yanjun 34 Posted March 7 Share Posted March 7 We all know that Synology's single volume limit has three cases: 16TB, 108TB, and 200TB. I checked the relevant documents carefully, the 3622xs+ I am currently using supports 200TB, provided the memory is greater than 32GB, but when I use 40GB of memory and 10 18TB hard drives to create storage space and storage volumes (RAID5, RAID6, SHR2 have all tried ), the limit is still at 108TB, does anyone know what the problem is. Quote Link to post Share on other sites
Tenshou 2 Posted March 7 Share Posted March 7 It only works on DSM 6.3 or lower. After that, they only allow 108TB. So you need to make a 200TB volume on the lower DSM version and migrate them to DSM 7.1 Quote Link to post Share on other sites
yanjun 34 Posted March 7 Author Share Posted March 7 3 minutes ago, Tenshou said: It only works on DSM 6.3 or lower. After that, they only allow 108TB. So you need to make a 200TB volume on the lower DSM version and migrate them to DSM 7.1 So you mean volume larger than 200TB cannot be created after DSM7.0? Is there an official announcement? Quote Link to post Share on other sites
flyride 767 Posted March 7 Share Posted March 7 https://kb.synology.com/en-global/DSM/tutorial/Why_does_my_Synology_NAS_have_a_single_volume_size_limitation https://www.reddit.com/r/synology/comments/kgcr1q/200tb_btfrs_volume/ Quote Link to post Share on other sites
yanjun 34 Posted March 7 Author Share Posted March 7 1 minute ago, flyride said: https://kb.synology.com/en-global/DSM/tutorial/Why_does_my_Synology_NAS_have_a_single_volume_size_limitation https://www.reddit.com/r/synology/comments/kgcr1q/200tb_btfrs_volume/ Thanks for the info, but I've checked this page, firstly the DS3622xs+ I'm using supports 200TB, secondly I meet the requirement with more than 32GB of RAM, in the info center I can see that my RAM is 40GB. I am using RAID6 btrfs. Quote Link to post Share on other sites
IG-88 1,036 Posted March 7 Share Posted March 7 4 hours ago, yanjun said: Thanks for the info, but I've checked this page, firstly the DS3622xs+ I'm using supports 200TB, secondly I meet the requirement with more than 32GB of RAM, in the info center I can see that my RAM is 40GB. I am using RAID6 btrfs. as 3615/17 are supported too for 200TB, try jun's 1.03b and dsm 6.2.3 if that works try redpill 6.2.4 to create a >108TB volume Quote Link to post Share on other sites
yanjun 34 Posted March 8 Author Share Posted March 8 18 hours ago, IG-88 said: as 3615/17 are supported too for 200TB, try jun's 1.03b and dsm 6.2.3 if that works try redpill 6.2.4 to create a >108TB volume Neither model supports 200TB, so we're now stuck in a dead end. Quote Link to post Share on other sites
IG-88 1,036 Posted March 8 Share Posted March 8 5 hours ago, yanjun said: Neither model supports 200TB, so we're now stuck in a dead end. on paper they do https://kb.synology.com/en-global/DSM/tutorial/Why_does_my_Synology_NAS_have_a_single_volume_size_limitation and there is also "Btrfs (Peta Volume)" https://kb.synology.com/en-global/DSM/tutorial/What_is_Btrfs_Peta_Volume Applied models: FS-series: FS6400, FS3600, FS3400, FS2017 SA-series: SA3600, SA3400 21-series: RS4021xs+, RS3621xs+, RS3621RPxs 19-series: RS1619xs+ 18-series: RS3618xs 17-series: RS18017xs+, RS4017xs+, RS3617xs+, RS3617RPxs DSM version: 7.0.1 and above RAID type: RAID 6 Memory capacity: At least 64 GB and https://github.com/dogodefi/redpill-load/tree/develop/config/RS4021xs%2B so twice a maybe ? Quote Link to post Share on other sites
Tenshou 2 Posted March 13 Share Posted March 13 (edited) They do support it. I am running a few volumes greater than 108TB started from DS3617xs and now on DS3622xs. Just make the volumes using Jun’s and then create a new DSM 7 install. Migrate those disks over and you will now have 200TB on your DSM 7 installation Edited March 13 by Tenshou Quote Link to post Share on other sites
