network detection problem 916+
apple3000
MyPC is i7 3770, realtek Giga family. RTL8168.
I have same issue above.
I used jun's 1.0.2b 916p synoboot.img.
and extra.lzma v 4.5 from
but, web browser or synology Asistant did not found my PC
Test 2. I have tested on Vmware12 (network driver is intel1000e. i edited vmx.)
my PC detected over network, and I installed successfully 916+ on vmware.
extra.lzma not include my PC network driver? realtek 8168?
But i saw extra.lzma 4.5 included r8168 driver from it 's driver list.
Test3. with 3617sx synoboot.img
MyPC detected over network.
So, I guess that 916+ extra.lzma has driver issue.
Edited by apple3000
yes, looks like it is the case, i was not so shure about the processor, afair jun said min. 4th gen, yous is 3rd gen but when it boots in vmware (handing down all processor stuff to the vm) and it boots then it must be working
did you try without my extra.lzma?
jun has realtek drivers too, lately i switched to drivers from realtek instead of kernel drivers in my extra.lzma (seems to work for non 916+)
whats the mainboard (onboard realtek i guess)?
you processor supports vt-d so in theory you could hand over the realtek card to the vm (as 2nd nic) for testing, that way you can install and check whats in the log about the realtek driver
Edited by IG-88
Thanks. I will try as your guide. Then i will report.
1. when i try before somedays, I use original extra.lzma from jun's 1.0.2b 916+. At the result, didn't find pc. So I changed 4.5 extra.lzma.
2.
1)Real testing PC1 - H61S1 (samsung OEM, onboard lan, realtek giga 8168), i7 3770 cpu 3rd gen. --> Failed.
2)Real testing PC2 - H110 (Juyeon OEM, onboard  lan, realtek giga 8168), i7 6770 cpu 6th gen. -->Failed.
3)virtual testing PC3 -ASUS H81M-C (Juyeon OEM, onboard,  lan reatek giga 8168, i7 4790 4th gen - VMWARE12 TESTing. i wrote above. vmware testing Success.
All PC support intel -VT and enabled.
3. how to add the realtek card to the vm? i edited .vmx and add e1000 (intel) but i don't know how to add realtek lan.
i tested network mod, NAT, Bridged. And i succedded at 2 methods.
isn't bridge mode mean real host's lan adaptor? then bridge mode means my realtek8168 lan..
i will try to test more and more.
Another check ? give me help. very thanks for your concerning.
 it was about handing over the pci-express device directly to the vm, no driver, bridge or anything, esxi does support that and i guessed vmware workstation does too (its called passthrough or vmdirectpath and in esxi its in advanced settings) but looks like it does not because windows does controll the hardware when using vmare workstation (i guess)
finding out with the log whats going on can be painful as the way is about connection a serial cable and having a computer on that serial connection to read the output (terminal like putty), its much easyer if you have it up and runnig
how about putting additional nic (other then realtek) into a system and install dsm, and after installing you can connect by that nic to the system and see the log about the onboard realtek nic
i have a question.
i installed 916P on vmware. and with putty, connected dsm
in directory " /lib/modules# ", listed all file to find 8168 realtek.
but i can not find those. like attached image.
vmware's NIC is e1000 (intel).
does have "lib/modules# " include only just existing NIC? no problem?
i connected serial port to find error. So, below is result.
i7 3770, DS916+ jun's mod 1.02b used.
.[H.[J.[1;1H.[?25l.[m.[H.[J.[1;1H.[2;21HGNU GRUB  version 2.02~beta2-36ubuntu3.9
.[m.[4;2H+----------------------------------------------------------------------------+.[5;2H|.[5;79H|.[6;2H|.[6;79H|.[7;2H|.[7;79H|.[8;2H|.[8;79H|.[9;2H|.[9;79H|.[10;2H|.[10;79H|.[11;2H|.[11;79H|.[12;2H|.[12;79H|.[13;2H|.[13;79H|.[14;2H|.[14;79H|.[15;2H|.[15;79H|.[16;2H|.[16;79H|.[17;2H+----------------------------------------------------------------------------+.[m.[18;2H.[19;2H.[m     Use the ^ and v keys to select which entry is highlighted.
