pedroj666 Posted July 13 Share #1 Posted July 13 I restart in TCPP but when I try to run the command ./rploader.sh update it always says "not fond". Also if I try to access tcrp through putty it always gives me the error connection refused. what am i doing wrong and how can i update the image? Quote Link to comment Share on other sites More sharing options...
Francisco Posted July 14 Share #2 Posted July 14 8 hours ago, pedroj666 said: I restart in TCPP but when I try to run the command ./rploader.sh update it always says "not fond". Also if I try to access tcrp through putty it always gives me the error connection refused. what am i doing wrong and how can i update the image? Hi all, unfortunately I have the same issue. Any clue how to solve this problem? Quote Link to comment Share on other sites More sharing options...
Francisco Posted July 14 Share #3 Posted July 14 15 minutes ago, MichelD said: ls sudo Hi MichelD, first of all thank you for your prompt reply. I have also tried it with the SUDO command, but without success. Quote Link to comment Share on other sites More sharing options...
pedroj666 Posted July 14 Author Share #4 Posted July 14 33 minutes ago, Francisco said: Hi MichelD, first of all thank you for your prompt reply. I have also tried it with the SUDO command, but without success. I'm not having any luck getting this to work either! Quote Link to comment Share on other sites More sharing options...
billat29 Posted July 16 Share #5 Posted July 16 run the command: date Is the date and time correct? If not, then that is your problem. Either your BIOS battery is dead OR DSM reset the BIOS when doing a recovery. If you run fullupgrade without the date correct, it seems to delete everything to make way for new files and then if it fails, you are stuck. Check BIOS settings, reset the date, download rploader,sh from the repository and run fullupgrade. Quote Link to comment Share on other sites More sharing options...
apriliars3 Posted July 16 Share #6 Posted July 16 (edited) Need to download rploader.sh to home/tc You can access to directory and copy the file to github repository pocopico/tinycore-redpill at develop (github.com) Or burn other time pendrive with .img tinycore PD: command sudo is not necessary Edited July 16 by apriliars3 Quote Link to comment Share on other sites More sharing options...
