costyy 0 Posted April 3 Share Posted April 3 (edited) I had a volume crushed after my system ssd went bad. I have a raid 5 volume composed from 10x4tb drives and got one initialized and another one not initialized. I installed ubuntu on another machine and got this message from the attached pics. From the 10 drives 9 have the linux partition on them the 10th is free space .Can I save the data from the drives or is it all lost? Edited April 3 by costyy Quote Link to post Share on other sites
IG-88 1,034 Posted April 3 Share Posted April 3 7 hours ago, costyy said: I had a volume crushed after my system ssd went bad. I have a raid 5 volume composed from 10x4tb drives not likely that the ssd is the reason as dsm does a raid1 over all disks and if one fails the the other disks still have a valid system usually if its raid 5 and you still have 9 of 10 disks it looks ok but in yous last screenshot it say's raid0 for md3 if you are still on the same hardware where the disks failed you might need to stop and try to make sure its not a problem with the hardware (ram, psu, ...) it might help to look for the old system partition and try to see whats in the logs might be better to know what happened - when the reason is unclear - before doing anything that might not be reversible Quote Link to post Share on other sites
costyy 0 Posted April 4 Author Share Posted April 4 I had the system installation and volume 1 on the SSD and volume2 on 10x4TB drives. I got a notification that volume1 was crushed then I tried to repair it but failed because of bad sectors on the ssds.I shut down the system because I had to go to work but when I tried to restart the system got the message that volume 2 was crushed.this is with the original hardware the bad ssd is not in the list but the system partition is the only one that works on it. pls help i got all of my data on that raid volume.thanks Quote Link to post Share on other sites
flyride 757 Posted April 4 Share Posted April 4 1 hour ago, costyy said: I had the system installation and volume 1 on the SSD and volume2 on 10x4TB drives. DSM system is on ALL drives. What was on Volume 1 that makes you think that it's the "system" installation? Now that you have restored your disks to DSM, you could start by posting a current mdstat so we have some idea about what the system thinks about the configuration of your arrays and their statuses. Quote Link to post Share on other sites
costyy 0 Posted April 4 Author Share Posted April 4 first i did a clean install of xpenology on the ssd after that i added the drives with the volume on it from a previous machine.i cant connect with ssh to the machine.the first pics from my 1 post are the drives from synology attached to a ubuntu machine. i wanted to recover the volume in ubuntu and reinstall a new machine on another ssd because my ssd is full of bad sectors Quote Link to post Share on other sites
costyy 0 Posted April 4 Author Share Posted April 4 (edited) i managed to connect with telnet to the nas and got this. i am a noob and don't know what to do Edited April 4 by costyy Quote Link to post Share on other sites
flyride 757 Posted April 4 Share Posted April 4 To orient you a bit on what is being reported: /dev/md0 is a RAID1 array and is the DSM "system" spanning all your disks. This array is working but some members have failed. /dev/md1 is a RAID1 array and is the Linux swap partition spanning all your disks. This array is working but some members have failed. /dev/md3 is a RAID5 array and is probably what you called /volume2 - this is currently crashed. Since you think you have a /volume1, it would make sense that it was /dev/md2 but at the moment the system isn't recognizing it at all. What to do next: 1. Generally it would be easier if you cut and pasted text from TELNET instead of picture screenshots as you gather information. 2. Get more information about the possibility of /dev/md2's existence by querying one of the disks for partitions. Post the results of this command: fdisk -l /dev/sda 3. Get more information about /dev/md3 by querying the array for its members. Post the results of this command: mdadm --detail /dev/md3 Quote Link to post Share on other sites
