Connecting to serial port -> VirtualBox
George
Hi all
In the following, now closed thread:
references made of connecting to a serial port to see more output etc instead of just Kernal booting.
How is this done on Virtualbox. Been using ssh for year, but always onto ssh, can't remember when last I connected to a serial interface.
G
There is
11 answers to this question
in vm config goto serial port, enable com1, modus host-pipe, uncheck connect with host/pipe and for path on windows have this "\\.\pipe\ds3615" (ds3615 is just a string you choose for each vm differently as you can have more then one vm using this)
in putty you select serial instead of the usual ssh or telnet, where the ip/host is (now named "serial line") comes the pipe you defined in the vm "\\.\pipe\ds3615" and speed is 115200, after starting the vm the pipe is available and you can connect with putty
Not to figure out how to do the putty component on a MAC using the terminal program
G
as mac os is derived from bsd i'd expect it to be like unix/linux
https://www.virtualbox.org/manual/ch03.html#serialports
On a Mac, Linux or Solaris host, a local domain socket is used instead. The socket filename must be chosen such that the user running VirtualBox has sufficient privileges to create and write to it. The /tmp directory is often a good candidate.
thanks
Curious, is this same serial port access available/configurable on a bare metal XPenology install, (note to self go look if it is available via quikcnicks boot loader).
G
ok, so I edited my VM configure to point to /tmp/ds3615
After restarting the VM I can see the file having been created via Terminal on my MAC.
Now what, figure I should be able to simply tail -f the file, but getting permission error/not allowed,
G
:) ok, that looks better, I can see the startup happen, and can interface with it.
Actually expected allot more to come to the screen, comparing to a previous thread and included screen grabs attached.
it ends with a login prompt, although it did not accept my admin username/password.
G
my posting was about host-pipe not file
You can tell VirtualBox to connect the virtual serial port to a software pipe on the host. This depends on your host operating system:
Edited by IG-88
