Djey Posted July 1, 2014 Share #26 Posted July 1, 2014 (edited) For advanced users, I've initiated a Github wiki to set up monitoring services with pi-control project. Please note everything is still a Work In Progress. Thanks for your feedback ! Edit : wiki link https://github.com/djey47/pi-control/wiki Edited July 6, 2014 by Guest Quote Link to comment Share on other sites More sharing options...
sl0n Posted July 6, 2014 Share #27 Posted July 6, 2014 I'm intersted in this topic, having no SMART data on ESXi hosts feels like being blind =) @Djey http://kb.vmware.com/selfservice/micros ... Id=2040405 I'm not sure you've seen that one, but just in cace. Basically, yes, the values are vendor specific, so a possible tool would need to know how to interpret it per vendor (maybe even model) basis. Cheers, sl0n Quote Link to comment Share on other sites More sharing options...
Djey Posted July 7, 2014 Share #28 Posted July 7, 2014 Hi, I already know this page, but thanks for the link anyway ! And hopefully Vmware documentation is pretty clear on the Internet Yeah, manufacturer or device specific interpretation would be a solution, but I don't like writing specific code - or would I have to modularize ?! Btw, immediate step is to translate raw SMART values to usable ones and OK/KO indicators. I will take this fact into account. Quote Link to comment Share on other sites More sharing options...
Guest MPaladin Posted August 22, 2014 Share #29 Posted August 22, 2014 2 questions please Is there any way to disable error message in xpenology saying there's a problem with the temperature ? To install pi-control on a raspberry pi, should it be clean installed ? I mean, I've already have a pi with openelec/xbmc, can I perform the install without problem ? and with future updates (openelec for example) will it still be ok ? thanks Quote Link to comment Share on other sites More sharing options...
Djey Posted October 14, 2014 Share #30 Posted October 14, 2014 Sorry for late reply, I did not get notifications about it 2 questions please Is there any way to disable error message in xpenology saying there's a problem with the temperature ? I wasn't able to suppress them. Anyone ? To install pi-control on a raspberry pi, should it be clean installed ? I mean, I've already have a pi with openelec/xbmc, can I perform the install without problem ? and with future updates (openelec for example) will it still be ok ? thanks Pi-Control is a lightweight script-based application, which does not rely on system libraries directly. You don't need to format your system to install it.As long as your updates don't break ruby script engine and SSH client it will be ok. At mine, I'm used to fetching git repository to /home/.../git/pi-control, and then I copy all files onto /media/.../pi-control (sdcard partition) to run them afterwards. Quote Link to comment Share on other sites More sharing options...
Djey Posted October 15, 2014 Share #31 Posted October 15, 2014 (edited) -sry for double post - Edited October 15, 2014 by Guest Quote Link to comment Share on other sites More sharing options...
Djey Posted October 15, 2014 Share #32 Posted October 15, 2014 For those interested in project, still: I've almost finished with a stable version of smartX webapp. https://github.com/djey47/smartX Release 1 will be available soon, in the meantime it can be installed manually by following instructions in README.md Here are screens of what can be achieved with ESXI smart data fetched by pi-control module: Quote Link to comment Share on other sites More sharing options...
sl0n Posted October 16, 2014 Share #33 Posted October 16, 2014 Awesome, I'll be testing it once v.1 is available. Quote Link to comment Share on other sites More sharing options...
Djey Posted November 12, 2014 Share #34 Posted November 12, 2014 Important Update : for your information, I just released following apps: pi-control : a ruby app which exposes REST services to manage ESXi server and get SMART data : https://github.com/djey47/pi-control smartX : a webapp displaying disks and SMART information : https://github.com/djey47/smartX pi-control is required to get SMART data, you only need to install smartX to easily watch storage state. Dedicated thread here: viewtopic.php?f=2&t=4475 Feedback is welcome Quote Link to comment Share on other sites More sharing options...
kolopeter Posted November 12, 2014 Share #35 Posted November 12, 2014 somebody checked phpsysinfo with plugin debian chroot(+apache)? Quote Link to comment Share on other sites More sharing options...
flyride Posted May 18, 2020 Share #36 Posted May 18, 2020 There really has not been a good solution to this problem. However, here is a method to suppress spurious SMART syslog messages. 1 Quote Link to comment Share on other sites More sharing options...
