Problem with satamap - how does it work?
Hi there!
Iam setting up a Xpenology NAS and have trouble with the satamap command.
First my Hardware:
i3-12100
Biostar B660GTN (ITX board with 4 Sata Ports)
3x Crucial MX500 1TB SSDs
16GB RAM
I used THIS guide to install DSM7 but have some trouble with the satamap command.
It looks like this:
Found "00:17.0 Intel Corporation Device 7ae2 (rev 11)"
Detected 8 ports/3 drives. Bad ports: 1 2 3 4. Override # of ports or ENTER to accept <8>
Computed settings:
SataPortMap=8
DiskIdxMap=00
WARNING: Bad ports are mapped. The DSM installation will fail!
I searched and found THIS post. So i tryed the "dmesg |grep sd" command and got my 3 SSDs and my USB stick:
[    0.690617] sd 4:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    0.690731] sd 5:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    0.690839] sd 7:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.722473] sd 8:0:0:0: [sdd] 242614272 512-byte logical blocks: (124 GB/116 GiB)
So i tryed to put in:
SataPortMap=41 (4= 4 Sata Ports - 1 = one USB stick)
DiskIdxMap=48 (4 because the first ssd is 4:0:0:0 - 8 because the usb stick is 8:0:0:0
But when i build the bootloader and restart the system i get some error (no drives found or something like that).
Is my understanding of the satamap command wrong? What kind of settings should i use?
Pls help
Thanks!
Edited by Timon-H
Your chipset on your motherboard is an INTEL B660, It manages 4 sata ports (present on the motherboard).
Why map your USB port? Your usb stick is recognized by the VID and PID that you enter in user_config.json (./rploader.sh identifyusb)
Test :
SataPortMap=4
DiskIdxMap=00
For any help, read :
Edited by renegadeBE
20 minutes ago, renegadeBE said:
Test :
SataPortMap=4
DiskIdxMap=00
Thanks for your reply!
Sadly with SataPortMap=4 i get the same error..
I also tryed the linked Tutorial but with that i no longer find my NAS after building the bootloader. Used Plattform: DS3622xs+ used architecture:broadwellnk.
17 minutes ago, renegadeBE said:
Bios configs :
- SATA -> AHCI
- C1E -> Disable
- Hot Plug -> Enable for all sata
My SATA configuartion menu only has:
Sata Controller ON/OFF -> set to  ON
SATA Mode Selectrion AHCI/Raid -> set to AHCI
SMART Self Test ON/OFF -> set to OFF
SATA Hot Plug ON/OFF -> set to ON
Hybrid Storage Detection and Configuration Mode OFF/Dynamic Config for hybrid storage enable -> set to off
C1E is some kind of Power State for the CPU? I looked into the CPU Power management and VRM settings but couldnt find a C1E setting.
EDIT: Found out that disabling "enhanced C-States" also disables the C1E C State. I tryed again to boot up the bootloader but this "no drives detected"..
Edited by Timon-H
SMART self test can stay ON
Yep ! Because this option causes problems
Install still not working ?
YEP not working..
no drives are detected..
in bios the drives are working just fine.
Post result of this plz
dmesg | fgrep "DUMMY"
[    0.375794] ata1: DUMMY
[    0.375795] ata2: DUMMY
[    0.375795] ata3: DUMMY
[    0.375796] ata4: DUMMY
Edit: I have also tryed "dmesg | fgrep "ata5" "
Results:
[    0.375802] ata5: SATA max UDMA/133 abar m2048@0x80602000 port 0x80602300 irq 124
[    0.687782] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.688674] ata5.00: supports DRM functions and may not be fully accessible
[    0.688822] ata5.00: ATA-10: CT1000MX500SSD1, M3CR043, max UDMA/133
[    0.688824] ata5.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    0.690471] ata5.00: supports DRM functions and may not be fully accessible
[    0.691303] ata5.00: configured for U
Edited by Timon-H
Edit your user_config.json
"SataPortMap" : "4",
"DiskIdxMap" : "00",
"sata_remap" : "4\\>0:5\\>1:6\\>2:7\\>3"
WARNING : If the last argument is not sata_remap add a ","
After, compil your loader and test ! :-)
@IG-88 Can you watch this please?
Still not working. i tryed setting it up clean. i typed those commands:
./rploader.sh identifyusb now
./rploader.sh satamap now
Then i edited the user_config.json with the values you send and safed it.
./rploader.sh serialgen DS3615xs
./rploader.sh backup now
./rploader.sh build bromolow-7.0.1-42218
Then i restartet and opend the IP Adress from the discstation. After some waiting the same "no Drives found" error.
23 minutes ago, renegadeBE said:
Last test :
edit directly to grub, press "e" on start. After edit, press F10
"SataPortMap" : "3"
"DiskIdxMap" : "00"
"sata_remap" : "4\\>0:5\\>1:6\\>2"
When i press "E" on startup i get some kind of config but there is no "SataPortMap" and stuff. See:
10 minutes ago, renegadeBE said:
Oh : are you sure you have compiled during the modifications ? Sataportmap=8
ok now i have tryd it right i think..
Still the same error but in the GRUB Editor my changes are visible.
Computed settings:
SataPortMap=8
DiskIdxMap=00
I haven't seen anyone successfully map over bad ports with Sata remap.  The rploader satamap is reporting your bad ports above by searching for DUMMY values in dmesg and reindexing the information to your controllers.
The B660 chipset appears to share silicon with the H670 which has 8 SATA ports.  Intel locks out the first 4 in your motherboard.
https://images.anandtech.com/doci/17162/2022_CES_Pre-Brief_Dec 15 Final-page-029.jpg
DSM won't install with ports that are electrically present and not functional (hence the DUMMY status).
