I am running DS3622xs+
Current DSM version: DSM 7.2.1-69057
Using AMD Athlon II on a Gigabyte board, a bit old I know, but it works. However the challenge is that out of many USB ports only a few seem to work, one for the bootloader USB stick and another that I use for my USB hub.
I have to use the USB hub to connect my CyberPower UPS because a direct USB cable does not work. I know because I tried the UPS directly with a Windows PC and I can see the UPS on Device Manager.
Is there anything I can do, such as change a config file etc. to get the UPS to directly work on the xpenology?
Many thanks all
