Jimmers 0 · ID: 1 Posted February 26, 2018 (edited) Hardware: Intel NUC5PPYH I have installed Jun's loader v1.02b DS3617xs using DSM 6.1. The box boots completely and is relatively stable. But I have encountered a problem with the NUC's embeded Realtek RTL8111/RTL8168 network adapter not playing well with the synology driver. This is a known issue with many other builds and kernels. I have checked and can confirm that the driver that DSM natively loads is the same one that I have had a problem with after installing Ubuntu 16.04 Workstation on the same model Nuc box. 0000:03:00.0 Class 0200: Device 10ec:8168 (rev 15) There is a fix, but it requires recompiling a file available from Realtek here. But that requires a copy of build-essential linux-headers to be on the NUC. There is also a problem where the drivers in DSM are not named conventionally so the Realtek make file will not find the correct files to replace. So I think the only way to repair the problem might be to take a known working device driver from a similar Debian kernel, I already have one on different NUC Ubuntu 16.04 and transfer it to the DSM and rename it to the Synology convention. Don't know if this will work. Any ideas? Edited February 26, 2018 by Jimmers Quote Share this post Link to post Share on other sites
IG-88 219 · ID: 2 Posted February 27, 2018 that's a little bit more then just "a file", but it's already done, the realtek drivers are part of my extra.lzma https://xpenology.com/forum/topic/9508-driver-extension-jun-102bdsm61x-for-3615xs-3617xs-916/ 23 hours ago, Jimmers said: So I think the only way to repair the problem might be to take a known working device driver from a similar Debian kernel, I already have one on different NUC Ubuntu 16.04 and transfer it to the DSM and rename it to the Synology convention. Don't know if this will work. that's not going to work, its not like windows, the driver has to be compiled specific for the kernel and in our case its not just kernel 3.1.102, its a sysnology modified kernel of this version so it hast to be compiled against the source from synology i wrote a how to about that, but you can just use the extra.lzma from above, no need to build your own driver https://xpenology.com/forum/topic/7187-how-to-build-and-inject-missing-drivers-in-jun-loader-102a/ 2 Quote Share this post Link to post Share on other sites
Jimmers 0 · ID: 3 Posted March 10, 2018 On 2/27/2018 at 5:42 PM, IG-88 said: On 2/27/2018 at 5:42 PM, IG-88 said: that's a little bit more then just "a file", but it's already done, the realtek drivers are part of my extra.lzma https://xpenology.com/forum/topic/9508-driver-extension-jun-102bdsm61x-for-3615xs-3617xs-916/ that's not going to work, its not like windows, the driver has to be compiled specific for the kernel and in our case its not just kernel 3.1.102, its a sysnology modified kernel of this version so it hast to be compiled against the source from synology i wrote a how to about that, but you can just use the extra.lzma from above, no need to build your own driver https://xpenology.com/forum/topic/7187-how-to-build-and-inject-missing-drivers-in-jun-loader-102a/ Thanks! This is very helpful. Quote Share this post Link to post Share on other sites
Ronnie_frown 0 · ID: 4 Posted January 5 @IG-88 I’m having nightmares with the RTL8111/RTL8168! I loaded the extension but it didn’t work, the NIC is recognized and I can see it loaded in the kernel if i ssh into the box, the network tab in DSM states that I have gigabit connection up and running but .... I get full bandwidth up but around 1.5 - 2 mb down. Tried both ds2356 and 57 but no luck. i had a box briefly running well but I can’t remember what loader / dsm 6.2 version I was running, I do remember that I was trying to reivive a broken build by using a newer loader than the one it had before. Any help would be appreciated Quote Share this post Link to post Share on other sites
Ronnie_frown 0 · ID: 5 Posted January 5 @Jimmers did the extra file work for you? If your build is stable please share what loader/dsm version you used Quote Share this post Link to post Share on other sites
Jimmers 0 · ID: 6 Posted January 5 Sorry Ronnie, I gave up on this port because the network driver was unstable and caused too many problems. Quote Share this post Link to post Share on other sites
