadm: forcing event count in /dev/sdq5(6) from 370871 upto 370918 mdadm: clearing FAULTY flag for device 11 in /dev/md2 for /dev/sdq5 mdadm: Marking array /dev/md2 as 'clean' mdadm: /dev/md2 assembled from 12 drives - not enough to start the array. # cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md4 : active raid5 sdl6[0] sdn6[3] sdo6[2] sdm6[1] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/4] [UUU_U] md5 : active raid1 sdn7[0] 3905898432 blocks super 1.2 [2/1] [U_] md1 : active raid1 sdr2[12] sdq2[11] sdp2[10] sdo2[9] sdn2[8] sdm2[7] sdl2[6] sdk2[5] sdf2[4] sde2[3] sdd2[2] sdc2[1] sdb2[0] 2097088 blocks [24/13] [UUUUUUUUUUUUU___________] md0 : active raid1 sdb1[1] sdc1[2] sdd1[3] sdf1[5] sdk1[6] sdl1[7] sdm1[8] sdn1[0] sdo1[10] sdp1[4] 2490176 blocks [12/10] [UUUUUUUUU_U_] unused devices: <none> If it matters, the Kingston SSD is my cache drive. Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #16 Posted January 16, 2020 Just to make totally sure we are not making a mistake, let's do this one more time. # mdadm --detail /dev/md2 Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #17 Posted January 16, 2020 12 minutes ago, C-Fu said: It means that it's not running right? Just trying to learn and understand at the same time 😁 I meant that the assemble command deliberately omitted /dev/sdr5 Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #18 Posted January 16, 2020 7 minutes ago, flyride said: # mdadm --detail /dev/md2 # mdadm --detail /dev/md2 /dev/md2: Version : Raid Level : raid0 Total Devices : 0 State : inactive Number Major Minor RaidDevice Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #19 Posted January 16, 2020 Arg, well that wasn't helpful. Sorry. Let's do this: # mdadm --assemble --scan /dev/md2 # cat /proc/mdstat Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #20 Posted January 16, 2020 (edited) 10 minutes ago, flyride said: # mdadm --assemble --scan /dev/md2 # cat /proc/mdstat mdadm --assemble --scan /dev/md2 mdadm: /dev/md2 not identified in config file. and mdstat doesn't show md2. # cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md4 : active raid5 sdl6[0] sdn6[3] sdo6[2] sdm6[1] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/4] [UUU_U] md5 : active raid1 sdn7[0] 3905898432 blocks super 1.2 [2/1] [U_] md1 : active raid1 sdr2[12] sdq2[11] sdp2[10] sdo2[9] sdn2[8] sdm2[7] sdl2[6] sdk2[5] sdf2[4] sde2[3] sdd2[2] sdc2[1] sdb2[0] 2097088 blocks [24/13] [UUUUUUUUUUUUU___________] md0 : active raid1 sdb1[1] sdc1[2] sdd1[3] sdf1[5] sdk1[6] sdl1[7] sdm1[8] sdn1[0] sdo1[10] sdp1[4] 2490176 blocks [12/10] [UUUUUUUUU_U_] unused devices: <none> Post #15 it did say mdadm: /dev/md2 assembled from 12 drives - not enough to start the array. Edited January 16, 2020 by C-Fu Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #21 Posted January 16, 2020 Ok, let's do this instead: # mdadm --assemble /dev/md2 --uuid 43699871:217306be:dc16f5e8:dcbe1b0d # cat /proc/mdstat Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #22 Posted January 16, 2020 1 minute ago, flyride said: # mdadm --assemble /dev/md2 --uuid 43699871:217306be:dc16f5e8:dcbe1b0d # cat /proc/mdstat Here's the output: root@homelab:~# mdadm --assemble /dev/md2 --uuid 43699871:217306be:dc16f5e8:dcbe1b0d mdadm: ignoring /dev/sdc5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sdd5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sde5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sdf5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sdk5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sdl5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sdm5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sdo5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sdn5 as it reports /dev/sdq5 as failed mdadm: ignoring /dev/sdp5 as it reports /dev/sdq5 as failed mdadm: /dev/md2 