using iSCSI LUN / Target as additional volume in XPE
myhtpc
Hi everyone,
Is it possible to include an external iSCSI LUN (nap-it or another XPE with iSCSI Target configured) as additional Volume within XPE?
Does XPE Have an iSCSI Initiator on Board?
My idea is to Set up XPE in a VM and playing in a second VM new verssions (4.3) without risking my data while using Data from stable XPE-VM via iSCSI
Any thoughs on this would be great
I am interested in that also -
I managed to connect to my iscsi target on a napp-it server via iscsiadm;
but that drive does not show up in the Synology volume manager.
Does anyone know what has to be done to enable a new disk for management via Syno Gui?
For reference i am using this:
/usr/syno/etc/rc.iscsi start
iscsiadm -m discovery -t sendtargets -p
iscsiadm --mode node --targetname --portal --login
This triggers hotplug daemon (i believe) to access the drive:
from /var/log/messages
Nov 1 22:47:43 kernel: [ 581.742397] sd_format_disk_name()=isda
Nov 1 23:11:49 kernel: [ 119.860213] syno_disk_type_get: SYNO_DISK_ISCSI
Nov 1 23:11:49 kernel: [ 119.860263] sd_probe: index=676
Nov 1 23:11:49 kernel: [ 119.860300] got iSCSI disk[0]
Nov 1 23:11:49 kernel: [ 119.860335] sd_format_disk_name()=isda
Nov 1 23:11:49 iscsid: connection1:0 is operational now
Nov 1 23:11:56 kernel: [ 127.120054] Wrong cpu core: 35822
So then i have a drive, its in /proc/partitions, i can access is with fdisk/sfdisk/parted but i cant get it to show up in syno volume manager
The only reason DSM has the iSCSI kernel modules to act as an initiator is for Time Backup pkg which snapshots dataset to a iSCSI target it mounts on itself (local backup) or from over the network (network backup) and then does the backup from that target. Look at DSM builds before Time Backup was released, they are not there.
You can set it up manually too like:
insmod /usr/lib/modules/libiscsi.ko
insmod /usr/lib/modules/libiscsi_tcp.ko
insmod /usr/lib/modules/iscsi_tcp.ko
echo "InitiatorName=iqn.2001-11.dsm.initiatorname" > /etc/iscsi/initiatorname.iscsi
and then start iscsid daemon
I suspect DSM knows not to enumerate the /dev/isd* devices as regular HDD. I would look toward compiling and loading normal iSCSI kernel modules?
Well,
/usr/syno/bin/synodiskport -iscsi
enumerates the iscsi drives;
I've tried modifying calls to /usr/syno/bin/synodiskport -sata (eg. in install.sh) to enumerate all sata/sas/iscsi drives;
I have even gotten a proper fd (autoraid) partition on it (synopart),
but i cant get neither LSI based sata nor sas nor iscsi drives to be reckognized :sad:
I am pretty sure that there is some coding in DSM that says "do not allow /dev/isd* devices to be enumerated for volume creation or hdd management or any other service but Time Backup".
Like I said, these kernel modules were added at the same time as Time Backup was and if you observe the system during Time Backup operation you will see that it mounts an iSCSI LUN and takes a snapshot and work on the LUN so that it knows what changes during the backup and so there are data access problems while backing up live data.
This is just what I observed when analyzing how Time Backup works.
Anyone try loading some standard debian kernel modules for the iSCSI initiator?
