Problem with ASROCK J3455B-ITX
koszyk
Hi Everyone,
I have got a problem with installation DS916+. Details in attachment. Got any ideas?
log
-patching file etc/passwd
patching file etc/rc
Hunk #1 succeeded at 173 (offset 10 lines).
patching file etc/synoinfo.conf
Hunk #2 succeeded at 273 (offset 3 lines).
Hunk #3 succeeded at 283 (offset 4 lines).
Hunk #4 succeeded at 299 (offset 4 lines).
patching file etc/synoinfo_8G.conf
Hunk #2 succeeded at 283 (offset 4 lines).
patching file linuxrc.syno
Hunk #1 succeeded at 39 (offset 2 lines).
Hunk #2 succeeded at 118 with fuzz 2 (offset 2 lines).
Hunk #3 succeeded at 479 (offset 95 lines).
patching file usr/sbin/init.post
START /linuxrc.syno
Insert basic USB modules...
:: Loading module usb-common ... [  OK  ]
:: Loading module usbcore ... [  OK  ]
:: Loading module ohci-hcd ... [  OK  ]
:: Loading module xhci-hcd ... [  OK  ]
:: Loading module usb-storage ... [  OK  ]
:: Loading module BusLogic ... [  OK  ]
:: Loading module vmw_pvscsi ... [  OK  ]
:: Loading module megaraid_mm ... [  OK  ]
:: Loading module megaraid_mbox ... [  OK  ]
:: Loading module megaraid ... [  OK  ]
:: Loading module megaraid_sas ... [  OK  ]
Insert net driver(Mindspeed only)...
Starting /usr/syno/bin/synocfgen...
/usr/syno/bin/synocfgen returns 0
Partition Version=8
 /sbin/e2fsck exists, checking /dev/md0...
1.42.6-15217:        /lost+found not found.  CREATED.
          42 inodes used (0.03%, out of 155648)
           0 non-contiguous files (0.0%)
           0 non-contiguous directories (0.0%)
             # of inodes with ind/dind/tind blocks: 0/0/0
             Extent depth histogram: 32/1
      195165 blocks used (31.35%, out of 622544)
           0 bad blocks
           1 large file
          24 regular files
           8 directories
           0 character device files
           0 block device files
           0 fifos
           0 links
           0 symbolic links (0 fast symbolic links)
           0 sockets
          32 files
/sbin/e2fsck returns 1
Mounting /dev/md0 /tmpRoot
------------upgrade
Begin upgrade procedure
Found an upgrade file on data volume. Begin upgrade
Checksum of system tarball verified.
/tmpRoot//etc ->        /tmpRoot/.upd@te/etc/
/tmpRoot//var ->        /tmpRoot/.upd@te/var/
Removing /tmpRoot/.upd@te//etc/ftpusers...
Removing /tmpRoot/.upd@te//etc/rc...
Removing /tmpRoot/.upd@te//etc/rc.network...
Removing /tmpRoot/.upd@te//usr/syno/etc/rc.atalk...
Removing /tmpRoot/.upd@te//usr/syno/etc/.htpasswd...
Removing /tmpRoot/.upd@te//usr/syno/etc/lpd/lpd.conf...
Removing /tmpRoot/.upd@te//usr/syno/etc/printcap...
Removing /tmpRoot/.upd@te//usr/syno/etc/ups.conf...
Removing /tmpRoot/.upd@te//usr/syno/etc/upsd.conf...
Removing /tmpRoot/.upd@te//usr/syno/etc/upsd.users...
Removing /tmpRoot/.upd@te//usr/syno/etc/upsmon.conf...
Removing /tmpRoot/.upd@te//usr/syno/etc/upssched.conf...
Removing /tmpRoot/.upd@te//etc/lvm/lvm.conf...
Removing /tmpRoot/.upd@te//usr/local/etc/rc.d/SynoEnablePersonalServices.sh...
Removing /tmpRoot/.upd@te//etc/rc.network_routing...
Removing /tmpRoot/.upd@te//usr/syno/etc/rc.tun...
Removing /tmpRoot/.upd@te//usr/syno/etc/afpd.conf...
Removing /tmpRoot/.upd@te//etc/pam.d/samba...
Removing /tmpRoot/.upd@te//etc/ppp/ip-up...