assembled from 2 drives - not enough to start the array. root@homelab:~# cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md4 : active raid5 sdl6[0] sdn6[3] sdo6[2] sdm6[1] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/4] [UUU_U] md5 : active raid1 sdn7[0] 3905898432 blocks super 1.2 [2/1] [U_] md1 : active raid1 sdr2[12] sdq2[11] sdp2[10] sdo2[9] sdn2[8] sdm2[7] sdl2[6] sdk2[5] sdf2[4] sde2[3] sdd2[2] sdc2[1] sdb2[0] 2097088 blocks [24/13] [UUUUUUUUUUUUU___________] md0 : active raid1 sdb1[1] sdc1[2] sdd1[3] sdf1[5] sdk1[6] sdl1[7] sdm1[8] sdn1[0] sdo1[10] sdp1[4] 2490176 blocks [12/10] [UUUUUUUUU_U_] unused devices: <none> 🤔 Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #23 Posted January 16, 2020 (edited) Ok, let me explain what's happening just a bit. According to mdstat, all the arrays that comprise your SHR are degraded but intact, except for /dev/md2, which is the small array that spans every one of your disks. When you had two concurrently crashed drives, this is what took your SHR down (since a RAID5 needs all but one device to be working). Once all the disks were online and addressable, we examined them in detail. All array members have an event ID associated with the I/O of the array. 10 (EDIT: 11, actually) of the drives were in sync, 1 was "just" out of sync, and 1 was a bit more out of sync. So the first --force command attempted to start the array, omitting the worst out of sync drive. A force command will cause the array to make irreversible changes to itself, so we want to do so very sparingly. I don't want to start the "bad" /dev/sdr5 with the array yet, and we are struggling with the exact syntax to do so. And it is erroring out on the "just" out of sync drive so despite our first "force," the view of that drive is not fully consistent throughout the array. Basically we are trying to start it in a degraded state, but not to force if not safe to do so. So.... let's first try: # mdadm --assemble --run /dev/md2 /dev/sd[bcdefklmnopq]5 # cat /proc/mdstat Edited January 17, 2020 by flyride Quote Link to comment Share on other sites More sharing options...
C-Fu Posted January 16, 2020 Author Share #24 Posted January 16, 2020 (edited) 14 minutes ago, flyride said: # mdadm --assemble --run /dev/md2 /dev/sd[bcdefklmnopq]5 # cat /proc/mdstat root@homelab:~# mdadm --assemble --run /dev/md2 /dev/sd[bcdefklmnopq]5 mdadm: /dev/md2 has been started with 12 drives (out of 13). root@homelab:~# root@homelab:~# cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md2 : active raid5 sdb5[0] sdp5[10] sdn5[11] sdo5[9] sdm5[8] sdl5[7] sdq5[13] sdk5[5] sdf5[4] sde5[3] sdd5[2] sdc5[1] 35105225472 blocks super 1.2 level 5, 64k chunk, algorithm 2 [13/12] [UUUUUUUUUU_UU] md4 : active raid5 sdl6[0] sdn6[3] sdo6[2] sdm6[1] 11720987648 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/4] [UUU_U] md5 : active raid1 sdn7[0] 3905898432 blocks super 1.2 [2/1] [U_] md1 : active raid1 sdr2[12] sdq2[11] sdp2[10] sdo2[9] sdn2[8] sdm2[7] sdl2[6] sdk2[5] sdf2[4] sde2[3] sdd2[2] sdc2[1] sdb2[0] 2097088 blocks [24/13] [UUUUUUUUUUUUU___________] md0 : active raid1 sdb1[1] sdc1[2] sdd1[3] sdf1[5] sdk1[6] sdl1[7] sdm1[8] sdn1[0] sdo1[10] sdp1[4] 2490176 blocks [12/10] [UUUUUUUUU_U_] unused devices: <none> I think it's a (partial) success... maybe? Thanks for the lengthy layman explanation, I honestly appreciate that!!! I was wondering about the event ID thing, I thought it corresponds to some system log somewhere. Edited January 16, 2020 by C-Fu Quote Link to comment Share on other sites More sharing options...
flyride Posted January 16, 2020 Share #25 Posted January 16, 2020 Something isn't quite right. Do you have 13 drives plus a cache drive, or 12 plus cache? Which drive is your cache drive now? Please post fdisk -l Quote Link to comment Share on other sites More sharing options...
