malefik36 Posted August 3, 2023 Share #1 Posted August 3, 2023 active backup очень бы пригодился в работе. ds920 dsm7.1.1 upd6 tinycore-redpill с весны успешно эксперементирую и пользуюсь Quote Link to comment Share on other sites More sharing options...
XPEH Posted August 3, 2023 Share #2 Posted August 3, 2023 Можно попробовать так Spoiler Login (replace URL, PORT, USER, PASS) https://URL:PORT?/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=1&account=USER&passwd=PASS for ActiveBackup its the following urls Get Activationstatus https://URL:PORT/webapi/entry.cgi?api=SYNO.ActiveBackup.Activation&method=get&version=1 Set ActivationStatus (use your SERIALNUMBER) https://URL:PORT/webapi/entry.cgi?api=SYNO.ActiveBackup.Activation&method=set&version=1&activated=true&serial_number="SERIALNUMBER" ? for Office365 its the following urls Get Activationstatus https://URL:PORT/webapi/entry.cgi?api=SYNO.ActiveBackupOffice365&method=get_activation&version=1 Set ActivationStatus (use your SERIALNUMBER) https://URL:PORT/webapi/entry.cgi?api=SYNO.ActiveBackupOffice365&method=set_activation&version=1&serial_number="SERIALNUMBER" for GSuite its the following urls Get Activationstatus https://URL:PORT/webapi/entry.cgi?api=SYNO.ActiveBackupGSuite&method=get_activation&version=1 Set ActivationStatus (use your SERIALNUMBER) https://URL:PORT/webapi/entry.cgi?api=SYNO.ActiveBackupGSuite&method=set_activation&version=1&serial_number="SERIALNUMBER" Раньше работало. Quote Link to comment Share on other sites More sharing options...
malefik36 Posted August 3, 2023 Author Share #3 Posted August 3, 2023 пардоньте меня....а что с этим делать? Quote Link to comment Share on other sites More sharing options...
XPEH Posted August 3, 2023 Share #4 Posted August 3, 2023 Пишите в строке URL. Подставьте свои адрес/порт/серийник и т.п. Должно активировать без участия синолоджи. Quote Link to comment Share on other sites More sharing options...
XPEH Posted August 3, 2023 Share #5 Posted August 3, 2023 1 Quote Link to comment Share on other sites More sharing options...
malefik36 Posted August 5, 2023 Author Share #6 Posted August 5, 2023 проверено на DSM 7.1.1-42962 Update 6 DS920+ https://ip_NAS/webapi/auth.cgi?api=SYNO.API.Auth&version=3&method=login&account=логин&passwd=пароль&format= cookie https://ip_NAS/webapi/entry.cgi?api=SYNO.ActiveBackup.Activation&method=set&version=1&activated=true&serial_number="серийный номер" спасибо коллеги. остальные проверю позже. Quote Link to comment Share on other sites More sharing options...
malefik36 Posted August 6, 2023 Author Share #7 Posted August 6, 2023 проверено for Office365 its the following urls Get Activationstatus https://адрес:порт/webapi/auth.cgi?api=SYNO.API.Auth&version=3&method=login&account=логин&passwd=пароль&format= cookie Set ActivationStatus (use your SERIALNUMBER) https://адрес:порт/webapi/entry.cgi?api=SYNO.ActiveBackupOffice365&method=set_activation&version=1&serial_number="серийник" Quote Link to comment Share on other sites More sharing options...
malefik36 Posted August 6, 2023 Author Share #8 Posted August 6, 2023 Get Activationstatus https://адрес:порт/webapi/auth.cgi?api=SYNO.API.Auth&version=3&method=login&account=логин&passwd=пароль&format= cookie Set ActivationStatus (use your SERIALNUMBER) https://адрес:порт/webapi/entry.cgi?api=SYNO.ActiveBackupGSuite&method=set_activation&version=1&serial_number="серийник" Quote Link to comment Share on other sites More sharing options...
