[SOLVED] My NAS is degraded, what to do?
Hello,
it seem i have a problem on one HDD, i can't access the DSM interface http://ip:5000, but my network share are ok.
What to do now ? Shutdown the n40l and remove the faulty drive, then restart with my other 4 disks ? or stay like that and wait to receive my new hdd ?
if i remove my faulty drive, and then restart i'll have access to DSM interface ? coz actualy it's the annoying thing..
thx for your help
best regards
Edited by Guest
you should still be able to access DSM regardless of how degraded a drive has become. I've had 2 of 3 go tits up on me before but still able to access it.
What version of DSM are you running? It's probably that that's gone bonkers.
Maybe try a different version, even if it means downgrading. There's stuff on here about 5.1 breaking the interface due to IP v6 issues. I think it even ported to 5.2
Try here:
viewtopic.php?f=2&t=6247
for clues on what do to.
thx for the answer.
i think i use 5.1 or 5.2 can't remember, but i did it on 09/04/2015, so i installed the version at this date.
I degraded my system on purpose about a week ago. I wanted to make sure that the SHR1 was working before i went ahead and tranfers all my data.
I did not encounter any errors accesing the dsm. try yourip:5001, Clear your browser history, ue the synology assistant.
guys, i did nothing just a port scan to see which port was open on nas' ip , and now i can access my DSM ..
damm that strange ! but i'm happy
