QLogic 111-01006+A0 problem with extensions
I have a problem with build :(
[#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/qla2xxx/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json
curl: (22) The requested URL returned error: 404 Not Found
[!] Failed to download https://raw.githubusercontent.com/pocopico/rp-ext/master/qla2xxx/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json
*** Process will exit ***
[-] Failed to update recipe for pocopico.qla2xxx extension for platform ds3622xsp_42661. The script will terminate as you do not
[-] have previously downloaded recipe which can be used if download fails. Try again later. If problem
[-] persists contact the extension packer for support (displayed below)
[#] ========================================== pocopico.qla2xxx ==========================================
[#] Extension name: qla2xxx
[#] Description: Adds  Support
[#] To get help visit: <todo>
[#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/qla2xxx
[#] Software author: https://github.com/pocopico
[#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/qla2xxx/rpext-index.json
[#] Platforms supported: ds1621p_42218 ds1621p_42951 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 dva3221_42962 ds918p_42661 ds3622xsp_42962 ds3617xs_42951 dva1622_42218 dva1622_42621 ds920p_42962 ds1621p_42661 dva1622_42951 ds918p_25556 dva3221_42218 ds3615xs_42661 dva3221_42951 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42962 rs4021xsp_42621 dva1622_42962 ds2422p_42218 rs4021xsp_42962 dva3221_42621 ds3615xs_42962 ds3617xs_42962 ds3615xs_41222 ds920p_42951 rs4021xsp_42218 ds2422p_42951 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 rs4021xsp_42951 ds920p_42621 ds918p_42962 ds3615xs_42951 ds3622xsp_42951 dva1622_42661 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds1621p_42962 ds3622xsp_42621 rs4021xsp_42661
[!] Cannot continue due to previous errors (see above)
[!] Failed to update all extensions for ds3622xsp_42661 platform - see errors above
FAILED : Loader creation failed check the output for any errors
I Try manualy add:
tc@box:~$ ./rploader.sh ext ds3622xsp-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/qla2xxx/rpext-index.json
Rploader Version : 0.9.2.9
Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop
Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master
Extensions :   redpill-misc
Extensions URL : "https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/rpext-index.json"
TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.broadwellnk-7.0.dev.txz/download
TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d
SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology%20NAS%20GPL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download
SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1be
COMPILE_METHOD : toolkit_dev
TARGET_PLATFORM       : ds3622xsp
TARGET_VERSION    : 7.1.0
TARGET_REVISION : 42661
REDPILL_LKM_MAKE_TARGET : dev-v7
KERNEL_MAJOR : 4
MODULE_ALIAS_FILE :  modules.alias.4.json
SYNOMODEL : ds3622xsp_42661
MODEL : DS3622xs+
Local Cache Folder : /mnt/sdd3/auxfiles
DATE Internet : 31102022 Local : 31102022
Checking Internet Access -> OK
Redpill sources already downloaded, pulling latest
Already up to date.
Loader sources already downloaded, pulling latest
Already up to date.
[#] Checking runtime for required tools... [OK]
[#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/qla2xxx/rpext-index.json...
[#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/qla2xxx/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json
############################################################################################################################################################################################################## 100.0%
[!] Extension is already added (index exists at /home/tc/redpill-load/custom/extensions/pocopico.qla2xxx/pocopico.qla2xxx.json). For more info use "./rploader.sh ext ds3622xsp-7.1.0-42661 info pocopico.qla2xxx"
but the problem was not resolved
If you are thinking of switching to DS918+, try using m shell.
Auto-includes pocopico's powerched extension driver, which recently fixed the power scheduled start issue on DS918+.
You can download and install it with the following command in TCRP Linux as shown below.
curl -L "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/my.sh.gz" -O;tar -zxvf my.sh.gz;
And, DS918+'s TCRP FRIEND loader is built as below.
./my.sh DS918+F
Edited by Peter Suh
