Problem to install 7.0.1 (or 7.1 as well) with Gigabyte B560I AORUS PRO AX
Ingridis13
Hi, Gentlemans!
I'm really sorry, but have some troubles with the Gigabyte B560I AORUS PRO AX + i5-11400 + 64Gb DDR4 (2x32)
Try a lot of variants, but I have ethernet link only before I had created loader. After reboot it is no link at all.
Try with 2-ports Intel Network Card: partially success with 3617sx, looks like DSM is installed correctly, but after reboot and "10 minutes" it says about migration.
And so in the cycle.
Could you please help me?
lspci -nnq
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:4c53] (rev 01)
00:02.0 VGA compatible controller [0300]: Intel Corporation RocketLake-S GT1 [UHD Graphics 730] [8086:4c8b] (rev 04)
00:14.0 USB controller [0c03]: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller [8086:43ed] (rev 11)
00:14.2 RAM memory [0500]: Intel Corporation Tiger Lake-H Shared SRAM [8086:43ef] (rev 11)
00:16.0 Communication controller [0780]: Intel Corporation Tiger Lake-H Management Engine Interface [8086:43e0] (rev 11)
00:17.0 SATA controller [0106]: Intel Corporation Device [8086:43d2] (rev 11)
00:1b.0 PCI bridge [0604]: Intel Corporation Device [8086:43c4] (rev 11)
00:1c.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port#5 [8086:43bc] (rev 11)
00:1c.5 PCI bridge [0604]: Intel Corporation Device [8086:43bd] (rev 11)
00:1c.6 PCI bridge [0604]: Intel Corporation Device [8086:43be] (rev 11)
00:1d.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port#9 [8086:43b0] (rev 11)
00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:4387] (rev 11)
00:1f.3 Audio device [0403]: Intel Corporation Tiger Lake-H HD Audio Controller[8086:43c8] (rev 11)
00:1f.4 SMBus [0c05]: Intel Corporation Tiger Lake-H SMBus Controller [8086:43a3] (rev 11)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H SPI Controller [8086:43a4] (rev 11)
03:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller I225-V[8086:15f3] (rev 03)
04:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
VERY big thanks in advance!
@Peter Suh@pocopico
18 answers to this question
As per @pocopico's guide
Do not use sudo before ./rploader.sh.
It may cause some abnormal error.
And since DSM 7.1 has already been released, is there any particular reason to use DSM 7.0.1?
unless there is a special reason
./rploader.sh build broadwellnk-7.1.0-42661
Build the latest version with
Finally, the issue of making the igc driver seems to be in charge of pocopico.
The linux driver is only a reference material, and it seems impossible to use it for direct installation.
So, if you want to use DS3622xs+ right now,
It would be better to purchase a separate NIC and install it with this card.
Edited by Peter Suh
2 hours ago, Ingridis13 said:
Hi, Gentlemans!
lspci -nnq
@Peter Suh@pocopico
I checked the storage and network of your motherboard's specifications.
It looks like a built-in Intel NIC with 2.5G speed, but I don't know exactly which ext is automatically mapped to. Either 1G or 10G is likely to be used, but for some reason ext seems to work unstable.
First of all, please attach the build log of the loader through the spoiler on the far right.
Maybe @pocopico can give you the answer.
I think we should start with which ext is automatically captured and used.
In February of this year, there was a similar inquiry to pocopico,
but it seems to have been forgotten without any response. It is exactly the same as your motherboard specs.
First of all, thanks a lot for your answer, Peter!
Actually, I'm not very familar with Linux, sorry I still learning to work with it.
Could you, please, make a little bit tip for me, how I can install igc correctly?
And I have problem with bspath on v.0.8.0.0 ("Couldn't find bspath in your $PATH")... Could you please make this question some clearer to me?
Thanks in advance!
Thanks in advance!
Please share the full build log of 0.8.0.0 as I said above.
If spoilers are difficult, you can just upload them.
Скрытый текст
Using username "tc".
tc@192.168.100.29's password:
  /) TC (\   Core is distributed with ABSOLUTELY NO WARRANTY.
