kaku Posted June 16, 2022 #1 Posted June 16, 2022 (edited) I have a bare metal system with following: COU : i5 Ivy Bridge Motherboard : Gigabyte GA-B75M-D3H tc@box:~$ lspci -nnq 00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller [8086:0150] (rev 09) 00:02.0 VGA compatible controller [0300]: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller [8086:0152] (rev 09) 00:14.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller [8086:1e31] (rev 04) 00:1a.0 USB controller [0c03]: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 [8086:1e2d] (rev 04) 00:1b.0 Audio device [0403]: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller [8086:1e20] (rev 04) 00:1c.0 PCI bridge [0604]: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 [8086:1e10] (rev c4) 00:1c.4 PCI bridge [0604]: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 5 [8086:1e18] (rev c4) 00:1d.0 USB controller [0c03]: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 [8086:1e26] (rev 04) 00:1e.0 PCI bridge [0604]: Intel Corporation 82801 PCI Bridge [8086:244e] (rev a4) 00:1f.0 ISA bridge [0601]: Intel Corporation B75 Express Chipset LPC Controller [8086:1e49] (rev 04) 00:1f.2 SATA controller [0106]: Intel Corporation 7 Series/C210 Series Chipset Family 6-port SATA Controller [AHCI mode] [8086:1e02] (rev 04) 00:1f.3 SMBus [0c05]: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller [8086:1e22] (rev 04) 02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06) 03:02.0 Ethernet controller [0200]: Intel Corporation 82540EM Gigabit Ethernet Controller [8086:100e] (rev 02) Building manual with following extensions: tc@box:~$ sudo ./rploader.sh build broadwellnk-7.1.0-42661 manual Spoiler Rploader Version : 0.8.0.3 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master Extensions : redpill-misc Extensions URL : "https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json" TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.broadwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology%20NAS%20GPL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1be COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : broadwellnk TARGET_VERSION : 7.1.0 TARGET_REVISION : 42661 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42661 MODEL : DS3622xs+ Local Cache Folder : /mnt/sde3/auxfiles DATE Internet : 16062022 Local : 16062022 Checking Internet Access -> OK Checking if a newer version exists on the main repo -> Version is current Redpill sources already downloaded, pulling latest Already up to date. Loader sources already downloaded, pulling latest Already up to date. Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_42661 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/releases/redpill-4.4.180plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/src/check-redpill.sh Got redpill-linux-v4.4.180+.ko Manual extension handling,skipping extension auto detection Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Removing : redpill-boot-wait Found build request for revision greater than 42218 Found extractor locally cached Copying required libraries to local lib directory Linking lib to lib64 Copying executable Removing temp folder /tmp/synoesp Checking if tool is accessible /bin/syno_extract_system_patch: /usr/local/lib/libcurl.so.4: no version information available (required by /bin/syno_extract_system_patch) Executed succesfully Creating temp folder /tmp/pat Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Found locally cached pat file /home/tc/custom-module/ds3622xsp_42661.pat File /home/tc/custom-module/ds3622xsp_42661.pat, is a compressed tar File /home/tc/custom-module/ds3622xsp_42661.pat is already unencrypted Copying file to /home/tc/redpill-load/cache folder ./VERSION Pat file sha256sum is : c80475ffb0d31894bbbad7437baa24e0cb97c88f7bfaa396b7f87c817efbab8b Checking config file existence -> OK Editing config file -> Verifying config file -> OK ! Clearing temp folders Processing add_extensions entries found on custom_config.json file : redpill-misc Adding extension "https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [!] Extension is already added (index exists at /home/tc/redpill-load/custom/extensions/redpill-misc/redpill-misc.json). For more info use "ext-manager.sh info redpill-misc" *** Process will exit *** Updating extension : redpill-misc contents for model : ds3622xsp_42661 [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0% [#] Extension redpill-misc for ds3622xsp_42661 platform is already up to date [#] Updating ds3622xsp_42661 platforms extensions... [OK] [#] Checking