IG-88 Posted July 20, 2018 Share #76 Posted July 20, 2018 4 hours ago, vortexxx said: Its OK working!!!, Many thanks for all. 1. Windows user need EXT2FSD, install. 2. Booting USB from xpenology insert PC with EXT2FSD 3. Assign drive letter to partition. 4. Find extra.lzma 5. download latest 4.9 extra.lzma from http://s000.tinyupload.com/?file_id=88305548032449150873 6. replace original extra.lzma 7. remove USB, insert in bare metal and power on. i was assuming you followed the normal howto and there is some text about the extra.lzma and how to modify grub.cfg on 1st partition and copy over the extended extra.lzma (if needed), usually you prepare/mount the img file with OSFMount and after that you write it to usb also win10 latest 2 or 3 versions can at least use the 2nd partition where the extra.lzma is located (there was one that could do both but MS changed things and atm its just the 2nd) Quote Link to comment Share on other sites More sharing options...
vortexxx Posted July 20, 2018 Share #77 Posted July 20, 2018 8 минут назад, IG-88 сказал: i was assuming you followed the normal howto and there is some text about the extra.lzma and how to modify grub.cfg on 1st partition and copy over the extended extra.lzma (if needed), usually you prepare/mount the img file with OSFMount and after that you write it to usb also win10 latest 2 or 3 versions can at least use the 2nd partition where the extra.lzma is located (there was one that could do both but MS changed things and atm its just the 2nd) I try 1020 on promox, is working and no need hard dance with drivers. My W10 cant see linux partitions, I dont know why. Its not a problem. Maybe you add this to top of this topic (and 1020 flashing bios too)? Quote Link to comment Share on other sites More sharing options...
IG-88 Posted July 20, 2018 Share #78 Posted July 20, 2018 1st and 2nd partiton on the usb flash drive are FAT partitions, out of curiosity i've tried Ext2Fsd-0.69.exe and with it i can "force" windows to have a drive letter for the 1st partition but there seem to be a accessrights problem as i was not able to open it, only when i opened notepad++ as administrator i was able to edit the grub.cfg, not as comfortable as using it normal but still better as mountig it in a virtualbox linux vm 1 Quote Link to comment Share on other sites More sharing options...
vortexxx Posted November 13, 2018 Share #79 Posted November 13, 2018 (edited) Good day, please can you help me? Its not Xpenology, I try to make 10G switch on VyOS, Its work fine on intel cards, but brocade 1020 cant run, I try to copy ctfw-3.2.1.1.bin to /lib/firmware/ but its not work [ 1.163499] Brocade 10G Ethernet driver - version: 3.2.21.1 [ 1.163534] bnad_pci_probe : (0xffff88040cb81000, 0xffffffffa0068250) PCI Func : (2) [ 1.163559] bna 0000:02:00.2: Direct firmware load failed with error -2 [ 1.163561] bna 0000:02:00.2: Falling back to user helper [ 1.164254] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.0.5-k [ 1.164257] igb: Copyright (c) 2007-2013 Intel Corporation. [ 1.164526] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k [ 1.164530] e1000e: Copyright(c) 1999 - 2013 Intel Corporation. [ 1.164555] Brocade BFA FC/FCOE SCSI driver - version: 3.2.21.1 [ 1.165673] ahci 0000:05:00.0: version 3.0 [ 1.179108] Can't locate firmware ctfw-3.2.1.1.bin [ 1.179412] Failed to load Firmware Image! [ 1.179422] bnad_pci_probe : (0xffff88040cb82000, 0xffffffffa0068250) PCI Func : (3) [ 1.179433] bna 0000:02:00.3: Direct firmware load failed with error -2 [ 1.179434] bna 0000:02:00.3: Falling back to user helper [ 1.180579] Can't locate firmware ctfw-3.2.1.1.bin [ 1.180889] Failed to load Firmware Image! Please help me. Edited November 13, 2018 by vortexxx Quote Link to comment Share on other sites More sharing options...
