farodor Posted July 4, 2013 Share #1 Posted July 4, 2013 hi, has anyone tested the xpenology with an ide controller? i want to set up an system with some sata and ide hard drives Link to comment Share on other sites More sharing options...
totalnas Posted July 5, 2013 Share #2 Posted July 5, 2013 Hi, Yes, tested with "virtual" IDE. The version compiled specifically for ESXi has IDE support at boot. And it works without any problem as boot device. I feel that if some developer adds support for legacy IDE devices in the kernel you can use it also for raid. Ask for it! http://xpenology.com/forum/viewtopic.php?f=2&t=521 Link to comment Share on other sites More sharing options...
skibax84 Posted July 5, 2013 Share #3 Posted July 5, 2013 i can confirm that works with ide controller on Gigabyte g41 motherboard Link to comment Share on other sites More sharing options...
totalnas Posted July 8, 2013 Share #4 Posted July 8, 2013 Hi, Anyone can test if this new release has IDE support? viewtopic.php?f=2&t=937 Link to comment Share on other sites More sharing options...
Trantor Posted July 8, 2013 Share #5 Posted July 8, 2013 Hi, Anyone can test if this new release has IDE support? viewtopic.php?f=2&t=937 Only two PATA drivers is included in this kernel: SiS PATA AMD/NVidia PATA If you want more, just tell me Link to comment Share on other sites More sharing options...
farodor Posted July 9, 2013 Author Share #6 Posted July 9, 2013 hi guys, thanks for your great response! i dont know what i want, i want a system for old harddrives ... and ide drives ... know i must clarify to buy a pc with ide and sata support with xpenology, that can be start und shutdown like the original synology .... important for me is the start und shutdown technology ... it works in xpenology? if not, i must buy a normal syno ... :/ Link to comment Share on other sites More sharing options...
totalnas Posted July 9, 2013 Share #7 Posted July 9, 2013 Hi Trantor, I feel that you need to also enable: PATA_LEGACY PATA_CMD640 PATA_VIA PATA_WINBOND PATA_SIL680 PATA_RDC PATA_PDC2027X PATA_MARVELL PATA_JMICRON PATA_CMD64X I think that this include 99% of current systems. Or you can enable as a module all of current Linux-3.x PATA drivers. TN Link to comment Share on other sites More sharing options...
Trantor Posted July 10, 2013 Share #8 Posted July 10, 2013 Hi Trantor, I feel that you need to also enable: PATA_LEGACY PATA_CMD640 PATA_VIA PATA_WINBOND PATA_SIL680 PATA_RDC PATA_PDC2027X PATA_MARVELL PATA_JMICRON PATA_CMD64X I think that this include 99% of current systems. Or you can enable as a module all of current Linux-3.x PATA drivers. TN Yes I agree. Schedule for v1.3 ^^ Link to comment Share on other sites More sharing options...
farodor Posted July 11, 2013 Author Share #9 Posted July 11, 2013 @Trantor: have you an answere of my question ? -> can the xpenology shutdown completely (poweroff) via task and also going on to a specified time ? like the normaly synology? Link to comment Share on other sites More sharing options...
totalnas Posted July 11, 2013 Share #10 Posted July 11, 2013 @Trantor: have you an answere of my question ?-> can the xpenology shutdown completely (poweroff) via task and also going on to a specified time ? like the normaly synology? Hi, I feel that the answer is NO! I explain: You can schedule by software a shutdown on a specific time. You can configure your BIOS to boot at specific time. But, you need to create a software that changes your bios values to set the new boot time. This is a hard work! Workaround: Configure your XPEnology to Wake-On-Lan, and use your router (with OpenWRT or another custom distribution) to wakeup your XPEnology at specific time. TN. Link to comment Share on other sites More sharing options...
Trantor Posted July 11, 2013 Share #11 Posted July 11, 2013 @Trantor: have you an answere of my question ?-> can the xpenology shutdown completely (poweroff) via task and also going on to a specified time ? like the normaly synology? Hi, I feel that the answer is NO! I explain: You can schedule by software a shutdown on a specific time. You can configure your BIOS to boot at specific time. But, you need to create a software that changes your bios values to set the new boot time. This is a hard work! Workaround: Configure your XPEnology to Wake-On-Lan, and use your router (with OpenWRT or another custom distribution) to wakeup your XPEnology at specific time. TN. I just test it on my Zotac box, shutdown and start work but I loose BIOS config Link to comment Share on other sites More sharing options...
farodor Posted July 12, 2013 Author Share #12 Posted July 12, 2013 for shutdown you dont need a specified software its a nativ function from synology and it works for the power up, yes wake on lan is an option ... i have to check this ... my router is a fritzbox 7270 ... i dont know how to shedule a wol on the fritzbox ... i think with the original firmware its not work ? Link to comment Share on other sites More sharing options...