 (/-_--_-\)           www.tinycorelinux.net
tc@box:~$ sudo ./rploader.sh update
Checking Internet Access -> OK
Checking if a newer version exists on the main repo -> Version is current
tc@box:~$ sudo ./rploader.sh fullupgrade
Performing a full TCRP upgrade
Warning some of your local files will be moved to /home/tc/old/xxxx.2022-May-01-                                   12-15
Updating custom_config.json
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100 33842  100 33842    0     0  36272      0 --:--:-- --:--:-- --:--:--  125k
Updating custom_config_jun.json
100  8954  100  8954    0     0  15411      0 --:--:-- --:--:-- --:--:-- 15411
Updating global_config.json
100  5692  100  5692    0     0   9361      0 --:--:-- --:--:-- --:--:--  9361
Updating modules.alias.3.json.gz
mv: cannot stat 'modules.alias.3.json.gz': No such file or directory
100  5591  100  5591    0     0  12452      0 --:--:-- --:--:-- --:--:-- 12452
Updating modules.alias.4.json.gz
mv: cannot stat 'modules.alias.4.json.gz': No such file or directory
100 89007  100 89007    0     0   156k      0 --:--:-- --:--:-- --:--:--  156k
Updating rpext-index.json
100  211k  100  211k    0     0   273k      0 --:--:-- --:--:-- --:--:--  833k
Updating user_config.json
100   431  100   431    0     0    719      0 --:--:-- --:--:-- --:--:--   719
Updating dtc
100  146k  100  146k    0     0   185k      0 --:--:-- --:--:-- --:--:--  185k
Updating rploader.sh
100 91060  100 91060    0     0   167k      0 --:--:-- --:--:-- --:--:--  167k
Updating ds1621p.dts
mv: cannot stat 'ds1621p.dts': No such file or directory
100  3026  100  3026    0     0   5226      0 --:--:-- --:--:-- --:--:--  5226
Updating ds920p.dts
mv: cannot stat 'ds920p.dts': No such file or directory
100  2423  100  2423    0     0   4606      0 --:--:-- --:--:-- --:--:--  4606
Please make sure you are using the latest 1GB img before using backup option
Current /home/tc size is 2.8M , try to keep it less than 1GB as it might not fit                                    into your image
Should i update the sde with your current files [Yy/Nn]
y
Backing up home files to sde : Backing up files to /mnt/sde3//mydata.tgz
Done.
tc@box:~$ sudo ./rploader.sh serialgen DS3622+ now
Error : DS3622+ is not an available model for serial number generation.
Available Models : DS3615xs DS3617xs DS916+ DS918+ DS920+ DS3622xs+ FS6400 DVA32                                   19 DVA3221 DS1621+
tc@box:~$ sudo ./rploader.sh serialgen DS3622xs+ now
Serial Number for Model : 2040SQRV17ZNQ
Mac Address for Model DS3622xs+ : 00:11:32:0B:11:40
Should i update the user_config.json with these values ? [Yy/Nn]
y
tc@box:~$ sudo ./rploader.sh satamap now
Found "00:17.0 Intel Corporation Device 43d2 (rev 11)"
Detected 6 ports/4 drives. Override # of ports or ENTER to accept <6>
Recommended settings:
SataPortMap=6
DiskIdxMap=00
Should i update the user_config.json with these values ? [Yy/Nn] y
Done.
tc@box:~$ sudo ./rploader.sh identifyusb now
Found USB Disk SerialNumber: 9242091134644701328
Vendor ID : 0x346d Product ID : 0x5678
y
tc@box:~$ sudo ./rploader.sh build broadwellnk-7.0.1-42218
Rploader Version : 0.8.0.0
Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : dev                                   elop
Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill mo                                   dule branch : master
Extensions :
Extensions URL :
TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bro                                   adwellnk-7.0.dev.txz/download
TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d
SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS G                                   PL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download
SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1b                                   e
COMPILE_METHOD : toolkit_dev
TARGET_PLATFORM       : broadwellnk
TARGET_VERSION    : 7.0.1
TARGET_REVISION : 42218
REDPILL_LKM_MAKE_TARGET : dev-v7
KERNEL_MAJOR : 4
MODULE_ALIAS_FILE :  modules.alias.4.json
SYNOMODEL : ds3622xsp_42218
MODEL : DS3622xs+
Local Cache Folder : /mnt/sde3/auxfiles
DATE Internet : 01052022 Local : 01052022
Cloning into 'redpill-lkm'...
remote: Enumerating objects: 1253, done.
remote: Counting objects: 100% (325/325), done.
remote: Compressing objects: 100% (41/41), done.
remote: Total 1253 (delta 302), reused 284 (delta 283), pack-reused 928
Receiving objects: 100% (1253/1253), 469.84 KiB | 1.58 MiB/s, done.