vortexxx Posted November 13, 2018 Share #80 Posted November 13, 2018 (edited) Its not my, but works fine. wget http://git.kernel.org/cgit/linux/kernel/git/firmware/linux-firmware.git/tree/ctfw-3.2.3.0.bin wget http://git.kernel.org/cgit/linux/kernel/git/firmware/linux-firmware.git/tree/ct2fw-3.2.3.0.bin wget http://git.kernel.org/cgit/linux/kernel/git/firmware/linux-firmware.git/tree/cbfw-3.2.3.0.bin cp ctfw-3.2.3.0.bin /lib/firmware/ cp ct2fw-3.2.3.0.bin /lib/firmware/ cp cbfw-3.2.3.0.bin /lib/firmware/ ] cd /lib/firmware ln -s ctfw-3.2.3.0.bin ctfw.bin ln -s ct2fw-3.2.3.0.bin ct2fw.bin ln -s cbfw-3.2.3.0.bin cbfw.bin modprobe -r bna modprobe bna Edited November 13, 2018 by vortexxx Quote Link to comment Share on other sites More sharing options...
vortexxx Posted November 14, 2018 Share #81 Posted November 14, 2018 Its no my but works from this https://gist.github.com/ViKingIX/95db2d154ebcf271f6df2d48d53e79a0 Get Firmwares cd /lib/firmware sudo wget http://git.kernel.org/cgit/linux/kernel/git/firmware/linux-firmware.git/plain/{ctfw,ct2fw}-3.2.5.1.bin Update initramfs sudo update-initramfs -u -k all Unload and lacklist bfa module echo blaclist bfa | sudo tee /etc/modprobe.d/blaclist-bfa Reload bna module sudo rmmod bna sudo modprobe bna Quote Link to comment Share on other sites More sharing options...
RacerX Posted December 30, 2018 Share #82 Posted December 30, 2018 (edited) Hello I'm back again, yesterday I setup a test on one of my N54L's. DMS3615xs_23739 works correctly Hardware wise Intel PCIE Desktop Nic e1000e is in the middle x4 slot 10Gb ConnectX2 in the x16 slot I reflashed the card according the PID from Mellanox The card is native Mellanox Infiniband but the ports can be configured to do IP or Infiniband This is just a test no data involved On the desktop I can see the Intel Nic but not the Mellanox 10GB nic Here is the log. dmesg -wH +0.000002] e1000e 0000:03:00.0 eth0: Intel(R) PRO/1000 Network Connection [ +0.000013] e1000e 0000:03:00.0 eth0: MAC: 3, PHY: 8, PBA No: E46981-005 [ +0.024683] Intel(R) Gigabit Ethernet Network Driver - version 5.3.5.3 [ +0.000005] Copyright (c) 2007-2015 Intel Corporation. [ +0.017744] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.1.3 [ +0.000005] Copyright(c) 1999 - 2017 Intel Corporation. [ +0.019045] i40e: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver - version 2.3.6 [ +0.000004] i40e: Copyright(c) 2013 - 2017 Intel Corporation. [ +0.022818] tn40xx low_mem_msg proc entry initialized [ +0.000007] tn40xx low_mem_counter proc entry initialized [ +0.000003] tn40xx debug_msg proc entry initialized [ +0.000002] tn40xx: Tehuti Network Driver, 0.3.6.12.3 [ +0.041244] qed_init called [ +0.000005] QLogic FastLinQ 4xxxx Core Module qed 8.33.9.0 [ +0.000002] creating debugfs root node [ +0.008795] qede_init: QLogic FastLinQ 4xxxx Ethernet Driver qede 8.33.9.0 [ +0.009530] Loading modules backported from Linux version v3.18.1-0-g39ca484 [ +0.000004] Backport generated by backports.git v3.18.1-1-0-g5e9ec4c [ +0.046503] Compat-mlnx-ofed backport release: c22af88 [ +0.000005] Backport based on mlnx_ofed/mlnx-ofa_kernel-4.0.git c22af88 [ +0.000002] compat.git: mlnx_ofed/mlnx-ofa_kernel-4.0.git [ +0.106092] mlx4_core: Mellanox ConnectX core driver v4.1-1.0.2 (27 Jun 2017) [ +0.000050] mlx4_core: Initializing 0000:02:00.0 [ +0.627691] systemd-udevd[5692]: starting version 204 [ +1.052738] mlx4_core 0000:02:00.0: DMFS high rate mode not supported [ +0.000235] mlx4_core: device is working