runtime for required tools... [OK] [#] Updating extensions... [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/rp-ext/raw/main/redpill-boot-wait/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/rp-ext/raw/main/redpill-boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0%[OK] [#] ========================================== redpill-boot-wait ========================================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for the boot device to appear [#] To get help visit: https://github.com/pocopico/rp-ext/redpill-boot-wait [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/redpill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill-boot-wait/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ======================================================================================= [#] Checking runtime for required tools... [OK] [#] Updating jg.acpid extension... [#] Downloading remote file https://raw.githubusercontent.com/jimmyGALLAND/redpill-ext/master/acpid/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [#] Extension jg.acpid index is already up to date [#] Updating pocopico.e1000 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [#] Extension pocopico.e1000 index is already up to date [#] Updating pocopico.e1000e extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000e/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [#] Extension pocopico.e1000e index is already up to date [#] Updating pocopico.r8169 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/r8169/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [#] Extension pocopico.r8169 index is already up to date [#] Updating pocopico.v9fs extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/v9fs/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [#] Extension pocopico.v9fs index is already up to date [#] Updating redpill-boot-wait extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill-boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [#] Extension redpill-boot-wait index is already up to date [#] Updating redpill-misc extension... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [#] Extension redpill-misc index is already up to date [#] Updating thethorgroup.virtio extension... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-virtio/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ################################################################################################################# 100.0% [#] Extension thethorgroup.virtio index is already up to date [#] Updating thethorgroup.virtio extension... [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [#] Downloading remote file https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/recipes/v7.1_broadwellnk.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0% [#] Filling-in newly downloaded recipe for extension jg.acpid platform ds3622xsp_42661 [#] Downloading remote file https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/install-acpi.sh to /home/tc/redpill-load/custom/extensions/jg.acpid/ds3622xsp_42661/install-acpi.sh ################################################################################################################# 100.0%[#] Verifying /home/tc/redpill-load/custom/extensions/jg.acpid/ds3622xsp_42661/install-acpi.sh file... [OK] [#] Downloading remote file https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/pkg/pwrbtn_pkg_v2.tgz to /home/tc/redpill-load/custom/extensions/jg.acpid/ds3622xsp_42661/pwrbtn_pkg.tgz ################################################################################################################# 100.0%[#] Verifying /home/tc/redpill-load/custom/extensions/jg.acpid/ds3622xsp_42661/pwrbtn_pkg.tgz file... [OK] [#] Downloading remote file https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/modules/pwrbtn-module-v7.1-broadwellnk.tgz to /home/tc/redpill-load/custom/extensions/jg.acpid/ds3622xsp_42661/pwrbtn-module-v7.1-broadwellnk.tgz ################################################################################################################# 100.0%[#] Verifying /home/tc/redpill-load/custom/extensions/jg.acpid/ds3622xsp_42661/pwrbtn-module-v7.1-broadwellnk.tgz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/jg.acpid/ds3622xsp_42661/pwrbtn-module-v7.1-broadwellnk.tgz to /home/tc/redpill-load/custom/extensions/jg.acpid/ds3622xsp_42661/... [OK] [#] Successfully processed recipe for extension jg.acpid platform ds3622xsp_42661 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0%[#] Extension pocopico.e1000 for ds3622xsp_42661 