Resolving deltas: 100% (865/865), done.
Cloning into 'redpill-load'...
remote: Enumerating objects: 1998, done.
remote: Counting objects: 100% (4/4), done.
remote: Compressing objects: 100% (4/4), done.
remote: Total 1998 (delta 0), reused 1 (delta 0), pack-reused 1994
Receiving objects: 100% (1998/1998), 114.70 MiB | 1.75 MiB/s, done.
Resolving deltas: 100% (940/940), done.
No extra build option or static specified, using default <static>
Using static compiled redpill extension
Removing any old redpill.ko modules
Looking for redpill for : ds3622xsp_42218
Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/re                                   leases/redpill-4.4.180plus-broadwellnk.tgz
Extracting module
Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/sr                                   c/check-redpill.sh
Got redpill-linux-v4.4.180+.ko
Testing modules.alias.4.json -> File OK
It looks that you will need the following modules :
Found VGA Controller : pciid 8086d00004c8b  Required Extension :
No matching extension
Found SATA Controller : pciid 8086d000043d2  Required Extension :
Found Ethernet Interface : pciid 8086d000015f3 Required Extension :
Starting loader creation
Found tinycore cache folder, linking to home/tc/custom-module
Checking user_config.json : Done
Entering redpill-load directory
Removing bundled exts directories
bsdiff binary was not downloaded
Cache directory OK
Want to use firmware files from /home/tc/custom-module/*.pat ? [yY/nN] :
y
cp: cannot stat '/home/tc/custom-module/*42218*.pat': No such file or directory
Processing add_extensions entries found on custom_config.json file :
[#] Checking runtime for required tools...
[-] Couldn't find bspatch in your $PATH
[#] Checking runtime for required tools... [ERR]
[!] Some tools weren't available - install them first
*** Process will exit ***
FAILED : Loader creation failed check the output for any errors
Extensions :
Extensions URL :
KERNEL_MAJOR : 4
MODEL : DS3622xs+
Redpill sources already downloaded, pulling latest
Already up to date.
Loader sources already downloaded, pulling latest
Already up to date.
Extracting module
Cache directory OK
n
tc@box:~$
Here you are! Thanks!!
Thanks, Peter! I tried with another NICs: 1) Broadcom 2) Intel (2-ports).
Could you please take a look on my another log?
Скрытый текст
tc@192.168.100.34's password:
tc@box:~$ ./rploader.sh update now
tc@box:~$ ./rploader.sh fullupgrade now
Warning some of your local files will be moved to /home/tc/old/xxxx.2022-May-01-14-06
100 33842  100 33842    0     0  40097      0 --:--:-- --:--:-- --:--:--  893k
100  8954  100  8954    0     0  15176      0 --:--:-- --:--:-- --:--:-- 15176
100  5692  100  5692    0     0   9470      0 --:--:-- --:--:-- --:--:--  9470
100  5591  100  5591    0     0  12180      0 --:--:-- --:--:-- --:--:-- 5459k
100 89007  100 89007    0     0   167k      0 --:--:-- --:--:-- --:--:--  167k
100  211k  100  211k    0     0   274k      0 --:--:-- --:--:-- --:--:--  863k
100   431  100   431    0     0    659      0 --:--:-- --:--:-- --:--:--  420k
Updating dtc
100  146k  100  146k    0     0   204k      0 --:--:-- --:--:-- --:--:--  204k
100 91060  100 91060    0     0   168k      0 --:--:-- --:--:-- --:--:--  168k
100  3026  100  3026    0     0   5280      0 --:--:-- --:--:-- --:--:--  5280
Updating ds920p.dts
100  2423  100  2423    0     0   4024      0 --:--:-- --:--:-- --:--:--  4024
Current /home/tc size is 3.3M , try to keep it less than 1GB as it might not fit into your image
y
Done.
tc@box:~$ ./rploader.sh serialgen DS3622xs+
Serial Number for Model : 2150SQRHG6J7P
Mac Address for Model DS3622xs+ : 00:11:32:39:89:A7
y
tc@box:~$ ./rploader.sh identifyusb now
y
tc@box:~$ ./rploader.sh satamap now
SataPortMap=6
DiskIdxMap=00
Done.
tc@box:~$ ./rploader.sh build broadwellnk-7.0.1-42218
Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop
Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master
Extensions :
Extensions URL :
TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.broadwellnk-7.0.dev.txz/download
SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS GPL Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download
SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1be
KERNEL_MAJOR : 4
MODEL : DS3622xs+
Receiving objects: 100% (1253/1253), 469.84 KiB | 1.20 MiB/s, done.