in RoCE mode: Roce V1 [ +0.000002] mlx4_core: UD QP Gid type is: V1 [ +1.121411] mlx4_core 0000:02:00.0: PCIe link speed is 5.0GT/s, device support s 5.0GT/s [ +0.000007] mlx4_core 0000:02:00.0: PCIe link width is x8, device supports x8 [ +0.000131] mlx4_core 0000:02:00.0: irq 45 for MSI/MSI-X [ +0.000007] mlx4_core 0000:02:00.0: irq 46 for MSI/MSI-X [ +0.000007] mlx4_core 0000:02:00.0: irq 47 for MSI/MSI-X [ +0.000006] mlx4_core 0000:02:00.0: irq 48 for MSI/MSI-X [ +0.000005] mlx4_core 0000:02:00.0: irq 49 for MSI/MSI-X [ +0.232870] mlx4_en: Mellanox ConnectX HCA Ethernet driver v4.1-1.0.2 (27 Jun 2017) Do I need to setup the grub info for the card? Edited December 30, 2018 by RacerX spelling error Quote Link to comment Share on other sites More sharing options...
vortexxx Posted November 20, 2020 Share #83 Posted November 20, 2020 Return to 10Gb after more time, this setup is working fine on 6.1 DSM only, you need only add to loader extra.lzma 8Gb from extra.lzma Quote Link to comment Share on other sites More sharing options...
vortexxx Posted November 20, 2020 Share #84 Posted November 20, 2020 If you want make cluster and need 10Gb switch, you can make this. insmod /lib/modules/stp.ko insmod /lib/modules/bridge.ko brctl addbr br0 // add new bridge brctl stp br0 off // stp off ifconfig br0 192.168.50.200 netmask 255.255.255.0 up // add address to bridge brctl addif br0 eth2 // add adapter one brctl addif br0 eth3 // add next adapter route add default gw 192.168.50.1 dev br0 // add GW to bridge and add this to autoboot Quote Link to comment Share on other sites More sharing options...
vortexxx Posted January 2, 2021 Share #85 Posted January 2, 2021 New good sound brocade 10G on 6.2.2 - works fine, but need manipulations. I try fresh install https://archive.synology.com/download/Os/DSM/6.2.2-24922 1. unpack https://archive.synology.com/download/Os/DSM/6.2.2-24922 and you need rd and zImage 2. make loader from https://xpenology.com/forum/topic/21663-driver-extension-jun-103b104b-for-dsm622-for-3615xs-3617xs-918/ 3. on your USB with loader, replace file rd and zImage from unpacking DSM 3. add extra.lzma from http://www.filedropper.com/extra3617v05test Works fine. Asrock h110m-dgs G3940 4Gb Quote Link to comment Share on other sites More sharing options...
IG-88 Posted January 2, 2021 Share #86 Posted January 2, 2021 2 hours ago, vortexxx said: New good sound brocade 10G on 6.2.2 - works fine, but need manipulations. should also be fine with 6.2.3 when the new extra for 6.2.3 is used https://xpenology.com/forum/topic/28321-driver-extension-jun-103b104b-for-dsm623-for-918-3615xs-3617xs/ when the system is up you would remove the usb (its only mounted when booting), replace the extra.lzma, put the usb back in and then update normally with the webgui to 6.2.3 (it will be 2 steps/reboots as there is already a u3 for 6.2.3) 1 Quote Link to comment Share on other sites More sharing options...
vortexxx Posted January 2, 2021 Share #87 Posted January 2, 2021 Its works, IG-88 thank you. Really unplug, update extra.lzma, plug usb again, and ypdate to 6.2.3. Im happy, MANY THANKS. Quote Link to comment Share on other sites More sharing options...
IG-88 Posted January 2, 2021 Share #88 Posted January 2, 2021 if there is a broken file message when u3 is installed use this 8its not just esxi) https://xpenology.com/forum/topic/28183-running-623-on-esxi-synoboot-is-broken-fix-available/ Quote Link to comment Share on other sites More sharing options...