Removing /tmpRoot/.upd@te//etc/ppp/ip-down...
Removing /tmpRoot/.upd@te//etc/ppp/ip-function...
Removing /tmpRoot/.upd@te//etc/ppp/ipv6-up...
Removing /tmpRoot/.upd@te//etc/ppp/ipv6-down...
Removing /tmpRoot/.upd@te//etc/ppp/options...
Removing /tmpRoot/.upd@te//usr/local/cups/mime.types...
Removing /tmpRoot/.upd@te//usr/local/cups/mime.convs...
Removing /tmpRoot/.upd@te//etc/cups/cupsd.conf...
Removing /tmpRoot/.upd@te//usr/local/cups/cupsd.conf...
Removing /tmpRoot/.upd@te//usr/local/cups/testprint...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/bannertops...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/commandtops...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/gziptoany...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/imagetops...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/imagetoraster...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/pdftops...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/pstops...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/rastertoepson...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/rastertohp...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/rastertolabel...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/rastertopwg...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/texttops...
Removing /tmpRoot/.upd@te//usr/local/cups/filter/hpgltops...
Removing /tmpRoot/.upd@te//etc/hostapd/stainfo.sh...
Removing /tmpRoot/.upd@te//etc/hostapd/mac_filter/mfscript.sh...
Removing /tmpRoot/.upd@te//usr/syno/etc/rfkill.sh...
Removing /tmpRoot/.upd@te//usr/syno/etc/iptables_guest_net.sh...
Removing /tmpRoot/.upd@te//etc/ld.so.preload...
Removing /tmpRoot/.upd@te//etc/tc/default.cmd...
Removing /tmpRoot/.upd@te//usr/syno/etc/ssl/mkcert.sh...
Removing /tmpRoot/.upd@te//usr/syno/etc/ssl/mkcgikey.sh...
Removing /tmpRoot/.upd@te//etc/logrotate.conf...
Removing /tmpRoot/.upd@te//usr/syno/etc/usbmodem/wcdma_list.json...
Removing /tmpRoot/.upd@te//usr/syno/etc/usbmodem/usb_modeswitch.d/*...
Removing /tmpRoot/.upd@te//etc/php/php.ini...
Removing /tmpRoot/.upd@te//etc/php/php-fpm.conf...
Removing /tmpRoot/.upd@te//etc/php/conf.d/opcache.ini...
Removing /tmpRoot/.upd@te//usr/syno/etc/synoservice.d/global.setting...
Removing /tmpRoot/.upd@te//usr/syno/etc/synoservice.d/system.cfg...
Removing /tmpRoot/.upd@te//usr/syno/etc/ssdp/dsm_desc.xml...
Removing /tmpRoot/.upd@te//usr/syno/etc/iptables_time_ctrl.sh...
Removing /tmpRoot/.upd@te//etc/profile...
Removing /tmpRoot/.upd@te//etc/inputrc...
Removing /tmpRoot/.upd@te//etc/dhclient/dhclient-script...
Removing /tmpRoot/.upd@te//etc/dhclient/ipv4/dhclient.conf...
Removing /tmpRoot/.upd@te//etc/dhclient/ipv6/dhclient.conf...
Removing /tmpRoot/.upd@te//usr/syno/etc/www/SSLProfile.json...
Removing /tmpRoot/.upd@te//etc/vimrc...
Removing /tmpRoot/.upd@te//usr/syno/etc/cacert.pem...
Removing /tmpRoot/.upd@te//usr/syno/etc/iptables_modules_list...
Removing /tmpRoot/.upd@te//usr/syno/etc/iptables_chain_list...
Removing /tmpRoot/.upd@te//usr/local/bin/python*...
Removing /tmpRoot/.upd@te//etc/sudoers...
Removing /tmpRoot/.upd@te//usr/syno/etc/openldap/ldap.conf...
Removing /tmpRoot/.upd@te//etc/pam.d...
Removing /tmpRoot/.upd@te//usr/syno/etc/vfs...
Removing /tmpRoot/.upd@te//var/run...
Removing /tmpRoot/.upd@te//var/state/ups...
Removing /tmpRoot/.upd@te//usr/syno/etc/ups...
Removing /tmpRoot/.upd@te//var/spool/postfix...
Removing /tmpRoot/.upd@te//usr/local/cups/backend...