costyy 0 Posted April 4 Author Share Posted April 4 (edited) i changed the last pic because one drive was missing root@NAS:~# fdisk -l /dev/sda Disk /dev/sda: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: EFC71854-746D-45B0-A19B-52AEB1C62FE7 Device Start End Sectors Size Type /dev/sda1 2048 4982527 4980480 2.4G Linux RAID /dev/sda2 4982528 9176831 4194304 2G Linux RAID /dev/sda3 9437184 7813766815 7804329632 3.6T Linux RAID root@NAS:~# mdadm --detail /dev/md3 /dev/md3: Version : 1.2 Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 3902163776 (3721.39 GiB 3995.82 GB) Raid Devices : 10 Total Devices : 8 Persistence : Superblock is persistent Update Time : Mon Apr 4 22:17:29 2022 State : clean, FAILED Active Devices : 8 Working Devices : 8 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : NAS:3 (local to host NAS) UUID : 9858866f:1e986c69:0e23d03d:34731de4 Events : 231229 Number Major Minor RaidDevice State 0 8 3 0 active sync /dev/sda3 1 8 35 1 active sync /dev/sdc3 2 8 51 2 active sync /dev/sdd3 3 8 83 3 active sync /dev/sdf3 - 0 0 4 removed 8 8 147 5 active sync /dev/sdj3 6 8 179 6 active sync /dev/sdl3 10 8 19 7 active sync /dev/sdb3 9 8 163 8 active sync /dev/sdk3 - 0 0 9 removed root@NAS:~# root@NAS:~# fdisk -l /dev/sda Version : 1.2 Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 3902163776 (3721.39 GiB 3995.82 GB) Raid Devices : 10 Total Devices : 8 Persistence : Superblock is persistent Update Time : Mon Apr 4 22:17:29 2022 State : clean, FAILED Active Devices : 8 Working Devices : 8 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : NAS:3 (local to host NAS) UUID : 9858866f:1e986c69:0e23d03d:34731de4 Events : 231229 Number Major Minor RaidDevice State 0 8 3 0 active sync /dev/sda3 1 8 35 1 active sync /dev/sdc3 2 8 51 2 active sync /dev/sdd3 3 8 83 3 active sync /dev/sdf3 - 0 0 -ash: root@NAS:~#: command not found 4 removed 8 8 147 5 active sync /dev/sdj3 6 8 179 6 active sync /dev/sdl3 10 8 19 7 active sync /dev/sdb3 9 8 163 8 active sync /dev/sdk3 - 0 0 9 removed root@NAS:~# Disk /dev/sda: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors -ash: Disk: command not found root@NAS:~# Units: sectors of 1 * 512 = 512 bytes -ash: Units:: command not found root@NAS:~# Sector size (logical/physical): 512 bytes / 4096 bytes -ash: syntax error near unexpected token `(' root@NAS:~# I/O size (minimum/optimal): 4096 bytes / 4096 bytes -ash: syntax error near unexpected token `(' root@NAS:~# Disklabel type: gpt -ash: Disklabel: command not found root@NAS:~# Disk identifier: EFC71854-746D-45B0-A19B-52AEB1C62FE7 -ash: Disk: command not found root@NAS:~# root@NAS:~# Device Start End Sectors Size Type -ash: Device: command not found root@NAS:~# /dev/sda1 2048 4982527 4980480 2.4G Linux RAID -ash: /dev/sda1: Permission denied root@NAS:~# /dev/sda2 4982528 9176831 4194304 2G Linux RAID -ash: /dev/sda2: Permission denied root@NAS:~# /dev/sda3 9437184 7813766815 7804329632 3.6T Linux RAID -ash: /dev/sda3: Permission denied root@NAS:~# root@NAS:~# mdadm --detail /dev/md3 -ash: root@NAS:~#: command not found root@NAS:~# /dev/md3: -ash: /dev/md3:: No such file or directory root@NAS:~# Version : 1.2 -ash: Version: command not found root@NAS:~# Creation Time : Sun Aug 9 11:21:40 2020 -ash: Creation: command not found root@NAS:~# Raid Level : raid5 -ash: Raid: command not found root@NAS:~# Array Size : 35119473984 (33492.54 GiB 35962.34 GB) -ash: syntax error near unexpected token `(' root@NAS:~# Used Dev Size : 3902163776 (3721.39 GiB 3995.82 