Hi everybody,
I was wondering if anyone could help me here.
Installed  DSM 7.2.1-69057 Update 3 on my pc with DS3622xs+ via @Peter Suh's M Shell for tinycore-redpill v.1.0.1.0.
Everything's fine except for the power off via power button.
Checking acpid.service:
root@ALAMO_Test_1:~# systemctl status acpid.service -l
● acpid.service - ACPI Daemon
   Loaded: loaded (/usr/lib/systemd/system/acpid.service; static; vendor preset: disabled)
   Active: active (running) since Wed 2024-01-31 18:02:25 CET; 9min ago
 Main PID: 25027 (acpid)
   CGroup: /system.slice/acpid.service
           └─25027 /usr/sbin/acpid -f
Jan 31 18:02:25 ALAMO_Test_1 systemd[1]: Started ACPI Daemon.
Jan 31 18:02:25 ALAMO_Test_1 systemd[1]: Starting ACPI Daemon...
Jan 31 18:02:25 ALAMO_Test_1 acpid[25027]: cannot open input layer
Jan 31 18:02:25 ALAMO_Test_1 acpid[25027]: inotify_add_watch() failed: No such file or directory (2)
Jan 31 18:02:25 ALAMO_Test_1 acpid[25027]: starting up with netlink and the input layer
Jan 31 18:02:25 ALAMO_Test_1 acpid[25027]: 1 rule loaded
Jan 31 18:02:25 ALAMO_Test_1 acpid[25027]: waiting for events: event logging is off
everything seems to work. Any ideas?
  • 1 month later...
Update:
This is the difference between my working DS920+ GIOSERVER (with correct power button power off behavior), and my new DS3622xs+ ALAMO under test:
as you can see, the first one is "enabled" (see third row), and the second one is "static". Any idea?
@Peter Suh @Hackaro1
gio_admin@GIOSERVER:~$ systemctl status acpid.service -l
   Loaded: loaded (/usr/lib/systemd/system/acpid.service; enabled; vendor preset: disabled)
   Active: active (running) since Thu 2024-02-01 08:00:06 CET; 1 months 6 days ago
 Main PID: 19978 (acpid)
   Memory: 0B
           └─19978 /usr/sbin/acpid -f
alamo@ALAMO:/$ systemctl status acpid.service -l
   Active: active (running) since Sat 2024-03-09 10:07:43 CET; 17s ago
 Main PID: 13395 (acpid)
           └─13395 /usr/sbin/acpid -f
check if evdev.ko and button.ko are present and loaded
If you mean from /usr/lib/modules there is no evdev.ko nor button.ko, as a matter of fact. What does it mean? And what should I do?
Thanks in advance
G.
PS: In my working DS920+ from /usr/lib/modules I can find just the button.ko, but no evdev.ko
evdev might be now part of synos kernel with 7.x (like ahci)
you can check on button.ko with
cat /proc/modules | grep button
that should show if its loaded
Another update:
I did a fresh installation using DS920+ as system definition. The power off button works as expected.
Still is reported as "static", but at this point I don't think that would be relevant.
alamo@MHP-TEST:/$ cat /proc/modules | grep button
button 5161 1 i915, Live 0xffffffffa0169000
This time @IG-88's suggention produces result.
So, basically it boils down to the DS3622xs+ choice, I guess.
It's time to understand why it doesn't work with that
produces zero result
if the module is not loaded it can't detect the press of the power button
the loader should (at least when activating the acpid add on) load that module
in theory a
insmod /lib/modules/button.ko
should fix that and after that the shutdown might work as expected
55 minutes ago, giacomoleopardo said:
Another hint: I tried the latest AuxXxilium's ARC with DS3622xs+and the acpi service does work!
if you found soemthing thats working for you that i guess its a solved problem
