Synology apps requiring a valid serial number
I have searching through the forum and apparently since DSM 6.1.2 a valid serial number is required to use some of the synology apps
Is someone maintaining a list of such apps? I have just installed Xpenology in a intel NUC and it's absolutely fantastic, but it a the apps I need are going to stop working I should move to other solutions, like OMV.
For the time being the apps which require a valid sn are:
-. Photo Station
-. Video Station
-. Audio Station
-. Quick connect
Some of them require a valid sn to transcode. Luckily I'm not using that ones nor quick connect.
The ones I really need and that for the time being are working for me with DSM 6.1.6 are:
CloudSync
USBCopy
CloudStation
Download Station
Transmission (there shouldn't be any problem with this one)
-. Any one is having problems due to non valid sn with those apps?
-. Any list of not working apps?
-. If I stop updating DSM but continue updating apps, those apps could stop working in the future? So it's recommended to stop updating DSM AND apps?
Regards:
J.A
Edited by javivanco
  • 3 weeks later...
  • 4 weeks later...
On 8.6.2018 at 12:18 PM, plomkiolki said:
when installing i ve used a SN provided by the generator in the procedure and all the apps mentionned are working perfectly fine.
but i confirm, you need a SN
could you provide a link where to find this generator? could not find it with search...:37_disappointed:
  • 3 months later...
including quick connect?
I'm using a photo station and download station and those are fine.  I get an error message when I tried to login for quickconnect.  "The system failed to perform the requested operation, there is an unkonwn error"
could it have been corrupted as part of my load?
  • 2 months later...
Video station doesn't seem to transcode anything if I use the default serial number in Jun's 1.03b loader with DS3615xs. If I use the serial number generator above, how can I modify the serial of an already existing installation on ESXi? Do I just change it in grub.cfg and re-upload that synoboot.img as the boot drive for VM? Or do things get written to that now that I have been using it and uploading a new one will break everything?
