Dell r510 12bay Server H200 LSI SAS (IT Mode) , Intel x520-da2 Nic - Help Required
Server Dell r510 12bay Server H200 LSI SAS (IT Mode) , Intel x520-da2 Nic
Im setting up Redpill with dsm7 model ds3622, my Intel 10gb dualport nic was found and used during the TinyCore setup but is not found with normal boot or synology assistant
The system worked without error on jun bootloader with dsm6
I have also tried to manually add this driver but still not found
./rploader.sh ext ds3622xsp-7.1.1-42962 add https://raw.githubusercontent.com/pocopico/rp-ext/master/ixgbe/rpext-index.json
I have since swaped the Nic out for an Intel 1gb card and all works, confirming I just need the drivers for the 10gb nic
Please advise which drivers to add so I can have the 10gb Intel x520-da2 card working again.
Process for install using latest version :
./rploader.sh update (non found)
./rploader.sh identifyusb
./rploader.sh serialgen DS3622xs+
./rploader.sh satamap (also read this is not required for hba ? )
./rploader.sh listmods ds3622xsp-7.1.1-42962
./rploader.sh build ds3622xsp-7.1.1-42962
./rploader.sh backup
exitcheck.sh reboot
Edited by jasonhill1
  • jasonhill1 changed the title to Dell r510 12bay Server H200 LSI SAS (IT Mode) , Intel x520-da2 Nic - Help Required
exitcheck.sh reboot
That card will not work with DS3622 try this card Intel X520-SR2 10GbE Dual Ports Ethernet Server Adapter w/2 SFP E10G42BFSRBLK  I'm Using it with no problems, didn't even have to add any drivers.  Plug and Play !   That card 10gb Intel x520-da2 works with DS3617 ... I'm using it on a R410
Edited by painkiller895
  • Like 2
Thank you I tried the ds3617xs and its now working, I wanted to use the ds3622xs+ as I believe this allowed more CPU's / threads but on further testing I think the ds3617xs is also ok for my needs as i have 24 threads I can use
I used the ARPL method choosing ds3617xs and the latest version & pat file.
ARPL:
https://github.com/fbelavenuto/arpl/releases/download/v0.5-alpha1/arpl-0.5-alpha1.img.zip
ARPL:
Yes sir ! Same loader I'm using.  Works well.
5 minutes ago, jasonhill1 said:
Thank you for the suggestion.
After testing with spare drives I've now reinstalled my data drives and migrated from a previous loader and dsm6 to the latest dsm 7.1.1
Great news, glad I was able to help.
Also I use Webmin which fails to start now on dsm7, but found it can be started via ssh, and maybe task schedular (as root, I'll try later)
# open a terminal and ssh to your nas and login as admin
> ssh admin@yournas
Password: xxxxx
admin@yournas> sudo /var/packages/webmin/target/etc/start
Password:
Starting Webmin server in /var/packages/webmin/target/webmin
admin@yournas> exit
logout
Connection to nas closed.
As found in this guide: https://github.com/gnadelwartz/synomin/issues/5
