SergeS Posted September 14, 2017 #1 Posted September 14, 2017 (edited) I have gen8 (xeon) on baremetal with latest loader and latest dsm, and noise is kind of very high, iLo reported fan speed is around 45%. Temperature seems to be ok, all four hdd are around 40C. Are there any way to lower the noise? I have searched on the forum here, but did not find anything practically useful. Edited September 14, 2017 by SergeS Quote
Balrog Posted September 14, 2017 #2 Posted September 14, 2017 If you have installed DMS bare metal on the Gen8 you need to install a software for reading the sensors. Without the sensors values the Gen8 will run in a "save mode" with enhanced fan speed. Search the forum for "AMS". Here is a good start: http://xpenology.com/forum/index.php?/topic/4242-HP-microserver-Gen8-and-hp-ams Quote
haldi Posted October 19, 2017 #3 Posted October 19, 2017 i have 18% Fan Speed normally. What are your BIOS settings for Fan speed / Temperature? Quote
coalfield Posted November 17, 2017 #4 Posted November 17, 2017 Anyone up to the challenge of a dummys guide for AMS for Gen 8 baremetal on 6.1? the referenced thread dates back to 2015 and I am not familiar with modprobe Currently fans are reasonable on my Gen8 as I don't have in the open so not sure how much of a benefit AMS would be however now the box is up and running on the latest I would prefer to have more visibility of temps. Any help appreciated Quote
pedalman Posted February 20, 2019 #5 Posted February 20, 2019 I really need to know that the proper "power settings" in ILO for the NL54 Gen8 microserver are if I run Xpenology 6.2x via loader. If I set OS Control Mode in ILO it will result in 42% fan speed when Xpenelogogy is loaded and running. If set to HP Dynamic Power Savings Mode does not change anything I noticed? Should there be a better way to use OS controlled and set up Diskstation to use less power if possible (idle time)? PS: I activated in Diskstation/Powercontrol "max fans" and can not deactivate it any more with a mouse click :/ is there a known way to SSH set this setting? Quote
