Help me chose a quad-port GbE NIC, please
asheenlevrai
As you could tell from the threads I started about issues with quad-port NICs from DeLock (Realtek RTL8111G), I am in a pretty annoying situation.
I am currently considering returning these cards and buy a different model.
The following cards are priced close enough and uses the BCM5719 chipset (AFAIU)
 - HP 331T (HPE 647594-B21)
 - ThinkSystem Broadcom 5719 1GbE RJ45 4-Port PCIe Ethernet Adapter
However, reading this, I wonder if it will work in ds3617xs with loader 1.03b.
Or would I need extra drivers?
Or wouldn't it work at all unless 918+ & 1.04b?
All the aforementioned NICs are PCIe2.0 x4
Cheaper alternatives include PCIe2.0 x1 but I was told to avoid these since the bandwidth could be limiting (although theoretically PCIe2.0 x1 is just enough for 4 GbE concurrent connections)
 - DeLock 89025 (based on Realtek RTL8111F)
 - Exsys 6084 (based on Realtek RTL8153B) !!"The Product is in PCIExpressform factor with a built-in USB3.1 (Gen 1)Host Controllerand 4 USB3.1 Gigabit Ethernet Converters to provide an instant expansion of 4Gigabit Ethernet ports for your Desktop, Server and Thin-Client computers."!!
Thank you very much in advance for your help.
Best,
-a-
Edited by asheenlevrai
  • asheenlevrai changed the title to Help me chose a quad-port GbE NIC, please
44 minutes ago, gadreel said:
I have this https://www.amazon.de/-/en/10Gtek®-Gigabit-PCIE-Network-I350-T4/dp/B01H6NE4X2/ref=sr_1_3?crid=1LDVHK8KG489E&dchild=1&keywords=i350-t4&qid=1626087365&sprefix=I350%2Caps%2C244&sr=8-3
I pass this through and never had an issue with it (DS918+). i350 chips was launched in 2011. I do not see any reason not to be supported.
@IG-88 do you know if this card would require any special drivers for 3617xs & 1.03b?
to be sure you would need to know pci vendor an product id
these are supported by the igb.ko driver (5.3.5.39) in the last published extra.lzma
17aa 1074  ThinkServer I350-T4 AnyFabric
8086 0001  Ethernet Server Adapter I350-T4
8086 0003  Ethernet Server Adapter I350-T4
8086 00a1  Ethernet Server Adapter I350-T4
8086 00a3  Ethernet Server Adapter I350-T4
8086 5001  Ethernet Server Adapter I350-T4
a more recent 2021 5.5.2 igb driver has one i350-T4 entry more
8086 00aa  Ethernet Network Adapter I350-T4 for OCP NIC 3.0
but thats a special version for .opencompute 3.0 spec, not relevant for your problem
so i guess it should work, if not with synology own driver in 6.2.3 u3 (igb.ko version 5.3.5.3, source ~5 years old?) then at least with the extra.lzma's newer driver
i had v5.3.5.4 around and that supports the following id's
17aa 1074  Lenovo ThinkServer I350-T4 AnyFabric
thats what is to expect to work ootb with 3617 6.2.3 u3
at least the extra.lzma it should work if your are unlucky and its a 8086:00a3
2 hours ago, gadreel said:
[8086:1521] 04:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
according to the pci.update file in the driver source thats just one of the main id's of i350, there should be sub id's like the one's from above
the sub id's might be there because of different phy chips (i guess), the 00a3 sub id not persent in the ootb driver is the only one (important) missing but present in the driver from my extra.lzma, if the card does not work ootb then try the extra.lzma with the newer driver
On 7/12/2021 at 2:23 AM, asheenlevrai said:
Best,
-a-
I was running HP card under 3615xs loader. This was a while ago, but I didn't need any drivers to make it work.
The card was:
HP 435508-B21
https://www.newegg.com/hp-435508-b21/p/N82E16816401074
  • 3 weeks later...
Hi :)
Just received 2 quad-port NICs based in Intel i350.
both of them work in random windows machines that I have around.
None of them work in my xpen system (aka "machineB" in this thread). Imean thy system won't even post... MachineB still boots ok with the single-port NIC I was using previously.
I guess there must be some other hardware incompatibility or issue. IDK. I'm pretty much lost right now...