Removing /tmpRoot/.upd@te//usr/local/cups/mime...
Removing /tmpRoot/.upd@te//etc/fw_security/sysconf...
Removing /tmpRoot/.upd@te//etc/init...
Removing /tmpRoot/.upd@te//etc/logrotate.d...
Removing /tmpRoot/.upd@te//etc/syslog-ng...
Removing /tmpRoot/.upd@te//var/lib/dpkg...
Removing /tmpRoot/.upd@te//etc/httpd/conf...
Removing /tmpRoot/.upd@te//etc/postgresql...
Removing /tmpRoot/.upd@te//etc/nginx...
Removing /tmpRoot/.upd@te//etc/wide-dhcpv6...
Removing /tmpRoot/.upd@te//etc/apparmor.d...
Removing /tmpRoot/.upd@te//usr/syno/etc/synoservice.d...
Removing /tmpRoot/.upd@te//var/dynlib...
Removing /tmpRoot/.upd@te//etc/iproute2/script...
Removing /tmpRoot/.upd@te//etc/ssl/certs...
Removing /tmpRoot/.upd@te//etc/dbus-1...
Removing /tmpRoot/.upd@te//usr/syno/etc/dbus-1...
Removing /tmpRoot/.upd@te//etc/avahi...
Removing /tmpRoot/.upd@te//usr/syno/etc/synovpnclient/scripts...
Removing /tmpRoot/.upd@te//var/lib/apparmor...
Removing /tmpRoot/.upd@te//usr/syno/etc/www/app.d...
Removing /tmpRoot/.upd@te//usr/syno/etc/rc.d...
Removing /tmpRoot/.upd@te//usr/syno/etc/bluetooth/...
Removing /tmpRoot/.upd@te//usr/syno/etc/smallupdate_patch...
Removing /tmpRoot/.upd@te//etc/ImageMagick-6...
chmod: /tmpRoot/.upd@te/root: No such file or directory
cp: can't stat '/tmpRoot/etc.defaults/VERSION': No such file or directory
cp: can't stat '/tmpRoot/etc.defaults/synoinfo.conf': No such file or directory
cp: can't stat '/tmpRoot/.system_info': No such file or directory
Setting up swapspace version 1, size = 2147414016 bytes
Untaring /tmpRoot/.SynoUpgrade.tar...
cp: can't create '/tmpRoot/*': No such file or directory
[   16.460728] BUG: unable to handle kernel NULL pointer dereference at 0000000000000011
[   16.468916] IP: [<ffffffff81359ea1>] syno_ahci_disk_led_enable+0x31/0x180
[   16.476022] PGD 1746a1067 PUD 174695067 PMD 0
[   16.480710] Oops: 0000 [#1] SMP
[   16.484122] Modules linked in: braswell_synobios(PO+) etxhci_hcd megaraid_sas megaraid megaraid_mbox megaraid_mm vmw_pvscsi BusLogic usb_storage xhci_hcd ohci_hcd usbcore usb_common el000(O) [last unloaded: braswell_synobios]
[   16.505285] CPU: 0 PID: 4210 Comm: insmod Tainted: P           O 3.10.102 #15217
[   16.513008] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./J3455B-ITX, BIOS P1.30 07/14/2017
[   16.523057] task: ffff88017a7fb040 ti: ffff88012f370000 task.ti: ffff88012f370000
[   16.530866] RIP: 0010:[<ffffffff81359ea1>]  [<ffffffff81359ea1>] syno_ahci_disk_led_enable+0x31/0x180
[   16.540532] RSP: 0018:ffff88012f373cd8  EFLAGS: 00010202
[   16.546084] RAX: ffff8801781b4000 RBX: 0000000000000001 RCX: ffff8801762014b0
[   16.553526] RDX: 000000000000000a RSI: 0000000000000000 RDI: ffff8801781b4380
[   16.561016] RBP: ffff88012f373ee8 R08: 00000000000024c0 R09: 00000000000024c0
[   16.568518] R10: 0000000000002640 R11: 0000000000002640 R12: ffff8801781b4000
[   16.575978] R13: 0000000000000001 R14: 0000000000000001 R15: ffffffffa01025c0
[   16.583504] FS:  00007f6d1f394700(0000) GS:ffff88017fc00000(0000) knlGS:0000000000000000
[   16.592005] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   16.598042] CR2: 0000000000000011 CR3: 000000012dc15000 CR4: 00000000003407f0