GB) -ash: syntax error near unexpected token `(' root@NAS:~# Raid Devices : 10 -ash: Raid: command not found root@NAS:~# Total Devices : 8 -ash: Total: command not found root@NAS:~# Persistence : Superblock is persistent -ash: Persistence: command not found root@NAS:~# root@NAS:~# Update Time : Mon Apr 4 22:17:29 2022 -ash: Update: command not found root@NAS:~# State : clean, FAILED -ash: State: command not found root@NAS:~# Active Devices : 8 -ash: Active: command not found root@NAS:~# Working Devices : 8 -ash: Working: command not found root@NAS:~# Failed Devices : 0 -ash: Failed: command not found root@NAS:~# Spare Devices : 0 -ash: Spare: command not found root@NAS:~# root@NAS:~# Layout : left-symmetric -ash: Layout: command not found root@NAS:~# Chunk Size : 64K -ash: Chunk: command not found root@NAS:~# root@NAS:~# Name : NAS:3 (local to host NAS) -ash: syntax error near unexpected token `(' root@NAS:~# UUID : 9858866f:1e986c69:0e23d03d:34731de4 -ash: UUID: command not found root@NAS:~# Events : 231229 -ash: Events: command not found root@NAS:~# root@NAS:~# Number Major Minor RaidDevice State -ash: Number: command not found root@NAS:~# 0 8 3 0 active sync /dev/sda3 -ash: 0: command not found root@NAS:~# 1 8 35 1 active sync /dev/sdc3 -ash: 1: command not found root@NAS:~# 2 8 51 2 active sync /dev/sdd3 -ash: 2: command not found root@NAS:~# 3 8 83 3 active sync /dev/sdf3 -ash: 3: command not found root@NAS:~# - 0 0 4 removed -ash: -: command not found root@NAS:~# 8 8 147 5 active sync /dev/sdj3 -ash: 8: command not found root@NAS:~# 6 8 179 6 active sync /dev/sdl3 -ash: 6: command not found root@NAS:~# 10 8 19 7 active sync /dev/sdb3 -ash: 10: command not found root@NAS:~# 9 8 163 8 active sync /dev/sdk3 -ash: 9: command not found root@NAS:~# - 0 0 9 removed -ash: -: command not found Edited April 4 by costyy Quote Link to post Share on other sites
flyride 757 Posted April 4 Share Posted April 4 Dude. Please don't change your historical posts. I can't tell what has changed now since the original pic is gone. The only way to get data back is to deliberately work through a validation process until something actionable is found. If things change midstream, the process will either start over (at best) or destroy your data beyond recovery (at worst). You also seem to be typing in commands without understanding what they are for. I suggest you stop doing that. Your data is at risk. Quote Link to post Share on other sites
costyy 0 Posted April 4 Author Share Posted April 4 k i will do what you say Quote Link to post Share on other sites
flyride 757 Posted April 4 Share Posted April 4 (edited) I'm trying to noodle out how your system is configured vs. the mdadm reports. You say you have 10x 4TB disks. Your RAID5 array thinks it has 10 members, but it can only find 8. Later you report an SSD. Can you tell me for certain which device the SSD is? I assume it is /dev/sde /dev/sdh and /dev/sdi are missing, but that could be because you have multiple controllers and you didn't resolve a "gap" between them, or it could be that the drive(s) isn't reporting any usable partitions We need to figure out more information. Please post results of this command: ls /dev/sd* We also can see if we can get any corroborating information from the array members about the construction of the /dev/md3 array: mdadm --examine /dev/sd[abcdfgjkl]3 That last command will report a lot of data. It looked like you accidentally pasted the previous results back into DSM and it tried to execute the results as commands. Please use care to make sure the copy/paste is accurate. Edited April 5 by flyride Quote Link to post Share on other sites
flyride 757 Posted April 4 Share Posted April 4 (edited) Edited April 5 by flyride Quote Link to post Share on other sites