      Press enter to boot the selected OS, `e' to edit the commands
      before booting or `c' for a command-line.                           .[5;80H .[7m.[5;3H*DS916+ 6.1 Baremetal with Jun's Mod v1.02b                                 .[m.[5;78H.[m.[m.[6;3H DS916+ 6.1 Baremetal with Jun's Mod v1.02b Reinstall                       .[m.[6;78H.[m.[m.[7;3H DS916xs 6.1 VMWare/ESXI with Jun's Mod v1.02b                              .[m.[7;78H.[m.[m.[8;3H        .[m.[8;78H.[m.[m.[9;3H        .[m.[9;78H.[m.[m.[10;3H        .[m.[10;78H.[m.[m.[11;3H        .[m.[11;78H.[m.[m.[12;3H        .[m.[12;78H.[m.[m.[13;3H        .[m.[13;78H.[m.[m.[14;3H        .[m.[14;78H.[m.[m.[15;3H        .[m.[15;78H.[m.[m.[16;3H        .[m.[16;78H.[m.[16;80H .[5;78H.[22;1H   The highlighted entry will be executed automatically in 1s.                 .[5;78H.[22;1H        .[23;1H        .[5;78H.[m.[5;3H DS916+ 6.1 Baremetal with Jun's Mod v1.02b                                 .[m.[5;78H.[m.[7m.[6;3H*DS916+ 6.1 Baremetal with Jun's Mod v1.02b Reinstall                       .[m.[6;78H.[m.[m.[6;3H DS916+ 6.1 Baremetal with Jun's Mod v1.02b Reinstall                       .[m.[6;78H.[m.[7m.[5;3H*DS916+ 6.1 Baremetal with Jun's Mod v1.02b                                 .[m.[5;78H.[m.[?25h.[H.[J.[1;1H.[H.[J.[1;1H.[H.[J.[1;1H.[H.[J.[1;1H[    0.292388] invalid opcode: 0000 [#1] SMP
[    0.296520] Modules linked in:
[    0.299591] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.102 #15047
[    0.306025] Hardware name: SAMSUNG ELECTRONICS CO., LTD. Samsung DeskTop System/SAMSUNG_DT1234567890, BIOS P04KJS.030.130809.XJ 08/09/2013
[    0.318439] task: ffff8802148c1510 ti: ffff8802148c4000 task.ti: ffff8802148c4000
[    0.325914] RIP: 0010:[<ffffffff8148f33e>]  [<ffffffff8148f33e>] sha_transform+0x2e/0x12e0
[    0.334194] RSP: 0000:ffff8802148c7d60  EFLAGS: 00010092
[    0.339502] RAX: ffffffff819c2a80 RBX: 0000000010325476 RCX: 00000000e8a4602c
[    0.346629] RDX: ffff8802148c7db0 RSI: ffffffff819c2a80 RDI: ffff8802148c7d98
[    0.353756] RBP: 00000000c3d2e1f0 R08: 00000000efcdab89 R09: 0000000010325476
[    0.360882] R10: 0000000067452301 R11: 0000000098badcfe R12: 00000000f33d5697
[    0.368010] R13: ffff8802148c7e66 R14: 0000000000000286 R15: 0000000000000004
[    0.375138] FS:  0000000000000000(0000) GS:ffff88021f240000(0000) knlGS:0000000000000000
[    0.383228] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[    0.388966] CR2: 0000000000000000 CR3: 000000000180d000 CR4: 00000000001407e0
[    0.396094] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[    0.403221] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[    0.410348] Stack:
[    0.412359]  0000000000000010 ffffffff81842cc0 ffffffff81842ce4 ffff8802148c7e66
[    0.419818]  0000000000000286 0000000000000004 ffffffff812fa652 efcdab8967452301
[    0.427273]  1032547698badcfe 00000000c3d2e1f0 ffffffff81842e10 0000000000000246
[    0.434730] Call Trace:
[    0.437178]  [<ffffffff812fa652>] ? extract_buf+0x62/0x140
[    0.442666]  [<ffffffff810579a5>] ? __wake_up+0x35/0x50
[    0.447894]  [<ffffffff812fa464>] ? account+0x104/0x290
[    0.453113]  [<ffffffff812fab9c>] ? extract_entropy+0x5c/0x170
[    0.458940]  [<ffffffff8115f047>] ? proc_register+0x67/0x140
[    0.464595]  [<ffffffff813e89fb>] ? neigh_hash_alloc+0x7b/0xb0
[    0.470428]  [<ffffffff813e8ab6>] ? neigh_table_init+0x86/0x2b0
[    0.476342]  [<ffffffff818a13af>] ? arp_init+0xc/0x47
[    0.481387]  [<ffffffff818a16c0>] ? inet_init+0x18e/0x27a
[    0.486780]  [<ffffffff818a1532>] ? ipv4_offload_init+0x63/0x63
[    0.492694]  [<ffffffff810003aa>] ? do_one_initcall+0xea/0x140
[    0.498522]  [<ffffffff81876dc8>] ? kernel_init_freeable+0x13a/0x1bb
[    0.504868]  [<ffffffff814909f0>] ? rest_init+0x70/0x70
[    0.510088]  [<ffffffff814909f5>] ? kernel_init+0x5/0x180
[    0.515481]  [<ffffffff814a2548>] ? ret_from_fork+0x58/0x90
[    0.521046]  [<ffffffff814909f0>] ? rest_init+0x70/0x70
[    0.526265] Code: 8b 5f 08 44 8b 17 41 56 44 8b 47 04 44 89 d1 41 55 c1 c1 05 41 54 45 8d 23 55 8b 6f 10 41 81 c4 99 79 82 5a 53 8b 5f 0c 41 89 d9 <0f> 38 f0 06 45 31 d9 89 02 45 21 c1 41 c1 c8 02 41 31 d9 41 01
[    0.546235] RIP  [<ffffffff8148f33e>] sha_transform+0x2e/0x12e0
[    0.552164]  RSP <ffff8802148c7d60>
[   20.291066] Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 1
how do you think? what problem is..