[   16.605493] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[   16.612960] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[   16.620435] Stack:
[   16.622558]  ffffffffa00fb250 ffff88012f373ee8 0000000000000000 ffffffffa0102610
[   16.630373]  0000000000000001 ffffffffa01025c0 ffffffffa00fe695 ffffffff8182d040
[   16.638192]  0000000000000001 ffffffffa01025c0 ffffffff81160faf 0000010a00000002
[   16.646002] Call Trace:
[   16.648577]  [<ffffffffa00fb250>] ? remove_card_detect_proc+0x20/0x20 [braswell_synobios]
[   16.657123]  [<ffffffffa00fe695>] ? synobios_model_init+0x1a5/0x390 [braswell_synobios]
[   16.665491]  [<ffffffff81160faf>] ? proc_alloc_inum+0x2f/0xb0
[   16.671520]  [<ffffffff811610c9>] ? proc_register+0x99/0x140
[   16.677411]  [<ffffffff81161259>] ? proc_mkdir_data+0x49/0x70
[   16.683445]  [<ffffffffa00fb250>] ? remove_card_detect_proc+0x20/0x20 [braswell_synobios]
[   16.691999]  [<ffffffffa00fb2be>] ? synobios_init+0x6e/0x490 [braswell_synobios]
[   16.699789]  [<ffffffffa00fb250>] ? remove_card_detect_proc+0x20/0x20 [braswell_synobios]
[   16.708390]  [<ffffffff810003aa>] ? do_one_initcall+0xea/0x140
[   16.714559]  [<ffffffff81089a13>] ? load_module+0x1b93/0x2110
[   16.720587]  [<ffffffff810869a0>] ? store_uevent+0x40/0x40
[   16.726319]  [<ffffffff8108a024>] ? SYSC_init_module+0x94/0xc0
[   16.732426]  [<ffffffff814a64f2>] ? system_call_fastpath+0x16/0x1b
[   16.738879] Code: 56 41 55 44 8d 2e 41 54 55 53 e8 fb df fb ff 48 85 c0 4c 8d 20 0f 84 54 01 00 00 48 8b 98 08 05 00 00 48 85 db 0f 84 3d 01 00 00 <48> 8b 7b 10 48 8b ab 48 32 00 00 e8 df bb 14 00 31 d2 31 ff 48
[   16.759962] RIP  [<ffffffff81359ea1>] syno_ahci_disk_led_enable+0x31/0x180
[   16.767181]  RSP <ffff88012f373cd8>
[   16.770860] CR2: 0000000000000011
[   16.774442] ---[ end trace baaa7e263ac392cb ]---
Killed
mknod: /dev/synobios: File exists
Starting /usr/syno/bin/synohdcfgen...
/usr/syno/bin/synohdcfgen returns 255
rmmod: can't unload 'braswell_synobios': Device or resource busy
End upgrade procedure
============upgrade
Wait 2 seconds for synology manufactory device
Mon Jan 22 16:18:29 UTC 2018
/dev/md0 /tmpRoot ext4 rw,relatime,journal_checksum,data=ordered 0 0
none /sys/kernel/debug debugfs rw,relatime 0 0
sys /sys sysfs rw,relatime 0 0
none /dev devtmpfs rw,relatime,s[   26.034363] VFS: opened file in mnt_point: (/dev), file: (/ttyS1)
ize=1847400k,nr_inodes=461850,mode=755 0 0
umou[   26.045826] VFS: opened file in mnt_point: (/dev), file: (/ttyS1)
nt: can't umount /dev: Device or resource busy
proc /proc proc rw,relatime 0 0
linuxrc.syno executed successfully.
Post init
mount: mounting none on /dev failed: Device or resource busy
[   26.113230] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
fgrep: /tmpRoot/etc/rc: No such file or directory
/tmpRoot/usr/bin/sed: can't read /tmpRoot/etc/rc: No such file or directory
fgrep: /tmpRoot/etc/rc.subr: No such file or directory
/tmpRoot/usr/bin/sed: can't read /tmpRoot/etc/rc.subr: No such file or directory
Installing /tmpRoot//usr/lib/modules/update/BusLogic.ko...