costyy 0 Posted April 5 Author Share Posted April 5 now is the original drives from the machine the ssd is not available in storage manager on the nas root@NAS:~# ls /dev/sd* /dev/sda /dev/sdb2 /dev/sdd /dev/sdf2 /dev/sdh /dev/sdk1 /dev/sdl3 /dev/sda1 /dev/sdb3 /dev/sdd1 /dev/sdf3 /dev/sdj /dev/sdk2 /dev/sda2 /dev/sdc /dev/sdd2 /dev/sdg /dev/sdj1 /dev/sdk3 /dev/sda3 /dev/sdc1 /dev/sdd3 /dev/sdg1 /dev/sdj2 /dev/sdl /dev/sdb /dev/sdc2 /dev/sdf /dev/sdg2 /dev/sdj3 /dev/sdl1 /dev/sdb1 /dev/sdc3 /dev/sdf1 /dev/sdg3 /dev/sdk /dev/sdl2 mdadm --examine /dev/sd[abcdfgjkl]3 /dev/sda3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : e6bdb94e:43119dd5:eaf58c3b:2fe8a5ff Update Time : Tue Apr 5 17:06:29 2022 Checksum : fc0251ab - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 0 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdb3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : c1e30c0d:9a95561a:236ce739:19445dc3 Update Time : Tue Apr 5 17:06:29 2022 Checksum : c120ce01 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 7 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdc3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : c8079b49:ad09810a:d893fb57:04e781e5 Update Time : Tue Apr 5 17:06:29 2022 Checksum : 2e1230b3 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 1 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdd3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : db99484d:ee26b85c:a92fa754:34e98ca2 Update Time : Tue Apr 5 17:06:29 2022 Checksum : 3dad7e09 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 2 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdf3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : d7e5fc86:dc5e26ff:a7aa9438:57e35830 Update Time : Tue Apr 5 17:06:29 2022 Checksum : 8b897715 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 3 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdg3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : ddc65815:dc638fa5:43af17f2:ae8573b3 Update Time : Fri Apr 1 14:35:29 2022 Checksum : fcf0987f - correct Events : 230661 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 9 Array State : AAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdj3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : edf7269d:22d055ef:65375e04:d2573885 Update Time : Tue Apr 5 17:06:29 2022 Checksum : b28bfbaf - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 5 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdk3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : e33b11e6:9a94ec8a:a2528d74:eff14c2a Update Time : Tue Apr 5 17:06:29 2022 Checksum : ac50b978 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 8 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdl3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : a564d2ce:0f719a0d:a9b3fc0c:6a93e9b8 Update Time : Tue Apr 5 17:06:29 2022 Checksum : 3ecbc12e - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 6 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) Quote Link to post Share on other sites
flyride 757 Posted April 5 Share Posted April 5 /dev/sde is missing again. Is there a reason for this or did it go offline? Also, is that the SSD you are speaking of? /dev/sdh is probably our missing /dev/md2 array member. It isn't showing any partitions so it may be completely trashed. But let's confirm this: mdadm --examine /dev/sdh Quote Link to post Share on other sites
costyy 0 Posted April 5 Author Share Posted April 5 (edited) posible that /dev/sde is the ssd that is not in the list mdadm --examine /dev/sdh /dev/sdh: MBR Magic : aa55 Partition[0] : 4294967295 sectors at 1 (type ee) Edited April 5 by costyy Quote Link to post Share on other sites