platform is already up to date [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000e/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0%[#] Extension pocopico.e1000e for ds3622xsp_42661 platform is already up to date [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/r8169/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0%[#] Extension pocopico.r8169 for ds3622xsp_42661 platform is already up to date [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/v9fs/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0%[#] Extension pocopico.v9fs for ds3622xsp_42661 platform is already up to date [#] Downloading remote file https://github.com/RedPill-TTG/redpill-boot-wait/raw/master/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0%[#] Filling-in newly downloaded recipe for extension redpill-boot-wait platform ds3622xsp_42661 [#] Downloading remote file https://raw.githubusercontent.com/RedPill-TTG/redpill-boot-wait/master/src/boot-wait.sh to /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xsp_42661/boot-wait.sh ################################################################################################################# 100.0%[#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xsp_42661/boot-wait.sh file... [OK] [#] Successfully processed recipe for extension redpill-boot-wait platform ds3622xsp_42661 [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0%[#] Extension redpill-misc for ds3622xsp_42661 platform is already up to date [#] Downloading remote file https://github.com/jumkey/redpill-load/raw/develop/redpill-virtio/recipes/ds3622xsp_41890.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ################################################################################################################# 100.0%[#] Extension thethorgroup.virtio for ds3622xsp_42661 platform is already up to date [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xsp_42661/boot-wait.sh file... [OK] [#] Updating extensions... [OK] [#] Verifying /home/tc/redpill-load/cache/ds3622xsp_42661.pat file... [OK] [#] Unpacking /home/tc/redpill-load/cache/ds3622xsp_42661.pat file to /home/tc/redpill-load/build/1655357395/pat-ds3622xsp_42661-unpacked... [OK] [#] Verifying /home/tc/redpill-load/build/1655357395/pat-ds3622xsp_42661-unpacked/zImage file... [OK] [#] Patching /home/tc/redpill-load/build/1655357395/pat-ds3622xsp_42661-unpacked/zImage to /home/tc/redpill-load/build/1655357395/zImage-patched... [OK] [#] Verifying /home/tc/redpill-load/build/1655357395/pat-ds3622xsp_42661-unpacked/rd.gz file... [OK] [#] Unpacking /home/tc/redpill-load/build/1655357395/pat-ds3622xsp_42661-unpacked/rd.gz file to /home/tc/redpill-load/build/1655357395/rd-ds3622xsp_42661-unpacked... [OK] [#] Apply patches to /home/tc/redpill-load/build/1655357395/rd-ds3622xsp_42661-unpacked... [OK] [#] Patching config files in ramdisk... [OK] [#] Adding OS config patching... [OK] [#] Repacking ramdisk to /home/tc/redpill-load/build/1655357395/rd-patched-ds3622xsp_42661.gz... [OK] [#] Bundling extensions... [#] Checking runtime for required tools... [OK] [#] Dumping ds3622xsp_42661 platform extensions to /home/tc/redpill-load/build/1655357395/custom-initrd/exts... [OK] [#] Packing custom ramdisk layer to /home/tc/redpill-load/build/1655357395/custom.gz... [OK] [#] Generating GRUB config... [OK] [#] Creating loader image at loader.img... [OK] [#] Cleaning up... [OK] Mounting /dev/sde1 to localdiskp1 Mounting /dev/sde2 to localdiskp2 Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (USB, Verbose)' { menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use No adequate space on TCRP loader partition /mnt/sde3 to cache pat file Found /mnt/sde3/auxfiles/ds3622xsp_42661.pat file Do you want me to remove older cached pat files and cache current ? [yY/nN] : y Found /home/tc/redpill-load/cache/ds3622xsp_42661.pat, copying to cache directory : /mnt/sde3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! tc@box:~$ ./rploader.sh backup Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 636M , try to keep it less than 1GB as it might not fit into your image Should i update the sde with your current files [Yy/Nn] y Backing up home files to sde : Backing up files to /mnt/sde3//mydata.tgz Done. tc@box:~$ ./rploader.sh ext broadwellnk-7.1.0-42661 info Spoiler Rploader Version : 0.8.0.3 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master Extensions : redpill-misc Extensions URL : "https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json" TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.broadwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology%20NAS%20GPL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1be COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : broadwellnk TARGET_VERSION : 7.1.0 TARGET_REVISION : 42661 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42661 MODEL : DS3622xs+ Local Cache Folder : /mnt/sde3/auxfiles DATE Internet : 16062022 Local : 16062022 Checking Internet Access -> OK Redpill sources already downloaded, pulling latest Already up to date. Loader sources already downloaded, pulling latest Already up to date. [#] Checking runtime for required tools... [OK] [#] ========================================== jg.acpid ========================================== [#] Extension name: ACPI Daemon [#] Description: ACPI Daemon that handles power button events [#] To get help visit: https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid [#] Extension preparer/packer: https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid [#] Software author: https://sourceforge.net/projects/acpid2/ [#] Update URL: https://raw.githubusercontent.com/jimmyGALLAND/redpill-ext/master/acpid/rpext-index.json [#] Platforms supported: ds3617xs_25556u2 ds3617xs_42218 ds3615xs_25556u2 ds3617xs_42550 ds3617xs_25556 ds918p_42550 ds918p_25556 ds3622xsp_42661 ds3622xsp_42218 ds3622xsp_42661u2 ds3622xsp_42661u1 ds3622xsp_42218u2 ds3617xs_42218u2 ds3617xs_42661u2 ds3617xs_42661u1 ds3617xs_42661 ds3615xs_25556 ds918p_42218 ds918p_25556u2 ds918p_42218u2 ds3615xs_42218 [#] ======================================================================================= [#] ========================================== pocopico.e1000 ========================================== [#] Extension name: e1000 [#] Description: Adds Intel(R) PRO/1000 Network Driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/e1000 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ======================================================================================= [#] ========================================== pocopico.e1000e ========================================== [#] Extension name: e1000e [#] Description: Adds Intel(R) PRO/1000 Network Driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/e1000e [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000e/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ======================================================================================= [#] ========================================== pocopico.r8169 ========================================== [#] Extension name: r8169 [#] Description: Adds RealTek RTL-8169 Gigabit Ethernet driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/r8169 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/r8169/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ======================================================================================= [#] ========================================== pocopico.v9fs ========================================== [#] Extension name: v9fs [#] Description: Adds Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/v9fs [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/v9fs/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ======================================================================================= [#] ========================================== redpill-boot-wait ========================================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for the boot device to appear [#] To get help visit: https://github.com/pocopico/rp-ext/redpill-boot-wait [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/redpill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill-boot-wait/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ======================================================================================= [#] ========================================== redpill-misc ========================================== [#] Extension name: Misc shell [#] Description: Misc shell [#] To get help visit: https://github.com/pocopico/redpill-load/raw/develop/redpill-misc [#] Extension preparer/packer: https://github.com/pocopico/redpill-load/raw/develop/redpill-misc [#] Software author: https://github.com/pocopico/redpill-load/raw/develop/redpill-misc [#] Update URL: https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ======================================================================================= [#] ========================================== thethorgroup.virtio ========================================== [#] Extension name: VirtIO [#] Description: Adds