final line said  'Kernel panic.."
Me think your CPU is not compatible with 916+
In the future please use proper code tags when posting such logs as it makes it difficult to read. I will edit this time.
i commented about minimal 4th gen cpu  earlier but the Test2 was about using the 916+ successfully on that hardware running vmware under it, if the hardware is not compatible that should not have worked - or was the description misleading? was the 916+ test2 done on a different hardware running vmware workstation12?
you're right.
i tested again yesterday.
cpu i7 6770, 6 Gen,  and its NIC is realtek 8168 . Boot success. but couldn't find at synology asistant. maybe NIC 8168 module problem.
So I prepare another NIC, intel lancard "CT 1000 gigabit".
when boot with intel lan, boot succeeded, and it was founded at synology asistant. and install finally succeeded.
summary.. above all.
PC1, 2, 3 have all realtek 8168 gigabit lan.
PC1 -i7 3770 3rd Gen, not working. because CPU is not compatible. that's right. it shows "Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu ~~~" on log.
PC2 - i7 6770 6th Gen, Working. but needs intel NIC. Realtek8168 not working.
PC3- i7 4790 4th Gen, working on VMWARE. I didn't test real pc. but it will be succeed, too at real pc because 4th Gen pc.
So, 916+ needs over 4th Gen CPU, and needs intel 1000 NIC or another NIC. realtek8168 not working.
thanks.
we need to be precise about the cips in question as there is a lot of problems with the naming of the driver (as you are using it)
so from your discretion its:
PC1. RTL8111F
PC2. RTL8111H
PC3. RTL8111G
did you try to use jun's loader without my extra.lzma?
also if you installed with a intel nic, what was in the log about the realtek nic? if its not working there should be at least a error message
i cant test the 916+ image with baremetal install (just as vm in virtual box), i testet the drivers i used with 3615 image and DN-10130 (RTL8168E based) pcie card an the driver source is the latest
http://www.realtek.com.tw/DOWNLOADS/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3
so if you can provide a log i can try to fix it
PC1. RTL8111F
PC2. RTL8111H
PC3. RTL8111G
1. yes, i used basic extra.lzma and your V4.5 extra.lzma.
2. with onboard realtek nic, 3770 is cpu panic (it is 3rd gen, so i will not test any more^^)
   in case i7 -6770, it has been done to "login prompt" when i saw console from serial comport.
a) i install DSM 6.1.5 pat through Synology asistant
b) and rebooting message in synology asistant. and pc was rebooted.
c) and next, process went to "login prompt". but synology asistant did not find mypc, and "starting message" still shows and time out 500s 499s 498s,,,,,,,,,,,,. and last shows on error message.
blablabla~~~~ Telnet ,,, 23.
3. my pc NIC realtek speccific chipset is below.
3770 is 8168E
4790 is 8168G
6770 is 8168G
I hope my test will help you.
i would attach serialport logfile after next days that i tested with 6770 realtek nic.
PC1. RTL8111F
PC2. RTL8111H
PC3. RTL8111G
1. i7 6770 onboard Realtek 8168, chipset is 8168G
First setup
916+8168G_NIC_onbard.txt
After reboot
916+8168G_NIC_onboard_afterReboot.txt
2. i7 6770 onboard Realtek + intel CT1000 NIC pci-e type. and i connected lan to intel.
