OopsDidYouReadThis Posted November 2, 2023 #26 Posted November 2, 2023 Hi, I have a DS1512+ with bad usb dom too. I have taken it out and tried to connect it via serial usb to ttl, plugged in to my windows PC + mac, my computers cannot detect the dom at all. It's dead. I need help, how does one who are in my situation, fix this syno boot issue without the image. Any image for ds1512+ available? (I know it may not be legal but it's only to fix my dead edom) :( Quote
Xeondile Posted March 8, 2024 #27 Posted March 8, 2024 On 11/2/2023 at 9:07 PM, OopsDidYouReadThis said: Hi, I have a DS1512+ with bad usb dom too. I have taken it out and tried to connect it via serial usb to ttl, plugged in to my windows PC + mac, my computers cannot detect the dom at all. It's dead. I need help, how does one who are in my situation, fix this syno boot issue without the image. Any image for ds1512+ available? (I know it may not be legal but it's only to fix my dead edom) :( Sorry a little bit late, but I had the same issue that the dom is not recognized because it hat an error and is running under usb 1.1 and the bios is not making it, so i but everything to a usb stick with hacking pid and vid and now its working again over usb. I uploaded the image, but it has a fake SN (CBKAN99999), so you need to go on the second partition and edit the vendor file with a hex editor. put in your serial, the last diggit is the checksum of the serial. can be calculated here: https://www.scadacore.com/tools/programming-calculators/online-checksum-calculator/ but in the serial in ASCII input and take the "CheckSum8 Modulo 256" in hex after the SN in vendor file Image is here: https://filer.net/get/fgr73l4drvtvkxcj It is from a original DS1512+ only changed vendor SN Hope that will help someone out. Quote
tepezed Posted March 11, 2024 #28 Posted March 11, 2024 Hi folks ! I encountered a faulty usbDOM I tried to unsolder/resolder a new controller, i dit it almost perfectly, (but on pin that was ripped off...) So i found an old USB dongle, I managed to flash VID PID, and it IS recognised. The last step : getting an image of a DS1813+ ... Anyone would have it ? Have a nice day ! Quote
tepezed Posted March 11, 2024 #29 Posted March 11, 2024 Update : I managed to extract my diskimages. It seems to work well ! Thanks for all infos there, it saved my device Quote
mrskoku Posted March 13, 2024 #30 Posted March 13, 2024 hi all, i have a problem with DS412+ as well. I was looking for adata c802 for a long time and finally i've found one on marketplace. But sadly pendrive was on different chipset than UT165.. bad luck... so i went again through all my old pendrives and i started looking for manufacturer's software for chipsets i've found in those pendrives. and i found one.. i've found a pendrive with controller: CBM2091, and I was able to change VID and PID with umptool209X V1.9.32_1107 tomorrow i'll transplant data from DOM to this pendrive - i hope that nas will start. but this is just a workaround. UT165 is ordered already- i'll replace it on DOM later on. Quote
Aetherone Posted March 25, 2024 #31 Posted March 25, 2024 On 3/12/2023 at 3:16 AM, 7up_ said: While it is definitely a lot easier to use the external USB drive, for anyone with a corrupt Synology USB DOM or if you wish to keep things internal, any generic small 9pin USB DOM will work as replacement although it does require changing out the socket if you wish for it to mount properly and of course you do need to modify VID/PID. Hello 7up_ I've obtained a USB DOM that appears to be identical to your photo, but I'm struggling to find a suitable utility to rewrite the VID/PID to 0400. Have been unsuccessfully trawling around usbdev.ru for a few hours now and hoping you can point me in a suitable direction? Chipgenius identifies the DOM as Description: [H:]USB Mass Storage Device(UNIGEN PHB2000IS1-ATB) Device Type: Mass Storage Device Protocal Version: USB 2.10 <- Hint: This device can run faster when plugged to a USB3.0 port Current Speed: High Speed Max Current: 300mA USB Device ID: VID = 1C79 PID = 3100 Serial Number: 40009A2DA0564870 Device Vendor: UNIGEN Device Name: PHB2000IS1-ATB Device Revision: 0100 Manufacturer: UNIGEN Product Model: PHB2000IS1-ATB Product Revision: PMAP Controller Vendor: Phison Controller Part-Number: PS2251-03(PS2303) - F/W 05.01.24 [2016-02-02] Flash ID code: 98D390267615 - Toshiba TC58NVG3S0ETA00 [SLC-4K] Tools on web: http://dl.mydigit.net/special/up/phison.html Possible Flash Part-Number ---------------------------- [1CE]TC58NVG3S0ETA00 [1CE]TC58NVG3S0FTA00 Flash ID mapping table ---------------------------- [Channel 0] [Channel 1] Quote