Installing /tmpRoot//usr/lib/modules/update/vmw_pvscsi.ko...
Installing /tmpRoot//usr/lib/modules/update/megaraid_mm.ko...
Installing /tmpRoot//usr/lib/modules/update/megaraid_mbox.ko...
Installing /tmpRoot//usr/lib/modules/update/megaraid.ko...
Installing /tmpRoot//usr/lib/modules/update/megaraid_sas.ko...
Installing /tmpRoot//usr/lib/modules/update/mii.ko...
Installing /tmpRoot//usr/lib/modules/update/mdio.ko...
Installing /tmpRoot//usr/lib/modules/update/libphy.ko...
Installing /tmpRoot//usr/lib/modules/update/atl1.ko...
Installing /tmpRoot//usr/lib/modules/update/atl1e.ko...
Installing /tmpRoot//usr/lib/modules/update/atl1c.ko...
Installing /tmpRoot//usr/lib/modules/update/alx.ko...
Installing /tmpRoot//usr/lib/modules/update/uio.ko...
Installing /tmpRoot//usr/lib/modules/update/ipg.ko...
Installing /tmpRoot//usr/lib/modules/update/jme.ko...
Installing /tmpRoot//usr/lib/modules/update/skge.ko...
Installing /tmpRoot//usr/lib/modules/update/sky2.ko...
Installing /tmpRoot//usr/lib/modules/update/ptp_pch.ko...
Installing /tmpRoot//usr/lib/modules/update/pch_gbe.ko...
Installing /tmpRoot//usr/lib/modules/update/qla3xxx.ko...
Installing /tmpRoot//usr/lib/modules/update/qlcnic.ko...
Installing /tmpRoot//usr/lib/modules/update/qlge.ko...
Installing /tmpRoot//usr/lib/modules/update/netxen_nic.ko...
Installing /tmpRoot//usr/lib/modules/update/sfc.ko...
Installing /tmpRoot//usr/lib/modules/update/e1000.ko...
Installing /tmpRoot//usr/lib/modules/update/pcnet32.ko...
Installing /tmpRoot//usr/lib/modules/update/vmxnet3.ko...
Installing /tmpRoot//usr/lib/modules/update/bnx2.ko...
Installing /tmpRoot//usr/lib/modules/update/cnic.ko...
Installing /tmpRoot//usr/lib/modules/update/ixgbe.ko...
Installing /tmpRoot//usr/lib/modules/update/r8168.ko...
Installing /tmpRoot//usr/lib/modules/update/r8169.ko...
Installing /tmpRoot//usr/lib/modules/update/tg3.ko...
Installing /tmpRoot//usr/lib/modules/update/usbnet.ko...
Installing /tmpRoot//usr/lib/modules/update/ax88179_178a.ko...
Installing /tmpRoot//usr/lib/modules/update/ohci-hcd.ko...
Installing /tmpRoot//usr/lib/firmware/bnx2/bnx2-rv2p-09ax-6.0.17.fw...
Installing /tmpRoot//usr/lib/firmware/bnx2/bnx2-rv2p-09-6.0.17.fw...
Installing /tmpRoot//usr/lib/firmware/bnx2/bnx2-rv2p-06-6.0.15.fw...
Installing /tmpRoot//usr/lib/firmware/tigon/tg3_tso5.bin...
Installing /tmpRoot//usr/lib/firmware/tigon/tg3_tso.bin...
Installing /tmpRoot//usr/lib/firmware/tigon/tg3.bin...
[   26.716327] VFS: opened file in mnt_point: (/dev), file: (/ttyS1)
umount: can't umount /dev: Device or resource busy
[   27.758739] EXT4-fs (md0): re-mounted. Opts: (null)
[   36.973783] sd 1:0:0:0: Attached scsi generic sg0 type 0
[   36.979152] sd 2:0:0:0: Attached scsi generic sg1 type 0
[   37.434484] Adding 2097084k swap on /dev/md1.  Priority:-1 extents:1 across:2097084k
[   37.908743] zram: module is from the staging directory, the quality is unknown, you have been warned.
[   37.919128] zram: Created 4 device(s) ...