See the tutorial troubleshooting section for some workaround options, although they aren't really good.
https://xpenology.com/forum/topic/62221-tutorial-installmigrate-to-dsm-7x-with-tinycore-redpill-tcrp-loader/
You will have the best results with one of the folllowing:
  1. Convert to a virtualized installation, connect the storage to the hypervisor and then attach the disks to a virtual SATA controller (RDM in ESXi, for example)
  2. Use a device tree platform (i.e. DS920+) which doesn't use SATAMAP.  There is some evidence that you can use a device tree configuration manually on any platform version, but this is incompletely tested.
  3. Disable your on-board SATA controller and add a PCIe SATA controller that doesn't have bad ports (this is probably least desirable with an ITX motherboard)
Oh.. Thats not nice..
I have tryed the DS920+ installation with the geminilake-7.1.0-42661 architecture. I left the satamap command just like the Turorial suggested. But i cannot get the webinterface to load with that. I even looked up the IP from the server via Router but nothing is loading... i dont have a serial port or adapter..
So PCIe to SATA it is? Any suggestion wich controller i should buy? i would love some M.2 to Sata to have the PCIex16 slot for something else..
If you feel like it, you can try this: edit your user_config.json, and build loader. Thanks to give feedback after test :-)
Custum pid/vid, sn, mac,...
Delete satamap and diskidxmap.
Add sata_remap
Custum internalportcfg and maxdisks
(we try to get out the dummy)
  "extra_cmdline": {
    "pid": "X",
    "vid": "X",
    "sn": "X",
    "mac1": "X",
  "synoinfo": {
          "internalportcfg" : "0xff",
          "maxdisks" : "4",
	      "support_bde_internal_10g" : "no",
	      "support_disk_compatibility" : "no",
          "support_memory_compatibility" : "no"
  "ramdisk_copy": {
Add sata_remap
  "extra_cmdline": {
    "pid": "X",
    "vid": "X",
    "sn": "X",
    "mac1": "X",
  "synoinfo": {
          "maxdisks" : "4",
  "ramdisk_copy": {
Thanks for trying to help!
I tried it, now I get a different error.
Error on the drives (1,2,3,4) and the sata ports got disabled. pls shutdown the system and use other drives..
Here a Screenshot from my config:
16 minutes ago, renegadeBE said:
Plz, give me results if this :
dmesg | fgrep "ata"
tc@box:~$ dmesg | fgrep "ata"
[    0.000000] BIOS-e820: [mem 0x0000000075703000-0x00000000757d6fff] ACPI data
[    0.052885] Memory: 16041500K/16549512K available (10242K kernel code, 1227K rwdata, 1916K rodata, 1184K init, 3660K bss, 507756K reserved, 0K cma-reserved)
[    0.199443] libata version 3.00 loaded.
[    0.375989] ata1: DUMMY
[    0.375990] ata2: DUMMY
[    0.375990] ata3: DUMMY
[    0.375990] ata4: DUMMY
[    0.375997] ata5: SATA max UDMA/133 abar m2048@0x80602000 port 0x80602300 irq 124
[    0.375998] ata6: SATA max UDMA/133 abar m2048@0x80602000 port 0x80602380 irq 124
[    0.376000] ata7: SATA max UDMA/133 abar m2048@0x80602000 port 0x80602400 irq 124
[    0.376001] ata8: SATA max UDMA/133 abar m2048@0x80602000 port 0x80602480 irq 124
[    0.376427] scsi host8: pata_legacy
[    0.376448] ata9: PATA max PIO4 cmd 0x1f0 ctl 0x3f6 irq 14
[    0.687910] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.687931] ata8: SATA link down (SStatus 0 SControl 300)
[    0.687951] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.687972] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.688827] ata7.00: supports DRM functions and may not be fully accessible
[    0.688852] ata5.00: supports DRM functions and may not be fully accessible
[    0.688870] ata6.00: supports DRM functions and may not be fully accessible
[    0.688933] ata7.00: ATA-10: CT1000MX500SSD1, M3CR043, max UDMA/133
[    0.688935] ata7.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    0.688965] ata5.00: ATA-10: CT1000MX500SSD1, M3CR043, max UDMA/133
[    0.688966] ata5.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    0.688986] ata6.00: ATA-10: CT1000MX500SSD1, M3CR043, max UDMA/133
[    0.688987] ata6.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    0.690554] ata7.00: supports DRM functions and may not be fully accessible
[    0.690586] ata5.00: supports DRM functions and may not be fully accessible
[    0.690608] ata6.00: supports DRM functions and may not be fully accessible
[    0.691283] ata7.00: configured for UDMA/133
[    0.691373] ata5.00: configured for UDMA/133
[    0.691381] ata6.00: configured for UDMA/133
[    0.728037] scsi host8: pata_legacy
[    0.728057] ata10: PATA max PIO4 cmd 0x170 ctl 0x376 irq 15
[    0.901463] usbcore: registered new interface driver ums-datafab
[    0.960712] Write protecting the kernel read-only data: 14336k
[    0.961958] Freeing unused kernel image (text/rodata gap) memory: 2044K
[    0.962082] Freeing unused kernel image (rodata/data gap) memory: 132K
On 7/10/2022 at 5:32 PM, renegadeBE said:
I don't know how to help you anymore. Sorry
@IG-88 may have another solution. Or another member...
If not, you can try another generator, it uses a different approach for identifying HDDs. I attached the topic for you.
OMG with that software i got it to work... sort of.
My Drives are now all there and i can upload the image from the Synology OS. But after 41-42% it gives me some error that the file is corrupted... I just downloaded it.. And yes i used the correct version...
