Notification rules issue with tinycore-redpill installation
Recently, I stumbled upon the DS3622xs+ (system version DSM7.1.1-42962) that was booted with tinycore-redpill and installed on esxi, compared with the official system under the same version. There is a big difference in [Control Panel] -> [Notification Settings] -> Rules Options.
As shown in the figure below, DS918+ is an officially purchased product, DS3622xs+ is a product installed on ESXI, and the system version is upgraded to the same DSM7.1.1-42962. But on DS3622xs+, there are no notification rules such as "system", "Package Center", "Security Advisor", "Power supply", and "Log Center". Where is the problem?
2 answers to this question
I have a DS3622xs+ 7.1.1-42962 from baremetal.
Although there are differences between bare metal and VM,
All the items you pointed out are showing up for me.
Is Log Center installed on DS3622xs+?
You need to install Log Center as a package once more to use advanced features.
Edited by Peter Suh
14 hours ago, Peter Suh said:
我有一个来自裸机的 DS3622xs+ 7.1.1-42962。
尽管裸机和 VM 之间存在差异,
但您指出的所有项目都显示给我。
DS3622xs+ 上是否安装了日志中心?
您需要再次将 Log Center 作为一个软件包安装才能使用高级功能。
Yes, it is installed. In fact, these options should be available directly after installing the system. These options came out after my fresh install, not sure what's causing the problem. I upgraded from 6.2.3
Answer this question...