Aetherone Posted March 25, 2024 #32 Posted March 25, 2024 (edited) oops, double posted. Sorry. Edited March 25, 2024 by Aetherone Quote
DSfuchs Posted April 1, 2024 #33 Posted April 1, 2024 On 25.5.2023 at 20:34, joad said: Hallo, ist es möglich, ein Original-DS3615xs-Image zu klonen und auf DS1511+ auszuführen? (Und in der Lage sein, DMS 7 auszuführen) No, the CPU architecture must be at least identical. Quote
Xeondile Posted April 10, 2024 #34 Posted April 10, 2024 @Aetherone for the Chip you get the MPALL software from here: https://www.usbdev.ru/files/phison/mpall/ For me it was version 5.13.0C, so I get my one to run. Basic Settings with this small settings, see attachment Quote
Aetherone Posted April 10, 2024 #35 Posted April 10, 2024 7 hours ago, Xeondile said: @Aetherone for the Chip you get the MPALL software from here: https://www.usbdev.ru/files/phison/mpall/ For me it was version 5.13.0C, so I get my one to run. Basic Settings with this small settings, see attachment Thanks. Had already been over usbdev.ru and pulled down pretty much every version they had. Most didn't recognise my device and the few that did couldn't cope with the Toshiba SLC NAND on it. After a bit of digging I spooled up a Windows XP machine which did a bit better but still failed to flash. Quote
Aetherone Posted April 14, 2024 #36 Posted April 14, 2024 HA! After a whole lot of fiddling I got the right combination of files to flash my Phison drives to F400. Turns out the various packages on usbdev.ru are incomplete - I needed "Phison_MPALL_v5.13.0C.rar" for an operational flashtool AND "firmware_ps2251-03.rar" for the correct firmware files to flash my units. Thanks to @Xeondile for the correct settings once this lot was cobbled together. BEFORE AFTER Some caution would be advised - a small number of online virus checkers flag these as potentially hostile but none of them can agree on exactly what the malware is so I'm not convinced it's a false positive given what these programs are designed to do. Still, be careful & use them offline, preferably from a disposable temporary Windows install. Quote
StandBugz Posted May 9, 2024 #37 Posted May 9, 2024 Le 12/01/2022 à 20:19, DSfuchs a dit : I still have some 8GB USB sticks with Synology / Diskstation identification. If anyone needs help, just contact me. Hello, need some for my old DS1813+ that looks dead… Blue Power Led blinking and blinking… so… need to replace the USB DOM or place the right stick. thx, greg. Quote
DSfuchs Posted May 9, 2024 #38 Posted May 9, 2024 (edited) Hello, I have summarized the many requests/problems here, with accompanying model upgrade, in a new topic, you are welcome: Edited May 9, 2024 by DSfuchs Quote
StandBugz Posted December 23, 2024 #39 Posted December 23, 2024 (edited) Hello everybody, back on earth.... So, I tried to plug the DOM on my USB port on PC: no response. I found an old USB key (only 1GB) MemUp UT163, changed with that tool HWUpg VID/PID at F400, Vendor name... Now, what is the next step? (is 1GB enough?) Thank's for all, Greg, alias StandBugz. Edited December 23, 2024 by StandBugz Put pics Quote
StandBugz Posted January 2 #40 Posted January 2 (edited) Hi Erverybody, happy 2025.... A question.. With DOM we can find on the market, EBAY, Aliex... With this tool (ChipGenius) we can read the Device Description (VI/PID...) Need to know the "Controller Vendor" for the Controller Chip maker. And after, need an utility to Edit the datas with that specific Controller: but... many time passed on russian website, not easy... Is there an universal tool somewhere to edit VID/PID and some more? Thank you, Greg. Edited January 2 by StandBugz faultss Quote
Jolly Good Posted January 2 #41 Posted January 2 (edited) 2 hours ago, StandBugz said: Hi Erverybody, happy 2025.... A question.. With DOM we can find on the market, EBAY, Aliex... With this tool (ChipGenius) we can read the Device Description (VI/PID...) Need to know the "Controller Vendor" for the Controller Chip maker. And after, need an utility to Edit the datas with that specific Controller: but... many time passed on russian website, not easy... Is there an universal tool somewhere to edit VID/PID and some more? Thank you, Greg. Those flash DOMs have a lot of variations, so no, there no universal tool for editing the VID/PID, but I can share, what proved to be successful for me: Get some MICRON 2GB 9-Pin USB Flash Drive DOM USB (Small 9PIN), available here: https://www.ebay.com/itm/304717730939 Make sure to get the small 9-pin version, if you want to avoid replacing the USB