Receiving objects: 100% (1998/1998), 114.70 MiB | 1.80 MiB/s, done.
Resolving deltas: 100% (937/937), done.
Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/releases/redpill-4.4.180plus-broadwellnk.tgz
Extracting module
Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/src/check-redpill.sh
[#] Checking runtime for required tools... [OK]
[#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json...
[#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json
######################################################################## 100.0%
[OK]
[#] ========================================== pocopico.tg3 ==========================================
[#] Extension name: tg3
[#] Description: Adds Broadcom Tigon3 ethernet driver Support
[#] To get help visit: <todo>
[#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3
[#] Software author: https://github.com/pocopico
[#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json
[#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621
Found Ethernet Interface : pciid 14e4d0000165a Required Extension : tg3
Searching for matching extension for tg3
Found matching extension :
"https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json"
Cache directory OK
n
tc@box:~$ apt get bspatch
-sh: apt: not found
tc@box:~$ install bspatch
install: missing destination file operand after 'bspatch'
Try 'install --help' for more information.
tc@box:~$ install bspatch now
install: cannot stat 'bspatch': No such file or directory
tc@box:~$ $PATH
-sh: /home/tc/.local/bin:/usr/local/sbin:/usr/local/bin:/apps/bin:/usr/sbin:/usr/bin:/sbin:/bin: not found
Extensions :
Extensions URL :
KERNEL_MAJOR : 4
MODEL : DS3622xs+
Already up to date.
Already up to date.
Extracting module
[!] Extension is already added (index exists at /home/tc/redpill-load/custom/extensions/pocopico.tg3/pocopico.tg3.json). For more info use "ext-manager.sh info pocopico.tg3"
Cache directory OK
n
Extensions :
Extensions URL :
KERNEL_MAJOR : 4
MODEL : DS3622xs+
Already up to date.
Already up to date.
Extracting module
Cache directory OK
n
tc@box:~$ $PATH
Extensions :
Extensions URL :
KERNEL_MAJOR : 4
MODEL : DS3622xs+
Already up to date.
Already up to date.
Extracting module
Cache directory OK
n
tc@box:~$
And I have bspatch-error with 7.1.0-42661 too...😪
This is forward log:
Скрытый текст
tc@box:~$ ./rploader.sh build broadwellnk-7.1.0-42661
Extensions :   redpill-misc
Extensions URL : "https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json"
TARGET_VERSION    : 7.1.0
TARGET_REVISION : 42661
KERNEL_MAJOR : 4
SYNOMODEL : ds3622xsp_42661
MODEL : DS3622xs+
Already up to date.
Already up to date.
Looking for redpill for : ds3622xsp_42661
Extracting module
Cache directory OK
Found build request for revision greater than 42218
Getting required extraction tool
Checking tinycore cache folder
Creating temp folder /tmp/synoesp
100  345M  100  345M    0     0  1742k      0  0:03:22  0:03:22 --:--:-- 1782k
Entering synoesp
extract rd.gz
finish
cpio: dev/console: Cannot mknod: Operation not permitted
cpio: dev/net/tun: Cannot mknod: Operation not permitted
42506 blocks
extract rd
mkdir: cannot create directory '/mnt/sde3/auxfiles': File exists
Copying required files to local cache folder for future use
Copying usr/lib/libcurl.so.4 to /mnt/sde3/auxfiles
Copying usr/lib/libmbedcrypto.so.5 to /mnt/sde3/auxfiles
Copying usr/lib/libmbedtls.so.13 to /mnt/sde3/auxfiles
Copying usr/lib/libmbedx509.so.1 to /mnt/sde3/auxfiles
Copying usr/lib/libmsgpackc.so.2 to /mnt/sde3/auxfiles
Copying usr/lib/libsodium.so to /mnt/sde3/auxfiles
Copying usr/lib/libsynocodesign-ng-virtual-junior-wins.so.7 to /mnt/sde3/auxfiles
Copying usr/syno/bin/scemd to /mnt/sde3/auxfiles
Copying required libraries to local lib directory
Linking lib to lib64
Copying executable
Removing temp folder /tmp/synoesp
Checking if tools is accessible
/bin/syno_extract_system_patch: /usr/local/lib/libcurl.so.4: no version information available (required by /bin/syno_extract_system_patch)
Copyright (c) 2003-2021 Synology Inc. All rights reserved.
