to be in need of assistance
Update to version 1.02 updated to the latest version.
NAS is not available on the network.
We even discovered that there was no assignment of IP at the same time.
In 6.0, the IP fixed allocation was performed, and then migrated silently.
Was this a problem?
Should the latest version of the DSM be reinstalled using the Reinstall option?
What exact version of the loader are you using? There is no 1.02 version as far as I know. There is v1.02a, v1.02a2 and v1.02b
Also what is your hardware? Give more information or it will be difficult to help.
Using 1.02B Loader
Information about your motherboard and network interface card would be helpful as @Polanskiman suggested please
Also the last 'good' version of XPE/DSM  that was working
In the meantime try disconnecting your drives and then boot test with the 5.2 and 6.0.2 loaders. For 6x loader make sure you have correctly edited the grub file for vid/pid and mac address settings