connector block on the DOM. The big 9-pin version is 2.54mm pitch and will not fit into the 2.0mm pitch socket on the Synology board. The named Micron DOM (SM3252C - ISP 141031-2C-r; verify the flash controller type with ChipGenius) can be flashed with - SMI MPTool V1.17.52 v1 I0312 [SM321AC,SM321BB,SM321BC,SM324BB,SM324BC,SM3252A,SM3252B,SM3252C,SM325AB,SM325AC], - Downloadable from usbdev.ru, https://www.usbdev.ru/?wpfb_dl=5548 Having unpacked the flash utility, use the following steps to edit the VID/PID 1) Run SM32Xtest.exe as administrator 2) Press scan USB 3) Press settings 4) Load default.ini. The code being asked for is: 320 5) Make sure that - VID is set to F400 - PID is set to F400 - Vendor name is set to Synology - Product name is set to Diskstation - FOLLOWING SETTINGS ARE TICKED OFF - Pretest - Download ISP - Copy test - Format - ONLY TICKED OPTION SHOULD BE - Write CID + TSOP Dual Stacked Package - Press OK 6) Press start 7) Response should be OK 8. Eject and reinsert the DOM 9) ChipGenius should now report F400/F400 Synology Diskstation Edited January 2 by Jolly Good 1 Quote
StandBugz Posted January 2 #42 Posted January 2 il y a 39 minutes, Jolly Good a dit : Those flash DOMs have a lot of variations, so no, there no universal tool for editing the VID/PID, but I can share, what proved to be successful for me: Get some MICRON 2GB 9-Pin USB Flash Drive DOM USB (Small 9PIN), available here: https://www.ebay.com/itm/304717730939 Make sure to get the small 9-pin version, if you want to avoid replacing the USB connector block on the DOM. The big 9-pin version is 2.54mm pitch and will not fit into the 2.0mm pitch socket on the Synology board. The named Micron DOM (SM3252C - ISP 141031-2C-r; verify the flash controller type with ChipGenius) can be flashed with - SMI MPTool V1.17.52 v1 I0312 [SM321AC,SM321BB,SM321BC,SM324BB,SM324BC,SM3252A,SM3252B,SM3252C,SM325AB,SM325AC], - Downloadable from usbdev.ru, https://www.usbdev.ru/?wpfb_dl=5548 Having unpacked the flash utility, use the following steps to edit the VID/PID 1) Run SM32Xtest.exe as administrator 2) Press scan USB 3) Press settings 4) Load default.ini. The code being asked for is: 320 5) Make sure that - VID is set to F400 - PID is set to F400 - Vendor name is set to Synology - Product name is set to Diskstation - FOLLOWING SETTINGS ARE TICKED OFF - Pretest - Download ISP - Copy test - Format - ONLY TICKED OPTION SHOULD BE - Write CID + TSOP Dual Stacked Package - Press OK 6) Press start 7) Response should be OK 8. Eject and reinsert the DOM 9) ChipGenius should now report F400/F400 Synology Diskstation Thank you, very Nice way to set the DSxxx as Og. i had a look with the ebay link, cheap as chips!!! But the does’nt want to ship in France, i will search for similar DOM. 👌😎😎😎 Quote
olteanalinleon Posted February 22 #43 Posted February 22 On 1/12/2022 at 8:19 PM, DSfuchs said: I still have some 8GB USB sticks with Synology / Diskstation identification. If anyone needs help, just contact me. I have a DS1812+ that died because of the DOM. I am totally lost as I don’t know how to get a DOM/USB stick with the data I need to access my data saved on my NAS. Would be much appreciated if you can give me some guidance where to start. Thank you Quote
ajhclarke24 Posted March 6 #44 Posted March 6 Hi guys, I'm new here but I'm trying to achieve the same thing with a DS1511+ I was going to try putting Redpill Arc Loader on as the bootloader on the NAS, but I want to run DSM7 on the DS1511+, but I'm having trouble trying to get it going. Anyone got any recommendations. I'm just trying Arc-C at the moment and seeing if that works. Thanks Quote
DSfuchs Posted March 8 #45 Posted March 8 On 2/22/2025 at 12:11 PM, olteanalinleon said: I have a DS1812+ that died because of the DOM. I am totally lost as I don’t know how to get a DOM/USB stick with the data I need to access my data saved on my NAS. Would be much appreciated if you can give me some guidance where to start. Thank you Here is the new thread I am following: Quote
DSfuchs Posted March 8 #46 Posted March 8 On 3/6/2025 at 10:37 PM, ajhclarke24 said: Hi guys, I'm new here but I'm trying to achieve the same thing with a DS1511+ I was going to try putting Redpill Arc Loader on as the bootloader on the NAS, but I want to run DSM7 on the DS1511+, but I'm having trouble trying to get it going. Anyone got any recommendations. I'm just trying Arc-C at the moment and seeing if that works. Thanks Here is the new thread I am following: https://xpenology.com/forum/topic/70401-synology-plus-series-internal-flashdom-repair-and-model-modding/ Quote
