horvathzeros 0 Posted March 16 Share Posted March 16 (edited) Hi, i never tried to install xpenology and my first try is with this mini PC CHUWI Herobox (cpu J4125 and network intel i225). https://store.chuwi.com/products/chuwi-herobox I tried with Juns loaders: v1.04b, v1.03b and even with 1,02b from this post and using "extra.lzma" that has to be compatible with intel i225 (realtek 8111) I get the screen that says "Screen will stop updating shortly, please open find.synology.com to continue" But find.synology.com and synology assistant never finds anything I checked my router and the network card has IP in that moment, but nothing happens. Maybe is something with the motherboard of this little computers? Im totally new on this and probably is not even possible with this hardware as is. Any idea or help is welcome, thnks guys! Edited March 16 by horvathzeros Quote Link to post Share on other sites
IG-88 1,034 Posted March 21 Share Posted March 21 On 3/16/2022 at 7:13 PM, horvathzeros said: network intel i225 if you search the forum for igc and i225 you will find some comments about intel not supporting older kernels and not providing a standalone driver like this one https://xpenology.com/forum/topic/28321-driver-extension-jun-103b104b-for-dsm623-for-918-3615xs-3617xs/?do=findComment&comment=260904 synology only uses kernel 3.10 (older units) and 4.4 newer/recent units only if someone backports the igc driver for syno's old kernel ... even dsm 7.1 is based on 4.4 and nothing has been seen with kernel 5.x from synology so far maybe try open media vault as nas os Quote Link to post Share on other sites
pocopico 549 Posted March 21 Share Posted March 21 Can you run tonycore redpill and provide an lspci -nnq Quote Link to post Share on other sites
horvathzeros 0 Posted March 22 Author Share Posted March 22 20 hours ago, IG-88 said: if you search the forum for igc and i225 you will find some comments about intel not supporting older kernels and not providing a standalone driver like this one https://xpenology.com/forum/topic/28321-driver-extension-jun-103b104b-for-dsm623-for-918-3615xs-3617xs/?do=findComment&comment=260904 synology only uses kernel 3.10 (older units) and 4.4 newer/recent units only if someone backports the igc driver for syno's old kernel ... even dsm 7.1 is based on 4.4 and nothing has been seen with kernel 5.x from synology so far maybe try open media vault as nas os Thnks for ur answer, i will check OMV 18 hours ago, pocopico said: Can you run tonycore redpill and provide an lspci -nnq I tried tinycore with driver extension for "igb" driver, when i probably need for "igc" cause didnt worked. When you say "provide an lspci -nnq" im not able to say if i tried, but maybe i did xD its hard for me to understand some expressions without an example. Quote Link to post Share on other sites