/bin/syno_extract_system_patch PATCH_PATH DEST_PATH
Executed succesfully
Creating temp folder /tmp/pat
Checking for cached pat file
Could not find pat file locally cached
Configdir : /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661
Configfile: /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661/config.json
Pat URL : https://global.download.synology.com/download/DSM/release/7.1/42661-1/DSM_DS3622xs%2B_42661.pat
Downloading pat file from URL : https://global.download.synology.com/download/DSM/release/7.1/42661-1/DSM_DS3622xs%2B_42661.pat
100  352M  100  352M    0     0  1534k      0  0:03:55  0:03:55 --:--:-- 1630k
File //mnt/sde3/auxfiles/ds3622xsp_42661.pat, is  encrypted
File //mnt/sde3/auxfiles/ds3622xsp_42661.pat, has been cached but its encrypted, re-running decrypting process
Found locally cached pat file /home/tc/custom-module/ds3622xsp_42661.pat
File /home/tc/custom-module/ds3622xsp_42661.pat, is  encrypted
Extracting encrypted pat file : /home/tc/custom-module/ds3622xsp_42661.pat to /tmp/pat
Creating unecrypted pat file ds3622xsp_42661.pat to /home/tc/redpill-load/cache folder
./VERSION
Pat file  sha256sum is : d16804d1b1fc282f2551ef7122f2f74a74c5e2b1148dc8e3f7e474cbaf20d93f
Checking config file existence -> OK
Editing config file -> Verifying config file -> OK !
Clearing temp folders
Processing add_extensions entries found on custom_config.json file :   redpill-misc
Adding extension "https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json"
[#] Adding new extension from https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json...
[#] Downloading remote file https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json
######################################################################### 100.0%
[OK]
[#] ========================================== redpill-misc ==========================================
[#] Extension name: Misc shell
[#] Description: Misc shell
[#] To get help visit: https://github.com/pocopico/redpill-load/raw/develop/redpill-misc
[#] Extension preparer/packer: https://github.com/pocopico/redpill-load/raw/develop/redpill-misc
[#] Software author: https://github.com/pocopico/redpill-load/raw/develop/redpill-misc
[#] Update URL: https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/rpext-index.json
Updating extension : redpill-misc contents for model : ds3622xsp_42661
[#] Updating ds3622xsp_42661 platforms extensions...
[#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json
[#] Filling-in newly downloaded recipe for extension redpill-misc platform ds3622xsp_42661
[#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/releases/install.sh to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/install.sh
[#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/install.sh file...  [OK]
[#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/releases/install-all.sh to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/install-all.sh
[#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/install-all.sh file...  [OK]
[#] Downloading remote file https://github.com/tsl0922/ttyd/releases/download/1.6.3/ttyd.x86_64 to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/ttyd
[#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/ttyd file...  [OK]
[#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/releases/install_rd.sh to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/install_rd.sh
[#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/install_rd.sh file...  [OK]
[#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/releases/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/lrzsz.tar.gz
[#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/lrzsz.tar.gz file...  [OK]
[#] Unpacking files from /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_42661/...  [OK]
[#] Successfully processed recipe for extension redpill-misc platform ds3622xsp_42661
tc@box:~$
  7.1.0-42661 0.8.0.0 (Reveal hidden contents)
KERNEL_MAJOR : 4
MODEL : DS3622xs+
Already up to date.
Already up to date.
Extracting module
Cache directory OK
Entering synoesp
extract rd.gz
finish
42506 blocks
extract rd
Copying executable
./VERSION
[OK]
tc@box:~$
There seems to be a problem or the process of copying the bspatch file under /usr/local/bin is omitted. Execute the three commands below in sequence.
curl --location "https://raw.githubusercontent.com/pocopico/tinycore-redpill/main/bspatch" -O
chmod 777 bspatch
sudo mv bspatch /usr/local/bin/
Run ./rploader.sh clean now after that.
