Big_11 Posted November 23, 2018 Share #1 Posted November 23, 2018 Hi guys, did anybody dealed with the function of the LED's (Harddrives, Warning, etc..) of an Acer EasyStore H340 with XPenology Loader 102b (MBR) Version ? would be very interested of.. regards Big11 Quote Link to comment Share on other sites More sharing options...
fannoute Posted November 23, 2018 Share #2 Posted November 23, 2018 Hi, There is a project for the lights on Mediasmart Server within Linux here : https://github.com/merelin/mediasmartserverd H340 uses the same controller so it should works even if I did not test it. Cheers Quote Link to comment Share on other sites More sharing options...
Dreadnought Posted November 24, 2018 Share #3 Posted November 24, 2018 17 hours ago, fannoute said: Hi, There is a project for the lights on Mediasmart Server within Linux here : https://github.com/merelin/mediasmartserverd H340 uses the same controller so it should works even if I did not test it. Cheers Can you tell your results if you try @Big_11 Quote Link to comment Share on other sites More sharing options...
Big_11 Posted November 24, 2018 Author Share #4 Posted November 24, 2018 Will do.. but first i have to migrate finally my old NAS to my new "AcerNology"... Quote Link to comment Share on other sites More sharing options...
Big_11 Posted November 25, 2018 Author Share #5 Posted November 25, 2018 @Dreadnought How did you PowerOff your Acer with Xpenology ? is the Power Button Working ? i shutted it off with the Power Button, but at next Restart i was informed that my Diskstation was not cleanly shutted down.. Quote Link to comment Share on other sites More sharing options...
bearcat Posted November 25, 2018 Share #6 Posted November 25, 2018 @Big_11 Have you installed the power button package? Quote Link to comment Share on other sites More sharing options...
Dreadnought Posted November 25, 2018 Share #7 Posted November 25, 2018 44 minutes ago, Big_11 said: @Dreadnought How did you PowerOff your Acer with Xpenology ? is the Power Button Working ? i shutted it off with the Power Button, but at next Restart i was informed that my Diskstation was not cleanly shutted down.. Hi I use the following package: and the normal shutdown menu. Quote Link to comment Share on other sites More sharing options...
Big_11 Posted December 15, 2018 Author Share #8 Posted December 15, 2018 @Dreadnought compiled the package on Ubuntu an as i try to start this message appears: Quote root@AcerNology2:/volumeUSB1/usbshare/mediasmartserverd-master# ./mediasmartserverd: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory -ash: ./mediasmartserverd:: No such file or Directory seems it has to be built in an dev-Environment of Sysnolgy, what i tried, but there i can't install the needed libraries caus apt-get or ipkg or anything else worked... any ideas to install needed libraries in Synology toolchain ? rgds Big11 Quote Link to comment Share on other sites More sharing options...
Big_11 Posted March 1, 2019 Author Share #9 Posted March 1, 2019 next Question : on my Acer H340 with XPenology works well, but the Warning Sign (Explanation Mark) is blinking all the time.. i can't see any Errors at the Dashboard... any Ideas ?? it doesn't really matters me, but without it would be fine… (more fine..) Quote Link to comment Share on other sites More sharing options...
lord_snot Posted April 3, 2019 Share #10 Posted April 3, 2019 On 12/15/2018 at 6:41 AM, Big_11 said: @Dreadnought compiled the package on Ubuntu an as i try to start this message appears: seems it has to be built in an dev-Environment of Sysnolgy, what i tried, but there i can't install the needed libraries caus apt-get or ipkg or anything else worked... any ideas to install needed libraries in Synology toolchain ? rgds Big11 I wonder if this could this be made into a Synology install package like the powerbutton package was? Quote Link to comment Share on other sites More sharing options...
Big_11 Posted April 4, 2019 Author Share #11 Posted April 4, 2019 I'm Sorry.. I do not understand what YOU mean.. Quote Link to comment Share on other sites More sharing options...
lord_snot Posted April 4, 2019 Share #12 Posted April 4, 2019 9 hours ago, Big_11 said: I'm Sorry.. I do not understand what YOU mean.. I'm suggesting if the mediasmartservd project was made into a Synology SPK package as the powerbutton package was, it would be much easier to install. See here... https://www.synology.com/en-us/knowledgebase/DSM/tutorial/Service_Application/How_to_install_applications_with_Package_Center#t2.2 Quote Link to comment Share on other sites More sharing options...
Big_11 Posted April 4, 2019 Author Share #13 Posted April 4, 2019 This was what i did!.. Read the thread above.. "seems it has to be built in an dev-Environment of Sysnolgy, what i tried, but there i can't install the needed libraries caus apt-get or ipkg or anything else worked..." Quote Link to comment Share on other sites More sharing options...
lord_snot Posted April 5, 2019 Share #14 Posted April 5, 2019 On 4/4/2019 at 10:57 AM, Big_11 said: This was what i did!.. Read the thread above.. "seems it has to be built in an dev-Environment of Sysnolgy, what i tried, but there i can't install the needed libraries caus apt-get or ipkg or anything else worked..." Gotcha! I think this may help. I'm a bit of a newb with this stuff. I'll dig in when I've got more time. http://rescene.wikidot.com/synology-ipkg Quote Link to comment Share on other sites More sharing options...
