Problems with initialize the harddrives
Hi Everyone,
I have install the DSM 5.2 on a Precision WorkStation R5500.
That works but when i try to initialize the hard drive, the software say's: check your network settings?
Anyone here with the same problem ? and maybe with a solution ?
I Have also try reserve my ip .. that works for the update, but not for the initializing from my HD's ?
Thx! :smile:
Same problem here!!!
Tried the 5644 version.
Now the weird thing.
I just did a fresh install on bare metal for the 5592 version with 5592 XPEnoboot and everything was OK.
The volume was created correctly.
It seems that is not possible to do a fresh install directly on 5644 version.
WEIRD THING IS THAT 2 OF MY HDDs ARE NOW WITH A PASSWORD ON HDD BOOT!!!
I'm not sure what caused this, as my BIOS do not have option to set HDD password.
Maybe Synology is attacking us now?
No, I was wrong, it is a Synology issue. Secure erase locks the drives.
http://forum.synology.com/enu/viewtopic.php?f=7&t=93103
Good topic, will write a tutorial for that =)