It is better to run ./rploader.sh before build XXX.
Edited by Peter Suh
Thanks, Peter!
It works fine for a while... Build was passed normally, and I see my NAS at network very well, BUT... install process failed on 55% (Can't install DSM... The file is probably corrupt.).
Could you please make any advices?
P.S. .pat was downloaded by me from /home/tc/redpill-load/cache/
3 minutes ago, Ingridis13 said:
Thanks, Peter!
I don't know why users think they should download from /home/tc/redpill-load/cache/ .
This file is a modified file.
The pat file directly from the Synology download page is recommended.
You may also encounter corruption messages with this pat file.
At that time, it may be necessary to analyze the log again.
Peter you are my HERO! It WORKS!
When I had download .pat from Synology -- normal process passed!
I thinked that I need download .pat from tmp-folder, because I read that kind of instruction a couple of months before (with RedPill 0.4.4 and DSM 7.0.1)
Thanks a lot once again for you help and great patience!!!
Btw, I can't see 2 of my SSD (for cache) at DSM -- only 4 HDD online.
Is it possible to diagnose and heal this?
Maybe it means two nvme ssd's.
Use the topic below to enable the nvme cache.
The loader no longer needs to be built.
Hi everyone!
I'm sorry for disturbing you, but I have another problem with the same system: I'd change ethernet adapter to Synology E10G18-T1,
and I'd changed the mac and s/n in user_config.json as well, and create image one more time.
My system freezed on "starting kernel with usb boot".
Could you, please, answer what can I do to fix this?
Big thanks in advance!
@Peter Suh
@IG-88
13 hours ago, Ingridis13 said:
Hi everyone!
@Peter Suh
@IG-88
This NIC uses aquantia chipset, and ext that supports aquantia chipset seems to be the only one below.
After building the TC bootloader, check if the "pocopico.atlantic" directory exists with the following command.
If you don't see this directory
It seems that you need to add atlantic ext separately.
ll *load/c*/e*
If atlantic ext is well added but IP is not visible
Contact @pocopico.
https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/rpext-index.json
  "id": "pocopico.atlantic",
  "url": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/rpext-index.json",
  "info": {
    "name": "atlantic",
    "description": "Adds Marvell (Aquantia) Corporation(R) Network Driver Support",
    "author_url": "https://github.com/pocopico",
    "packer_url": "https://github.com/pocopico/rp-ext/tree/main/atlantic",
    "help_url": "<todo>"
  "releases": {
    "ds3615xs_25556": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3615xs_25556.json",
    "ds3615xs_41222": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3615xs_41222.json",
    "ds3615xs_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3615xs_42218.json",
    "ds3615xs_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3615xs_42218.json",
    "ds3615xs_42661": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3615xs_42218.json",
    "ds3617xs_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3617xs_42218.json",
    "ds3617xs_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3617xs_42218.json",
    "ds3617xs_42661": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3617xs_42218.json",
    "ds3622xsp_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3622xsp_42218.json",
    "ds3622xsp_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3622xsp_42218.json",
    "ds3622xsp_42661": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds3622xsp_42218.json",
    "ds1621p_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds1621p_42218.json",
    "ds1621p_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds1621p_42218.json",
    "ds1621p_42661": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds1621p_42218.json",
    "ds2422p_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds2422p_42218.json",
    "ds2422p_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds2422p_42218.json",
    "dva3221_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/dva3221_42218.json",
    "dva3221_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/dva3221_42218.json",
    "dva3221_42661": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/dva3221_42218.json",
"dva1622_42661": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/dva1622_42218.json",
    "dva1622_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/dva1622_42218.json",
    "dva1622_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/dva1622_42218.json",
    "ds918p_25556": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds918p_25556.json",
    "ds918p_41890": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds918p_41890.json",
    "ds918p_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds918p_42218.json",
    "ds918p_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds918p_42218.json",
    "ds918p_42661": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds918p_42218.json",
    "ds920p_42621": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds920p_42218.json",
    "ds920p_42218": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds920p_42218.json",
    "ds920p_42661": "https://raw.githubusercontent.com/pocopico/rp-ext/master/atlantic/releases/ds920p_42218.json"
Edited by Peter Suh
