levikats11 Posted January 21, 2019 Share #1 Posted January 21, 2019 Hi everyone, When I try to update(with a pat file) my Dell Optiplex to DSM 6.0 I get an error. Error: " unknown error occurs(21)" I cant update manually because the pc giv es me a Network error: Connection failed. please check your internet connection. Can someone help me out? Thanks! Quote Link to comment Share on other sites More sharing options...
bearcat Posted January 21, 2019 Share #2 Posted January 21, 2019 You can not "jump" from 5.2 to 6.x using the control panel, you will need to read and follow this (or this) guide. Quote Link to comment Share on other sites More sharing options...
levikats11 Posted January 22, 2019 Author Share #3 Posted January 22, 2019 Thank You! that worked. But I can't install anything from package center it gives me the error: Connection failed, Please check your network settings. Quote Link to comment Share on other sites More sharing options...
bearcat Posted January 22, 2019 Share #4 Posted January 22, 2019 @levikats11 If you try to ckeck your networks settings, they will appear blank I guess From earlier experience with a problem like that, after upgrading (from a different bootloader) try these steps: Activate the SSH service in DSM (if not active) Connect to your NAS with an SSH client (e.g. putty) (or from Win 10, open a cmd window, run : ssh admin@my.nas.ip (replace with the actual IP) Enter your credentials (user: admin) Change folder to root (cd /) Delete the xpenoboot folder (sudo rm -r .xpenoboot) If the SSH service keeps stopping, you have to be quick You might have to reboot after this. Quote Link to comment Share on other sites More sharing options...
levikats11 Posted January 22, 2019 Author Share #5 Posted January 22, 2019 Thanks! Can I install dsm 6.2 on non AHCI system? Do you have a link or something? Thanks Quote Link to comment Share on other sites More sharing options...
painkiller895 Posted January 23, 2019 Share #6 Posted January 23, 2019 23 hours ago, levikats11 said: Thanks! Can I install dsm 6.2 on non AHCI system? Do you have a link or something? Thanks Try loader DS3615xs It all depends on your hardware also... Quote Link to comment Share on other sites More sharing options...
