nick w Posted June 3, 2015 Share #1 Posted June 3, 2015 Has anyone successfully updated to 5.2 on an HP Gen7 Micro Server The process - Write Image to new USB Power Down Server Take out old usb and insert new one Power On Select Update/install/downgrade wait for it to boot synology assistant - connect to server Migrate = Done DSM 5.2-5565 PAT download c50385e13495fef366fbd590bbe376fb I wont go to update 1 just yet Is that correct? Thanks N Quote Link to comment Share on other sites More sharing options...
Hackerjac Posted June 3, 2015 Share #2 Posted June 3, 2015 that is correct, i did the same with my gen 7 n36l, worked like it should Quote Link to comment Share on other sites More sharing options...
nick w Posted June 3, 2015 Author Share #3 Posted June 3, 2015 HackerJac, Did you update to Update1 on 5.2? There are 2 options for me to update DSM 5.2-5565 or DSM 5.2-5565 update 1 Im not sure which is safer Thanks N Quote Link to comment Share on other sites More sharing options...
Hackerjac Posted June 3, 2015 Share #4 Posted June 3, 2015 i did DSM 5.2-5565 first, them downloaded the update 1 and made a manuel install within dsm 5.2 had to hard reboot the server after the u1 install to get it working Quote Link to comment Share on other sites More sharing options...
fjf Posted June 3, 2015 Share #5 Posted June 3, 2015 i did DSM 5.2-5565 first, them downloaded the update 1 and made a manuel install within dsm 5.2had to hard reboot the server after the u1 install to get it working Same here. Quote Link to comment Share on other sites More sharing options...
andyxm715 Posted June 3, 2015 Share #6 Posted June 3, 2015 The process I used to update my G7 N54L Server (going from 5.1-5055 Update 5 to 5.2-5565 Update 1) Power Down Server Take out usb boot drive and update with latest boot image / re-insert usb drive Power On Select XPEnology DSM 5.2-5565 top boot option NOT debug or install/upgrade option wait for it to boot log in via web browser Download DSM 5.2-5565.pat from http://www.xpenology.nl/xpenology-software/ update and let it reboot log back in via web browser go to control panel - update and restore, check for updates, let it download and install update 1 wait for it to reboot Done Quote Link to comment Share on other sites More sharing options...
wvh3 Posted June 3, 2015 Share #7 Posted June 3, 2015 Yea, that's what I did,.... now mine is inaccessible... and won't show up in Synology Assistant... not sure how I'm going to resolve. Always make sure you back up your data! Quote Link to comment Share on other sites More sharing options...
Hackerjac Posted June 3, 2015 Share #8 Posted June 3, 2015 have you tried this For those who made th Update to 5.2-5565 Update 1 and can't access the dsm: 1. First to get access crowpet wrote:Think i got it on my n54l with Monitor and keyboard localy atached! 1. Login as root 2. type su 3. ifconfig eth0 - I only had a ip v6 adress -> so no connection 4. type ifconfig eth0 #IPofNAS# netmask 255.255.255.0 up -> now you can connect via browser on the given ip 5. Login in DSM in Browser 6. Goto "Controlcenter" -> "Network" - Check the settings on your NIC "LAN1" and tourn off ipv6 - I have set the ip to static Don't reboot!!! 2. Now you can Trry to downgrade (migration install) - to keep your app's and configs - Ive done the steps here "http://xpenology.me/how-to-downgrade-from-dsm-5-2/" but ive installed the "DSM 5.2-5565" from here "http://xpenology.me/downloads/" - After the migration install iam up an running and everthing seems fin now Dont update again or the dsm will got the same errors!!!! Hope this is a help 3. Think about a clean install / test system Quote Link to comment Share on other sites More sharing options...
wvh3 Posted June 3, 2015 Share #9 Posted June 3, 2015 Yes, first thing I tried. System is still not accessible after having entered those at the CLI Quote Link to comment Share on other sites More sharing options...
nick w Posted June 3, 2015 Author Share #10 Posted June 3, 2015 The process I used to update my G7 N54L Server (going from 5.1-5055 Update 5 to 5.2-5565 Update 1) Power Down Server Take out usb boot drive and update with latest boot image / re-insert usb drive Power On Select XPEnology DSM 5.2-5565 top boot option NOT debug or install/upgrade option wait for it to boot log in via web browser Download DSM 5.2-5565.pat from http://www.xpenology.nl/xpenology-software/ update and let it reboot log back in via web browser go to control panel - update and restore, check for updates, let it download and install update 1 wait for it to reboot Done So why not upgrade? Thats what I normally do during upgrades. If I don't select update do i lose my apps? Thanks. N Quote Link to comment Share on other sites More sharing options...
nick w Posted June 3, 2015 Author Share #11 Posted June 3, 2015 have you tried this For those who made th Update to 5.2-5565 Update 1 and can't access the dsm: 1. First to get access crowpet wrote:Think i got it on my n54l with Monitor and keyboard localy atached! 1. Login as root 2. type su 3. ifconfig eth0 - I only had a ip v6 adress -> so no connection 4. type ifconfig eth0 #IPofNAS# netmask 255.255.255.0 up -> now you can connect via browser on the given ip 5. Login in DSM in Browser 6. Goto "Controlcenter" -> "Network" - Check the settings on your NIC "LAN1" and tourn off ipv6 - I have set the ip to static Don't reboot!!! 2. Now you can Trry to downgrade (migration install) - to keep your app's and configs - Ive done the steps here "http://xpenology.me/how-to-downgrade-from-dsm-5-2/" but ive installed the "DSM 5.2-5565" from here "http://xpenology.me/downloads/" - After the migration install iam up an running and everthing seems fin now Dont update again or the dsm will got the same errors!!!! Hope this is a help 3. Think about a clean install / test system Would you suggest not going to update 1? Shall I avoid it now when i got to 5.2 Thanks. N Quote Link to comment Share on other sites More sharing options...
