john7103 Posted January 7, 2019 #1 Posted January 7, 2019 HI ALL IM NEW TO XPENOLOGY I SUCCESSFULLY INSTALLED JUNS BOOTLOADER 6.1 I MISTAKENLY TRIED TO UPDATE FOR NO OTHER REASON OTHER THAN THERE WAS A UPDATE AVAILABLE WHICH SEEMED TO BRICK MY NAS SO I HAD TO START OVER WHICH I HAVE DONE BUT NOW IM NOT SURE IF I CAN USE THE PACKAGE CENTER TO INSTALL PACKAGES SAFELY SO IF SOMEONE COULD PLEASE LET ME KNOW AND ALSO IF THERE IS ANYTHING ELSE I NEED TO BE AWARE OF THANKS Quote
flyride Posted January 7, 2019 #2 Posted January 7, 2019 Package center will only offer you packages that are compatible with the DSM version you are running. So I wouldn't worry about that too much. Upgrading DSM through the Control Panel is a different matter. Disable automatic updates and monitor the reports and testing that others are doing before upgrading DSM itself. 1 Quote
bearcat Posted January 8, 2019 #3 Posted January 8, 2019 13 hours ago, john7103 said: IF THERE IS ANYTHING ELSE I NEED TO BE AWARE OF THANKS There is a key on your keyboard, probably marked "Caps Lock" that's not working 😏 Quote