flyride 757 Posted April 5 Share Posted April 5 7 minutes ago, costyy said: posible that /dev/sde is the ssd that is not in the list Do you know why /dev/sde was not online, then online, and now offline again? If there is an unresolved problem, we need it sorted before we start trying to fix arrays. Please advise on what is happening here. Now, in regard to your lost /dev/md3 array - the bad news is it looks like somehow the partitions have been deleted on /dev/sdh, which I think is one of the two missing members. This isn't a corruption as a new partition has been created in place. Maybe the /dev/sdh device got put into a Windows machine and accidentally overwrite the existing partitions that would not have been recognized there? Please advise on what may have happened here. Since /dev/sdh is kaput, that means the only possibility of recovering your /dev/md3 is /dev/sdg3. It seems intact but is out of date (about 600 writes). We can theoretically force it back into the array and it should work, but there will be a small amount of corrupted files that were affected by the missing writes. Quote Link to post Share on other sites
costyy 0 Posted April 5 Author Share Posted April 5 al the problems started when my ssd volume crashed friday.until yesterday all the time that ssd showed up in storage manager but today i cant see the ssd in the list .at this moment the drives that i see are this. Quote Link to post Share on other sites
flyride 757 Posted April 5 Share Posted April 5 We don't want the drive popping in and out. Maybe replace the SATA cables for all three devices encountering problems before proceeding? Quote Link to post Share on other sites
costyy 0 Posted April 5 Author Share Posted April 5 k i changed the cables Quote Link to post Share on other sites
flyride 757 Posted April 5 Share Posted April 5 Anything different in Storage Manager? Quote Link to post Share on other sites
costyy 0 Posted April 5 Author Share Posted April 5 same drives are with system partition failed and ls /dev/sd* /dev/sda /dev/sdb2 /dev/sdd /dev/sdf2 /dev/sdh /dev/sdk1 /dev/sdl3 /dev/sda1 /dev/sdb3 /dev/sdd1 /dev/sdf3 /dev/sdj /dev/sdk2 /dev/sda2 /dev/sdc /dev/sdd2 /dev/sdg /dev/sdj1 /dev/sdk3 /dev/sda3 /dev/sdc1 /dev/sdd3 /dev/sdg1 /dev/sdj2 /dev/sdl /dev/sdb /dev/sdc2 /dev/sdf /dev/sdg2 /dev/sdj3 /dev/sdl1 /dev/sdb1 /dev/sdc3 /dev/sdf1 /dev/sdg3 /dev/sdk /dev/sdl2 root@NAS:~# mdadm --examine /dev/sd[abcdfgjkl]3 /dev/sda3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : e6bdb94e:43119dd5:eaf58c3b:2fe8a5ff Update Time : Tue Apr 5 18:30:43 2022 Checksum : fc026569 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 0 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdb3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : c1e30c0d:9a95561a:236ce739:19445dc3 Update Time : Tue Apr 5 18:30:43 2022 Checksum : c120e1bf - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 7 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdc3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : c8079b49:ad09810a:d893fb57:04e781e5 Update Time : Tue Apr 5 18:30:43 2022 Checksum : 2e124471 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 1 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdd3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : db99484d:ee26b85c:a92fa754:34e98ca2 Update Time : Tue Apr 5 18:30:43 2022 Checksum : 3dad91c7 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 2 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdf3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : d7e5fc86:dc5e26ff:a7aa9438:57e35830 Update Time : Tue Apr 5 18:30:43 2022 Checksum : 8b898ad3 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 3 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdg3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : ddc65815:dc638fa5:43af17f2:ae8573b3 Update Time : Fri Apr 1 14:35:29 2022 Checksum : fcf0987f - correct Events : 230661 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 9 Array State : AAAAAAAAAA ('A' == active, '.' == missing, 'R' == replacing) /dev/sdj3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : edf7269d:22d055ef:65375e04:d2573885 Update Time : Tue Apr 5 18:30:43 2022 Checksum : b28c0f6d - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 5 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdk3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : e33b11e6:9a94ec8a:a2528d74:eff14c2a Update Time : Tue Apr 5 18:30:43 2022 Checksum : ac50cd36 - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 8 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) /dev/sdl3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 9858866f:1e986c69:0e23d03d:34731de4 Name : NAS:3 (local to host NAS) Creation Time : Sun Aug 9 11:21:40 2020 Raid Level : raid5 Raid Devices : 10 Avail Dev Size : 7804327584 (3721.39 GiB 3995.82 GB) Array Size : 35119473984 (33492.54 GiB 35962.34 GB) Used Dev Size : 7804327552 (3721.39 GiB 3995.82 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : a564d2ce:0f719a0d:a9b3fc0c:6a93e9b8 Update Time : Tue Apr 5 18:30:43 2022 Checksum : 3ecbd4ec - correct Events : 231229 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 6 Array State : AAAA.AAAA. ('A' == active, '.' == missing, 'R' == replacing) Quote Link to post Share on other sites
flyride 757 Posted April 5 Share Posted April 5 Still no /dev/sde. I guess we will ignore that for now. We need a little more information before trying to force the array online: cat /etc/fstab and df -v Quote Link to post Share on other sites
costyy 0 Posted April 5 Author Share Posted April 5 cat /etc/fstab none /proc proc defaults 0 0 /dev/root / ext4 defaults 1 1 /dev/md3 /volume2 btrfs 0 0 root@NAS:~# df -v Filesystem 1K-blocks Used Available Use% Mounted on /dev/md0 2385528 1624380 642364 72% / none 16459916 0 16459916 0% /dev /tmp 16475452 928 16474524 1% /tmp /run 16475452 4696 16470756 1% /run /dev/shm 16475452 4 16475448 1% /dev/shm none 4 0 4 0% /sys/fs/cgroup cgmfs 100 0 100 0% /run/cgmanager/fs Quote Link to post Share on other sites
flyride 757 Posted April 5 Share Posted April 5 Interesting, DSM doesn't think your SSD has anything useful on it at all. Again, we'll ignore it for now. Current status: You have 8 members of a 10-member array that are functioning. RAID5 needs 9 to work in "critical" (i.e. non-redundant) mode. You have one more member that is accessible but is slightly out of date. The next step is to try and force that member back into the array in hopes that your data will be accessible. If it works, there will be a slight amount of corruption due to the stale array member. This may or may not be important. If that corruption is manifested in file data, btrfs will report it as a checksum error, but will not be able to correct it due to the lack of the 10th drive for redundancy. There are several methods of restarting the array with the stale member. The first one we will try is a non-destructive method - just resetting the stale flag. mdadm --stop /dev/md3 then mdadm --assemble --force /dev/md3 /dev/sda3 /dev/sdb3 /dev/sdc3 /dev/sdd3 /dev/sdf3 /dev/sdg3 /dev/sdj3 /dev/sdk3 /dev/sdl3 then cat /proc/mdstat Post output, including error messages from each of these. Quote Link to post Share on other sites
costyy 0 Posted April 5 Author Share Posted April 5 mdadm --stop /dev/md3 mdadm: stopped /dev/md3 root@NAS:~# mdadm --assemble --force /dev/md3 /dev/sda3 /dev/sdb3 /dev/sdc3 /dev/sdd3 /dev/sdf3 /dev/sdg3 /dev/sdj3 /dev/sdk3 /dev/sdl3 mdadm: forcing event count in /dev/sdg3(9) from 230661 upto 231229 mdadm: /dev/md3 assembled from 9 drives - not enough to start the array. root@NAS:~# cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md1 : active raid1 sda2[0] sdb2[1] sdc2[2] sdd2[3] sdf2[5] sdg2[6] sdj2[7] sdk2[8] sdl2[9] 2097088 blocks [12/9] [UUUU_UUUUU__] md0 : active raid1 sda1[0] sdb1[5] sdc1[1] sdd1[2] sdf1[4] sdk1[8] sdl1[9] 2490176 blocks [12/7] [UUU_UU__UU__] unused devices: <none> Quote Link to post Share on other sites
