jastsai 2 Posted August 14, 2020 Share Posted August 14, 2020 I installed the HP HC360T on my i7 6700 custom box and for some reason only 1 of the Ethernet ports is getting 1gbps. The other was is only 100mbps. Is that common for you guys? Thanks. Quote Link to post Share on other sites
IG-88 715 Posted August 15, 2020 Share Posted August 15, 2020 all cases i can remember where about cable and little mishaps (port on switch configured to 100Mbit, wrong switch connected) seems unlikely that the driver for a dualport card would be only be working for one port the right way whats on the other side of the cable? Quote Link to post Share on other sites
jastsai 2 Posted August 24, 2020 Author Share Posted August 24, 2020 On 8/15/2020 at 7:39 AM, IG-88 said: all cases i can remember where about cable and little mishaps (port on switch configured to 100Mbit, wrong switch connected) seems unlikely that the driver for a dualport card would be only be working for one port the right way whats on the other side of the cable? The both cables goes into a Synology Router. I set it up as bonded. Just 1 is bonded at 1gb and the other one is 100mb. Quote Link to post Share on other sites
IG-88 715 Posted September 1, 2020 Share Posted September 1, 2020 what happens when you switch cables or use it without a bond maybe try a different switch for testing Quote Link to post Share on other sites