[   37.951596] Adding 556028k swap on /dev/zram0.  Priority:1 extents:1 across:556028k SS
[   37.975395] Adding 556028k swap on /dev/zram1.  Priority:1 extents:1 across:556028k SS
[   37.999155] Adding 556028k swap on /dev/zram2.  Priority:1 extents:1 across:556028k SS
[   38.022809] Adding 556028k swap on /dev/zram3.  Priority:1 extents:1 across:556028k SS
==================== start udevd ====================
[   46.376845] NET: Registered protocol family 10
[   46.424745] sit: IPv6 over IPv4 tunneling driver
[   46.938279] init: syno-auth-check main process (5545) killed by TERM signal
[   47.715603] ACPI: Requesting acpi_cpufreq
[   48.536932] systemd-udevd[5865]: starting version 204
===== trigger device plug event =====
[   48.609632] fuse init (API version 7.22)
[   48.625662] e1000e: Intel(R) PRO/1000 Network Driver - 3.3.4-NAPI
[   48.632072] e1000e: Copyright(c) 1999 - 2016 Intel Corporation.
[   48.947976] Intel(R) Gigabit Ethernet Network Driver - version 5.3.5.3
[   48.954835] Copyright (c) 2007-2015 Intel Corporation.
[   49.033212] ixgbe: Unknown symbol mdio_mii_ioctl (err 0)
[   49.038918] ixgbe: Unknown symbol mdio45_probe (err 0)
[   49.140812] r8168 Gigabit Ethernet driver 8.044.02-NAPI loaded
[   49.147238] r8168 0000:02:00.0: irq 140 for MSI/MSI-X
[   49.166415] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   49.178331] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
[   49.178331]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[   49.178331]  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   49.423966] Loading modules backported from Linux version v3.18.1-0-g39ca484
[   49.431409] Backport generated by backports.git v3.18.1-1-0-g5e9ec4c
[   49.824676] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[   49.833325] ACPI: Power Button [PWRB]
[   49.888152] Linux agpgart interface v0.103
[   50.038233] [drm] Initialized drm 1.1.0 20060810
[   50.183270] bio: create slab <bio-1> at 1
[   50.188604] Btrfs loaded
[   50.212661] exFAT: Version 1.2.9
[   50.300831] jme: JMicron JMC2XX ethernet driver version 1.0.8
[   50.321665] sky2: driver version 1.30
[   50.340672] pch_gbe: EG20T PCH Gigabit Ethernet Driver - version 1.01
[   50.363190] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.2.42
[   50.385483] QLogic/NetXen Network Driver v4.0.80
[   50.398421] Solarflare NET driver v3.2
[   50.410179] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[   50.417583] e1000: Copyright (c) 1999-2006 Intel Corporation.
[   50.431440] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de
[   50.446227] VMware vmxnet3 virtual NIC driver - version 1.1.30.0-k-NAPI
[   50.476927] cnic: Broadcom NetXtreme II CNIC Driver cnic v2.5.16 (Dec 05, 2012)
[   50.501218] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 3.13.10-k
[   50.509438] ixgbe: Copyright (c) 1999-2013 Intel Corporation.
[   50.554989] usbcore: registered new interface driver ax88179_178a
Hide
  • 3 weeks later...
only thing i can see that "syno_ahci_disk_led_enable" comes from libahci.c so the crash seems ahci related and that is part of the precompiled original synology kernel
the board seems to be widely used here with the 916+ image so we can rule out a general incompatibility
check ram with ram test of a bootable linux disk
maybe try different cable and disk?
https://xpenology.com/forum/topic/9761-dsm614-sn-apollo-lake-dts-audio-plex-hardware-transcoding/
9 hours ago, sbv3000 said:
Maybe try the 3615 image?
i realise you may want the 916/3455 Cpu features, but a test of this image might show the same errors or none, so pointing to a hardware issue
i've been running the 3615 6.1 image on a 3455m flawlessly for over a year.
Strange thing is that @nevusZ (see 3 posts above) has the same board and it works for him with the 916+ loader. :35_thinking:
1 hour ago, koszyk said:
My mistake;) I try 3615/3617 and works flawlessly. But I wanted to use hw transcoding. @nevusZ have ASROCK J-3455-ITX (4xSATA3, M.2 socket), mine motherboard (J3455B-ITX) have only 2xSATA without M.2. I suppose it's different here.
Perhaps that might be it. Stick to 3615xs it's the most used loader by members and works fine.
