Need help! Can't login - wrong password
tobi16a
Hi guys,
I am desperate. I run a Dell T20 with Xpenoloy DS 5.2-5967 and since a week I try to remember and login to my DS. It could be that I change my pw with my phone in the browser - but I can still not remember. It might be that I typed the wrong password. And now I can't access my personal important stuff. PLEASE HELP.
I already tried the following things:
- resetuser=admin at the booting, but I deactivated my admin account
- telnet is deactivated
- the login counter is set to 5 attempts
- I installed a fresh DS 5.2-5967 on the other disk but I could not mount my old disks
How can I reset my settings / password without losing data?
There are other ideas? Hacking the smb?
Please help me.
Tobi
Edited by tobi16a
2 answers to this question
Assuming you are the correct owner of the box, and not somone trying to hack ;-)
I faced a similiar problem with the box of a friend, but that was running DSM 4.3.
I was trying many things, including the "Password of the day trick"
As can been seen in that thread, there is a way to manually delete the DSM system partitions,
letting you reinstall the system from scratch, while keeping the data. It works, but can be dangerous if you make a mistake.
What I ended up with, was an update to 5.2, allowing me to reset the config, and keep the files.
Since you allready are on 5.2, maybe a forced install, using a new stick, will give you the option to migrate your data,
or if your HW is compatible with DSM 6.1, you could try that upgrade.
btw:
Is your system set up to autoblock IP adresses after Xnumbers of failed logins?
That might keep you out, even with the correct password.
Answer this question...