wvh3 Posted June 4, 2015 Share #12 Posted June 4, 2015 Ok, so update... After several reboots and attempts at different fixes, I was able to use the "ifconfig eth0 netmask up" command, along with setting the Version# back, along with Install/Upgrade boot... finally Synology Assistant sees the nas, and attempts to write 5.2.5665 to it... even so it Still doesn't come up with an IP by itself, so once again I manually set it using the ifconfig command... and Im now finally able to log into the DSM. Now, Im looking at doing a Clean Install to fix this mess... I thought I read someone mentioning an ability to perform a clean install while maintaining the Data on the drives, but I can't find that information now. I'm cleaning out my data to prepare for a full backup if Im told that a clean backup is Going to be destructive.... but let me know if Im wrong. Thanks for the help and suggestions ya'll (especially hackerjac and crowpet) Quote Link to comment Share on other sites More sharing options...
A.S._id Posted June 4, 2015 Share #13 Posted June 4, 2015 Warning! downgrade from 5.2-5565 to 5.1< without lost data, possible via Nanoboot install/upgrade After install/upgrade Nanoboot turn off NAS, flash Xpenoboot 5.1 and make migration Quote Link to comment Share on other sites More sharing options...
Hyperbit Posted June 4, 2015 Share #14 Posted June 4, 2015 There must be one bug with out HP machines i can ping my server but webservices are offline only this helps: . Login as root 2. type su 3. ifconfig eth0 4. type ifconfig eth0 #IPofNAS# netmask 255.255.255.0 up -> now you can connect via browser on the given ip 5. Login in DSM in Browser then the Webinterface is reachable, and shows a error "Dienst [Web Station service] konnte nicht gestartet werden. Bitte kontaktieren Sie den Synology Kundendienst, um Unterstützung zu erhalten." whats wrong with our machines? Quote Link to comment Share on other sites More sharing options...
taffeys Posted June 4, 2015 Share #15 Posted June 4, 2015 Has anyone successfully updated to 5.2 on an HP Gen7 Micro Server Yes, I updated my N54L (with modified bios) to 5.2-5565 Update 1 without any problems. Quote Link to comment Share on other sites More sharing options...
pm1982 Posted June 4, 2015 Share #16 Posted June 4, 2015 Are all apps in example Audio Statio, Video Station working correctly? Bacuse on mine HP N40L XPeno, all apps are disabled and I can't start them. EDIT: Resource monitor doesn't work anymore. Quote Link to comment Share on other sites More sharing options...
anthonyuk Posted June 5, 2015 Share #17 Posted June 5, 2015 Are all apps in example Audio Statio, Video Station working correctly?Bacuse on mine HP N40L XPeno, all apps are disabled and I can't start them. EDIT: Resource monitor doesn't work anymore. For previous updates I needed to reboot 2-3 times before all things were back to normal. The disabled apps was one of the things that was resolved in this way. Hope it helps. Quote Link to comment Share on other sites More sharing options...
freddan83 Posted June 7, 2015 Share #18 Posted June 7, 2015 Anyone who has solved the no-eth-connection problem? Quote Link to comment Share on other sites More sharing options...
pm1982 Posted June 8, 2015 Share #19 Posted June 8, 2015 I solved mine "no-eth-connection problem" only by following these steps: 1. Login as root 2. type su 3. ifconfig eth0 4. type ifconfig eth0 IPofNAS netmask 255.255.255.0 up -> now you can connect via browser on the given ip 5. Login in DSM in Browser Quote Link to comment Share on other sites More sharing options...
lolvince Posted June 8, 2015 Share #20 Posted June 8, 2015 i have the same problem of pm1982. n40L no detect with Synology assistant, video sation, audiosatiton, ressource monitor, and few apps dosent work ! Quote Link to comment Share on other sites More sharing options...
Hyperbit Posted June 8, 2015 Share #21 Posted June 8, 2015 We need a solution that works even after rebooting. Ipconfig Command works only until reboot. Quote Link to comment Share on other sites More sharing options...
lolvince Posted June 8, 2015 Share #22 Posted June 8, 2015 Indeed, Each to restart the same problem . With the new version 5.2 to 5565.2 IT does not correct the problem ? Quote Link to comment Share on other sites More sharing options...
nick w Posted June 8, 2015 Author Share #23 Posted June 8, 2015 My n54l updated without any issues to 5.2 Sent from my Nexus 6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
freddan83 Posted June 8, 2015 Share #24 Posted June 8, 2015 I solved mine "no-eth-connection problem" only by following these steps:1. Login as root 2. type su 3. ifconfig eth0 4. type ifconfig eth0 IPofNAS netmask 255.255.255.0 up -> now you can connect via browser on the given ip 5. Login in DSM in Browser Yes this works, but not after a reboot (for me anyway) Quote Link to comment Share on other sites More sharing options...
pm1982 Posted June 8, 2015 Share #25 Posted June 8, 2015 Strange, for me it works even after reboot. Quote Link to comment Share on other sites More sharing options...