First setup
916+intelCT1000.txt
After reboot
916+intelCT1000_afterreboot.txt
916+intelCT1000.txt
916+8168G_NIC_onboard.txt
kind of good it happens with jun's extra.lzma too, so i did not messed up anything with my newer driver from realtek
916+8168G_NIC_onboard.txt show that the driver was loaded and a eth0 was created so driver works (mostly) only thing is that it does not get a dhcp adress, its just an APIPA adress 169.254.14.204
it looks the same with the intel (dualport) nic, loads, eth0/eth1 present but only gets a APIPA adress
the thing i'm interested in is the /var/log/dmesg from a system that uses intel (or any working nic), was installed with dsm and after this realtek card added (lan connected on both), the dmesg should contain information about the r8168.ko driver loading, finding hardware and maybe commenting about anything thats wrong
i'll have to get me a better/newer test hardware for a few days, i guess i will see that it is a intel based that can handle 916+ and i will borrow that realtek pcie card too so i might be able to test that combination the next days myself
hi,
did some testing and there was no problem with the driver in general, it does work/load in the same way is it does for the 3615
one odd thing (also seen with the 3615, did test it when seeing it with 916+) is that at first try after first boot with flash drive (no dsm installed) and realtek on the net, synology assistant showed a apipa address (like seen in your logs), as i was giving my desktop a additional address from this range i could access it the over the web-interface and install dsm (manual, dsm from local file)
i also tried installing dsm with a intel nic and after this inserting the realtek as 2nd nic and there was nothing special to notice, just showed up and got a dhcp address, nothing unusual in log, also removing the intel after install was no problem, realtek came up as 1st nic in dsm
after this i tried a fresh install without the intel card and only the realtek, with the same loader i used for the intel nic (mac address of intel in grub.cfg) and the dhcp worked as expected, no apipa dress just the same address the intel got before, but i could not reproduce it, after changing the mac in grub.cfg the realtek nic got a normal dhcp address
so the driver works, just there seems to be a strange dhcp problem with the boot loader on first install, but when using the synology assistant it shows the correct ip address (apipa range) and when using the apipa address with the browser the install process worked
(also did tests with first 6.1(.0) and 6.1.5 as first install but there was  no difference, worked as expected)
/var/log/dmesg
[Sun Feb 25 20:31:43 2018] e1000e: Intel(R) PRO/1000 Network Driver - 3.3.4-NAPI
[Sun Feb 25 20:31:43 2018] e1000e: Copyright(c) 1999 - 2016 Intel Corporation.
[Sun Feb 25 20:31:43 2018] e1000e 0000:00:1f.6: setting latency timer to 64
[Sun Feb 25 20:31:43 2018] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[Sun Feb 25 20:31:43 2018] e1000e 0000:00:1f.6: irq 139 for MSI/MSI-X
[Sun Feb 25 20:31:43 2018] e1000e 0000:00:1f.6 eth0: registered PHC clock
[Sun Feb 25 20:31:43 2018] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) dc:4a:3e:80:1c:ce
[Sun Feb 25 20:31:43 2018] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[Sun Feb 25 20:31:43 2018] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[Sun Feb 25 20:31:43 2018] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[Sun Feb 25 20:31:43 2018] r8168 0000:01:00.0: irq 140 for MSI/MSI-X
[Sun Feb 25 20:31:43 2018] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,
776, and US6,327,625.
[Sun Feb 25 20:31:43 2018] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                            This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses>.
                            This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/>.
Edited by IG-88
On 2018. 2. 26. at 7:35 AM, IG-88 said:
hi,
/var/log/dmesg
in my case, I have realtek 8168 onboard NIC.  Although trying several times, but assistant found xpenology on lan At First booting.after rebooting , at 5 step, error 23.
Assistant did not find xpenology on lan.
I don't know why. just was successful only using intel lan.
thanks your testing report.
so you still can try installing with intel nic, after install connect both nic's to network, use intel to ssh and check /var/log/dmesg and webgui for 2nd nic, if both nic's are present and getting a dhcp address i would think it will work to remove the intel nic and using the onboard realtek, if the intel works and the realtek does not you can post errors from dmesg and messages about he realtek nic
After install connect both nic's to network, I use intel to ssh and check /var/log/dmesg , and i attached 3 log file.
I input static ip address to both nic's.
So intel has *.*.*.75
     realtek has *.*.*.76
dmesg1 is first thing. intel + realtek.
dmesg2 is second. rebooting and i connected to realtek , still has intel nic.
dmesg3 is 3rd. i ejected intel nic and booting with realtek. by the way, this reatek nic has *.*.*.75 in lanport 1. but worked.
dmesg3_connect_to_rtl8168(onboardreltek_removeintel)
dmesg2_connect_to_rtl8168(intel+onboardreltek)
dmesg1_connect_to_intel(intel+onboardreltek)
newer linux system (depending on distribution) might keep a ethX reserved even when card is missing and new cards get e new ethX but the key value for this is the mac address and the mac is still the same as it was set in the kernel config in grub.cfg, same mac, same ethX
looks normal, realtek driver is loaded and there is eth0/eth1 or with just the realtek only eth0
also it works as expected after installation, problem seems to be dhcp related and only in bootloader when installing dsm
sorry but i 'm limited in resource and knowledge so i only look for the drivers (works as it should be) and try to help people get things running, well when we see the positive side - at least you got it runnig with the internal nic