VirtIO support for fast network/PCI/SCSI/network/console paravirtualization under QEmu (Proxmox, VirtualBox, virsh, and similar) [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/RedPill-TTG/redpill-virtio [#] Software author: https://www.linux-kvm.org/page/Virtio [#] Update URL: https://github.com/pocopico/redpill-load/raw/develop/redpill-virtio/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3622xsp_42550 ds3615xs_25556 ds920p_42218 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ======================================================================================= I have tried separately both ACPI extensions below https://raw.githubusercontent.com/jimmyGALLAND/redpill-ext/master/acpid/rpext-index.json https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json But still cant shutdown using Power Button. If anybody can help please do. ls -l /etc/systemd/system/multi-user.target.wants/ Spoiler total 8 lrwxrwxrwx 1 root root 37 Jun 14 16:15 atalk.service -> /usr/lib/systemd/system/atalk.service lrwxrwxrwx 1 root root 37 Jun 14 16:15 avahi.service -> /usr/lib/systemd/system/avahi.service lrwxrwxrwx 1 root root 36 Jun 14 16:15 ntpd.service -> /usr/lib/systemd/system/ntpd.service lrwxrwxrwx 1 root root 61 Jun 14 16:16 pkg-synosamba-env-setup.service -> /usr/local/lib/systemd/system/pkg-synosamba-env-setup.service lrwxrwxrwx 1 root root 56 Jun 14 16:16 pkg-synosamba-nmbd.service -> /usr/local/lib/systemd/system/pkg-synosamba-nmbd.service lrwxrwxrwx 1 root root 56 Jun 14 16:16 pkg-synosamba-smbd.service -> /usr/local/lib/systemd/system/pkg-synosamba-smbd.service lrwxrwxrwx 1 root root 70 Jun 14 16:16 pkg-synosamba-wstransfer-genconf.service -> /usr/local/lib/systemd/system/pkg-synosamba-wstransfer-genconf.service lrwxrwxrwx 1 root root 36 Jun 14 16:15 ssdp.service -> /usr/lib/systemd/system/ssdp.service lrwxrwxrwx 1 root root 36 Jun 14 16:15 sshd.service -> /usr/lib/systemd/system/sshd.service lrwxrwxrwx 1 root root 41 Jun 14 16:15 synotifyd.service -> /usr/lib/systemd/system/synotifyd.service systemctl status acpid.service ● acpid.service - ACPI Daemon Loaded: loaded (/usr/lib/systemd/system/acpid.service; static; vendor preset: disabled) Active: activating (auto-restart) (Result: exit-code) since Thu 2022-06-16 11:06:32 IST; 16s ago Process: 25601 ExecStartPre=/sbin/modprobe button (code=exited, status=1/FAILURE) Edited June 16, 2022 by kaku code edit Quote
pocopico Posted June 16, 2022 #2 Posted June 16, 2022 (edited) Head over to https://github.com/pocopico/4.4.180plus-broadwellnk and download button.ko copy it to /usr/lib/modules/ login on your DSM as admin user and run the following : sudo -s ln -s /bin/kmod /sbin/depmod ln -s /bin/kmod /sbin/modinfo depmod -a Edited June 16, 2022 by pocopico 1 2 Quote
kaku Posted June 16, 2022 Author #3 Posted June 16, 2022 Thanks @pocopico This works. FYI depmod -a sudo depmod -a depmod: WARNING: could not open /lib/modules//modules.order: No such file or directory depmod: WARNING: could not open /lib/modules//modules.builtin: No such file or directory 1 Quote
Ostap60 Posted November 14, 2022 #4 Posted November 14, 2022 В 16.06.2022 в 19:06, kaku сказал: sudo depmod -a depmod: WARNING: could not open /lib/modules//modules.order: No such file or directory depmod: WARNING: could not open /lib/modules//modules.builtin: No such file or directory I have the same Quote
maxime Posted February 19, 2024 #5 Posted February 19, 2024 On 6/16/2022 at 4:47 PM, pocopico said: copy it to /usr/lib/modules/ Hi! I'm trying to do it using WinSCP, but I obtained "Permission denied". How can I login as root user? Quote
MrBlackMan Posted July 1, 2024 #6 Posted July 1, 2024 Hi @pocopico I have the same problem but i can not fix this on my system. CPU - Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz Motherboard: Gigabyte H55N-USB3 synobios="broadwellnk" unique="synology_broadwellnk_rs4021xs+" I also try to fix this problem with the add button.ko to /lib/modules but this is not have effect. Now my acpid service have this error Jul 01 16:39:02 Nasik acpid[15535]: cannot open input layer Jul 01 16:39:02 Nasik acpid[15535]: inotify_add_watch() failed: No such file or directory (2) and in /dev folder input is absent sh-4.4# modprobe button modprobe: ERROR: could not insert 'button': Exec format error sh-4.4# modprobe -r button sh-4.4# depmod -a depmod: WARNING: could not open /lib/modules//modules.order: No such file or directory depmod: WARNING: could not open /lib/modules//modules.builtin: No such file or directory sh-4.4# kmod list | grep but sh-4.4# Quote
