Onknight 2 Posted March 7 Share Posted March 7 So I want to start over wipe the system Clean But every time I try I get the following in photo below @IG-88 @flyride System Wants me to Recover and don't work ... I am stuck Quote Link to post Share on other sites
0 gadreel 17 Posted March 7 Share Posted March 7 (edited) Did you wipe also the USB with the bootloader? I am not 100% sure but I think if you wipe the HD drives is not enough. Edited March 7 by gadreel Quote Link to post Share on other sites
0 Onknight 2 Posted March 7 Author Share Posted March 7 I did not wipe the harddrives.. The system crashed and could not wipe them Quote Link to post Share on other sites
0 gadreel 17 Posted March 7 Share Posted March 7 (edited) What about the USB bootloader? Did you wipe the USB and tried to a make a new one? Edited March 7 by gadreel Quote Link to post Share on other sites
0 Onknight 2 Posted March 7 Author Share Posted March 7 @gradreel Yes and get that screen above when I boot Quote Link to post Share on other sites
0 amikot 8 Posted March 7 Share Posted March 7 (edited) I think you have 2 options: Recover and than wipe harddrives in DSM menu remove hard drives and wipe them using PC. Redooing USB bootloader stick is not necessary. Edited March 7 by amikot Quote Link to post Share on other sites
0 Onknight 2 Posted March 7 Author Share Posted March 7 using Darik's Boot and Nuke (DBAN): to wipe the drives Then I'll do a Reinstall Quote Link to post Share on other sites
0 IG-88 755 Posted March 7 Share Posted March 7 48 minutes ago, Onknight said: using Darik's Boot and Nuke (DBAN): to wipe the drives Then I'll do a Reinstall there is a 2nd option in the grub menu for this, should bring you to a reinstall with factory defaults, "DS3615xs 6.2 Baremetal with Jun's Mod v1.03b Reinstall" also you would not need to wipe the whole drive, just the partition table would be enough and if you want to keep your data on the data volume it should be enough to remove the 1st partition on every drive the only thing from dsm an the loader is the kernel of the dsm version you had installed (6.2.0 on the original loader, the files are zImage and rd.gz) Quote Link to post Share on other sites
0 Onknight 2 Posted March 8 Author Share Posted March 8 (edited) 'I've been unsuccessful wiping the drives completely Is there any tool that I can use in Dos or or L Linux Edited March 8 by Onknight Quote Link to post Share on other sites
0 IG-88 755 Posted March 8 Share Posted March 8 depends on your experience, win10's gui tool can be picky about removing partitions and diskpart (cmd) is not so easy to handle (if never used before) linux is fine, cfdisk is easier to handle then just fdisk you could use GParted when you use "startx" after boot with "SystemRescue" (bootable from usb) https://www.system-rescue.org/disk-partitioning/Standard-partitioning-tools/ its pretty straight forward with a gui, delete partitonts click apply and thats it on windows MiniTool Partiton Wizard Free - its easy to use as its more graphical, https://www.partitionwizard.com/ i often use dmde (https://dmde.com), more recovery tool but can be used for that too in the free version Quote Link to post Share on other sites
0 Onknight 2 Posted March 8 Author Share Posted March 8 I can't get it to go I deleted the pations with G-parted but once get into Bootloader I reinstall the OS it puts me back into Recovery mode so GIVE UP Quote Link to post Share on other sites
0 amikot 8 Posted March 8 Share Posted March 8 There is no need to wipe the drives completely. Only partition table must be cleared. It can be done easily from on linux with GParted or on windows10 with diskpart console tool. If after installation you landing constantly in recovery mode it may be caused by faulty drive. I had identical problem. I was struggling to install Xpenology and was thnking there is something wrong with bootloader, whilst the real cause was faulty HDD. I had bad sectors and after NAS could not boot from hard drive. So my suggestion is to try another drive. Quote Link to post Share on other sites
0 IG-88 755 Posted March 8 Share Posted March 8 11 hours ago, Onknight said: I can't get it to go I deleted the pations with G-parted but once get into Bootloader I reinstall the OS it puts me back into Recovery mode 1. dont use fixed ip when installing, leave it to dhcp for installing 2. use original loader (with kernel 6.2.0 on it) and isntall 6.2.(0) aka v23739 3. install on another system and after installing trnasfer usb and disk(s) to the one aou want to use Quote Link to post Share on other sites
0 Onknight 2 Posted March 12 Author Share Posted March 12 Backup !! updates can be found here Quote Link to post Share on other sites
Onknight 2
13 answers to this question
